- Has anyone used a TYC window regulator+motor
- Alternator suggestions?
- Noise when I turn steering wheel counter-clockwise
- Trouble moving off in drive on a frigid morning
- Emer Brake Cable Replacement - what else needed?
- The Front Passenger (Right) Side Creaking Noise
- maxima heaven!!!!!!
- Any idea what this noise is?
- Manual Transmission Rebuild Question
- Bosch 13783 O2 Sensor question (P0136)
- '96 Maxima charging issue
- Valve cover bolt snapped
- Sources for new charcoal canister for my 95?
- 1995 control arms
- Planned clutch replacement.
- headlight plastic or glass
- It's Official: No More MOOG Problem Solver LCAs
- acts like battery is dead but it's not, won't crank
- 97 SE- 12v outlet or cig lighter ?
- Oil Cooler hoses on radiator
- New Full SS Clutch Line Leak At Master
- 15 Amp Stop Light (Brake Light) Fuse Keeps Blowing
- Shaking car
- Got a P0734 code - how screwed am I?
- any aftermarket a/c compressors worth it?
- P/S Hose Copper Crush Washers?
- my 1995 maxima has a flat spot during acceleration
- Headlight question- What type is 97-99
- should my side markers blink? ( put aftermarket lights in years ago )
- Need advise asap! Tiny oil leak a problem??
- Crank Position (POS) Pigtail Qs ...
- Buying a 4th gen, what issues to look for?
- 95 maxima not charging
- Standard vs automatic transmission
- Should I keep my Max?
- ok, so weird, but awesome!!!!
- Wheel bearing kit
- Code P0130-because of steering pump leak
- Spedometer and cruise control dont work
- Car gets no power :(
- Steering pump change and now check engine light?
- 1995 Engine & Transmission Swap
- 2 car problem: stumbling, misfiring feel. Is spark plug boots the right fix?
- Flywheel Plate for Crankshaft Sensor Issues
- Ins Co. wants to declare my car salvageable....
- Power Steering pump failed all of a sudden
- maxima A32 VQ30DE fuel injector
- Scraping sound after replacing front brakes, and a question about the inner pads
- Rear wheel hub replacement
- 1997 Nissan Maxima GLE - I'm Back
- Looking to swap
- passenger door lock not locking fully
- odd one here
- Black Friday/Cyber Monday 2017 - Deals Start Now!
- OK ... Now Wait ... Reality Check ... Strut Refresh
- Hvac always cold
- 95 Cruise control
- Crunchy clutch noise
- Check engine/seatbelt warning/battery bulb part number?
- My CEL bulb was blown so i swapped with the one next to it. What bulb was that? 1997
- Random no start
- Hidden Sound System Upgrade
- Clock and radio power windows dash lights not working
- Car died while driving
- Thought transmission was going bad !!!!??
- Blower motor ?
- Stalling issue only happens going into gear with cold motor.
- Multiple DTC codes and gasoline vapor smell
- key fob stopped working/ 95 max
- Replacing Cruise Control / ASCD stopper
- I'm Back
- Stripped Compression Rod Bushing Clamp Bolts
- Another Starting problem
- Computer help
- Upper Strut Mount Recommendations?
- Seat Covers | A Premature Testimonial
- How can you tell if your timing is off?
- dek 280hp build questions
- new transmission limitted slip dif?
- spongey brakes after pad / rotor replacement?
- at what point do our maximas fade away?
- Transmisson issues
- 1995 Maxima MODS?
- How much buildup can you get out of EGR guide tube by removing temperature sensor?
- P0600 code
- What is this exhaust gasket?
- Coils not firing
- 1995 SE, Alarm has started randomly sounding
- Steering Wheel Off Center
- Replacing rear fuel injectors
- Map light replacement
- Two More Warpspeed Y-Pipes Received
- Finally hit 300k
- Auto Climate Fans Won't Turn On
- car won't start / stay running
- Anybody have a source for interior trim parts?
- Shifts real hard from 1st to 2nd
- New flywheel ring gear?
- Can I bypass the ac???
- Got a couple codes need some direction
- Door panel courtesy light not wotking
- What turbo do I use for a 95 maxima. Vq30de???????
- Beat Side View Mirror Covers
- Stuck Tranny Drain Plug
- Bank 1 O2 Sensor Shows Low Voltage
- 97 dead
- Problems with Fuel Injection - 95 Maxima
- Anyone running 245/45/18 lowered?
- I just did something crazy this week: But I kept the Max...
- Soldering 6 points on MAF
- Sputtering, loss of power and idle issues
- How cure fault in EVAP sensor ground wire to ECM
- Discount OEM parts? I need a fuel sending unit for my 99
- found a 99 se emerald green, new paint, no rust, 155,000
- Cam valve timing
- 98 Maxima moonroof issue resolved at $0 cost
- Vq30dek swap into 99 maxima
- Almost 2yrs later... Pics Pics Pics
- MINT 95. How much is my car worth?
- 96 Maxima still stalling.
- Help me get this 3.5 swap running again
- Poured a little oil on alternator what to do
- Electrical problem
- windshield washer reservoir question
- Replace Knock Sensor
- Anyone ever towed with uhaul dolley
- 99 5 speed clutch replacement in 2017
- 0801 P1490 EVAP Vacuum Cut Bypass Valve
- 99 SEL ...rims won't come clean
- Please say hello to the NEWEST-newest-newest member of the Maxima.Org family...
- Perhaps It's A Silly Thought | Modified Exhaust Silencer?
- Squealing real loud. Please help
- CT DEK swap help
- 1996 Maxima problems
- Does Nissan still issue recalls on 4th gen Maximas?
- headlight cloudy fix
- 99 Cali Spec P0160 code today
- Cardone MAF
- Power antenna motor replacement
- Engine swap from 1999 to 1995 maxima
- Mods to my Maxima
- Alternator 2 prong harness
- Rough start, rough idle, loud pops
- R34 retros wont aim
- Turn signal/bumper light options in 17'
- Power steering metal tube
- Camber Adjusting Bolts?
- ECCS Relay HELP: Normal or Short to Power???
- Bottom strut flange is not lining up?? Too far down?
- Bottom strut is not lining up?? Too far down?
- 2 issues
- Messed up the AC
- P0201 and Cylinder 2 Misfire
- Question on 18" g35 coupe wheels
- Help trace evap pressure sensor ground fault
- Help. No start. 96 Maxima.
- Muffler recommendations? 3" open supercharger-back
- Engine Cradle Difference Auto vs Manual Question
- muffler replacement
- Dragging brake. Replace hub and caliper?
- Check Engine Light
- LED Strip Placement
- Recommendations for diagnostic tool.
- '96 Hit 230k the other day. How long left?
- 1999 maxima gle
- After Market Seat Covers
- Trunk grey cover
- New genuis way to reach the egr valve!
- WTF 4th gen Maxima TRUCK?! LOL
- Help - Reinstalling Power Steering Pump Tensioner
- Positive cable power fuse
- 4th gen with unrecognized wing
- 99 maxima to 03 motor swap
- Any alignment specialist in the building?
- Please ID this part - help diagnose CEL
- code 1493 - still a problem
- Tach is pegged at 8500, and acts possessed
- Obd system monitors - 'E' not ready
- My 1996 GLE was stolen
- Any New Mass Air Flow sensor experiences ?
- 95 maxima, PO400 & PO325
- Auto transmission not shifting up
- Exhaust Manifold to Y-Pipe Studs ...
- Short Throw shifter mod for 4th and 5th gen
- Tranny Fluid Change Worth It?
- Where can I find a fuel rail without the fuel injections nor fuel pressure regulator
- Engine Codes - Intake Air Temp Sensor
- Slight slipping in transmission
- Suspension member? Replace Retap or Weld?
- Do ghost codes matter? What does the ECU do with them?
- replaced brake light fuse, worked for a short time....
- reasonable cost for wheel bearing replacement?
- What newish car would be the equivalent of a 4th gen Maxima?
- Spin the wheel, how's your Max going to start this time!
- Question about cheap ebay knock sensors
- Driver Front Signal, What did I fry?
- Idler pulley nut got rounded - what thread size to replace?
- After 3 years, time to replace the KYB AGX struts.
- Horn suggestions?
- My 99 maxima
- How do I remove the upper back seat?
- P0305 P1448 P0440 all at the same time!
- Interior LED Power Spots?
- Horn stuck on
- P0154 0509 FRONT O2 SENSOR-B2 Can't seem to fix. Could the code mistakenly be PO133?
- 1995 Maxima Misfire (need advice)
- Not only flexpipe was rotted, but so was the cat
- 4th gen hoods
- Trunk lids on Maxima and I30
- Lowered and axle vibration on take off
- RPM fluctuates and car dies - occassionally
- I replaced TPS and adjusted with feeler gauges, but still doesn't drive 100% correct
- Crank no start p0335
- 97 maxima gle tach gauge gone haywire.
- Replacing full 97 exhaust, do I have all the parts?
- Cruise control malfunction?
- I've a few questions about a 98 maxima
- Magnaflow catalytic converter part #23706 oxygen sensor port too small
- 95 maxima. Won't start.
- Door lock assembly for 95 no longer made HELP
- Big budget. Blown HG. What should I do?
- Front end, interchangeable parts?
- Halos for a 95???
- Front lip and grill mesh?
- R34 Headlight - Fogging Over
- Odd Sound from driver side front wheel
- Cleaning mesh in center vents. How??
- 95 Maxima Stalling Out
- Manual Transmission Shift Linkage Bushings
- occasional and different O2 sensor codes
- Do OEM SE Front Springs have a top/bottom?
- Alternator bracket
- alt battery light help.
- Cylinder 4 is not firing
- BBK Upgrade
- Should I pull the engine to replace the clutch?
- Farewell To My Baby!
- 4th gen
- Pioneer AVH-290BT Head Unit Upgrade
- Photobucket ...
- 1995 MAXIMA no. 1 MISFIRE...PLEASE HELP
- Wobble/Humming Noise
- Won't accelerate past 3,000 rpms
- Has anyone resealed their Y-Pipe?
- Urgent question : control arm
- Headlights?
- maxima meet?
- No electric signal to conduct diagnostic
- Seat and carpet cleaning with a garden hose.
