- Stillen Y change exhaust tone?
- best headers?
- KYB AGX with progress springs
- Interior door light (step light) is not illuminating...
- Help Transmission cooler needs changing
- Bomz Install Help
- Can anyone run a CarFax for me
- Ever used the "Spiralmaxx" intake inserts?
- Problems starting
- Front and rear rotors?
- VQ35 in a 4th gen?
- odd but serious question...
- Help with backup lights
- Where to buy....
- need help with cruise control on 98 GXE
- 18" 2"in drop
- Spark Plug Question: NGK type vs. Bosch Platinum 4
- P1130 fault code?
- 99 Max racing on cold starts
- Clearing an Air Bag indicator light
- Is this a good deal on a 99 Maxima?
- Just installed frankencar a few ???s
- Anyone Familiar With The NVIS System?
- Need some tips on performance parts for 4th Gen. Max
- Maxima Headers OR Bodykit
- cerfiro Headlights & HID's cardomain updated
- 2 tone max
- 3 questions here, thx~
- Change out LED's in stock spoiler light...
- nissan's 100 point check up: problems
- GR 2's plus H&R Springs Set-Up???? 5speed
- whats your choice?
- how do you get those scratches out?
- Part Numbers for Strut Mounts
- Hayden tranny cooler hose size?
- Attaching the Stillen front lip.
- Hose Part Number
- quick question
- Does the 4th gens look better with a stock wing or without?
- ecu part # for 95 gxe or se 5spd?
- Who Is Th Most Custom
- With our older cars, i think you are gonna like this product
- Strut Bar Install Gone Bad!! HELP!!!
- Antenna replacement
- I have a couple of problems
- '99 SE Air Bag Warning Light
- Cracked Foglight...What can I do?
- Oil Light that Flickers
- Need an online store for KYB dust boots
- pics & directions for 97-99 Maximas with mesh grill - please post
- 200 bucks to blow
- clear spoiler led replacement
- Ebay Key=Teh win... You like? [PICS]
- CV axle/ 100 point inspection
- How did you get to your Y-pipe bolts???
- Smoked Cefiro headlights - problems
- cutting Stock shifter? good/bad?
- cams
- I Got Brain Today...
- 97 cluster SE question
- I got bent over at the dealership today
- Opinions on 5-speed conversion
- What kind of intake should ***** get?
- 95/96 Red Clears
- 4th gen power trunk release
- Cars making a knocking noise...sounds like trouble, anyone got any ideas?
- Trailer Hitch pics on a 4th Gen?? Anybody?
- anyone here install 9004 upgraded harness?
- When resetting codes....
- greasing antenna
- Car covers?
- petition to auto remove (useless)threads
- CEL p0400 egr valve... change the soliend??? i was told
- solora
- Tein S tech's
- Dtc 0409
- where can i get a clear lens for my stock spoiler?
- Question About Replacing Coil Springs.........
- Recently Bought Passport 8500
- replacement power antenna
- Oil Catch Can
- keyless entry question
- will bigger tires/rims effect GAS Mileage?
- How do you fit Apex WS cat-back on '97?
- Altezza Gen II for 95/96?
- Which intake should I go with?
- power antenna help!
- looking at buying a 4th gen maxima
- exhaust
- Normal Reverse Glow Guages
- Stalling right after morning startup
- VARIABLE INTAKE what does it do?
- Ecu Code Translation 0307 + 0509
- suspension question
- YOUR opinion on an intake, frankencar, injen clone or POPcharger? Opinions please
- Replacing axles. Do I have to remove Gear Indicator Switch?
- Anyone here?
- intake
- detonation after Y pipe
- Nissan should have mad this...
- code 1302 and MEVI
- Where does this hose go?? ~ CAI
- Whose Maxima is this and where's his/her homepage???
- newbie question....where to hard-wire cigarette lighter 4 port hub?
- maxima i30 grill
- A/C throws air, but its not cold
- courtesyparts.com clutch set
- Need a 5-speed fluid flush writeup...
- 97-99 headlights finally installed
- lower control arm
- What's the easiest way to check/change the flywheel?
- stolen max
- Emissions recall on 96 P8132 ???
- jet or no jet?
- JWT ECU and code 1005 in 1997 Max
- Just changed plugs! Help please!
- ?Adjusting Koni Shocks?
- Airbag module installation! HELP
- Struts for Pro-Kit
- Cupholder inside armrest on a 96
- Has anyone tryied the speed limiter remover??
- need how-to for acc belt replace.
- Found brake problem now need help solving it!!!
- 6-Speed Maxima?
- Exhaust question.....
- Recommend me a QUIET muffler
- cup holder
- stock shocks problem
- color change on the clock..etc
- cali or fed spec
- Leather seat covers
- question on gauge turn signal
- All-Red Tailight Write-Up
- does bose hookup direct if i dont originaly have bose?
- sunlroof leak.........Help!
- Ripped STEERING boots
- Any other cams than JWT?
- Why do you Mod???
- JWT cams
- Hid headlights for 4th gen
- questoin about alternator....once again
- Pricing question
- New here, need advice (Euro-spec)
- What is the 4th Gen exhaust path?
- Need Gauges from SE
- '96 SE, clutch master cylinder?
- poltergeist elec problems
- need an answer
- Problems on my car..
- !!I need advice about lowering my car!!
- Real Dash Kits?
- sunroof repair
- So frustrated please help
- Thoughts on the this forum - please vote!
- Updated Cardomain Page!! please take a look!!
- accurate transmission?
- is my tranny supposed to do this?
- Dynomax mufflers anyone???
- best clutch?
- attention 4th gen owners!!!!!!! need advice
- Painting bodykit-quick question
- car runs rough if it hasn't been run for a full days
- Can someone help me with the Red/Clear mod?
- recommendations on where to purchase alternator?
- Ngk Iridium Ix ???
- Dust boots for Tokico Illuminas
- these intake questions have got to stop
- Eibach Pro-Kit or Tein H-Tech Springs?
- gad engine ground????
- Any problems with these size tires.....
- what do you guys think of these black taillights?
- Anyone familiar with this CF HOOD?
- Service engine Light
- REV Limiter
- New Exhaust
- Throttle position sensor??
- painted dash VS. aluminum dask kit
- which intake should i go with?
- Which Springs do you suggest?
- Y-Pipe and UDP
- You have to read this.......
- air filters
- Whats the difference between Tokico (silver) & Tokico (Red) Springs???
- What should be my next mod.
- shake when idle, clunk when engaging 1st and 2nd gears
- Pulls to 7700rpm smoothly
- location of the EGR solenoid?
- i want everyones opinion
- 18’s with stock springs and struts?
- Motor Cuts out after WOT!
- Interior rattles and the TSB
- Aftermarket Variable Back Pressure Muffler for 4th gen?
- Lets get it straight... which exhaust... intake + y-pipe + _____ ???
- Newbie with Questions (Performance Related)
- ngk platinum or copper?
- Guys with JWT/MEVI: Have you pulled your plugs?
- got a few maintinence questions
- Fog Lights
- Which Intake mod is best paired up with a Y-PIPE?
- Proper tool to remove airbag locking bolts
- Help! Ebay, Is it a possibility??
- warpspeed y pipe question
- Clips on top of coil packs and plugs.....
- Best Spark Plugs For Performance??
- Stock wheel paint?
- washer nozzles universal?
- New Y-pipe installed today
- 97se Stalls on deceleration with clutch disengaged
- yea my cold air intake just came
- Coolant puddle on the ground
- What is needed for a Double Din Installation
- What does this part do?
- headlight problem
- battery issues
- Helppp!!!!!!!!!!!
- $ 3,500 from Uncle Sam
- whining sound
- Eibach Springs!!1
- Key Chip Bypass
- better launch in a 4th gen auto
- week engine idle
- Spare Key Installation? DIY?
- climate control?
- Erratic Idling: Bad Mass Air Flow Sensor?
- Can the stock clutch handle all N/A mods?
- Question about Oxygen Sensors
- someone has to have an answer to this..tch
- Doing suspension...whats the best?
- does anyone know the BUlb size for the front signal lights?
- why did my brake light on spoiler stop working ?
- moonroof
- is this for real?
- What strut to use?
- glow gauges install
- Curious
- suspension installed...PICS
- Tune-up
- After 5 long years with my 4th gen, I sold out
- Loss of power after a little burnout..
- Goodbye org, bought a new 350Z
- loud noise when releasing brakes - really strange - any ideas?
- Signs of bad bearings?
- 1997/1998
- Can the Cruise control be ''adjusted'' ??
- ATTN: Guys with MEVI + JWT ECU
- clutch completely toast?
- Cefiro Headlight + HID + Eyelids
- Help with some obd 2 codes please
- 95 maxima smokes
- Y pipe installed a week ago, now the vibrations.
