- y-pipe questions
- scratches all over body
- Eibach Prokit & KYB GR2 driving impressions
- B&G spring install which way is rightside up?? somone!!
- cleaning inside of headlights
- How can i tell if i have a CA emissions car?
- Does any one know the simularities between Gen IV Max and 90-96 Z's?
- auto tranny flush
- ****what "other" stock steelies match our bolt patterns?*****
- Code 11/02 Rev Sensor Help!!!!!!!
- oem replacement cat.
- Need Help: Noise Coming From Engine Bay
- Mevi?
- fuel economy???
- New Axles, now Rev Sensor Code
- Can I clear the codes myself?
- Winshield Washer Reservoir
- motor mount help
- Electrical Gremlin (clock + beeping remind out)
- where is EVAP canister located?
- Security system lockout.
- Please suggest a selling price for a 97 with all the goodies
- broken oil/engine temp sensor. help
- car almost dies after i start
- every mod i do, one thing goes wrong... how about u?
- NeoVVL VQ, haha look what I found
- code 0210
- need a link on how to change oxygen sensor on 97 GLE
- spring compressors?
- straight pipe?
- CV boot
- Air control lights keep going one by one
- anyone have a spare spoiler light for 95se ?
- knocking
- back door panel
- Where to get CF hood from?
- High Idle Please help :(
- So how many gaskets do I need to replace for this leak? (pic inside)
- Engine dies while stopping at a red light
- Y-Pipe Rattling
- Keys locked in car, help!
- diy angel eyes
- why brake light does work?
- Rear seal leak
- audio, remote key stop working
- beeping sound after ignition
- the max lost a bunch of weight today
- Check Engine Light blinking while driving?
- help? will a 5th gen spring fit a 4th gen max 98 se max
- want to change springs? which are oem?
- Fixed my ECU issue!
- bad alternator diode
- sound deadening, need advice
- different size rims
- have ecu code 0304 and 0111
- Cattman Headers
- Cefiro???
- cleaned TB a month ago, still high idle. how to fix?
- Intake question
- 40..60..80..Series
- ECU Codes: 0705 & 0309 PLEASE HELP!
- What's this noise??
- Locking/Non-Locking Differential...
- Testing Coils
- Replacement HID Bulbs
- automatic trans filter
- P1320 & P0302 Codes - Thoughts?
- rattle or noise in the front shokabsorber
- the red/clears tails
- Want to buy ignition coil set for 99 Maxima
- KNOCK SENSORS? What's the problem?
- 99 jumps when accelerating: NEED HELP
- 2001 Muffler?
- Anyone with a 96 grill on 97 bumper
- Engine Imobilizer System?
- Heat/Air doesn't work.....blower help...hehe
- Remote Start
- Can airbag cover be removed?
- air tool guys look here-spring install-metric or standard?
- Broke the plastic cover piece on speedometer cluster, plz Help
- 96 max auto stalling problem
- 97 GLE Alarm Wiring Diagram?
- Knock sensor question
- Knock Sensor Dilemma. Need some assistance. Check this out...
- Who has angel eye pics in headlights?
- Looking for a new mass air flow sensor
- Keyless (not what you think)
- Maxima Gauge Cluster 39,629 miles... $5 ???
- Alarm remote programming messed up
- My 99 ECU not like the sticky picture
- R33 headlights finished...
- Help! My car keeps stalling out.
- White brake light ?
- anyone got a write-up on how to do a hacked airbox?
- 10-03 Cell After 5 speed conversion Please Help!
- Hella Horn Installation
- exhaust/midpipe rubber hangers
- My 99 ecu is not like the pix in the sticky
- ECU Codes
- Quick question on foglight fuse
- Problems with y-pipe?
- Is it possible to get y-pipe, suspension, and catback for under $1000?
- ecu code
- Finally: Pics of my car.
- New Sparkplugs?
- 95/96 Front Bumper
- Wheel Alignment Spec.
- Hella Horn placement
- p1320 or 0201 code
- Tie rod part of the CV axle?
- Need new Bushings!
- Keyless remote question
- Bad strut or mount? 4th gen
- Reset 99 ECU by disconnect battery????
- What is your mileage with the same auto tranny?
- Suggestions on Mods for 98 SE
- Does Anyone Have a 4th Gen from Tochigi Plant?
- Vent visors
- Squeaking dash....help please
- To replace axle or just the cv boot?
- NEON!!! under car, underseats, in trunk, POST PICS
- Headlight aim/adjustment on 99 Maxima
- catback exhaust DISASTER!
- anyone else not get a raised rev from TS?
- Alternator Whine on 95SE
- Cali-spec max
- WTB: Dry Nitrous kit
- What kind of Oil to use 95 max se..
- why is my antenna acting retarded
- How do 4th Gens behave in the SNOW?
- Clutch
- Mother of all Y-pipe threads
- Did you know the 98-99 shifter is different than the 95-97?
- Anyone know what mounts these are?
- getting it registered tmarw FINALLY!
- 5 Speed Swap
- price for new tires?
- Y-Pipe suggestions?
- VQ35 Swap
- grounding wires
- for all you techies and want to know hows
- Looking 4 photos of polished intake manifold (vq30de)
- DYNO chart: 4th Gen with only ECU vs. Stock 4th Gen?
- 95-96 Custom made clear tail lights
- Did i get screwed?
- Intake
- broken red/clear tail lights
- Knock Sensor on a 98
- Guage pods....???
- 97-99 Conversion.....?????
- Stone Mountain Racing Y-Pipe
- JWT ECU for 95-99 Maximas: Is this how it shakes out?
- How to check for magnetized signal plate? need experienced help!
- 1996 Maxima Codes
- I need to a you all a simple question
- where can I buy a cover for tire air stalk thing?
- 97-99 front bumper fitting on 96 max???
- Anyone with springs-how do you like them??
- carbonfiber tail skyline style pics?
- Need to clean the throttle body?
- 96 max code 0111
- t stat and how long to r&r
- What HID kits would you recommend for a Maxima?
- cant find answer in fluid/lubricant forum. can you help?
- What kind of problems will i run into with a fiberglass bumper?
- just rear-ended somebody in my Maxima, need opinions on repair cost:
- Engine Oil Drain Plug Spec
- Rim issue
- Loud Clonking sound
- Looking for taillights
- 95 Maxima SE Starter Issues
- Top end noise
- 2K-2k1 Motor in a 4th gen
- my 1st amateur Maxima video...
- Is my alternator starting to die?
- Cars with over 175,000... please answer this question:
- Here are working links for BROKEN "How-to"s
- looking for pics of 2k3 se wheels w/h&r
- which strut/spring combo gives a comfy ride?
- Rear Window Off Track....Please Help
- bumper bulbs suck! help?!
- Dimming headlights
- Got the new 18's mounted! Pic's inside
- Where is my brake booster hose?
- Looking For Some Really Good Struts
- Those who are riding on Tein Coilovers
- 95 vs 97 Fog lights
- Fuel filter replace ?
- Brake light problem
- Is my Maxima worth hooking up?
- quick question about a 2001 5spd tranny in my 95 5spd max...
- quick mevi question
- wont pass smog because of codes???
- Eibach Springs..Your opinion
- Another one **sigh**
- whistleing sound
- 1997 SE Heater Issue
- Alarm ad ons
- Guys, should I get these? Are they easy to install????
- spoiler's light out
- heated seats
- New Rooftop pics (parking garage)
- purge volume controller?
- Definitive Motorsports Underdrive Pulley ?
- Looking for the 4th gen who put the 350z seats in his car...
- swapping on the 2k/2k1 Intake Manifold
- my recently purchased 96 gxe
- DR mod/CEL 1205???
- Know where to get one of these?
- Quick Question (probably asked many times before)
- Anyone have pics of new black euro headlights with black DC bumper lights?
- maxima 1 week old and already leaking..???HELP
- 7th time check engine light
- simple ECU code pull ?
- Sparks and fuel filter: $380
- Coil packs which brand? what changed 3/99
- any maxima's with HP Evo's?
- Spark Plug gap???
- Re: Leaking at brake area
- Need help programming my garage door opener?
- Tokico Blue Shocks
- Grinding/rubbing noise...help
- Stock pillar tweeters
- does my gas light work?
- Need Help Buying Knock Sensor
- Steering wheel shakes
- engine flush liquid
- maxima wont stop going to the left
- rear springs install
- Trunk does not open
- Changing rear brakes - "how to" link broken
- where to drill into firewall????
- help heater only works on high
- picture time!!!! stillen kit... 56k might not wanna come in
- heated seat lights
- lurching when stopped in drive
- emerg. brake light always on
- another tranny bearing problem
- when stopped, my car jerks, wtf is goin on?
- Redding Out Tail Lights w/ Sentra Twist
- Can i disable my factory alarm? It cutoff my Fuel!
- Write up on mirror install
- UDP worth it?
- what should be the first exhaust mod done to the max??
- Another exhaust Ques?ion
- Hitachi Boost Sensor
- Not liking silverstars...
- Roof spoiler????
- What is the diameter of the stock exhaust flex section
- Does it hurt anything if I...
