- Part Number For Rvm Puklley
- Budget Y question
- Gauge Cluster
- 1995 engine interchangeability
- what's the link between the starter and tranny??
- After Market Goodies
- ABS Light
- problem, hearing a whining noise please help
- installed y-pipe
- Fair price for '99 SE Limited
- Maximum Tunning Contact Info
- Biggest Lip / Deep dish rims
- unknown hose
- wont start when its cold
- Looking for a Filter
- What ground control coilovers to get?
- Just got y-pipe and STS put on :D
- Soft top for 95-99 maxima
- improved stillen lip needed
- ALL NEW PICS ------> check them out!!!
- some photoshop fun...
- Custommaxima.com Racing Straight Pipe
- Question about changing springs
- pathfinder TB update
- Brake Help, Please.
- Harlan switch question.
- CEL at 85k
- Overheating
- 9004 HID Install - high beam indicator issue
- photoshop assistance needed
- Opinions on rims
- IACV Location
- Changing Back brakes for a 99 Infiniti I30 the same as changing brakes for a Maxima?
- Tick Tick Tick...what's the noise?
- Are Kumho SUPRA 712 tires decent?
- TYC projectors for 4th gen 97-99....
- Strut Mount Information...Please Help!!!
- Blinker Blinks Fast?
- Jdm Skyline Gtr Headlight Set, Maxima 95-99
- Muffler
- urethane or fiberglass front?
- New Pics of New Wheels
- best one to buy
- can i bum your resinator??
- 95 Xenon Headlight Conversion
- How to clean CRAYON of your cloth interior??
- Help in removing wood grain dash trim
- '97 Black Max GLE- Body MODS
- for those of you who have HID's
- B&M short shifters
- Door Trim Replacement
- I just dropped almost 6k in MOds!!!!
- What makes an SE an SE?
- New pics! Check it out!!!
- body kit help!
- Ok, Here Goes My Transmission!!!!
- exhaust question
- Any other bulbs beside Polarg for side/turns?
- offset on 18s? or anyone with 245/40/18s help!
- California Emission laws.
- Introducing new product...
- HELP needed diagnosing oil leak (pics)
- How to launch(5speed)...
- What is this part i found in my Maxima
- brake problem, please help
- Vb mod w/check engine?
- Code 0503 and 0304 help please...
- About to go for a 2500 mile ride. Any advice?
- Auto tranny drop resistor mod questions
- NEED HELP!!! Clearance Lights...
- Switches
- What size tirs would you recomend?
- To those who have installed KYB dustboots...
- Help With My Future Max...?!
- VI Woes !!! Please Read
- Just had my VB mod done
- Ideas on where to put kill switch???
- Body kit setup anyone
- RSTB questions
- Thinking about selling my rims
- MT fluid change
- Suspension help needed...
- 235, 50, 17's? Anyone have pics with drop
- 99 orange tailight=just an insert?
- New 99 SE owner looking for people in L.A.
- keyless entry
- Several write ups w/ pics (Cardomain)
- Bosch Vs. NGK
- anyone cheat on their inspection
- o2 and Knock sensor's gone
- 0605 and 0903
- ecu chip for 95-02 maximas
- The ocassional misfire issue again
- Transmission oil for 96 5-speed
- Help With An Intake
- Front passenger headlight removal
- FX35/45 wheels on your max?
- Brakes Questions.
- Spoiler on Max
- Electrical problem has me puzzled
- Oil on spark plug...
- EVAP Pressure Control Sensor-???
- Intake sound
- I got the rattle...
- looking for a 95 max owner
- wheel Quest.
- Drilled and Slotted Rotors
- Ecu Code Q
- Bad idle after new O2 sensor
- mid-pipe help
- 17 inch wheels
- Will a CAI Midpip fit like a frankencar?
- NGK Wires
- Rusty Rotor
- Manual Swap w/ 02 6-speed possible?
- Quieter Intake?
- Loose Battery Terminal Clamp
- 19 inch rims
- Where could I get the cheap fog lights again
- Orange max with custom white/orange interior
- What do you think of my new wheels?
- 97 max GLE remote question
- What could I get for my 99 SE titanium finish rims 5 spoke 16' rims with RSA's
- 5th gen plenum VS MEVI (pics inside)
- Need some help deciding on 5-spd conversion...
- Cyl 4 misfire
- Major Question, Sos
- How do you remove window tint?
- rear ended by ricey civic DX- how will his insurance try to screw me?
- Testing coils
- Is the alternator from a 4TH gen. compatible with any other gens.?
- can u do a 6speed swap from a 5th gen into a 4th gen?
- 90,000 miles on a set of brakes?
- Carbon Fiber hood installation
- replacement front bumper...ebay???
- H3 Fogs
- knock sensor
- Rattling
- got to get my y-pipe installed...
- how to re-wire foglight
- 95-96 Red clear tails
- Noisy stabilizer bushings
- Does this part exist?
- What effects exhaust sounds?
- what are OEM O2 sensors?
- cardomain issues...
- very bright headlights
- What you think.. 99 superblack GLE
- K&N Filters
- To those with an uninstalled set of KYB dustboots laying around...
- Input on Y-Pipes Please
- Does the 97-99 stock grille insert fit in a 95-96?
- flushing out radiator (haynes manual way)
- Shock degradation.
- Wheel lock size?
- fought with a pothole-and lost.
- HID users... please read!!!
- will a bad knock snesor cause the engine to stuble a little?
- Engine Dress-Up
- "brake" and "battery" dash lights are on. Bad alternator?
- raced a celica
- Engine rebuild
- 99 fog light
- Pr Intake Or Injen Or......
- steering wheel shaking when stop
- Thoughts on the MEVI.
- ran diagnostics Bad Knock Sensor--->>>
- O/D indicator
- Maxima check engine light
- check engine light problem. plz help!!!
- Can someone tell me what is this? PICS INSIDE
- Replacing Wheel Stud
- TPS and MAF - why have both?
- just cleaned my T.B!
- Gap size for Spark Plugs
- Trany fluid
- Crank Sensor (REF) code 0407
- Just set up Homepage
- Monroe Sensatrac rear struts
- What aftermarket muffler do u guys have??
- (0302) egr code. need advice
- Factory alarm questions
- guys with Carbon fiber hoods...question for you
- Anyone have any sound clips of the Apexi WS catback?
- whats good price to pay for stock 5 star 16" rims
- AAHHH!! I bent a valae
- Rear Brake Caliper - Replace Advice
- How much variation in tire pressure makes a noticable difference?
- heater heats up slow (?)
- grill from grille-tech.com
- What do you guys think of my window spoiler
- A/C Extra-Cold and lines freezing
- Odometer Stopped working
- Lost to a SOHC NEON
- stupid question-wat is a MEVI
- will these fit on a max?
- who's got the pacesetter catback?
- G-tech Competition Review
- Sub placement ( anyone do this?)
- Addco vs Progress RSW
- blah, errors suck!
- Shift Lock
- i went to autozone and they pulled po600 code serial comm. error?
- air ride for the max
- What's the best OEM leather shift knob?
- Trouble Shifting
- Still getting 01 02 CEL code after swapping all coils..any ideas?
- 5 Speed
- Alternator or something gone wrong! HELP!
- rotor replacement
- 6 spoke or 7 spoke? What do I do!?
- EVAP Control Sensor- Code 74
- how much can i lower with sarona body kit?
- camber plates. Do I need them? Lowered GC's as far as they go
- Leaking fluid....need help
- Anyone have a dyno chart w/ and w/o the Frankencar?
- Maxima model years
- cant remove screw...HELP!!
- Rims
- Clear corners
- vac guage for a MEVI?
- My Rotors Are Very Thin...Help!!
- Carbon fiber muffler on black max?
- Muffler opinions
- New User...Some Questions
- side marker bulbs
- Where can i buy 15" kosei's?
- gxe speed limiter removal need help
- light specifications for a 99 SE?
- How much hp am I losing?
- fuel mileage- cold weather, warm weather.
- can someone link me to skylin tail light?
- Squeeling sound at starting
- I need a link please
- Questio about installing slotted rotors
- Question about cutting rear Sprint spring
- i want tilting headrests
- Post Konig Tantrum 17" on a maxima
- 1995 Electrical Problems
- Anyone have Maxxim Pursuit wheels?
- 1995 Maxima GLE Question
- Slight Backfire when Car is Cold?
- Reseting ECU
- broke head off bolt of park/neutral switch seal...HELP!!!!
- No more Beep Beep - Installed Hella Horns!
- Headlight Question
- maxima tee's
- Rear deck speakers
- Tinting
- About to put in H&Rs, KYB AGX, need help
