- any good mods for our vq30's
- Ding on AC Compressor Pulley
- alternator fuse
- Black Plastic in Oil Pan
- Help. Transmission shifting problems
- 97 maxima won't start, died on freeway
- A thank you to ALL you senior members
- Rack and pinion boot
- vq30dek swap with de intake cam question
- Random stalling at idle, no CEL - Solution
- P1401 code
- Left front side vibration
- Some footage of being obnoxious in town
- 97 gxe auto no start
- WS Y-Pipe+Megan straight pipe+QTP cutout= BWAAAAAAAHHHH!!!!!
- coolant leak? any ideas?
- 96 Maxima- Idle Slowly decreases until it shudders and dies.
- so how do get ridd of p1445
- beer shift knob...
- Cold start problem
- Another No Start Thread
- Comprehensive and complete maintenance on 98 Maxima GXE 5 speed @200k miles
- Use Fuel Pump to Pump tank out?
- Question about 00vi times
- 00vi swap
- 1999 Maxima Elec Problems
- EGR blockoff
- 94 maxima Rack & pinion replacement
- Best Parts Site
- Cel 0407
- Rack and pinion
- 95 Max - Front brakes
- Elctrical conections
- HELP! Coil pack grommet stuck in spark plug cylinder.
- P0135 Bank 1 Sensor 1 Cali spec
- wth, keyless entry stops working all together
- Spark plug help?
- so I got a 98 5 speed and I found something new
- issue when replaced bulb
- Trouble Codes: P0171, P0174, P0325, P1447
- 1998 A/C switch
- motor oil for transmission lube?
- Poll: Engine size that ppl think your car is
- Lower control arm bolts
- Cylinder 1 dead?
- Whining from speakers after HU install
- STS install issues...
- No Start BS IS FINALLY FIXED
- 96 GXE engine electrical issue?
- vq30de-k question
- Need Help Fingering This Out
- check this ish out
- fixing my no start but what is this sensor
- going to get a MEVI soon so i have some questions
- Rear end movement
- Car heat smells like burnt glue, wet engine
- 1995 Maxima GLE missing parts
- 'Hack' into ECM
- Hard start problem
- Weird issue with LCA replacement. Help appreciated!
- paint my fogs yellow
- What brand windshield should I get
- 97 gxe power seat harness
- Those running DEK injectors & fuel rails with aftermarket AFR
- So i'm looking to install fog lights
- DTC 0807 and 0807 common cause?
- car wont go pass 40km?
- Needing some electrical advice...
- Need your quick opinion on clutch/motor mounts parts & labor cost
- Antenna Mast Woes
- Squeaking noise maxima 99 gxe
- Cat is on its way out the door?
- Half and half intake question
- Near Atlanta? Own an Auto? Want $100?
- CD Player glitching up
- help!! axle boots comming off..
- use trailer hitch or Tow ball mount?
- Need an Expert. Video of My Car Not Starting
- so i happy with my 4th gen now for...?
- Front end vibration...
- Rockauto oxygen sensor STD SG438is NTK
- 97 gxe keyless entry program
- just installed Wsp ypipe!
- A Guide: How to Make System Monitors Show as Ready
- Engine splash shield?
- VG30DE MAF from a J30.
- Jetta lip
- Alternator and Battery readings - How long do I have before it will die?
- j30 retrofit
- '96 Universal Catalytic Converter
- Failed NJ Inspection
- 3.0 L VG30DE V6 Swap
- 95-99 sentra lights on my 99 max
- My HVAC and the Nissan Dealer - help!
- 97 maxima vehicle speed sensor
- aww crap...is this a sign of the end
- Weird noise from driver side wheel, maybe brakes?
- 95 nissan maxima "help"
- clutch went flat and shifting was denied...
- OBX Long tube headers v2 headers installed *another review*
- Now I'm Pissed
- ypipe installation
- No start
- 1995-96 Fogs
- auto lsd tranny swap
- Wierdest transmission issue...EVER!! Plz read
- Flex Pipe Size
- help with code 1005 egrc
- Need a definitive Answer!! O2 Location
- O2 sensor
- cam bearing identification numbers
- Timing chain cover removal: need some help
- O2 revived itself?
- after market cd player installation
- Difficult to shift into reverse
- Any ideas on my climate control problems?
- 5.5 Gen Wheels on 4th Gen?
- Foglights for 99
- No more Nicoclub FSM :-(
- center dash drawer broken??
- Found a nice deal I think.
- Driver Side Door Lock Jammed!
- fix my maxima once and forall. maf?
- Rusted Rocker panels - replace with Stillens?
- codee help
- any clue on on this sensor on the tranny?
- Question for those running with a 5th gen throttle body and iacv
- Yellow Corners
- Misc. bulbs for 97 Max
- 97 Max SE with electrical issues
- ugh car died
- 1st gear in an automatic?
- Schmelly's swap thread
- 97 maxima newbie!!
- Starting problem after tranny/clutch swap (Soloution)
- An idea do new exhaust tip. Opinions please.
- manual rack and power steering delete
- Rounded spark plug.
- 96 max/99 front clip want to add fog lights
- Interested in LCD Gauges?
- Hanging Aftermarket Muffler Help
- 4th gen with a 5th gen front yah or nah
- Idle drift
- LCD Gauges
- im going to plastidip my car.
- 95 in trouble
- Is the torsion bar rear adjustable?
- Front end grills and headlights
- TPS help
- license plate light screws ?
- Foglights not working due to?
- Grounding issue?
- stereo not working
- Heater stuck on?
- Disabling auto headlights a32 -99 ?
- AMB button (or maybe Temp Ctrl button) switch?
- 95 Max - Rough idle
- It's a timeless style
- My Max by the Beach
- help.....Got MAP sensor code after having the intake off
- Turbo
- OBD-II Scanner Programs
- Warpseed ypipe + CAI= 0-60?
- can't reprogram keyless entry remote
- Corner lights acting up...
- Mudflap mounting screws
- interior light fuse keeps blowing???
- Megan Muffler
- what would you pay for this rare find...
- Arggg front strut install headache
- Head Bolts
- Supercharger
- Trunk lip spoiler
- maxima r34 1pc headlights
- Thoughts on eBay catbacks?
- 1996 maxima Auto starter problems.
- Asktray (Console items & trim ) removal
- 18" wheels curiosity (inb4 wrong section)
- any luck with Tsudo muffler
- Alternator Harness Compatibility
- 2nd Gear Grinds After Replacing Transmission
- ecu questions
- Rough Idle help pls
- antenna delete
- Oem carpets question
- help.. car used to be auto and its been swapped for a 5-spd..(not by me)
- will the VQ35DE or VQ30DE-k auto tranny fit on a VQ30DE?
- Argggh Dang oil leak/alternator
- Emissions Help Needed, Bad.
- Which fuel filter do you use?
- Knock Sensor......
- Timing cover question?
- of course this happens now!!!!
- Just Installed 20" rims hearing a Loud Clunk...HELP
- Time for new gaskets
- my problem is back again..no start bs
- Moog strut mounts k90655 will not work.
- any rubbing or smaller
- help choosing muffler
- OEM suspension replacement...
- steering issue
- 98 maxima
- Pictures of your core radiator supports please
- Help changing fuel filter.
- Flywheel Interchangability
- electrical problem?
- New to the forum!
- Performance upgrades
- Help with lights not working.
- heated steering wheel cover
- New here
- ECU replacement?
- SO poly Motor Mounts? Anyone make them? Can I buy already Filled?
- does anyone reconize this car its from new york
- knock sensor code ...
- Power Antenna lowers when braking
- 00vi gurus please help
- Now taking orders for Cattman header/y-pipe systems
- Replaced coolant temperature sensor. Now running "hot"
- 99 Maxima outfitted with the full 01 DEK
- ATL people
- Electric turbo/supercharger from ebay???
- Replacing radiator thermostat necessary too? Where to find radiator mounting rubber?
- 1996 gle please help
- Does anybody know where to get R34s
- Unique rim fitment question!!
- black box in the trunk?
- Suspension setup advice please
- What is this code: P0136
- 5 speed trans fpr my 99 maxima
- Mandrel Exhaust Systems
- de-k
- deleted my exhaust thread because...
- HELP Need help to identify parts to reassemble dash, and an assortment of components.
- Anyone use / recommend a "complete" shock strut suspension kit?
- Starting problems
- Stop/Brake Light Out
- fuel filler neck?
- ignition or starter?
- fry my ignition switch ?
- Airbag Light On
- Where to order OEM parts?
- 4th gen vq35 swapped starting problems.
- need help identifying part
- 99 Maxima ECU (repair or purchase used)
- Need a high output alternator
- A/C lights flickering
- Any Idea What These Are?
