- 1997 5 speed
- Quick Question
- why is my ecu giving me an 0505
- Are 4th Gen Windshields Interchangable: Will a 95 or 96 windshield fit my 98?
- Suspension overhaul questions
- I finally bought a Maxima today!
- Different radio antenna for 95-99 Maxima?
- Knock Sensor 97SE
- Fuel Vapor smell inside
- Change auto trans transmission
- hey should i debadge my max?
- Help with 99 max stalling/limpmode problem
- Which is better- Ebay Catch can or home depot
- I want to find a 1998+ sterling mist 4th gen...
- K&N Air Filter worth it?
- Death of my beloved 4th gen
- Please Help!
- manual to automatic climate control
- Best Setup for amp/sub Install
- how many miles does a maxima last?
- rough idle and runs rough
- good price on tranny?
- 5 speed swap
- HeadUnit Problems, need suggestions
- I really need my keyless fixed
- Coilpack wiring pin out
- 3.5 VQswap cam spacers....and a few other?
- A question on coil packs.
- Bad Injector
- Anymore places to look for a Maxima?
- additional parts needed to replace valve cover gasket?
- air bag
- brake pads?
- need help brake light stays on the dash
- 97-99 front end conversion?
- HELP ASAP - DOOR LOCK FROZEN
- Check out my really cool Rotor Glowing mod...
- My maxima on dubs!
- "Aircon" fuse keeps blowing..
- Redrilled 4th gen lower?
- 1-4 code
- TIMING ADVANCE
- where can i get amber corners
- looking to buy a 95-1999 maxima, a couple of questions...
- ABS brake upgrade...
- need help..tranny problems AGAIN!
- Little box connected the battery positive
- sound system?
- My old pebble beige maxima is no longer...
- Why do some 2000 maxes sell cheaper then 4th gens?
- how to adjust the parking brake lever?
- windows dont roll up or down?
- tranny question
- wideband o2 sensor?
- How can I fix damage leather(Tan)
- can fed car cat fit on/in cali car
- Instrument Panel Dimmer Switch
- Yes another "car won't start" thread...
- 96 Infiniti i30, adding heated seats, is there a lot of wiring involved?
- which flywheel is the best
- Q's about cloth to heated leather sway... HELP
- BIG decision and question....
- L.E.D.s
- Should I be worried?!
- Spark plug Horsepower comparison
- knocking noise
- How Long do Break Pads Typically Last?
- Heater core replacement
- VQ35DE
- Carbon Fiber parts...
- Strut Removal Question
- Suspension Opinion
- new starter, engine light is on....revs being affected
- Is there a trick to replacing your hood:having a problem getting it bolted.
- engine is ****ed. car for sale i guess
- What parts wear out/break that might strand me (at 130K)?
- ~URGENT~ car wont start,lock, unlock
- Tranny is slipping... belt?
- ignition switch cause long starts?
- ebay MaF!!!
- opinions on exhaust
- Any tips the keep the exhuast from moving around?
- how to force car to start with bad starter? tut for removal/location?
- In search of new wheels
- EBAY EXHAUST??
- 95-96 vs 97-99 catback differences
- quick valve cover question
- strut mount question
- Knock sensor question.
- WIRING ISSUE.....Pls help
- before buying Bumper Lights, what bulbs does everyone use for them?
- Worth the risk?
- question on maxima interior
- Alt. Fuse?
- 1500-2000 idle undulations when warm? Vac leak?
- ???mounting location for hood pins for a cf hood??
- noisy suspension, could it be due to my struts?
- Driver's side window glass removal and replacement...
- se Rim
- LED Tail Light How-To.
- Jugging after warmup? Please Help!!
- Motor guys step in. Having major throttle drop issues
- I'm getting some hesitation/misfire
- which muffler would you guys recommend?
- Rattling noise coming from my front right driveside wheel
- HOW TO: THE CHEAP end all wheelhop mod.
- question about shifter trim
- Pulley Squeak - Vid Inside
- Engine really loud at 6K-6.5K
- Vacuum hose from EVAP purge control valve to EVAP purge volume control closes itself
- When in doubt...MacGyver that sh*t.
- VSS- Where is it?
- pic: dirty a$$ evap volume purge control valve...solve CEL 1008?
- Help! No heat after radio removal and install!!!
- question for ecu code AND where to get part
- Brake Caliper bolt/pin question.
- will 5th gen cat fit 4th?
- OEM head studs VS ARP studs
- ? new smog fuel tank evap test??? did i get ripped off?
- part number for Oil Pressure Sending Unit?
- Battery Light On after Alternator Replacement
- Cost for Repairs?
- exhaust backpressure question
- Hub Bearing Question
- '97 Tranny issues....again
- Good bye old Maxima
- Failed Smog, please help, drive cycle?
- 2000-2001 guage cluster in 4th gen
- "Klump" noise
- Crimson Red With Black Body Kit?
- can somone run a carfax for me?
- Bad Alternator causing power (hp) loss.
- Where to buy Walbro ?
- Interesting CEL code "1B" as read from Consult port
- Cup holder won't stay in place
- Maxima Interior Disaster Cleanup?
- Eibach springs- do i need the camber kit?
- fog light removal
- so i just adjusted the IAVC....
- trunk rattling. nor will it open with button.
- blower fan motor makes noise
- Heater Issues
- Front Speaker Installation
- Going back to Dino from Mobil 1: EP ?
- any one round the 07840 area
- thanks to everyone you guys rock
- Change Rear Spark Plugs 96
- Need help on my Rear o2 sensor
- desperate for help: my car died
- p0600 97 Maxima
- better then stock
- Where does the APS plug into?!?!?
- Outter tie rod bolt spins freely
- What color is your clock, C.C., & radio.......
- Spoiler Question
- o2 sensor and engine trouble codes
- help...failed smog
- door hinge question
- what type of input does a tach and speedo have?
- Car won't idle after CEL reset.
- Two Maximas, one key
- Light bulb question-
- New axle seal is leaking...
- Car not starting after y-pipe install?! WTF? HELP PLZ! DD!
- Custom parts wanted???
- New method to opening tails?
- HID FOGLIGHTS!!!!!!!! HELP needed....
- upper oil pan leaking
- With red clears do you need a amber bulb?
- Official member of the 200k club
- Strut Question
- egr system
- Odd headlight problem
- Gun metal or bronze 97 se rims?
- 100k on rear pads normal?
- r34 Lens
- axxis/pbr MM pads, report what u thought of them.
- Anyone hear the JDM N1 catback in person?
- groundng kits??
- So the car broke down...
- Cam timing?
- installed pathfinder 6 disc bose
- SE Rims
- e46 bixenon retros i just bought
- Parking brake lever issue!!!
- R34 Engine in a 97 se?
- replacing spoiler grommet/clip help
- Thermostat installation / getting warm question:
- NOISE: Metal rub Front Driver Side
- Any1 ever seen this maxima before? Yellow paint job with stillen kit?
- Can I mount 205/60R/15 on steelies that have 215/65/15 on them currently?
- Bay cleanup/detailing with pics
- whining sound when riding the clutch?
- WHY does my transmission....
- 9004 -> 9007, draw off battery positive?
- 95/96 Glass Headlights
- 00VI Idling Problems...
- What do you think this max is worth...
- Cylinder #5 misfire
- hesitation when gas is low
- cat-converter deteriorate???
- Bose radio mod.. what do you exactly need?
- Red clear 95 outer taillights?
- cefrio retro
- 5th gen catback on a 4th gen?
- is there a working HOW TO for install strut bars? any1?
- y-pipe? converter flex unit? wtf???
- Worth it?
- Wierd High RPM
- Autotragic is happening my Maxima
- Comprehensive Manual (5spd) Trans Rebuild - Write up (with pix)
- knock sensor
- HELP ME! my transmission is acting wierd...
- lowering spring questions
- HEADLIGHTS? AE ? GLASS OR PLASTIC? any suggestions?
- Engine swap.
- OK to start car in park with no tranny fluid????
- HELP!!! no power in rear driverside door
- Oh Man...
- matching trunk carpet for sub box
- How to change thermostat
- Lowering Aim - Front Headlights
- Need Help wit KNock Sensor
- 97 SE fog lights not working+sticky pass doorlock
- please help cps(pos)car wont start...i searched
- Need some advice!
- Overnight, my car went from a soft ride to feeling like riding on bricks
- Partially torn dustboot...will they do?
- pathfinder throttle body
- Is upper radiator support weld on?
- Rear Deck Removal Help
- Car messed up
- So I installed my clutch and flywheel...<PLZ help>
- replcing dust cover on a 5spd tranny
- has anyone had trouble installing nissan fast
- Bleed clutch more?
- 1999 SE-L with no ECU screw??
- Any experience with eBay OEM-styled muffler?
- ebay intake
- Different popping sound FR suspension
- Is the cigariet lighter and heated seat buttons on the same fuse?
- One Piece Headlight Sets... worth it?
- Should my friend buy this max?
- Is this radiator on its last leg? PICS
- weird moaning sound...
- Before I replace my broken clock, is there anything to check?
- help car chokes
- Coolant replacement in Auto Climate Control maxima
- Video of my car (exhaust and driven)
- HELP!!! Bad knock sensor
