- Blacked out tail lights
- The newest Maxima owner
- 95 Converted To A Skyline
- Flywheel resurfaced???????????
- Adjustable Struts? KYB vs Toxico etc.
- why my car shift bad on 1, 2, 3 gear
- under Kunstruction Maxima/Skyline :) NIZMOLEE
- I dynoed the MAX
- Testing Injectors
- knock sensor replacement
- not sure what to use...
- Philips Bluevisions
- man i love my car
- LSD questions ?
- Need advise on FSTB
- Identify steering fluid problem
- Aluminum Overlay on Tan Interior Max, opinions??
- lower springs??what is best to use help i want to know what u guys thiking??
- weird air conditioning sound!!??
- Who has 98 gauges with BLUE lights?
- Amsoil
- Grinding noise when starting Max
- B pipe OR RSB
- Budget Y-pipe for a 1997 SE CA spec
- Good and bad news
- Skyline Bumper PICS... Fitment problems
- flywheel reviews?
- Carbon Fiber Gen-2 Pics!
- battery died, and airbag light came on
- front left heater oxygen sensor replace and still light
- how get the best time on 0-60 mph
- what is going on? please help.
- another 3 or 4 months.. what's the deal, custommaxima?
- Cheap tires for 18" rims
- cat back exhaust system
- berettas are slooooow
- Red Clears
- foglight question
- Turboing my new engine
- what is the ideal offset?
- The heat in my 95 doesn't get as hot anymore.
- Drivers door handle
- Bought a new car!!!!
- tip for those with coilovers
- CAI vs Hybrid
- Problems shifting....take a gander...please
- Rear Main Seal trouble! help.
- Do you have Oil Cooler and transmission Cooler in your Maxima
- newbabe; knock sensor and Rear Heater O2 sensor
- Exhaust + ECU learning curve
- Car moves in neutral
- whats wrong with my car?
- FSTB Installed... WOW!!
- $15.00 intake mod?
- max is freaking out
- Power steering pump went out :(
- springrate comparison
- Heated Seat Button Fell Off
- Please Help: front left heated oxygen sensor replacement
- Skyline Bumper Fitment?!?!?!?!
- Just ordered new suspension!
- How much did u guys pay for tranny flush??
- doing an engine swap......
- Could this be the starter??
- Eibach Springs Help
- bose head unit relocation in 4th gen
- Anyone have exhaust and trailer hitch interference?
- Flashing Air Bag light
- How To Reaim My Headlights. ..
- Y-Pipe difference?
- Frankencar Hybrid
- lowest miles on 4th gen
- going on 3rd alternater
- In case you were all wondering...
- Some input please
- uh...why not jus lowering springs??
- motorvate.ca updated: Alternator R&R
- People with Rota Subzero rims, did you have any issues fitting the rear wheels on?
- Warpspeed B pipe?
- Oil Question
- How much did a paint job cost YOU
- Photoshoppers can you help if its even possible...
- PICS: Possible new 95/99 Skyline body kit pics are up ---->
- walbro fuel pump
- Tire Pics
- My Newest Toy! (Pics)
- Shifters - Which is best?
- EGRC solenoid valve problem
- spark plugs one step cooler
- Bad sounds whem I turn hard
- freaking clutch!!!
- mirror
- Labor cost for replaciing suspension
- about to order budget b-pipe
- auto tranny shifting issues
- stillen intake
- Problem with shifter
- Ignition coil question.
- Check eng. turned itselff off?
- engine oil cooler sandwhich adapter??'s
- i need pics of silverstar's on the car
- Need Help pulled code and this is what it said....
- Pics of my max
- 60 series tires on 15 inch wheels?
- rim size for 97 maxima GLE
- Please Help!
- Next Purchase: COILOVERS
- Removing Overspray
- Air Bag light????
- stillen front lip question
- Should I worry about that annoying whining sound?
- Will Straight pipe Effect Emisions- Any recommendations---EBAY ITEM LINK
- check out this code reader
- ONLY 3 options for body kits?
- Light Spark Knock?
- Why my Max is so cold?
- Mudflaps & bodykits
- ST Springs For a 4th Gen??
- need help locating EVAP valve...FAST!!!
- M3 side mirror w/led in different place
- A believer in the "hacked air box"
- Brake Dust...or just plain dirty??
- Is it just my battery?
- 90k Service-- got fleeced
- Is this true? At highway speeds use overdrive gear to conserve fuel.
- Rear window defroster, defrosts too slow.
- Results of Starter Maintenance and cleaning of ground wires
- 99 SE vs. SE-L??
- Thanks
- battery light on b/c belt shredded....
- Question about Ben's ECU mod
- Should I buy???
- Newbie 1998 Maxima SE!! HELP
- Both my fog lights cracked. What can I do??
- Good deal?
- People with rt cat...and stillen exhaust...what bpipe you running
- mixed kits
- going to kentuky
- IAC valve difference
- Joint Axles CV Boots Busted
- Mounting Passport 8500 Directly on a 4th Gen
- want to clear out my tail light
- Never let my sister drive your car.
- Tranny coolers.....any suggestions?
- Finaly got My new AGXs!
- service manual
- Will a 2001 maxima engine fit in a 96 maxima
- after engine start up sound???
- I can't wait
- Very Important!!!! In Need Of A New Engine....
- I can't wait
- 4th gen maxima w/ sprint springs = no neon underbody kit?
- The BLOB and my car!
- Strut Bearting part number?
- ECT sensor....again....sorry!
- Speaking of Alarms... Powerlock?
- which catalytic convertor will fit on an april 95
- Why do my brakes lockup when it's cold? (Can't push pedal down)
- What lowering springs?
- LED Turn Signal Lights
- ASAP Help : ECU Code Reads "Closed Loop Control"
- What are the highest quality bumper lights?
- Suspension Guru's I need some help
- To much negative camber?
- Weird thing happened to my Maxima yesterday...
- Anyone have a rattle near the passenger dash?
- HELP.....My Clock is DEAD
- Woodgrain dash....
- passenger mirror
- For those with auto body/painting know-how
- 235/45/17 Tire Question??
- trunk switch ?
- Phase 2/oem fender ? and exhaust ?...
- 18's on Eibachs and Tokicos
- How to reduce wheel-hop?
- Is it possible to relocate the e-brake?
- Horrific sound
- New Coils....Alignment, Should I Wait?
- Fog Light question
- Is this possible/legal - pics
- Anyone hear new 350Z exhaust?
- Aluminum dash kit???????
- Carbon Fiber Hood, not Fiberimages...
- Yet another problem when I start my max...help please>>>
- Looking into buying
- Painfully squeaky door (causes cringes)
- hesitation
- Adding Wire to the Fuse Box
- is 3qts enough oil?
- 300 zx twin turbo engine
- Those with J&S Safeguard...
- Performance Clutch?
- Aftermarket Headlights
- Suspension Question. .Please Help!
- **Air Conditioning Question** - Blower motor related..
- KONI sport
- Will 96 dirver side mirror fit 98?
- Rust...
- Weird poping sound
- Possible Paint Chips & Two General Paint Questions
- Stock alarm good enough??
- FRUSTRATED Re: ECU Reset (Please help)
- Annoying humming sound while crusing??
- Clock Death
- to those who ordered budget y-pipe
- ty
- help! my car is locked in park!
- My clock starts at 1:00 every time I get in the car now.
- Cheaperr mods?
- check out my 97 and comments please
- $675 for stock replacement clutch??
- bank one
- Jacking Point for Maintenance
- new engine - will not start, HELP
- Slow Fuel Gauge
- ANy body Install the BOMZ CAI?
- maxima is sick
- Any cheap place to install Springs/Struts???
- 145,000 on Original front brake pads?
- HELP!!!Problem w/ my rear door hinges!!!
- Engine light flashing above 4000 rpms?
- Locking Calipers?
- Timing Chain Rattle
- Red/Clear tails
- Redline in 3rd on auto trans ok?
- need instruction to install wire looms....
- Newbie, hard time searching...
- Steering problem when cold
- Transmission question.......
- Getting suspension....what to go with??
- Kev's writeup on SAFC
- Question about mudflaps...
- Anyone delt with an DTC P1447
- A/C speeds malfunction
- Hating valet parkers BLEW MY SHINE!
- Can i use 1997-99 stillen intake on 1995-96?
- Need serious help with hesitation???
- Timing chain removal
- Correct Maxspeed Spring Install?
- Lighting
- max in fast and fearless 4
- Another b-pipe question...lil more specific please help
- Custom Catback
- Questions about budget ypipe ordering
- Which model K&N or Apexi filter should i buy to fit the bomz cai
- Lower Grill for a 95
- Question about manual transmission change
