- Auto Gear Selector - Button popped out
- Front End Frustrations
- Look what i found :D [[BOMZ CAI]]
- R35 GTR Seats in a 4th Gen
- 3rd gear scrapes/grinds when shifting!!! HELP!!!
- How to wire DDMtuning HID Kit?
- 00VI+Emissions=Pass or Fail?
- Check out my OLD/NEW front bumper
- Custom Maxima Coilovers?
- Suspension talky talky
- Foglight rewire failed
- Help on starter problem diagnose
- Any 99 with NATS stolen ?
- P1706 - PNP switch
- code central
- 2000 rpm limit on 95 Se
- Sticking Driver Power Window 98 Maxima
- DEK AND DE FUEL RAIL
- Suspension question: what to do?
- How much approx to fix wiper linkage?
- replacing clutch slave
- got a new toy
- I need your opinion about A/T Flush
- good upper intake manifold degreaser?
- Who does a good retro fit?
- need help/opinions
- Anyone have pics of Tokico HP Blues shocks and springs setup on their car?
- 2001 EGR question
- Fix this damn cupholder.
- Side markers. Show me yours
- engine light reset, cycle time
- PCV
- weird rattling around the tranny.
- Drop Resistor - How do I test?
- im looking for a thread
- Rear toe alignment problems Please help
- Chrome Pillars
- KYB GR2's and Tein Springs or KYB GR2's and Stillen Front Lip?!!!
- Anyone purchase the recent ebay Adjustable Fuel Pressure Regulators?
- Chrome In Fogs Peeling?
- remote truck pop install with a few pics
- power seat and windows problem
- Oil Change
- clean up the stickies?
- rpms gauge and odo meter not working
- Help, Need advise on these wheels. pic inside
- P0745 - Pressure Line Solenoid help
- Shift Knob Removal
- Clutch no tension - cant shift when ON
- always low on coolant
- HH Auto Wheel and Trim
- Have you guys seen these?
- Reason why 4th gen maximas are being stolen at least from what I know
- car won't shift into gear
- shocks and springs: help
- DNA COILOVERS???
- Photo of 2010 Maxima wheels on 4th gen
- SPEEDOMETER REPAIR SERVICE
- HOW TO PLEASE READ- 98 to 99 ecu
- clutch specs
- Possible damaged strut?
- Amsoil engine transmission flush
- wiring up a 2001 ASCD to a 98 SE
- Requesting photos of brembo slotted rotors installed
- need help with ckps sensor!
- Im having some electricla problems that are stealling my horsepower
- wired rolling noise
- need help which wiper motor to buy!!
- Any place to get OEM misc parts?
- Won't drive forward-help!
- car stalls after start, p0130, p0135, p0325
- Hard (or no) starting in cold weather
- what else should i do??
- Springs/Shocks best pricing?
- One Step Forward, Five Steps Back....
- Disabling factory alarm on a 96
- trunk remote
- How to take off Front Wheel Hub?
- Emergency. Part number needed
- Electrical Issue
- Metal Scraping Sound When Driving
- How do I heat my 96 maxima while parked it's outside?
- Belt squeal FTW
- Any knows who's car this is?
- Amber corners?
- CEL in my 96 maxima
- My damned headunit wont start up!! (bring reading glasses)
- Ignition coil connector broke...options?
- 97...LED Needles
- Need your exhaust opinions
- 98 Trans/Axle/Clutch Issue
- My car started sputtering please help
- Please help with my lacking power in my 97 5peed
- Strut removal problem.
- Crank position center wire, below oil filter
- 1998 antitheft problems
- Weird Knock Sensor Problem
- Wierd smell only when engine is cold
- roof wing debate...
- Ebay Bumper Signal Lights
- HELP ME FIX THE MISS UNDER LOAD
- What size speakers in '97 Maxima SE w/out Bose?
- CODE P1320 NEED HELP
- got these from the junk yard
- exhuast help
- Help with my front end
- What is so special about a 95 5 speed Maxima ECU?!
- Another drive to Texas in my I30
- Gear indicator on dash?
- outer taillights
- To sell or not
- Revved 3K with E-Brake on
- ABS in the Snow
- 96/97 tail light fit and modification question
- Mystery Misfire
- How is this for the first seafoam ever on my Max?
- 3.5 swap question about fstb
- "Specialized" Mechanic
- Front Hub question.
- What headlight bulbs do you use?
- How often do you replace your NGK PFR5G-11 Spark Plugs?
- Stone Mountain Racing Y pipe?
- Whats the easy way to install a auto tranny in.
- Looking for How to on installing the PR CAI
- Where can I buy a 99 SEL wheel / rim?
- I took my Maxima for a drive Video (A32 with DE-K Swap)
- Where does this hose go?
- R34's projector
- driver door unlocks but none of the others
- any1 down for a meet in MD?
- trans makin clicking noise
- Engine Hoist: Exhaust Studs?
- Check this video out.. Repin the 4th gen!
- Cam Sensor Reference Voltage
- IACV Pink Plug?
- Fog Light + Bracket Install Guide
- Good Bye and Good Luck
- miss my 5spd; mod the auto?
- Changing Fog Bulbs (97-99): Dummies Guide
- changing the alternator 96 max
- Steam/smoke coming from near firewall
- CEL flashing after resetting ecu
- Antenna Problem
- Will the 97-99 OEM alternator fit my 95
- I need a quick opinion on a BOSE HU
- Can Someone Post A Few Pics Of Their AE'D OEM Headlights
- 3.5 swap...
- Can't shift out of neutral after axle swap! Help!
- Where is the IAT Sensor?
- Sensor failures
- Hesitation/Jerk when fully stopped in ‘Drive’ -Auto
- Manual BLOWER/FAN voltage = 0v
- RPM Dip / 5sd
- Cabin gas smell
- My 99.... Immobilized!!
- Need Help with HIDs and Headlights
- maxima in the snow?
- 97+ Apexi WS exhaust on a 96 car
- Need help with wire harness
- engine blew up:) need a new one! you have one?
- Where do I connect these pipes??? Bottom of TB and top of tranny.
- rear speaker wiring
- Car will not turn over
- Making an Exhaust thread, Need help.
- How do I remove the the doors from 4th Gen ?
- Any safc users on 4th gens?
- Alternator Cleaning
- fog light install instructions 97-99
- new alternator, car still whines after install
- Help car won't start after trans install....
- my maxima sounded like a semi truck
- Where to buy new flywheel
- Idle Issue???
- What's George Forman got on your grill?! Grill pics wanted!
- Max has water in the oil, what would you do?
- rear quarter panel body work question pic inside
- Weird noise AFTER car is started in cold (VIDEO)
- Stereo, Clock and 12V cigarette lighter shut off randomly
- Saying goodbye.
- Intermittent Rough idle and high idle starts. (Videos inside)
- headlight housing replacement
- Dumb fluid changing questions.
- Show me your gauge cluster
- Redded Out the Tails
- im never letting my friends help with my car
- Filthy rich 98 with no codes. Any ideas?
- Replaced My Radiator ( Pic's inside)
- 98 Maxima SE, 190K, how to tell if starter motor is dead?
- defective starter solenoid?
- 99 starting issue
- Gambles progress thread
- 100K
- regreasing starter: how much grease?
- What maintenance to do?
- 9 years of ownership, 165K and still a daily driver
- where do you get non-****ty leds for tails?
- fan buttons above the temperature slider
- car won't start ?
- Custommaxima catback
- Question on one ground cable
- Help: 96AutoSE, Hesitates on Accel, Occasionally Quits under load and idle. ECU? MAF?
- mystery rattle at top of windshield?
- 95 GLE TSB questions
- iPhone issues
- back in the game
- Post your Maxima X-mas haul.
- Stolen 1996 Maxima in Brooklyn Please if you know of something pm me
- Easy RWD Idea
- coolant leak - water pump - opinion needed
- which swap should i do? de or dek?
- Headers and Y pipe or just Y pipe?
- how do i change the oil pump plz help!
- LED Guage Bulb Type?
- Electrical Problem HELP
- Make SURE you get what you want for Christmas, Hanukkah, etc. @ Cattman Performance
- Crank Pulley Check
- Static Electricity Shock everytime I get out the car
- Cattman December Discount Sale in Group Deal
- Help: Getting 0111 code on my 97 Max
- please help with crankshaft pulley
- courtsey lights will not come on
- Weird ticking sound from around timing chain cover
- Stainless Steel Clutch line one piece failed!
- Chassis/suspension tightening
- Odd coil pack issue???
- o2 sensor ECU readjust
- 2009-2011 VQ35DE SWAP?
- 5 speed swap ECU Question?
- Rear door corner trim removal
- NAPA/Altrom and Aftermarket Parts
- Engine Mount w/ Pics
- Misfiring
- clutch slippin in 1st when floored...
- Bought new radiator Through EBay.!!!
- Starter regrease how to
- Rear Brake Piston
- Torque Link
- infinit q4 engine
- Mufler/Exhaust Bolt Question - Size?
- maxima starts up very sparingly
- Will not rev above 2400rpm. PLEADING FOR HELP!
- 4th gen styling
- Gas fumes when heater is on
- DO NOT Put Tape On Coil Packs
- So i was spray painting my car......
- OBX y-pipe
- midwest maxes?
- Driverside axle seal leak.
- Birth,Mods,Death,Rise,Fall,Rise,Reborn of the batmobile (my 99 max)
- 97 Maxima Gauge Cluster and Speedometer Problem
