- Shifter Bushing Loose? Help!
- headlight socket wiring problem !
- warpspeed fitment with pacesetter cattback
- SP2 Question...Not what you think
- Headlights-on & Key-in Warning Chime
- Tire Pressure!
- My Trunk Has Just Jammed Shut! What Now?
- wires through the fire wall with a 5 speed
- HELP...my door latch
- farewell to my max...
- Windsheild squirters
- How do I tell what my ecu is
- reverse lamps after 5 spd swap
- ebay cheapest place for complete tokico illumina suspension??
- bought rebuilt 5 speed, starter location is different...help?
- car will not start, not battery
- IT WAS THE PEDAL!! But I Still need some tuning.
- 90k mile tune up question help...
- how to remove tint
- do you think this rims would look good on a max
- debadging
- OBX Catback
- Do you HAVE to change oil after Sea Foam?
- Anyone buy these?
- Converting 9004 to H7
- car has been jerking/bucking in first gear
- vent/trim painting
- In Desperate Need of Cat.!
- Budget Y-pipe special
- Symptoms of bad tie rods?
- anyone have the Diamond clear tail lamp from Custom Enterprize?
- differential bearing issue?
- Trouble, Trouble? CEL, Knock Sensor, TPS Sensor--shifting code --Comments Needed
- someone help ASAP!!!! airbag light jus came on!!
- people with JWT ecus....
- 06 civic si rims on my maxima ??
- about to order flywheel. any tips or suggestions for installing?
- blue lights in corner lights?
- can someone send me instructions for cefiro headlights?
- Tach problems on 4th Gen (created post)
- 3.5 Done some new codes
- See you guys later
- aluminized or stainless steel?
- Do I really need to get new rear brake calipers?
- 1st gear grinding, leaking transmission
- NGK Plugs....Plats or Copper?
- poping sound from front of car, HELP!
- Time to switch over to synthetic oil
- Time For a New Exhaust ?? (Full color Pics!!)
- transmission interchangability question
- Axle play?? Driver side Leaking 5spd (Pics inside)
- 95 Hood struts into 97' and vice versa
- now what
- Drivetrain clunk
- pic request blue led gauge
- NOOBIES: The "I AM NEW HERE BUT HAVE A QUESTION" thread...
- Whats the biggest size resonator the Maxima can take?
- Radiator Leak?
- Code 09-08 ECTS.What the....?
- wiring question
- what do you guys think Greddy sp2 or Cattman exhaust which is better?
- weird squeaking noise
- Need Help.. Coolant Issue
- Spotted 4th gen with rims, Going to cape cod
- coilovers?
- Can You Tap the Brake Booster Line ??
- Hid's Projectors/non Projector People Come Please.
- Car stalls whenever I get to a stop
- 3.5 Swap done, come see...
- Washer squiters
- What Kind Of Bumper Is This???
- Fuse for interior lighting? Headlight electrical connection?
- fog bulbs
- 95-96 grille-tech
- Brake Wear Heavier On Passenger Side??
- Pealing-out
- are these any good???
- Transmission filter
- Windshield Wipers
- Breaking prob!! Slotted/Dimpled
- Bad starter???
- Common issues with 97's ASAP!!
- faulty ignition switch
- sometimes, car needs extra cranks when carryin heavy loads
- Rims/wheels On 4th Gens, Post Pics
- PCV Hose
- Why does my Maxima shift hard into 2nd gear?
- rear hub....what other models?
- where to get a K&N air filter for cheap?
- Replacing front bumper
- Weird issue please help....
- Place Racing CAI Review and Warpspeed Complete System
- trade in 4th gen for 03 six speed ???
- Reasons for Maxi's Stalling and cheap solutions
- Car hiccups
- Anyone ever replace their radiator support?
- spec v question...
- Damn Iat Sensor
- jack and jackstands
- Anybody try these head lights yet?
- Tranny cooler
- IACV and injen
- Lateral Link Hitting Sway BAr
- front passenger window switch
- Replacing Engine Mounts
- Video of my old Maxima
- how to safely remove spraypaint from car paint??
- Retrofit Question
- Tint measurements
- Tint Pics.
- Removing side door moldings ..
- Locations of the O2 sensors...
- rear wheel spacers
- ICHIBA USA Aluminum Hubcentric Wheel Spacers
- why am i getting condensation on my turn signal lamps?
- wheel alignment and FSTB
- air bags
- drop resistor
- Service Engine Light?
- headrest improvement
- Digital cluster mileage
- tranny whine
- Magnet touched my t/s ecu
- tinted headlights???
- Cluster Needles Sticking; Need Help!!!asap
- help! hood won't pop!
- my freakin intake filter fell off! dirt in engine??
- how do you know when water pump is bad?
- help with water pump replacement process
- Red/Clear Tails
- FPR or FUEL PUMP?
- Taillight leak
- Check Engine Light diag, results.
- jsut some progress of my interier
- ahh help! trunk stuck closed!
- Fog Lights Crooked
- Replacing tie rods
- bad gas?
- Are Ding kings the best bet to remove dents...
- 3.5 swap...code 0701 (multiple cylinder misfire)...car's running great...what's up?
- For the record, NAPA axles are teh win!
- washer nozzle removal
- Anyone know what these 3 "sensors?" do/how they're hooked up?
- '99 Auto Climate Control LED Mod
- pulling funny
- sell it or not
- I think my tranny is leaking [5-speed] (pics)
- Air Bag Light (Not Blinking)
- Tranny Question
- How to diagnose cyl. 4 misfire? code 0605
- Alternator noise + shaking + new clears
- Stock fuel injector output?
- starting problems (alternator/starter?)
- Coilover Springs ,True or False?
- HID Install Gone Way Wrong!!!!!
- suspension question
- Picture Request-G35C 18x8 on 4th gen sterling mist
- Front pass. window (motor turns forward and back)
- 6th-4th Gen wheel fitment
- car drives like CRAP?
- How to test vehicle speed sensor?
- Another successful retrofit
- New foglights
- ECU code
- Changing ATF in high-mileage car that has been neglected...
- Turn Signals not working
- Ionic dynamics rear lip spoiler. CANT SEARCH
- Adjustable Shock Strut Combo Vs. Coilovers
- Respray update
- LED Tail Lights
- is this safe??
- Alignment Sucks
- wtf? O2 sensor replaced, now CEL is back on with same code
- ticking at startup.....but is it the tensioner?
- Another lowering thread
- Fast Cd
- removing corrosion inside wiring harness?
- Help! Rear brake caliper noise
- 1996 gle amp?
- 98-99 auto climate control unit in a '95?
- 96 GLE with ABS light on
- auto trunk open?
- Ce Headlights!!!
- Tried installing short ram intake
- Wiper Arms.
- Inserting Trans Seals ?
- Just a little FYi about our stock B-Pipes
- Quick Question 97-99 Bumper Conversion
- Under the Flywheel ??
- Passenger Step Lamp Inoperative...Is this why?
- Window Tinting - Has anyone in PA ever been ticketed for 20%?
- Squeaky Suspension
- Speedometer stoped working
- Adding a second max to the familly!!
- Parking Brake Button
- Fixed code P0446, still problems
- UR lightened flywheel?
- subframe connectors
- shocks
- BOSE stopped working
- Is this wheel bearings ?
- Air Horns
- 4th gen or 5th gen
- From beginning to end.
- What coulda made my car shut off?
- Camber Bolts - Using them?
- EGR problems
- Strange Start-up Noise
- Cruise Control doesnt work
- Car Jerks, what could be wrong?
- getting engine misfire code
- Drivetrain clunk (and a LONG story)
- EGR Problems 3/2 Code - Help!
- ECU fried!?!?!
- HELP...Sensor Issues.
- Start up noise *sound clip* - bad TC tensioner?
- Magnetic Oil Drain Plugs
- oil leak!
- Belt Change - 99 GXE
- Stock Speaker Sizes
- acronyms
- HELP, car wont go into gear with new clutch
- vertical left front movement/clunking (font end)?
- POLL: Which 4th gen do I keep?!?!?!?
- Pinstripe - should it stay or should it go?
- quick HID question.....
- how to tell when your fuel pump is bad?
- progress RSB install help! quick question!
- Water pump quote
- OBD II or I ?
- 8000k Hids + Fogs ( Pics! )
- KCMaximas 4th-Gen Supension Parts Page?
- So I got the PO325
- H-techs or Progress?
- Help!!!problems With 00vi On 95!!
- Custom System.
- People, where do u put ur xbox/ps2 in your 4th gen?
- How do you change a window?
- Trans making noise when your foot is OFF the clutch? It's the input shaft bearing
- JDM Black altezzas
- Reverse is gone Right front corner is tucked
- Window Trouble
- Why you SHOULDNT do burnouts in your 4th gen maxima. *pics*
- Now I am really frustrated...
- Cutting Headlights From Factory Alarm
- Clifford Alarm Trouble
- Knock Sensor Bulb Seized
- What's the Offset of your wheels, size, and brand?? post pics if you got em
- EVAP code will not go away...
- Easy fix
