- can i leave these bolts on the cat???
- Car Still won't Run. changed valve cover gasket now this..
- Finally! My Max is back!
- Y-Pipe and O2 Sensor Question
- **95 ECU vs 99 SEL ECU**
- E-Brake handle very loose/ funny sounds from the rear.
- what's this part ?
- A bunch of CEL's, what could it be?
- cold air intake
- Does anyone know where i can get the Chrome Gauge Rings
- white wheels on white 4th gen
- cat question.....
- dash bezel and lower retaining clips
- help - sticky door won't close well
- Grounding Wire connected to Catalytic Converter?
- MEVI help
- Cattman Performance looking for gen4 Max y-pipe customers in SoCal...
- Why do my RPM's jump when I press the brakes?
- Opinions on Shocks
- oxygen sensor
- OBD connection problem
- Fuel Injector cleaning kit (where to hook it up)
- Climate Control Bulbs Missing!?
- CLUSTER HELP!!!
- SE Gauge Cluster Question
- newb question (which maxi?)
- Too good to be true???
- HELP!!!! - I don't know how to make a thread title but kevlo kept this open
- 99 MAF Same As 97 MAF?
- Shudder Shake Studder during slow constant speeds
- 1996 maxima P0136
- Rough ride
- tranny or linkage?
- PRESSURE WASHING VQ30DE??
- MEVI activation indicator
- Details on how to remove headlight?
- some kind of electrical problem....i think
- !997 Maxima Question
- Knock sensor
- clutch recommendations
- Pioneer unveils NEW products at 2010 CES [Video Coverage]
- Security/Programmed Key For Motor Swap?
- Which Viper security alarm works for a 4gen
- inspection time, worried about emissions...
- 4th gen vip style fog lamp?
- hole in exhaust?
- Passender rear wheel sound
- Wheel bearing noise??...newly installed
- need help again
- VQ35DE VS VQ30DE-K
- '96 Engine Mounts
- Rear Brake Stuck
- Subwoofer in car?
- Rear DS Brake Caliper Issues
- Question about changing ATF.
- Crankshaft Sensor (REF) Question
- Code PO733...
- help windshield wipers wont cut on...
- Fixed and Oil leak, now Crank-No Start. At my Wits end!
- Do Cali-spec cars use a different battery from Fed spec?
- How lower idle speed just a bit?
- New Member - third 4th gen
- B&G set up comments?
- CEL
- Cluster swap problem
- Pic request; o2 sim mods
- Ok, using pmhor's decoder
- Are Pacesetter STS Any Good
- Question about climate control options on a 97
- ebay coils -WARNING (long)
- help replacing serpentine belt.
- RPM's dip sudenly while idling
- Cali spec -_- y pipe help
- U ever use Chevron Techron Fuel System Cleaner
- Is the AC compressor on the 4th gen the same as the 5th gen
- Where do i find the cefiro touring s grille?
- warpspeed y pipe Q?
- Cranks all day but wont start =(
- Please, help- upper oil pan leak
- B&M STS Problem
- FOUND Maxima Gone Wrong.
- HELPP!!! WHATS GOING ON?!?!?!
- help with p1336 code
- Budget site?
- quick question
- Seat Belt Tricks?
- trailer hitch
- 9004 to 9007 Conversion Output Photos
- three way catalyst
- newb question Knock sensors
- Will this ECU work?
- License Plate Bracket...retainer nut?
- Pls confirm the following fuses (based on diagram)?
- Alternator or starter ?
- TPS- Throttle position sensor
- Car Barely Warms Up; Is that good or bad?
- Brake line thread
- Surely this has to be a coincedence
- Purchased a short Ram intake with no hole for the air temp sensor??
- Sanding Fluted Lenses
- Aftermarket MAF?
- Need Camber ... Any Ideas
- How to program key fob with 5-speed
- HAs anybody ever
- Anyone with a Maxima Flywheel or knowledge of one, Please come in!!!
- Tranny swap question
- New 02 Install
- Is 1999 Cali Spec Engine the Same as the Fed Spec Engine? Rebuild or Swap Engine?
- Engine cuts at 2,000 revs
- Trunk closing problem..
- Steering Problem/noise...
- Converting GXE to SE
- Trunk Clip...were to find?
- Anyone ever disconnected their power steering?
- check engine light on need help
- '99 with weird engine rattle...
- Spent $800 for repairs and still have the same damn problem....HELP!!!
- Removing ECTS and air intake scoop - help
- Wheezing Car....when will it end?
- 4th Gen Photo Request
- low or no pressure in cooling system???
- Weird starting issues w/ new starter, advice appreciated
- Camber/Caster kit
- TWM Performance STS Review
- WEIRDEST VQ30 PROBLEM EVER!!!!!!!
- Is my radiator cracked? (Pics inside)
- Bad to chirp 2nd gear?
- bogging when at open throttle
- Obx underdrive pulley
- battery drain
- ADVISE TO BUY A 4TH GEN..
- Auto shift points '97
- power steering pump?
- Bent driving light bumper mount
- Ebay LCA help *pic* included!
- Rough Idle -->Torque Converter or CKP sensor?
- Battery being drained even after alternator replacement
- Alright!! WTF Could I Have Done To Destroy My New Wheel Bearing?
- timing chain install question(s)...
- The EGR Valve
- Noticed leak on garage floor...
- 4th Gen Throttle Body Size?
- How do I remove the black paint from the front grill "NISSAN" Emblem?
- i think i overfilled the antifreeze....
- how often do you need to get an alignment>?
- Which year analog cluster fit on 97 gle?
- shifter trim peice(wood grain) for manual
- left turn only noise-any other options other than splash guard?
- What do I need to remove my MEVI?
- dust boots
- Need a way to test guages without a car
- Oil leak from timing chain cover?
- Is there a site where i can buy a full turbo kit for the maxy?
- Squeals coming from ???
- How my new Mexican reman Duralast starter from AZ sounds
- P0600...helpful Hints
- exhaust gases
- Tach Error?
- Removing the EGR Solenoid valve
- Left part of my cluster started flickering
- Is this a normal behavior from A/C ?
- How do I open the hood when normal method fails?
- 97 maxima gxe 5 speed jw ecu and mevi or 98 gle auto max
- HELP:Another ks thread w/ jack-pot code
- brake rotor question
- Tranny noise...
- Help locating the EGR Solenoid valve.
- Help: Bose out Aftermarket HU in
- Is ths hole suppose to be cleaned (near IACV)
- Lower rad support fix-North NJ
- rack and pinion ????
- What are those 2 pieces from a 96 - *pic*
- Ok guys.. Doing a Major Facelift for the maxima
- Connector without a mate
- Y-Pipe with headers from EBAY!!
- p1336 (CKPS POS) and strange hesitation problem
- looking for a thread that has pmohr pwning a noob
- Need Conformation on TDC timing gear positions
- Booster Check Valve
- nissan part # 3822535F00 cir clip
- crankshaft pulley replacement
- What is this part.?
- New HID's wont fire?!?!?!?!? 2 sets tried
- tranny rebuild?
- Rims don't fit
- Question about 5spd vs. Auto Diff
- Car / lights turned off while driving.
- So this is what a tune up gets me??
- Eeek out that extra mpg...
- Knocking noise from timing chain area.
- WTB: Newer Motor for my mAx! 00 & up
- Can I use a Throttle cleaner for MAF sensor?
- Rear oxygen sensor wire harness..
- Just got 96 5spd...cant get off shift knob...yes i searched please help..
- Brake and Battery light with new Alt.
- any good or crap?
- 02 and Knock
- Let me in that nice 4th gen...
- stripped bolt on compression rod bushing clamp *pic*
- what are the 4th gen major issues?
- NEED HELP ASAP PLEASE! VERY IMPORTANT!
- Throttle tap shake
- just replaced outer cv dust boot
- EVAP Canister Purge VOLUME Control Valve
- I need a rear passenger brake caliper
- Any Sticky on How to Pull Auto Tranny From 95 Maxima?
- side mirror fuse location
- A32 MAF - pink label -does the code matter?
- What exactly does the term "A32" refer to?
- White gauges question
- need new radiator
- Soft Brake Pedal...need help! Getting the roundaround!
- Brake caliper? Master Cyl?
- Toss'in the Bose and I need some help
- Goodbye to the org and the car
- Alternator Amperage
- Problem With Shock Replacement!
- Autozone Alternator or OEM?
- What's Going on? (starter related)
- Is my starter going?
- HELP!! Leaking Coolant. Bad Radiator?? pics included
- I want to change from AE style lights and black bumper lights to all clear lights..
- Spongey brakes! Nothing I do helps!
- sway bar bushings overtightened??
- Question about California Evap system Vs. nonCali
- P1320 and P0325 right after installing new clutch
- vent shades
- AGM Battery with pics
- idler pulley flys off ????
- misfire cylinder 6.
- Rear child seat latch
- Help.... I have this weird burning smell in my cabin.
- HELP! Car Won't Start (Tranny/Crankshaft?)
- Stalling and hesitation problems
- Headlight Problem
- A big update!!!!
- Bye Bye 3.0
- '96 Maxima - Sound System Will Not Work.
- were is the eccs relay located at?
- VLSD
- HELP Engine hestiation only after extended driving.
- altima to maxima 5 spd
- Alignment specialists, take a look.
- Does Autozone have good starters?
- '96 Maxima - Sunroof Open All the Way
- '96 Maxima - Airflow Vent Control Levels
- In your opinion, which sideskirt and rear kit looks best? Stillen-OR-Ionic Dynamics?
- 95 Maxima Water pump.
- MAF differences
- help??!! - Transmission/Clutch Problems
