- Least expensive Tokico HP...
- tokico HP's and springs for $443? good? or GR2/STECHS?
- underdrive pulleys
- What causes clicking noises when going straight?
- pics of 5th gen SE wheels on 4th gen?
- Selling 15" rims off maxima GLE
- anyone know who was running the GD's on the window ventshades??
- Quesitons: Major clutch slipping
- clear corners on 1996 max
- this sucks....
- CLIMATE control problem...
- Muffler Replacement
- Ebay Ball Joints FTL!!! *pics*
- need help, simple just need to know...
- Anyone here with a 95-96 SP2 in a 97-99?
- how to get paint off taillight?
- Code 11 07
- Belts or Pulley?
- Power loss?
- Good Fidanza Story. Great Company !!! A+ Customer Service
- Anyone have these lights?
- Help!!! Replacing my rear pads right now!
- SES light
- what is this black box?
- Is this tranny doomed? (Sound Clip)
- reset
- can u rebuild the TC tensioner?
- brake squeel
- Tokico Hp Kit with Blues
- Painted Grill.
- new front brake pads installation....easy??
- wHERE TO GET THIS.......
- Fstb
- Upgrades?
- Seafoam...
- New engine time?
- How much did you pay to get your shocks installed?
- Passenger Motor Mount Removal
- k2motor
- Side Markers
- Water Pump = DIY or not?
- need advice on air flow sensor
- ===> ==> => GOODBYE 4th Gen Maximas!
- HELP!!! So who here has tein basic coilovers?
- Is it worth it???
- alternator going bad???
- Cowl hood for the max
- VQ30DEK full swap
- Rsb
- does the front brake heatshield rotate?
- short shifter Options
- Clear Coat
- Window wiring
- my AMB button is screwed up
- To UDP or not...this is my question.
- Just got my headlights and there not right need some help....
- All 4th Gens LOOK Inside!! Tell me what you think.
- Is it my CV Joint, Bearings, Ball Joint? Help Please
- Yet ANOTHER Illumina/H&R thread...
- replacing rear window glass
- 96 maxima angel eyes
- Hydrolocked engine on fuel, did I damage it?
- am having a really really weird problem
- Y-pipe fitment issue...what can I do?
- How Unique is your car?
- Tow hitch questions...
- Old scratched up headlights? Not anymore!!
- For maximas, non-bose to bose, how complicated?
- Blue Maxima + Black Rims
- SLAMMING on the brake
- vibration when turning left
- maf cleaner + throttle body cleaner
- So my Max handles better on STOCK springs
- Does anyone know hot to upgrade the interior lights to blue?
- gas door broke off :(
- ATF in the cylinders for carbon build up. 2 questions
- * 10 Reason Why YOU Love Your MAXIMA...Continous Thread
- Ball Joint Replacement
- SRS Light Flashing
- throttle body spacer?
- What is "ashless petroleum based ATf"? ... Nissan Matic 'D" ATF, Amsoil Universal ATF
- Question about throttle body
- Clean headlights?
- When to change water pump.
- Clear Corners in NJ
- 350z cams in maxima 3.5???
- Yellow clear corners? I don't think so.
- where is the best place for cv axels
- Ok what is this?
- floor it to save gas??
- LED mirrors.....
- Good Riddings J30, Welcome Home 96 GLE!!
- HELP! Vacuum Cut Valve Bypass Valve, i need some help
- How to fix rims...(wheel-scuff repair)
- 02 Sensors, 1999 Calif-spec, how many, locations, which triggers P0159/P0158 codes??
- Is a BBK really worth it for street use?
- Effing Coils 0201
- 170K Here Comes the Problems
- Fuel injectors failing in a row?
- RIP Maxima - You were an excellent car....
- code 1,1 crankshaft position sensor help
- What causes power steering fluid to...?
- is knock sensor really bad??
- lug nut size
- WTB: driver (left) front KYB AGX Shock
- ebay intake with K&N filter
- CE CLear Black AE light output
- Power steering fluid
- What kind of head lights do you have installed?
- Need help finding part for suspension install
- Strut Still Good?
- m3/m5 spoiler/lip??
- I'm doing a 5SPD SWAP!
- interior Q
- tranny pan bit the dust on a median (pan question)
- HELP!!! 4 ecu codes
- '97 changes to front and rear
- Bearings
- Not another INTAKE THREAD !! o=)
- CODE 1008/1445 help please...
- a few (new) ebay finds with a question....
- Fuel Door Release Latch
- Losing O/D?
- Bose system
- o **** gas fumes in garage
- Help!! GAS shooting out of tank!!
- a quick rear hub assembly question
- throwing 0701, help needed
- Exhaust questions (dont want opinions on best setup!)
- Alignment Firestone....
- flywheel questions
- Issues With Starting
- Intake temp sensor (code 0401)
- changed axles now car wont start? wtf?
- exhaust system loose?
- Opinions on motor mounts
- 98 GLE AWARENESSes!??..Suggestions?
- Radar Detectors : Whats on your dash board?
- fstb install
- FSTB install
- Creep groan - brake noise
- How to aim the headlights
- keyless entry ????
- Re-fuel light doesnt come on!
- EGR reason i failed emissions?
- Are fogs glass or plastic??
- why will the 1990 n/a calipers not work with big brake kit?
- Suspension problems.
- Maxspeed Lowering Springs
- Camshaft Position Sensor problem and more.. a lil help please......
- K Sport Lowering Springs.
- Grille.
- Who sells 5spd bearing kits?
- Oxygen Sensors...Brands?
- Air con + fans: need some advice
- Walker O2 sensors...
- Redline Max
- What can cause sloppy steering/handling?
- removing passenger side axle
- Projector Headlights ...
- i beleive my clutch is going HELP
- HID kit for my 4th GEN
- Question: Trunk lid swap
- Budget Y soon (there'll be a big sale)
- Can I get my Maxima to sound like a stock G35/350Z?
- Hard starting wether its hot or cold
- Seatbelts Backwards
- exaust system
- Good prices on rotors/pads?
- clicking/clanking noises under my Maxima
- I really want this parts software!! Anyone know where I can get it from!?
- Strange Loss of Power
- fuel filter replacement question
- Antifreeze Leak Need help
- starter problems???
- weights of stock wheels...?
- to all people who have drilled & slotted rotors
- Big Brake Kit
- Front caliper pin bolts...
- Throw Out Bearing just destroyed my whole clutch Assy.
- Clear or Orange
- two things: emblem removal and clear corners
- i cant tell....
- Squeal sound on startup?
- Just need an opinion on where to go first
- Exhaust related.... (not a which sounds best thread) pics
- starting problem, need help
- Install? your opinions - pics
- Changing the Map light bulb in 4th gen
- front wheel studs
- Stainless Steel Headers+Y-pipe = $ 230
- Changing spark plugs
- exaughst system
- Hydroplaining a Max...A Firestone story.....
- Door Inserts
- Opinions on my car please (PICS.!)
- Different front lowering springs??????
- poll: at what RPMs do you shift
- Pictures of Brushed Aluminum Dash Kit
- Hood cracking across the centre
- engine dress....
- changed front and rear engine mounts; should i change upper rt also?
- Heres another one for you guys. 56K NO
- Got an aftermarket rear view mirror?? step inside...
- Raybestos QS owners: Did you use factory nissan shims?
- Hid Question..It's buggin me ..
- Planning to repaint the exterior, myself
- Brakes: Anyone running brembo blanks, with nissan pads?
- Someone should do this for 4th gens.
- Help with clearence lights problem.
- Anybody knew if Q45 center caps fit I30 BBS
- HELP: Axle and transmission problem with PICS
- IACV is it still good??
- Weird noise...
- Green bulbs ?
- Air Bag Light
- Frankencar Intake
- dumb quick intake question...
- Front Suspension Bushing Reviews
- End of the Maxima...
- SSautochrome Y& Headers
- Picture Time, not for the faint of heart (56k)
- Rear Brake Pad Wear indicator??
- More Body Work Pics!!!
- Luminics melts harnesses?
- Odd question about front lip fitment
- to people who replaced their taillights....
- Why can't i chirp second?
- Zenn
- Window tints and inspection?
- call me anal...but is it possible to install a shorter antenna?
- Mufflerbearings Install????
- Rotors and break pads
- ebrake light doesnt go on
- What is the most quiet aftermarket cat back exhaust system?
- SS clutch line
- Rear Toe
- Ebay Control Arm Owners Step In
- Car eats alternators????
- Installed Place CAI and awaiting Cattman Catback
- Spoiler Brake Light out
- B&M Copy Short Throw Shifter Review
- Water Pump Replacement
- How much to charge AC system
- Gle/gxe/se??
- Front Strut Bar
- Cattman CAT?
- Speedo Head Replacement Dilema
- New 95-96 Red/Clear Taillights
- Made a Video of My Boys Maxima and Mine...
