- P0505, Idle control malf.
- 3 codes....
- Adding a sub w/bose...quick question
- What is a better look?
- Sunroof Repair Kits?
- Interior change
- Block heater power?
- Near Stall at WOT?
- Coolant gauge problem
- My TPS reads 90 percent at full throttle
- how to get to the drive belts?
- Axle Replacement
- FSTB causing creaking. Possible fixes?
- i changed the plugs in my 97, now it has to warm up before i can put it in gear
- My passenger front door won't lock - Door Motor?
- A32SHOP.COM - New Year, New Site!
- CLUTCH PROBLEM URGENT!!
- Ok.... Who's Car is this?
- '99 max What to look out for?
- loose carbon in charcoal canister
- Looking to get muffler tip
- HAPPY NEW YEAR TO ALL ON THE ORG
- 4th gen with black 03 rims pics plzzzz
- high pitch whine noise
- what are good websites for performance parts?
- brake line part # / or possibly used part
- Oil Leak above power steering pump?
- 95 Maxima scan tool help
- Re-wired foglights - corner lights / rear lights don't work
- How much is my car worth? Where can I sell it?
- Need Some Reassurance and Some Info... Trans Service Issues
- What do you guys think about these headlights?
- o2 color codes
- 5MT Gurus...a spring came out of my tranny.
- changing spark plugs
- Bumper and Blinker rewire Completed
- DIFFERENCES IN O2 SENSORS
- Help me identify this shifter
- auto tranny issue with downshifting?
- removing brake light?
- Transmission Maintenance Q - Disassembly For Filter Change?
- annoying noise.. Axel Bearing
- Strange Movement While Acel.
- Brake Pads... Daily Driver.... Are HPS really miracle pads?
- Liscence Plate Harness
- Downloadable FSM
- Q: Add RF CD Changer to 95 GLE
- Door Light killed Window Switch?
- polishing upper intake manifold
- Enough!!!!!!!!
- Anyone use a thermometer in your 4th Gen?
- HawK HPS brake pads, How long to they last in a Gen4?
- Need help code p0302
- Map Light
- axle seal question.....
- MOOG ball joint question Gurus step inside!!
- Axle Question
- Few questions
- Possible blown shock?
- TRANSMISSION QUESTION
- warpspeed exhaust system on the max??
- Merry Christmas On Maxima.org
- O2 Issue
- How can I find production date of my max?
- Weird lighting problem please help
- strange grind/squeak sound
- Bad ECU Harness HELP
- Whinny noise, dimmed lights, is my alty bad? Problem after problems -_-
- Auto and 5spd. Timing ring the same?
- 1995 Max Air Bag Light - Fixed
- power steering hose
- Eastern Catalytic Converter?
- Interior LED mod?
- New Auto Shift Nob?
- How much am i worth?
- Want to have rear sway bar installed...any good places in San Diego area?
- Muffler / exhaust clunking
- Woul a trunk from a 95 fit on a 98 maxima?
- Burning smell
- Scared And Confused!
- 97 MAXIMA IAT?????
- Winter mats.......
- car makes squeaking noise .......
- cluch break in
- does anyone know how much shorter the ralco sts is than stock
- 19x 9.5
- grounding kits question.....
- NEW HERE AND HAVE A QUESTION
- Tons of Suspenstion issues! YAY
- Yay or nay on the new badge and headlight bulbs
- warning to those with led tail lights
- Need to verify.....Downstream O2 Sensor
- 5spd Ignition - Push Button Release
- cool miles ;)
- Help decide: Bi Xenon or single kit
- Vandals - broken window
- Car not starting: Key issue
- I finally can afford a drop...
- will this grill fit on my 97 max?
- 155k...time for a new clutch but which one
- Any experience with Spicer strut mounts?
- What's it worth?
- WTB: 4th Gen Y-pipe fed spec
- brake upgrade with sawblades???
- projector foglight for retro
- Transmission going out?
- Anyone Know TJ_Max?
- Wanted: 1 Tokiko Blue Front Shocks
- Brake master cylinder help
- 97 maxima...HELP!
- rear main seal-repair info
- Pulsey steering when cold
- Shed a Tear For Me Maxima Brothers & Sisters
- What you guys think of this roof spoiler?
- Long distance driving with CEL light on
- The end of my 97 Maxima...
- Stereo, clock, windows dont work??
- Getting a P0731 and P0733 Code on my 4th gen
- my retrofit!
- Ok order placed for Tokico Illumina kit
- Are these 19's or 20's on this 4th gen?
- Wipers wont work -blows fuse everytime... help please! snows coming.
- pictured removal of front headlights, please!!
- injector cleaning idea
- Crazy 98 Max Engine Problem.. **Need Veteran Assistance
- what happens if i don't replace KS?
- Climate control?
- passenger door not auto unlocking
- The longest your car has been at the body shop?
- EXHAUST TIP
- Hood won't close all the way..?
- keyless
- Rubber burning...
- Lost my lug nut key. Now what?
- How to reinstall rearview mirror?
- How do I get lateral link out of the LCA?
- Mirror Replacement
- Can't Find Keyless Remote Instructions
- Power Steering Pump Install
- Tinting outside headlight pieces
- Rattle at rear valve cover
- factory alarm not working, what gives!
- Small rubber gear in the window regulater?
- Brake pad wear indicator - which side?
- Question about front wheel hub
- MAJOR electrical nightmare.. please HELP
- Clutch question!
- nex coilovers???
- Water Pump squeeking at idle - means?
- How difficult would it be to add heated seats & mirrors to a '95 GLE?
- Heat not working properly
- 1106 Code
- Accelerator Issues
- taillights....not altezzas
- Matching AT control unit
- driver side power seat stuck???
- good mechanic in around central/norther nj
- oil leak.from..?
- Power Steering
- Plug in Power Steering Hose?
- Any Old Magazine Scans of Maxima Reviews?
- Spotted Black max in West Palm Beach
- Driver's side visor lights dont work?!
- 300zx Clutch Disc same as Maxima?
- police dashcam of 4th gen...
- coil pack blew up? pics
- loud rattle in morning start up...
- Tranny Swap
- HTP Billet 4th Gen MAF Adapter
- Will a 95-96 BCM work in my 99?
- Rear Suspension Alignment
- Exedy Stage II Chattering
- Change power steering fluid?
- what is a h4 harness??
- sunroof height adjustment?
- Cattman End-of-Year Sale now up!
- Oil light flickers at stops (sometimes)
- trouble starting
- Has anyone bought carbonfiber hood recently?
- R34 Fitment
- Need recommendations for winter floor mats
- What do i need for a BBK?
- Alternative Spoiler Available?
- The mods you LOVE that u've done
- HELP AXLE HELP
- Lights dim at High RPMS.
- How do I fix the rear door window?
- Few question..
- intermittant high idle after driving on fast/extended trips?
- cut a wire .. did i screw something up?
- Engine braking....
- ~~(some advice?)Starting Issue~~
- Back of headlight Rubber protector?
- Has anyone bought anything from 2kracing?
- gas cap pressure release??
- Car throwing bad codes, Bad ecm?
- Magnaflow Y-pipe/Cat Assembly
- Merry Christmas Everyone... Free FSM, Recalls, TSBs... Everything
- Got Rear Ended by a fking WONDER BREAD truck!
- MAF?
- Very stupid question...SE/GXE/GLE??
- Flashing CEL. A Diagnostic mode of some sort?
- Does your clock go BRIGHT when the dimmer's turned up?
- Exhaust Leak in Flex Tube - Any Fixes?
- P0300 code, can someone help me. Im stumped
- Anyone have these 18" OEM MAX wheels?
- 95 Max running rough - Help needed
- Vibrant catback
- I hope someone can help with my starting problems
- NeoWedge led's in climate control?
- *-***Bodykit question***-*
- part number for master cylinder firewall spacer need for swap
- Suspension Problem
- Can Mitsubishi Evo MR wheels fit on 4th gen?
- Antifreeze in my tranny fluid??
- 200,000 Miles!
- Maxima sitll stalls when warm
- Thermal Element for High Idle in TB
- engine oil leak, front seals...
- what tool set is best for our cars????
- Opinions plz on suspension combo, Blues&CMS
- performance ideas needed HELP ME!
- How do you know if you have bad bearings?
- rear valve cover gasket-repair info
- what do you guys recommend? (headlights)
- New Front Seats – looking for options
- Bell Housing Code
- stillen battery tie down worth it???
- Adding Power Seats
- Dead Fuse?
- Gear Whine
- my OCD was acting up....
- Need help; my car wont run but its starts up
- clamp to big for battery terminal
- what hood to get.
- I need a picture of...
- Clutch issue
- looking for oem or better lca's for my 95..
- Anyone do an auto-dim mirror install?
- Transmission Search/Swap Nightmare
- That Black Sealant Crap Around Our Tail Lights?
- Exhaust question
- Best place to buy Shocks/Springs
- 4th gens in North america = built in Japan
- Next is a GREDDY SP2
- Front brakes... calipers?
- poor 4th gen! I hate to see a ricer behind the wheel of a max
- Battery
- Fidanza vs. Stillen Flywheel ... What other parts are needed?
- how to make fog lights be on without headlights.
