- What Next? For My 99 Maxima?
- Maxima letters on grill ?
- HELP HELP car wont start
- Window Defrosters
- Belts
- aftermarket fog lights
- Red / Clear question (I searched)
- rewire corner lamps quick question
- Anyone know hte part number for the clips that hold hte guage bezel in place?
- 95 Max question
- Need Some Help with a steering problem
- Is the interior worth it?
- pull an ecu code
- greddy sp
- Blown fuses!
- replacing alternator belt?
- Bad Alternator? How much? and other crap
- Ebay PR intake Question, Need some input/guidance!
- Suspension
- I am back!
- Any advice on installing axle seals welcome
- Cefiro 1-piece light adjustment screws: chrome OEM vs black aftermarket
- is touch up paint obvious?
- Squealing in reverse
- question about painting body parts
- Strange Vibration?
- 1995 Mods
- Anyone else had a front strut insulator tear?
- need inspection sticker in NJ
- Clear Corner Rewire Cracking
- which body work is cheaper?
- Destroyed Antenae
- AC Display, Clock Display, and Bose Display
- slight hesitation under 3k RPM
- i think my car is slightly backfireing
- I wish the Max could sound like this
- Radiator
- Good Smelling AC
- tail lights?
- Well, hell, what do I do now?
- Whats a good battery for our cars?!?!?!?!?
- Downstream Oxygen Sensor
- When Start Up
- How often do you change your air filter?
- what is a trans range sensor circuit????
- o2 sensor pert number?
- 2 Seperate Heater Related Noises Inside the Car
- harness upgrade diagram
- starter noise, know how to degrease, just a quick question
- button for indiglo gauges
- e-manage fuel systems
- Illumina Adjustments
- Power Steering FLuid, Windshield Washer Fluid, and Fuel Injector questions
- what is the frontal area for our cars?
- JWT Popcharger
- Know any shops that install shocks? S.CALI
- Black max with powdercoated SE rims
- What year and engine type for Z Fuel filter
- Photoshoped max
- how much could i get for my MAX
- EGR help :(
- Clean/Polish headlights
- help with starter
- headers
- Tail and trunk difference 95/96 to 97-99??
- Reduce fan noise
- intercooler kit??
- Wheel off set (mm) HELP!!!
- 5th gen. clutch is in...but I'm worried about the gear lube...
- Starting problems on two maximas...
- Where can I get blue LEDs for dash?
- I thought there was a sticky for the use of seafoam?
- Parking Brake Light & Battery Light lit up on the dash
- Advice on Reducing Droning Sound.
- 55watt vs 100watt fog lights
- Stumped on low idle issues
- engine block heaters?
- Tranny fluid
- Night MaXimA pics
- Headlight and Relay Question
- Does anyone have a Koyo Radiator?
- Installed Tokico springs w/ Illuminas
- Break-in????
- Beige 4th gen w/ black rims ?
- coolant trouble
- rough idle when in drive
- low groaning sound when backing up
- lights
- Any recommendations for good brand of O2 sensor?
- Goodbye to the .ORG for now.
- for car specialists
- Very very first sign of bad coil packs?
- Indiglo gauges
- any one know about this
- main rear seal question
- 1995 Maxima Questions - Please help
- mass air help
- car died, need alternator belt? hopefully
- Front Control Arm Bushing Replacement
- do you have the same problem? need discussion
- Changing a Starter need advice
- looking for a factory service manual online
- Help ! Need Struts ! Advice ??
- 95/96 vs. 97+ Grill
- brakes lock up
- Is this product any good
- exhaust setup?'s
- Car wont start
- blown heads on maxima
- Intake backfire?
- High Flow Cat?
- Question about a Warpspeed product
- Need Opinions Please!
- anyone have this gas mileage issue??
- water temp sensor
- How Do I Install Altezza Taillights On A 96 Max?
- anyone else have problems with 1156 led bulbs?
- Difficult to fit a GReddy EVO on a 97?
- REBUILT or NEW tranny?whats better?
- EGR & Knock Sensor!
- Rear Calliper Compatability
- I'm going the 3.5 bottem end with 3.0 heads route
- Engine Coolant Temperature Sensor testing
- megan or greddy???
- Power Steering Pump replacement questions...
- my heating isnt working right
- Anyone with cold start info from shop manual?
- videos?
- Can you adjust your own alignment?
- Knock Sensor Fix
- Uhg, I've got too much oil in the engine =(
- tips for replacing passenger side axle
- Auto Climate Controls Back-lit?
- XS-POWER Y-pipe
- IS there any way to get aftermarket memory seats and heated seats?
- IBOBUK, where did you post those instructions?
- suspension question?
- should stop audio when idle?
- Squeaking when I turn the wheel...
- Question I havent seen anyone ask
- Will all oil drain out if I remove oil filter?
- replacing knock sensor
- Where did all the headers go?
- Those with sprint springs!!! please come in
- y pipes ... cali / fed
- Effect of octane on O2 sensor damage?
- please help I am going mad!!!
- 95 max se still trouble starting in cold weather
- Bump stops and Illimuna shocks
- Eff yo' Greddy bishes. (List your custom exhaust setup)
- G35 sound
- strut tower braces
- Power steering hose replacement question
- Cooling system question
- Cleaned TB now idle at 1,100
- Best/cheapest homeowner scan tool
- Anyone have pictures of a stock y-pipe?
- catbacks once again
- Power Antenna Wiring Problems
- fuel gauge sending unit
- Engien Mount
- DTM help
- axle question
- Does anybody know what the inner tie rod ends do?
- Fog Lamp Suggestion
- we need more aftermarket support
- adjust tokicos
- Car ideling at like 550???
- PCV valve question
- Check Engine Light & Knock Sensor
- Turn Signal/Hazard Issue
- Low end power
- cali or fed ??
- Car running in safe mode for awhile
- HID H3's in the fogs?
- Any problems with B-pipe and crossmember bar?
- Is my block cracked? (Pics)
- Got ECU Code 1005 but can't clear it
- Fog lights ...
- how do you remove auto
- Speaker Replacement
- Need Extended Studs
- Urethane Engine Mounts
- Common Places for Oil Leaks?
- Installed Headers
- Any Info on PowerLock Anti-Theft Device?
- Temp sensor = Heat?
- Need some assitance :)
- CV-Joint boot (left)
- Abs Issue?
- 5speed shift seal leaking?
- any sujestions
- want to drop, but...
- Installing aftermarket yellow ( lexus style) foglamps
- Air bag
- One Fob Opens Two Maximas......wierd!
- Installed a true CAI, and now problems help!
- Manual Transmission Fluid Capacity and Type
- HID Help!!!
- what to do
- pressure bleeder vs speed bleeder
- E-brake problems
- PR Motor mounts?
- power locks don't work when car off
- greddy sp2 exhaust my 99 maxima help??
- I think I have a fuel delivery problem
- re-painting car, but what color?
- help! I lost 3rd and 4th gear!
- hood clearcoat peeling
- 96 Max Power Steering pump replacement
- '95 Brake light staying on
- CAN I POLISH MY HEAD and other engine parts ON MY 99 MAX
- how do you know if
- Turbo kit
- good offset for new rims
- Qustions about Dealer Fraud
- Ordering my y-pipe today!
- signs of starter problems
- Cattman website?
- Ebgine
- kill switch
- Suspension setup
- IACV Clicking Resolution
- installed tokico illuminas
- hazzard and defrost switch problem
- Any Site like Wheelskins.com that has replacement leather arm rest cover????
- Question about CEL and hard starting
- new 95-96 rear tail light idea
- starting problem
- my new wheels!!!!
- whats a means EGI ON THE FUSE BOX
- Dash retaining clips
- How to tell my engine is knocking?
- Need a recommendation for rotor replacement.
- poor gas mileage on a 1996 I30
- Replace windshield and back window.
- LED Clearing Light bulbs.
- I need light conversion help...
- Maxima problem
- Wasted Guy + Rain = Wreck!! *UPDATE*
- Starter problems
- 99 clutch hose sweat out problems
- What is this in the engine bay? (Pic inside)
- adding keyless entry to GXE
- Changed over to winter rims
- Car Alarm
- Quick question -- Tire rotations...
- If I were to buy something like this...
- Yet another Suspension thread (ride quality ?'s)
- Megan Exhaust
