- 1999 SE-Limited issues?
- Noob question - where do YOU install your vacuum gauge?
- Battery,Alternator?
- Problem this morning :(
- Exhaust Question
- pin stripes
- Flip Flop Trunk Conversion
- Electrical System
- noise after axle install
- speed
- '99 Transponder Key
- OEM clutch is Valeo??
- Shifter Stiff when cold
- Front strut bar and rear sway bar worth it?
- Procharger?
- camberkits?
- Questions for B&M shifter owners
- best price for OEM starter?
- what's the best place to get o2 cheap?
- 96 GLE Auto ****s Hard From 1st to 2nd
- LED swap causing CEL ?? help
- Replacing battery cables?
- Need Starter Help
- Alternator???
- Im loosing oil compression good...WTF...
- HOw hard is it to instlal PCV valve?
- Really Need help, I did everything, P.O.S car doesnt start after tranny swap!!
- Z3 Fender Pics?
- quick question about spare tire in the trunk
- Tokico Illuminas and springs?
- Wheel alignment - Please help!
- Wire for Kill Switch
- Wierd braking noise- please help!
- carfax (car critic) I'm guessing it's a repost, but...
- Is there any SS mufflers that arn't straight through flow?
- Need a pic of 4th gen. w/ Miglia EV-S 18's - lowered, no body kit!!
- 1st Oil Change on Rebuild
- Parking Brake Replacement
- Oil Leak
- Need help finding noise-maker!
- Headers ?
- Projector Lens Question
- Car with bent rear axle??
- Sporadic Hesitation and Stalling...
- Should I replace the OEM starter?
- Strange odor eminating from front end????
- Overdrive light on.
- wtf, odometer not working - 97SE
- did anyone notice a gain with a UDP
- fuel injector making static noise
- under seat neon wiring help!
- Keyless Remote Question
- This is Great!
- Gas coming out of the exhaust
- 99 headlight in 98 (need quick reply)
- Hazard & Defroster Lights...
- half-a55ed mechanic job
- Redline Max y-pipe
- fuel pump ???
- ECU Upgraded Shifting Auto
- Seriously... I need a headlight bulb that will last for more than 3 months
- Car Shuts off
- Any recomendations?????????
- how would angel eye fogs look?
- Remote lock lights
- 300zx Brake Upgrade Questions.
- window fell down, is it off track?
- Installed 5th gen clutch in 4th gen
- biggest tires that fit on this 99 max?
- Cylinder 6 Misfire...
- Stock 5th gen muffler?
- Sunroof leak
- New diagnosis for rotable noise.
- Heat Problem...
- Dynomax Superturbo muffler part # for our cars?
- Anyone have pics of 00'-01' 17" SE rims without center caps on a 4th gen?
- Wha do you guys say about these taillights???????????
- What is the best headunit replacement
- +1 for D2's
- TS ecu is in: Not impressed.
- S-Tech with AGX spring turning in the strut..
- brake light issues
- Please tell me my trans isnt f#cked up..
- 1996 front bumper converted to 1997
- CEL flashing; i don't know why
- Spark plug question
- How hard is it to install hood shocks?
- Corner Lights Won't Work!?!
- Fastest Max is the 95 GXE? Is this why?
- Brighter climate control thread
- Rear wheel bearings
- Saying goodbye to the GXE
- Y-Pipe Noise
- 97 problems....
- VQ35 thermostat in a VQ30?
- squeaking noise on the tein basics?
- Bose Amplifier price oppinions
- 1205 line pressure solenoid valve
- Do AE edition door sills fit 4th gen?
- For those who got SFCs from Warpspeed
- 02?
- s-tech/gr2 combo
- need some advice
- Where to buy Optima Battery ?
- radiator/General Questions
- What I did W/clear tape, and a Sharpie....
- Strut Mount Price?
- 95-95 red clears on ebay
- 5th gen muffler on a 4th gen?
- Thermostat Help
- Reverse Glow Gauges question pls help
- So I just spend 3 hours fixing my car in 21 degree weather
- Clock keeps fading out
- CV Axle nut
- Engine issue!!!! help!
- Y-Pipe and Failed Smog
- Weak heater
- New CD player..
- D2 coilover manual.
- Water Pump Install??
- Incessant Cassete Deck Grinding - Possible Fix or New Head Unit?
- Still throwing codes...
- What gives, alternator, iac valve?!!
- What should a mechanic charge for a clutch job (labor only)
- cold start up problem.computer reset?
- Let's see your manual shifter knobs!
- Bad o2 ruining peformance?
- WTF happened to my gas gauge? take a look, i cant figure this shiet out [pix]
- WTF, car won't open anymore?
- Fuel Economy suddenly dropped, but ks is OK?
- Venom 400 control module
- Bulb numbers for interior.
- Worth saving my rims?
- annoying problem that wont go away
- need some help!
- 5 speed internal tranny problems
- Remote Starters
- Replace rear calipers or not
- !?Starting Trouble!? HELP!
- little low end power...why?!?!
- Battery Question
- Windshield tinting
- 98 Maxima won't Start
- No Heat......Let's try this again!
- Weird Steering noises..help
- 2 screws to adjust headlights?
- wtf?? shameful max
- Speed limiter on 99 GXE
- knock sensor
- Opinion on y-pipe
- What is damaged n how much to fix it?????..asap
- Need Opinion on new exhaust and components
- Wheel Stud Sheered Off
- Y-Pipe Question
- Battery life?
- Can't make up my Mind need Fellow Orgers Advice
- accelerated pad wear with drilled rotors?
- Confused?
- 0304 code
- Battery Relocation
- SS Brake Line install not going so well
- Adjusting the Illumina settings
- This just ruined my night!
- Clear out 97-99 Outer Taillight
- what kind of batteries you guys use?
- dual intake
- My car is shutting off and stalling- need help.
- 4th Gen crash
- Replacing the passenger side transmission fluid seal
- 300zx maf in a 4th gen max?? need quick help
- Program this!
- cant get the FARKIN grille off! wtf am i missing?!
- How to avoid CEL after using drop resistor?
- Weird banging sound when brakes applied! and other questions
- question about CM 95-96 Red/Clears
- Heated seats on 95
- Key fob programming
- Anyone running PC680 drycell?
- Mod to change automatic shift RPM
- e-brake sticking when it's cold sometimes
- Eric I have a question for you
- Cold morning start problems
- Brake warning light
- Keyless Entry Question
- What grease to use for Starter
- irotors brake disc (long)
- Should i do it?
- Grounding kit?
- Driveshaft help, STAT!! Pics
- Thumping sound while driving
- Car trouble
- Re-retrofited my headlights
- Pass Driveshaft issue
- Vibrating while driving
- Exhaust suggestions
- AC Compressor Bearing replaceable?
- 0903 Qwik Question!!
- Exhaust and Headshield Question
- 5spd swap - insurance
- Weird Power issues
- Cylinder 6 misfiring...
- My TL HID Retrofit...
- 5th Gen Clutch Parts
- Maxspeed with tokico blues
- Washington State Peeps?
- OEM Starter Question
- Ebay intake
- headlight help
- Ever had lights on your console go out?
- Another new problem: Tires rubbing on something
- Audiovox AX901 Remote Stater
- flashing airbag light
- Ebay Strut Bar
- Shifting problem - Wont go from P to Reverse
- Those D2's or other coilovers with adjustable camber plates... step in.
- cold morning starting
- Cleannnn :D, but I have a few questions.
- Maxima Cooling System Pressure ??
- One fuel filter went out - what causes this
- Checking and Replacing spark plugs...
- Carpet ruined! Where to buy/how much?
- added 6th gen emblem on door (pic)
- Why is my carpet always wet?
- Info on Cry02 Cryogenic Intake Mods?
- Squeaking A/C Fan
- How to test cooling fan speeds?
- A bit of a wierd question...
- Hmmm, I wonder how this will sound...
- Anywhere to get new OEM floormats?
- it dont start.
- oil light is on, any possibities besides oil sensor?
- key fob
- Alternator choices?
- who makes the best headlight bulbs?
- Replacing Stock Exhaust Questions
- Got 357 miles from a full tank!
- 95-96 clears on ebay.
- Could this be an electrical problem?
- E-brake light on
- Need input/opinions on my ebrake freezing up this morning...
- car parts online
- Which bank is which??
- Can you replace strut bearing without removing strut?
- 4th Gen muffler
- Bumper painting price?
- Why do I not have ABS?
- Abs?
- Seriously, can you reach the fuel filter with the Intake on?
- decisions decisions...coilovers
- Clock LED goes dim
