- KS Question
- 95 SE project or Parts car?
- 1996 Maxima - "Sputtering" Starting Car
- Hood Support Struts
- Weird Noises Coming From Suspension - Struts? Strut Mounts? Inner Tie Rod?
- New Ball Joint a little loose?
- Wheel Bearing How-To Other Than Motorvate?
- Perforated leather seats
- Water leak issue
- help. tranny problem..bad
- Need help with a mystery car non-start.
- FREE PAINTJOB NEED OPINIONS!!!
- Power Window Trouble - Diagnosis?
- cat question
- Is this a reasonable quote for putting in another engine
- Front or rear coil pack is longer?
- 96 Maxima ecu pinouts?
- looking for a good site for rotors
- Help asap
- Sputtering Problem
- ac blowing really friggin slow?
- Who's got my back?
- Which heavy-duty battery do you guys recommend for 97 GLE?
- Sexy Blacktop?
- COIL PACKS
- Good mirrors for visibility / distance gauging
- SPOTTED: 4th gen. at Applebees stripmall in NY.
- talk about diamond in the rough! my find on ebay...
- Blue Maxima + 124mph on hwy 19 + body kit = FUNNY S*** :D
- High idle issues
- Lights interior and outside Dim when idling ... 2nd battery and/or Capacitor needed?
- 1997 Analog GLE cluster replacement with Digital?
- O2 sensor or heater?
- Search Function Down?
- I own the world's most jealous Maxima
- easy question
- Headlight Removal
- Should I keep her as a daily driver?
- no bounce on rear suspension
- simple atf question
- Car leakin antifreeze...D**n!!!
- CA Smog -4th Gen Ignition timing should NEVER be checked
- Should I spoil her?
- Steering Question
- I need a new manual tranny.
- Passenger Seat won't slide
- Looking for the quietest exhaust possible
- Replacement Headlights for SE - Where to buy?& is SE "different"?
- Can you adjust the starter engagement switch on the clutch pedal?
- New Quad retrofit nearly complete!
- Car stalls then OD light starts blinking ?
- help on codes ?
- Dreaded 1005 CEL
- Front Back Struts Springs joints 1996 Max
- 97 maxima wont start in cold weather?
- Splice 99 o2 Sensor onto 95 Sensor!
- Was looking through some old pics...
- Need Help!
- Aftermarket coils - any good?
- P0300/P1320 - Diagnostic help needed
- Has anyone purchased these OEM type headlamps?
- failed emissions test w/ a 95
- A/C Clutch
- New project
- VQ30 Replacement Engine for a blown engine
- Heat not hot and clicking sounds in the dash
- Changing Fro and Rear Motor mounts
- Side Glass/window?
- Odd volatage from alternator, low volts on battery
- Saying goodbye to the max...
- No in cabin heat & engine overheating
- Ebay ABS Sensor
- Help - Cold Start Issues w/ 97 Maxima
- im skeptical.(Offical Resonator Thread?)
- will 00 maxima cluster fit 95?
- HELP .... WIPERS DONT WORK, AND IT STARTED SNOWING !!!!
- Question about cams?
- who has the g2 euro tail lights blacked out ?
- Picture Request: White 4th gen on Evo 5s
- HELP PLEASE!
- fitting a 5th gen exhaust on a 4th gen
- Spoiler LED problem...
- Ebay NGK spark plugs any good?
- 95 Maxima slipping automatic tranny help.
- Ebay replacement bumpers
- Maxima Airbag replacement?Help!!!
- TCS/Slip on -> Engine stumble
- window problems.
- Heater Core time
- EVAP valve v. Fuel filler cap 0111 EVAP code
- Whine From Upper Intake?
- What kind Gas Milege to you guys get?
- 95 Nissan Maxima Smelling like gas strong.
- Rear Calipers and E-Brake
- Help with clunking
- rear window mod - is it possible?
- HELP!!! ECM
- Anyone have the xxr 006 rims? Cheap on Ebay
- What do you think of these radiator hoses??
- interchangable struts?
- OEM wheel selections
- Shifter Problem Anyone ?
- Am I getting ripped off...?
- Three diff. NGK spark plug types. Which to go with?
- Proggresive my rate
- Cant find a thread!!!
- c-pillar for maxima question...
- r34 ebay headlight owners step in
- Front Right Heated O2 sensor
- Problems with my ALT Belt. Squeaking.
- Possibly coolant in in LIM
- Exedy OEM Clutch Kit for $106.63 with free shipping
- Poll: 2k SE wheels or 2k6 Sl wheels?
- What causes fuel injectors to die?
- Steering? Suspension?
- Maxima Stolen
- Auto vs. manual transmission size
- UPDATE: NEED HELP! Car Dies When Coming To A Stop
- Key FOB
- So long Maxima community...
- check engine light - no codes??
- Odd question...about lowering just the front?
- Replacing Head Unit: What do i need to do???
- Baffle Plate Replacement
- tune Q
- Starter spins with key removed from ignition.
- While my UIM is off
- Driver headlight doesn't work - Daytime Running Lights - DRL
- a mod a day... what's yours?
- Front struts........which way is correct?
- Problems with BOSE Sterio System. 95 Maxima
- Denver salvage recon
- 2 CEL codes fast question !!!
- Strange problem, not catching grip / traction?
- Ebay Knock sensor's - any good seller's out there
- I took the restrictor plate off the red dragon..
- strut issues maybe ?
- POWER STEERING ISSUE..
- real rough idle..any ideas?
- Help - car fails emission for ignition timing in CA
- DIY Front Valve Cover Gasket Installation Guide
- Radio problem in 4gen
- HELP... Wiring I35 seats into 4th Gen....
- Lights flash when starter died
- Suspension Install Help...
- Does / can anyone put a 5th gen ballast in a 4th gen car and have the hid effect?
- odd starting issue
- went to the junk yard today.....
- Changed bumper lights and now the side blinkers does not blink
- How can I find out what type of axles I have
- Clock too dim when lights on daytime...
- centering steering wheel
- slave cylinder question
- Maxima would only start when in Neutral
- Weird problem.
- VSS connector?
- 96 Maxima clear Cefiro A32 headlights
- Duel Q thread; oil in intake. long read.
- Electrical Gremlins
- Starting Issues, Possibly P/N Inhibitor Switch
- Are TL Projectors too big for R34 headlights?
- 95/96 Headlights with the Cefiro Mod
- 1st/ Reverse : feel and hear something loose
- What are the symptoms of a Waterpump going south?
- Car stalled, but restarted
- Spoiler 95-99: searched and got more confused
- Motorvate.ca
- Im about to sell my max
- Fixing the max up.
- Converting Auto to Manual, Questions!!!
- has anyone got the custommaxima.com catback they make?
- (replacement)do i have heated seats? cant tell?
- factory 99 catback interchangeable with 96?
- HELP rear cover gasket
- Question about a part for auto to 5speed swap
- P0139 Code
- NEED TO KNOW ASAP
- is a 95 maxima have 9007 bulbs or 9004?
- Is this my IACV?
- Need help with my greddy sp2 catback..
- Help!! Brakes
- Just bought two betls AC and PS...
- fsm & tranny?
- true dual exhaust
- new VSS but...
- ck engine light...VSC?
- Am I being ripped off?
- My retro projectors *pics*
- Car is hesitating
- Axle seal leakin
- NEED HELP! Car Dies When Coming To A Stop
- HELP! where do i put the spring compressors
- spolier trunk swap
- 9007 conversion schematic
- Remanufacturered or Used Transmission
- A/T Help Wont come out of 2nd Gear
- Help!! with speedometer
- here is link for removing front axle on 4th gen
- Rewire low beam into high beam light
- Vibration after driveshaft replace. HELP!
- Terrible Terrible Bottom end. MAF or TPS?
- Need help with drive belt change
- 1995 Max..is she dying a graceful death or worth saving
- Projector / HID Headlight Retrofit Complete, yayz0r
- Front Valve Cover Gasket
- lip question
- HELP IT WONT START!!
- So depressed
- Fender bender .. can u guesstimate ?
- Water In My Intake
- thinking about painting........
- Motor Mounts
- 1996 Infiniti I30 rebuild
- DIY Windshield Washer Pump replacement
- headlights
- High Idle problem.. WITH AN ACTUAL VIDEO O_O
- Idler Pulley Help
- Alternator FIRE
- Check Engine Code 0505 and engine misfire
- Tranny fluid level
- bad gas fumes inside car. yuck( Evap system issue?)
- starter? ignition switch?
- Headlights blink~
- Checking out my voltage on my hazard and my defroster buttons
- Fast starting question ?!?!?
- Windshield washer fluid doesn't spray
- best 4th Gen maxima reviews, EVER!
- help! new dropped suspension still feels like a hoopdie
- Replacing front axles? Who has done it on their Max and how hard was it? Help!
- Unusual radiatior hose problem
- car dying, running out of power (alterator or battery)
- 4th Gen 5Speed Axle LSD or not?
- What are my best, affordable suspension upgrades??
- Coil pack issue maybe? im stumped
- stock seat dimensions
- Threading on Shift Knob Mount
- engine runnin hotter than usual
- 99 harness swap to 96...Direct?
- Cattman Y-pipe discounts for 95-01 Maxima test fit in OC/CA
- alternator???
- Black Air intake fastners, right above the grill on th, how do I get them in there?
- Any problems with silicone radiator hoses?
- UNDER SPLASH SHIELD
- How many miles have you driven with "clicking' CV joinits?
- Weird noise from underbody, Grinding/Whistleing/Hissing
- Looking to Spray on my Boosted vq30
- Had starter rebuilt, now Service Engine Soon light is on
- Wierd Clunky front rht side noise going 20+ mph????
- Rough engine, cyl 2 misfire codes
- Smoked or Clear Ebay taillights for White Max
