- Ksports coilovers question!!!
- please tell me that maxima wheel bolt pattern is 5x112
- WTF is in my coolant
- rear main seal
- Please Help Trying To get Bose/Auto Climate Control out
- Motor Mount Options.
- magnaflow universal muffler on stock exhaust system
- 4gen with rims and NO drop, Lemme see em!
- CE fog owners commentary?
- Have I got this the right way round?
- Tranny question
- Electrical gurus jump in here:
- seat bracket
- trunk lip
- Those 95/96ers who did a 97+ conv.
- Battery light and brake light come on at the same time
- trunk lip
- Cleaning UIM
- bumper dent (56 warning...)
- South Bend Clutch or 5th gen????
- Its brake time...step in and help
- got a great deal on vq35 + tranny...should i swap??
- Just got a Present :) WHEELS!!!
- How long/many miles did your KYB AGX last?
- Anybody relocated battery to the trunk?
- Where to Buy CF hood ??
- KSports or D2's????
- Starting Issue's
- Excessive windshield noise 80+
- slight missing, no DTC codes
- Ebay Coilovers on stock?
- My Doing a trans swap my self need help.
- Max owner w the 350Z stereo
- Ashtray problem
- Car just took a crap.
- All You Lightweight Guys!!!
- Front Strut Brace
- noise from hot engine parts/exhaust
- crap, just ran into an accident
- Blown Valve?
- How much could i sell my maxima for?
- My trannie travails continued
- Poorman HAI
- Ripped boot (pic)
- Where is Fuel Pressure Regulator
- Made Maxima Video
- Turn Signal Problem....
- 95 Maxima Temp Gauge
- Fog Lights for a 96 Max
- ABS light is solid on
- Greddy Sp2 Installation Q
- Car undulates side to side
- new york state inspection
- Harness replacement ideas
- Bose HU replacement?
- Finally looking how I want it to look..step inside for pics..
- Tires/rims
- Lucas oil?
- need source where to buy 5th gen setup....
- NEW PICS~ blue/purple pearl blingin'........
- How often do you get an alignment?
- EGR Cleaning
- 97 a/c compressor vs 95 model
- low idle
- Fuel Rail
- Nitrous & Intake System
- Could someone please post a pic of...
- another starting question.....
- Dealer wont recall EVAP because of y-pipe
- Installation needed
- Installation Info
- Anyone painted their needles?
- Problem with High and Low beams
- How do you program door opener?
- Great to poor performance
- AHh! Help with indiglo gauge wiring needed
- sp2 instalation on a 97-99
- Question for those guys who painted over chrome on stock grille(97-99)
- Leak at IM gasket?
- projectors retrofit
- Self-fixing sensor.
- Fuel line Size?
- Oil on Spark plug....
- FYI: Certifit Parts (bumpers @ 34.50)
- Nissan Maxima Shop Manual
- Fuel INJ Sys Right bank lean CEL
- stubborn trunk rattle
- Bi-Xenons & DRL
- Help with security system..
- When i start the car up...
- LED Mirror Shell
- double flat!!
- sounds weak on start-up..
- Fans dont turn off.....(kinda long)
- Tools needed for driveside axle replacement?
- Gauge Rings Install
- rear brakes seizing
- Diferential Diagnosis - Starter Vs. Power steering Pump
- rear pads
- Break Squeak
- Question about sensor/leaking oil on a 99 SE
- how much should i pay????
- Reconditioning brake calipers
- Weight reduction
- how much faster is an SE than a GXE
- 5 Speed Guys help!!!
- Russian maxima wrapped in nismo
- 97 Maxima Bose audio compatibility
- How to remove Audio sytem from dash
- changing ecu harness help
- Megan Racing Exhaust need extra sensor pipe???
- 97 only starts sometimes
- Just got my CF fenders in today.....
- Motor Trend Review Article
- what should i replace my agx's with
- TPS testing and replacement(can't drive car now)
- CF Hood and Hood Pins
- Typical current pull
- Question about noise in exhaust
- which roof wing to get ?
- Shocks/Struts
- megan r exhaust any comments?
- Bluetooth Handsfree Mute Circuit for Bose
- Photoshop new 350z rims
- level 10 auto tranny vs. 5 speed manual
- Popping Noise from Left front....hard steering
- murano washer nozzles
- muffler replacement
- trouble starting
- P0138 and P0139 Help!!
- Best way to install clutch system!!!
- Avg Joe - factory front suspension fading - Best Course of Action?
- timing chain tensioner part number?
- question on axle seals for 99
- i call it a toy
- Lights dimming when pressing brake.
- Anyone have website or phone number to budget exhaust ?
- 5spd shifter bushings!
- ngk iridium?
- One year of owning my maxima
- Old Lady With David L's and Clear Turn Signals :'(
- car tugs..please help!
- shark fin antenna...is it possible to do?
- '98 GXE Manual, not in the stickies?..
- 97-99 Head Lights or Custom Enterprise Euro Clear ?
- Weird Scrapping sound
- rack and pinion boots
- How much time do you spend on your cars?
- help troubleshooting after wreck
- 98 tach in a 95?
- Indiglo gauges (4 color) stopped working - causes?
- Air Bag Light Flashing
- For all you lowered guys
- need help choosing tires
- CV boot winding noise (pics)
- Crankshaft Position Sensor Cleaning
- I think my trans. broke... anyone confirm
- Anyone purchase EBAY axles?
- 97 max start issues
- Y-Pipe bracket rusted off and flex pipe is shot...what best deal for new 1 nowadays
- H&R/illumina vs. Ksports
- 0111 Code.. what should I check first?
- Possible that some 99's have 2K 5spd. transmissions?
- Car is trowing a 0903 code
- Starter question
- 3rd brake light
- V8 Beast vs. Maxima Video
- Installed H&R with Tokiko Illumina
- weird sound during cold start
- RedlineMax.com
- help with timing tensioner replacement
- Heater not working?
- I need help removing my intake manifold
- 350z Rims on 4th Gen Question
- What to look for-95' SE 5spd
- cleaning maf
- spraying pure oxygen...??
- question about center console
- FLUED?? guys help!!
- Cross drilled slotted rotors
- Jet Computer chip? worth it?
- Duralast batteries, thoughts/opinions?
- Fluids and Lube Sections Sucks!!! :mad:
- multiple cylinder misfire :(
- Help now please!!! ATF what is USE NISSAN-MATIC "D"
- need help fast!!!!!
- Autometer Temp Gauge with 03 cluster swap
- lug pattern?
- missing in how-to's
- how are your interior pieces holding up after 11 yrs+?
- Proper Torque for lugs?
- About headlights adjustment.D@mn it
- best fog light bulb?
- battery terminals
- Projector fogs
- Interior questions (gauges & paint)
- Clutch Suggestions
- tachometer signal comes from?
- Headlight question
- Funny noise?? any suggestions
- Difference between 8 tooth and 10 tooth Starter
- Right bank running lean, where do i start?
- 96 Maxima-Is it possible to change the analog climate control to a digital control-?
- Car Doent Start In The Morning...help
- name that suspension noise!
- trunk mechanism
- Help P01335 code
- Wiper Jammed on 97 Maxima
- 18's on a 4th gen... Rubbing?
- installing fog lights
- help me out with this code!
- muffler question?
- Squealing @ cold start-up; belts?
- Sunroof visor
- Double Check: Am I missing something? suspension parts order.
- So you change your flywheel and clucth kit also...step in
- What to do about tranny...
- Knock Sensor Question
- cel light?????
- engine runs better with CEL on!
- i have REALLY bad gas mileage!!
- what paint to use for painting fog light lens?
- Discriminating Laws
- Engine almost stalls when shifting out of gear
- AC compressor replacement
- LED needles - anyone successfully do speedo in a 97???
- rear caliper piston boot stuck. how to fix?
- CEL is *BLINKING* randomly....
- New to the 4th gen forum
- Cleaning Fuel Injectors
- foam in bumper?
- Any how-to's on rear brakes?
- 00-01 Manual in a 4th gen?
- Problem with removing spoiler from the trunk.
- Sell It Or Keep It?
- O2 Sensors... Bosch vs. Denso?
- PCM swap
- decisions to be made.....
- strange sound when I accelerate!!
- Weapon R Dragon Intake
- Need help with custom side markers!
- What is this part called?
- fog compatibility
- Wanted
- Remote starters
- URGENT!!!!!Problems with the car....
- Custom Maxima (Enterprise) FSTB Question
- Will it burn the valves
- Signs of me needing rear brakes?
- Another Compatibility Question
