- A/C compressor
- Complete 00vi With Vafc-2
- Car overheating...
- What a $1000 got me
- Throttle Position Sensor Help
- Y pipe install slight glitch
- Is anyone selling finish led boards for the map light ?
- ASAP question - CEL with ignition on or no?
- Heated seat switch led
- LED GAUGES semi Failure
- how to replace Rear Valve Cover Gasket?
- master or slave
- nissan maxima seats
- Need help
- Strange starting problem
- Changed my VSS(Vehicle Speed Sensor). Problem solved (malfunctioning odo/speedo, CEL)
- Very strange electrical problem.
- Installing new crank pulley need help!!!
- rear illuminas are bouncing too much, dial caps lost
- Rubbing noise while driving?
- For those w/350Z, freeway blasters, or a nice big horn
- 95 Max: Service Life of Stock Timing Chain
- No Start
- V-Power cured my engine, but threw a code...
- FINALLY....time to KILL the SQUEAK
- New but old
- Will 17 X 7, 50 Offset rims fit on 4th gen w/o rubbing?
- Timing advance on Nissans?
- How to upgrade/update the stickies- Your input!!!!
- HELP- SEATS WONT MOVE, WINDOWS WONT MOVE
- Strange Accel Problem
- anyone else having trouble finding the maxima.org decal thingy?
- Tranny help please
- i30 hood
- Help plz
- Popping Noise
- Just blew a Brand new Moog balljoint in 5 days. HELP
- Window Louver's
- QUICK QUESTION ABOUT RACING SEATS
- dropping on tein s and have a question
- Missing Gasket...
- Shuddering While Accelerating (Stop and Hwy Speeds)
- Powersteering Fluid Question
- Brake fluid question...
- Oil and Coolant leak troubles...
- None of my inside lights are working
- 96 Transmission PROBLEMS! (after used swap)
- Bose vs aftermarket
- Spectra Premium Radiator - Any Reviews?
- New 55w/100w 9004 bulbs? wiring Q?
- Replacing Powersteering Hoses
- ECU trouble
- Help!! with tranny
- Intake comparison
- Help installing Ultimate/hks ignition
- 5-spd. shifter noise...still
- !!!!!!!The Stickys for all Stickys!!!!!!
- 95 Max engine dead, gone, and partly burned!!!!
- Fender Mounted Blinkers
- autozone radiator?????
- Rough Engine
- long time no .ORG :(
- Engine Check Light Code P0500
- 5-speed transmission replacement question
- possible part-out... How to??
- Map Light...
- Causes of starting problems: 95 Max
- Need help figuring out why my '96 still overheats
- question on 300zx tt injectors
- HELP! half my key is stuck in my ignition!
- Production Date Question
- 01 rear calipers?
- Brakes need work - Is this a reasonable quote?
- Location of Oxygen Sensors in a 1999 Cali-Spec Maxima
- Clutch Hydraulic System...
- 04 wheels on a 97?? Help me out...
- 95 Max PowerSteering fluid leak?
- what bank is what?
- r34 headlight problem, both fogging up
- Shifter Bushing Install
- What bulbs do the r34 headlights use?
- Need real quick help on axles
- Bent strut or lower control arm??
- Any DIY on how to clean the IACV?
- Max WROTE OFF...
- Design of the Water Pump Location
- Rear Timing chain o-ring leak
- Ebay intake problem, questions. Help!
- How to make remote work while car started?
- Radiator Drain plug stripped
- Stock Alarm Going off randomly
- header question
- rough idle with break booster hose detached
- LED gauges driving me nuts...
- broke off a bolt in the Intake Mani
- Voltage regulator. Worth the money?
- NEED SWAP IN NYC
- Help, smoke coming from the rear of the engine???
- 5 speed swap -> Pilot bearing?
- wont start
- Extremely wet driver and passenger floor
- Where can I get new Poly Engine Mounts for a decent price?
- Stock Max Top Speed
- Pulley questions...
- Engine not idling at steady rpm
- DIY replace tie rod end and ball joint using Autozone? Possible?
- Got 0509, replaced O2, then got both 0509 and 0115
- bad alternator history, ignition seems weak, should i be concerned about this...?
- i need some input.....
- Brake lines rusting badly.
- 95' fed spec tps & jwt ecu question
- Lower radiator support differences
- Is this a good way to get at the EGR valve tube?
- ES LCA Bushing install
- Power steering fluid in my gas tank
- need a part for my vehicle
- Starting issues can't figure out
- Brake light staying on
- IACV and TB
- Lower Rad. Support Rot - replacing lower rad. support (DIY questions)
- Front License Plate Bracket
- 99 positive battery cable
- 95 Maxima with 98 Engine- HELP HELP!!!
- to those with creaking door hinges....
- When I buy D2 coilovers, what else do i need to buy?
- starter over crank
- alternator replaced, now battery died. radio is odd too
- Car not starting, no spark
- how do i clean Rust "dust and stain" inside corner light?
- Hey Guys :: My '96 Maxima
- 1995 maxima very hard to start when cold and have 2 codes..p0400 and p0325?
- So which year should i get
- rear wheel bearings
- CV boots and Vinylex/303
- wtb pigtail for A/C
- suggestions regarding p1400 code
- illuminas fail again!!?
- Headlight goes off then on when I bang on hood. Help!
- Mysterious sound while turning
- Replace Seats
- Questions about front turn signal lights....
- Garmin GPS friction mount?
- I got my cake, and Im eating it
- New member to 4th gen community
- Lop-Sided Suspension
- 99 - Will not turn over.
- Can you tell what problem is causing this sound?
- 95 tranny kickback into first, possible solution????
- Backup Projectors.. Stock Wiring?
- Missing, stumbling, slipping, and loss of power...
- Would you replace OEM struts if you did axles?
- 1998 Max for 1800?
- Anyone replaced your struts? I need a parts list!
- Car wont start right...has never started right for that matter...
- anybodys elses 5 speed whining in 1st?
- ACK! - 96 wont start?!?
- R34 headlight question
- Ebay trunk spoiler set back.
- maxima weight - 5spd vs auto
- Antifreeze leak
- Preventative maintenance while I'm doing my alternator
- Egr gasket forgotten after intake manifold assembly?
- looking for an exhaust video of sp2.....
- Radiator Cooling Fans (Help!)
- Looking for someone to LED my speedometer
- 95 se automatic stutering/bucking when I put the foot to the floor?
- knock sensor related
- so what do you guys think about this maxima?
- Egr Valve code issues
- Tachometer doesnt work...
- Is it possible to drop a 4th gen without a bone jarring ride?
- 96 I30 or 98 MaxSE + questions on each
- Average Temp. for your Maxima
- Dealership Inspections
- POLL: WHAT CAI DO YOU THINK IS BEST?
- Haunted Bose Radio and clock
- Help installing factory cd in a 1997 max
- 2005 seats on my 95?
- idle drop
- Quick question
- Power Steering Leaking - Rack/Pinion? Gasket?
- P0100 & P0110 codes...
- i need help with projecor mod *PIC's*
- ebrake problem!
- Diff. Engine Sound+Slightly Rougher Idle (EGRC Solenoid - CEL - or Timing Chain?)
- 00vi and egr help needed
- Where can I get this done?
- n/a sounds like turbo...wtf?
- I need a solution and some torque specs!
- 99 Only, Do you have rear deck rattle? I think i found the problem...
- Clattering Sound From Back End
- Troubleshooting starting issue, HELP
- Ignore or fix? EGR and Knock Sensor
- Half-and-Half Intake Setup
- RSB install.
- Which intake to use for Seafoam?
- 95 MAXIMA SE Might sell....thoughts?
- 1995 SE with lots of upgrades
- Is there issues with wheel alignment when car is dropped 2"
- Can anyone tell me the name of the color of this maxima?
- bad mount????
- Maxima.org FTW!
- Quick question
- PIAA Xtreme White Plus or Super Plasma GTX? (H3&9004)
- List of issues...
- my e46 retro - big pics
- throwout bearing
- Squeaking suspension, weird oil smell, and knocking when i have defroster on
- Weird Idling issue!!!!!!
- water pump
- AC compressor
- transmission output bearing
- AT 2 MT
- Starter: Nissan Parts Vs. Autozone
- How To: Fix Your Spoiler LED Light
- y pipe
- Estimated labor costs
- A32 headlight replacement problem
- My motor got loud recently.
- stupid question about towing a maxima.
- blew a d2 coilover again, rebuild?
- Strut mount problems?
- Starting Issue 00vi/Injector related??
- Tranny rebuild. Does this look like the right kit??
- Starting Probs When Cold
- Starters & Alternators
- Did anybody replace their idler pulley assembly?
- is this right?
- Whining noise alternator or belts? what is it?
- Streetglow LED's
- Quick Question: Will OEM 03 Hood Struts fit on a 95?
- Maxima!!!
- 1106 code
- O2 Sensor - Upstream
- Wheel Bearing problem... i think.
- Prepping for Roadtrip
- car leaking oil and coolant!!
- I'm tired of low quality buttons/clips/screws/retainers that Nissan provided.
- regarding a short antenna solution (power mast into stationary connection) - question
- Starter Sig
- For the guys with auto ecu w/ 5psd
- Replaced starter, now engine dies
- Intermittent Extremely High Idle
- question on trany swap
- What would you do with two Gen 4's?
- No starting issue - help!
- Wierd faint whine when cruising 5-20mph
- chipping the ecu?
- PLEASE HELP! Need 4th gen Radiator Install DIY ASAP
- clutch kits advice, OEM vs Daiken Exedy
