- traction control didnt even work
- Timing Chain / belt replacement ???
- Replacing #5 fuel injector any help welcom
- transmission question..
- Maxima Final Gear Ratio
- Accidental Downshift (auto)
- Auto vibrates in 3rd
- What shoe did you guys get your pearl white paint job ?
- WS high flow Cat...clogged?
- WTB '95 5spd ECU!
- HELP tail lights are cloudy
- Corner lights in tails - quick question
- I think AC is over charged
- Smell Gasoline everynow and then....
- How bad does it get with a bad ks?
- Cefiro Question
- Help with Harlan switch
- Ebay Front Strut Bar... Any good?
- What changes did they make to the 1999?
- WS cat back exhaust.
- Removed intake = resolved shift problem from 1st-2nd
- Loud engine...like a diesel
- Anyone have non maxima side skirts installed?
- b-pipe and exhaust system
- Everyone who fitted 350z seats in their maxima
- 95/96 grille mod options
- How to tell if your maf is bad?
- got some ECU codes - multiple cylinder misfire and knock sensor
- problems maybe ks maybe cluth
- What tires do you prefer??(Best in your opinion..)))
- brakes keep smoking
- Tranny Flush without Paying 99$
- headers buzzing?
- What the heck happened here...
- New PICS after wash tell me wat you guys think 56k warning
- Car domain site up
- Coilovers?
- Cigarette Lighter Fuse?
- how do u change fog light bulbs on a 95???
- starting problems since doing clutch?
- My Bose system stopped working
- ALternator question
- PS Flush: Turkey Baster method:
- Online sites for Nissan OEM parts
- Navegation: who has one?
- windshield wipers: Brand?
- For those who replaced their knock sensor themselves...
- AC belt squeaking?
- Totaled Maximas
- Klearz, what kind of workman ship?
- Windshield Wipers wont work!!!
- H&R spacer question
- wheelsourceUSA vs. wheelguyz.com vs. woodandwheels.net
- airbag lamp, here we go again!
- Need Help On The Harlan Switch
- P0400 and EVAP Control Not Ready
- Diff. in BCM Part #'s?
- EVAP Canister
- Replacing lower radiator support- Help please
- Question about Brakes
- Anybody have an ACT clutch and not like it???
- Clutch hose removal(How does it come out?)
- AE Mod using other colors
- microvision question
- Thursday Hell (56K warning!)
- Another Max now sporting 300ZX TT Calipers with 13" Cobra rotors!!
- Can I rip off the heat shield btwn car and exhaust?
- The unluckiest week ever
- Question about BCM
- Loss of POWER
- How do I change these?
- timing belt replacement?
- Vrbration through brake pedal...
- Problems With My Max!
- I messed somethig up :(
- Turning Rear Brake Caliper Piston Stuck?
- Car Overheats with AC ON
- leaving tomorrow
- Just Curious If It Has Been Done Before
- AE mod gone bad...
- link help!
- DIY Dry Ice dent remover?
- Car is stuck in Manhattan garage - DEAD
- Fluid Flush: Price? Needed?
- New Sparkplugs: NEW WIRES?
- What color is the ground wire on the stock headlight harness?
- I need a fast Reply On Microvision
- replace two belts: $190?
- help "airbag" uninstallation
- CEL light problems...
- ECU codes, 1 Undefined other issues as well
- FS- 99 Stock Down Pipe, Fed spec, 50K miles cheap
- Spotted: 3XSS123 on Nobel Dr. San Diego
- Brakes rubbing...Help!!!
- Can i clean headlights with nail polish remover?
- Coolant Temperature Sensor
- Bose Hu from 99 max in my 97?
- Best place to get an upgraded wiring harness?
- Lower Intake Manifold - help-
- Alignment specs: Is this right?
- Fast Maxima
- B-Pipe/Cat CONNECTION
- removing clear corners
- tunr signals
- Can anyone tell me if this is worth buying?
- Missing button on my Bose radio
- Nismo Exhaust Hangers
- Lightened Pulleys and UDP
- New Red LED Interior :)
- Safe for tranmy to shift in Auto?
- What should i do?
- People interested in GD for CF hood+trunk
- hesitation in 1st = KS?
- LCA bushing install tomorrow
- Paint remover from plastic
- Trunk - different from 96 and 97-99????
- ebay universal seats
- Short shifter
- lub your antenna?
- lub your brake caliper?
- painted 5 spoke se wheel question?
- 00-01 I30 5 spokes on a 4th gen, anyone ever done it, pics?
- Quick Question about timing belt
- Tranny problem !!!!
- TGP (triple gauge pod)
- Help with tree sap, tried everything
- What is the website with Maxmods?
- Knock Sensor put in and reset, pulled code again?
- Need of Sound!
- PS2/Power Install
- Altezza Lights Look Cheap
- expected dyno numbers
- Any pics on nissan maxima 97-99 on 6th gen se rims?:
- Who here has the ultimate garage???
- vibrant exhaust?
- lowering very soon. what to watch out for?
- New Car
- Clicking/whistling from wheel area after installing rims NEED HELP ASAP!!!
- 87 or 89 octane?
- led or 194 bulb
- First time using LM1 Data Logger
- car wash *pics* after 5 months of no wash
- What exactly is an MEVI?
- Please Give Me Some Feedback
- ck engine light on.
- Link for thread: cleaning the coil packs?
- rust/ moisture in 2 valves
- Car shaking over 60mph?!
- another HID retro on the way
- Headers... is it worth the $$$?
- 1998 Maxima Gear Ratio
- cleaned TB, CEL!! HELP!!!!
- Error Code P0402 - Pre Cat missing. Warpspeed Y-pipe
- Trans problem i think? Help!
- Pic Wanted:
- RPM gauge acting weird..
- Rad. fans died- 98 SE maxi, help?
- Bad Bearing Sound Under the Hood
- Need help ASAP, will these fit?!??!?! I have 2 hours to decide!
- QUICK pic OF BLACK 95-96 MAX with stillen lip
- roll on window tint good or bad?
- Production Date Mystery
- Overheating, gushing out of coolant overflow..
- Transmission wont change gears
- Is it worth changing the check engine bulb?
- Yet Another A/C Question
- How to fix Ecu Code 1001 ?
- This is why I hate AUTO...
- 18 inch rims...
- Burned out, car stuck in 3rd, OD light flashes...
- Super 4th Gen?
- Loose clutch
- Optima Dead (2 months, ran twice)
- My car is the life, and will be the death of me
- Hood struts
- END LINKS!! How much for labor?
- How much is this worth?!?!?!
- Oil EVERYWHERE HELP!!!!
- Good Bye
- Need help with car Repair(reply fast pls.
- Mevi / 5th Gen Vi
- IS it worth Dropping This Ride!!!
- Getting very frustrated...
- pain is ruined!!
- DIY brake job question
- silverstar
- CEL-I know this has been posted 50 times but I went all the way to page 39 (the end)
- Anybody ever replace their Bose lights with LEDs?
- EEK! Coolant leaking off of oil pan. Help
- Pics Of My Ride
- OBX SS Catback
- Aftermarket flywheel: is it worth it?
- IS300 rims on a maxy
- Car shakes when at a stop
- Weird Starter problem
- Anyone have a picture of their 350z touring rims on a 4th generation?
- Write up on how to change TPS SEnsor
- shock sensor
- Just had the 02 sensor replaced and code is still showing
- Is $800 a good price for a 00 tranny
- ECU Ideas
- Header Leak need help
- Knock Sensor Relocation?
- Are These Any Good?
- Grounding kit or confounding kit?
- Gauging Intrest on a vented carbon fiber hood for 4th gen
- replacing the a/c evaporator
- New rear calipers on!!
- PICS of my mods: Cefiros, Carputer, Wheels...
- need new clutch what kind should i get
- Dashboard fuse question...
- Wiper linkage - need help
- Intake Question
- 5th gen clutch
- Radio installations
- pulled some codes need some help
- Greddy Sp2 Low Hanging B Pipe
- dash lights went out
- Widest rim I can fit in the wheel well?
- Code 0136 (aka 0707) - just replace rear O2 or anything else to check?
- OD light problem...
- WOOHOO!! Finally got my cardomain back up, check it out!
- stupid indiglo gauge on/off switch
- paradox-system emblem!!!!!!!!!1
- Help me with my rear window switches!
- Gentlemen...Show Me Your Aftermarket Fog Replacement!!!
- NYC roads keep destroying my front strut mounts
- FINALLY decent pics of the new max!!! L@@K
- Spoiler Led Set
- CF Hood GD!!!
- CarPuter Installed and working PIC inside.
- Brake rubbing
- MONZA Performance Exhaust Systems
- 4th Gen Scanner query
- air conditioning stinks like ***
- Suspension question -- Choosing strut mounts
- drag racing questions!!!
- Stumped... car won't start
- Camshaft Position Sensor.. how to...
- removing annoying dealer sticker
- A/C Recharge
- 5spd swap suggestions
- Max won't start :(
- can anyone help me install an o2 sensor in richmond, va?
- Bad MAF?
- stealership...arggg
- car leak again...help please
- rim=police target?
- rear brakes noise
