- Friggin alarm siren went out.
- performance help!
- popcharger?
- Muffler
- help with led in switches
- Is there a how to... jack up your car and change the rims?
- Dead Battery or Bad Altenator?
- flashing headlights cost me losing fog lights !
- after diagnosing the codes, i need help plz
- How many of you installed a Glass/Shock Sensor to Stock Alarm?
- Disabling factory keyless entry
- Which Spark Plugs for Better MPG?
- 1st New Pic of ceasars chariot
- Your thoughts on a 98 SE...
- brake problems
- Bulb in Door light??
- What should I Expect
- Gas pedal loose
- Red Lights
- Adding breather filters
- Why are stock 97 SE wheels like this?
- Rough Cold Starts. PLEASE HELP!
- URGENT!: Stripped transmission bolts after dropping pan!!
- Found a really good parts site!
- Strange Ratteling noise in my car...
- happy new year to all .. hope noone got any dui/dwi last night...
- Problem with locking door
- Anybody have Piaa Xtreme White headlight bulbs?
- budget y pipe
- couple complaints about maxima remote entry... confirm with me please...
- Mystery rubber tube - not connected anywhere!
- DAMMIT and Happy New Years!!!!
- 95-99 VIS CF Hood
- sae bok ma ne ba du sae yo
- air filter problem, help plz
- help car wont start
- Just Ordered Tein S Tech Springs
- How much would you sell for?
- Cefiro Headlight ineed nstallation information.
- Who has a Apexi WS Cattback here?
- help quick!
- Need help with hurt 98 max
- Need Help Making Stock Spoiler Brake Light work
- question on red/clear taillights...
- How do I...
- autozone checked my CEL light for free.
- AGX/Sprint owners tell me how it is
- CAn you swap a 97 grill on a 96
- headlights??
- body kits
- did 2 projects to my gxe today!: check them out!
- Aaahhhhhh!!! Hate 95 cupholders!!
- Guage Cluster, swap?
- Dents
- Decent quality, good priced, shift/ebrake boot?
- cutting stock shifter
- throttle cable and the perfect launch...theory
- Slave Cylinder
- Best place for SS brake lines
- size 74 blub
- need help quick!!!
- Infiniti I30t
- 20 HP "CHIP", what are you takes on this thing??
- Difference Between Infiniti I30t And Max
- 02 sensors
- Help!! car's almost stalling
- Help!!!!
- Problem Starting In Cold
- E-Brake Light (mini problem)
- levoc auto shiftknob on custommaxima.com?
- ricefob hittin 100k soon, need a check list to watch out for...
- Tranny Pan Bolt Pattern?
- Insatlled new HID KIt
- Need Help!! Code 0201
- Re: Opinions on the Skyline Body Kit
- Need help with wiring up my Airhorns..Please
- Problem with Stock BOSE radio
- who could change a knock sensor?
- engine light on
- re: mpg
- new car (long post)
- Lousey Ignition coils
- close call - check your hoses!
- Pop sounds when I turn wheels left
- Foglights
- which lights are these...
- bosch cermic brakes?
- Plug #'s for 1 step colder
- Why the shaking at 70 mph?
- Light Bulb Listing (all Lights Used In Max)
- R/C Body for 4th gen Maxima!!!!!
- Need help with this.....
- Auto Tranny in Cold Weather
- keyed car
- I have never seen my CEL flash at me before...
- Power steering pump leak
- How do you stop break squeaking?
- what is absolutely the best performance brake pads for our cars?
- knock sensor changed, now bigger problem.
- Front Heated O2 Sensor Stuck, Tips?
- Changing to climate control
- Car runnin sluggish don't know why?
- Antifreeze smell from under the hood
- Tools for Shock Replacement- Question
- Is the dealer trying to rip me off?
- code help....
- Trunk Release Won't Pop Thr Trunk
- Plug diagnosis
- Clutch Pedal Making Noise
- Where to find a good tranny
- How to get the back door panels off?
- 95/96 to 97/99 front end conversion
- Good price on a mevi....
- Sorry, quick spark plug question
- Will it hurt to add an MEVI to a..........
- Questions on swapping from auto to stick...
- Lightened Flywheel?
- Tockico HP or GXE OEM,which is softer?
- Does anyone have pics of Nokya artic purple or artic white headlights
- Afew Questions
- Grill mesh on a blue maxima, anyone got pics?
- How should I remove a glass sticker?
- Fiberglass Fenders?
- LSD tranny vs tranny rebuild
- Good websites
- Grills for a body kit
- MAF adapter
- * NEW * 95-99 Maxima Stone Racing Headers and Y-Pipe Released! (Hi-Res Pics)
- Wheres the best place to buy a hidden hitch?
- Grill for 95-96 Maxima
- TSB for Timing Chain rattle
- should i buy suspension mounts/boots? & camber kit?
- new caliper grabbing rotor
- anyone knows about a recall for alternator
- Anybody ever got a CEL code 0707 (Rear Heated O2 sensor)
- Programming Keyless Entry
- Where can I get Goo Gone!?
- Street Scenes upper/lower grilles for 97-99 maxima
- HID bulb question
- Repost-car hasn't started in 2 days
- 2K1 Motor, 95 Manifolds and ECU, No Problem.
- my rpms stay at 1k and sometimes over..
- tranny install tips/advice...
- 300zx master cylinder ?
- strut knocking sound
- Gauges, turn signals and windows not working
- Horn will not go off
- Front Doors Won't Fully Close
- intake manifold question
- Splash Gaurds?
- How Many here bought thier Max brand new?
- CV blew up, now I need to change suspension and axles.
- Harsh shifting w/Auto transmission
- Good place to get cheap coil packs???
- Auto Climate Control Lights Replacement
- New Member
- Climate Control...
- Burning smell?
- screen mod for a 96 maxima. i need help
- VB mod
- catback parts?
- Need Additional IACV Info.
- spark plug removal
- help! rear window power motor is broken, how do i fix it?
- WTB: CAI pipe and cone setup in good condition
- HeadLamp Help - Please
- 4 Got to attach Climate control tube back
- emergency: barren,axle,strut problem
- had a bulb explode in my headlight
- just got a 0905 cel code
- Drop Resistor VS. Valve Body Mod
- Mod that all non-HID people should do.
- Dash Lights won't come on~!
- How do take off the stcok e-brake handle
- Are parts interchangable??
- Wiring Diagram
- Which HID manufacturer?
- Altezas
- Level 10 or MobileTek VB
- 5sp swap, help needed
- Check Engine code P0705??
- Drop resistor mod?
- 0705 & 0903 Codes
- New engine installed!!
- Just came back from Kragen's Auto Parts for sparkplugs and have a question.
- How to Change power steering pump belt??
- The dreaded CEL returns! :(
- intake gains
- Maxima o2 sensors
- need more detail than FAQ . how to adjust clutch
- Which is brighter for the corner lights?
- Rims vs MEVI
- Udp, Is This A Good Deal Or A Rip Off?
- ecu
- New Steering Wheel Trouble
- Amsoil By-Pass Oil Filter Mounting Kits
- Whut Now?
- What should I use to seal minor crack on CF Hood??
- Shift boot installation?
- tranny cooler
- Looking for REDMAX
- Tien H-Tech
- Neutral Safety Switch
- Humiliated a Mustang GT
- Updated Pics
- cornering lights
- ball joints and front end bushings
- Help, Max wont go over 2K RPM's
- Energy Suspension Control Arm bushings installed
- Huge Problem~! *long*
- Blinker clicking...Is there a way to stop it
- Bumper Lenses (esp. if uve had urs stolen)
- Heated Seat Problem
- Rear window won't roll up or down!
- Coolant resovoir
- slave cylinder going bad????
- New Updated Pictures of the Car
- Max won't start, buzzing sound
- Carbon fiber Interior,
- Another one bites the dust (tranny destroyed)
- Clutch Repacement, Not for the Faint hearted...
- Hub/Wheel Bearing Gurus needed
- Starting Problems
- pics of black leather on a tan interior
- Fuel Presure
- Torque on knock sensor
- Ball Joint / Smashed Finger
- Installing Sprint Springs
- Has anyone tried the Silverstar headlights?
- Remove power steering - increase power?
- Maybe trading in car...:*/
- Heater doesn't work on "1" "2", or "3" speeds...
- crap logo!
- K + N filter, hacked air box
- How to clean corner lights
- Tail Lights
- Have 96 Max, want 97-99 trenz grille, what to do?
- replacing knock sensor with a resistor
- Bomz Air Intake
- car dont wanna start :(
- HID wiring harness on Ebay
- coils....
- mesh grill
- Sterling Mist w/ mesh grille
- Coils...
- GPS Set-up?
- Let her Breath!!! Write-up on replacing injector
- Maxima Engine ?
- Christmas presents to myself!
- new front lip
