- radatior problem?
- replacing radiator...what else?
- Yet Another Issue - Possible o2 Sensor?
- removing door handles- HELP!
- 1995 Maxima blown head gasket. . .1000 bucks. .. what should i look for
- Lower Core Rad Support
- Car wont start
- Really rough ride...
- interior illumination problem
- Mechanic says i need new struts...
- need some input
- gettin in to gear issues
- Nissan say I need an upgrade everything!!!
- calling all people that had work done with KRRZ350
- Salvage title 99 SE. worth $3000?
- Rough Idle with A/C on......
- How far off can the tire size be before the ABS light comes on?
- Will stock 17" rims from 2002-2003 Maxima fit on '99 model?
- EBay O2 sensors - any good?
- Transmission Rebuild
- Misfiring
- Arash's 96 story and future.... come in and give some opinions (updated daily)
- Do your brakes squeal?
- Fog lights wont turn on
- cruise control not working
- Transmission Fluid Mixup
- Resetting Airbag
- are there any aftermarket grilles for the 4th gen?
- Need new front brakes - Suggest budget rotor and pads
- Spark Plugs / Coil Packs / Fuel Filter.. muffler?
- ash tray light?
- faulty alternator or new battery?
- Xenon or Bi-Xenon for Maxima 98?
- Storm in chicago car got flooded got a p0134 code.
- Anyone have these?(alittle ricerish)
- exhaust set up too ricey?
- Fuse Panel Fix
- center console
- what could make car SEEM to run hot...
- EGRR question
- air bag light, and weird plug
- Rotor size for J30 caliper
- Problem with headlights
- hard start and black smoke in morning???
- Grill Mod......
- Fed to Cali Engine.
- TPS issue
- Rear Ended Today
- alternator bolts???
- Headlights are buggin out! Help!
- Finally lowered on new shoes
- car won't start .. WTF
- Cart starts but then turns off..
- proper bolt size for exhaust/cat
- clogged EVAP system
- What is the model number for the map light bulb?
- As far as replacement Gauge Clusters go, will any 4th gen work?
- alternator/ac drive belt issues
- What controls how fast the Rpms go down when the gas pedal is released?
- Water Pump Replacement
- Spoiler Removal Problem
- evap and KS
- reasonable & economical suggestions for a a/t...
- vqpower 'how to' links don't work???
- MPG on your 1995 maxima ?!?
- water pump/tensioner help, please
- story of my maxima... life, hospitalization, and resurrection!
- Iddle RPM
- Passenger Fog light broken
- How to remove cruise control vacuum pump?
- Brake light on... again!
- Independent Nissan Mechanic in KC??
- new front grill???
- Headgasket fixes?
- Brake hose clip install?
- Wheel spacers and extended studs a few ????s
- What would you do?
- Ebay Headlight Bulbs?
- Blizzaks for $66
- What's fender height diff front to back?
- what could this be?
- Water got into my intake, is my engine finished?
- OEM Remote - No Horn/Alarm?
- quick question about 300zx brakes
- weird feel in the steering after start
- Question about keyless entry
- What causes a CV boot to blow?
- weird clunking noises...
- IM back
- What Year Were The Immobilizers Introduced?
- pulling codes
- Long lasting repairs (brakes/axles/bearings/suspension)
- Buying 98 SE - Opinon query
- creeky noise everytime I turn the wheel
- Rusted rotors...
- Anyone got these taillights...
- rough idle
- Is this the Vortech super Fmu that fits?
- Moving on
- Drivers front door speaker issue
- Ghost in temp gauge
- Speed not reading while in gear.
- HID's on non projector lights?
- Has anyone ever stripped their cluch pedal freeplay adjust nut?
- got SES light today .. how much $$ am I looking at?
- My rpmm gauge is posessed
- Wheel Making Thump noise
- My Left fog light burns out every 2-3 days why?
- fan speed control
- Infiniti GONE!!!
- sunroof question
- So my ECU was smoking today!!!!!!
- How to remove the fog bulbs
- Show your custom dash
- Help me find the right battery for my 97 SE
- Quality bump stoppers
- Who changed camshaft position sensor??
- Need Help Quick! Car Wont Start!
- Lowering Car by Heating Stock Springs?
- How to lower car like 3-4 inches budget way???
- Stalling problem when going neutral...
- Why are maximas so hard to come by these days?
- failing rack & pinion...
- Wanna see a 4th gen wipeout... on ice?
- My OCD is acting up.............Inner and outer tails dont match !
- EGR Problem - But What Exactly Is Failing?
- White smoke...
- Questions about KYB AGX struts
- OH SH** MOMENT
- 3rd gen seat into 4th gen, is it possible?
- Clockspring
- Car Acting Up
- Brake light won't turn off
- Car needs a tune up... not sure where to start
- Y pipe question
- My new project..... to be continued
- air bag code help?
- R34 Retro w/ s2000 projectors and infinity j30
- Stalling problem
- Company that paints interior trim?
- Parasitic Drain-Help
- NOT READY...WTF???
- idling problem
- What king of Spark Plugs does your 4th gen have?
- wth feel like i lost 30 hp
- MEVI SOLENOID HARNESS
- Fuel Octane MPG difference
- Idea for heat shield
- Suspension Trouble? Need Help ASAP
- wire hardness
- Front-end damage, now no AC?
- climate control leds new idea!!!!
- Running ****ty, EGR or MAF? read
- HELP! Car dies..many questions
- Ridiculous brake fade
- Need help replacing passenger CV axle
- Is this a good deal? Black on Black...
- dumb question about trim around windows
- crashed the maxii :(
- Can someone post a pic of their ECU(from passenger side)
- Car starts.Sometimes.
- Funny acceleration...
- Just got in a lill acident i have a few questions.
- Suspension gurus, I need help with uneven wear.
- 8 foot breaker bar...cant get axle nut!
- Can't pass smog test!! My car is running too rich. Help!
- How long are the REAR stainless brake lines?
- Bent rim.
- mevi installed rough idle
- Exhaust/Emissions Issue
- Doing suspension/brake work tomorrow, any tips?
- HELP! electrical issues!
- Mevi Owners FYI
- help idler pulley belt fell off
- oil drain plug washer?
- A\C only works when i put it on 4.
- mods and maintenance then problem; please help!
- AC blowing Hot Air?
- Question on Cattman Y Pipe.
- Cv shaft replacement question
- Proper method to break in clutch
- Stock box w/ franken?
- 95-96 or 97-99 fog light
- How often to change the belts in the car.
- Replaced all 3 O2 sensors car feels no different and get same MPG
- What temp is your motor?
- Goodbye 4th gen, hello ?
- Stripped bolt on LCA ball joint... Any ideas?
- Climate control only blows thru front vents
- Parking Light Assembly
- pig just pulled me over for a "loud exhaust" lmao
- 1995 Maxima Hitch - Flat Drawbar
- Glow Gauge install - Remove Bulbs?
- Trouble Code 0213. Not Found in ECU Decoder
- Train horn installed on a maxima w/ a few extra interior mods.
- quick question
- canister purge control valve (10-08)
- Good fuel pressure regulator?
- Ques. on stock settings
- Big 3 Three with pics???
- 5th gen muffler, how much better?
- Window regs
- 4th gen turbo kits
- My car is slower than it should be. Any help diagnosing this?
- 95 Maxima rebuild
- Fog light alternative rewire?
- CV Axle
- Caster off 8 Degrees
- Car randomly dying at idle sometimes catches it self but still pudders? MAF?
- New Alternator,Starter,Battery Still Shutting Off
- Electrical mods
- Clock section and vents, can't snap it in!
- Strut mount?
- Nissan Sport magazine!
- Anyone seen a maxima on these?
- How many 18" rims can you fit in the trunk?
- Chipmunk Attack!!
- Tranny issue?????
- Car bucks/jerks in first gear bad - suggestions?
- Starter Problem? I thought so! Replaced twice so far... Help!!
- Having trouble starting in my Max
- Goodbye Maxima...
- My baby has rust...
- Engine cover for 4th gen?
- Car not Idiling correctly - Please help
- font o2 sensors 2 white 1 black wire normal wtfffff
- 97 auto problems, weird shifting
- "electric turbo" simple question, please don't flag or flame!
- Key broke in ignition... any ideas?
- Is this ECU compatible?
- Frame of passenger door bent...
- I am about to remove the Passenger side CV axle..
- RPM's dropping below "normal" at idle
- Okay this is driving me NUTSO!! (5spd Tranny) HELP!!
- ECU Codes: 0807 (EVAP), 0111 (EVAP), 0304(Knock)
- AUTO WINDOWS
- so i had this click with i turn now for a month
- rought ride 95
- help with O/D flashing but no codes
- a/c not blowing from middle vents!
- Key ring light + door open dome not working
- engine timing issue?
- Engine Swap Question!
- Where to drill hole in firewall?
- Tried alarm beep...now lights dont flash!
- my blower is making weird noises
- Which give softer ride AGX or Illumina's
- ebay LCA anygood?
- interior light problem (need help)
- Alternator?
