- Bulb size question
- '96 Maxima Video
- Any ideas? Need help.
- help with 1999 maxima power lock winndow not working
- Alternative routes for removing water pump
- Alarm security question
- SOLVED - Intermittent misfire at speed / rough idle
- Low idle/ oil light flickering.
- HELP** New AMSOIL ATF Brown/Black in Bottle?
- 96 SE with RS5F50A manual trans (correct oil seal?)
- Clicking on sharp Turns, CV joints?
- 1998 oem fuel injector?
- Engine Rebuild kit
- 98' maxima fuel pump relay?
- Help with tire sizes
- need recommendations for a lightweight crank pulley
- old member returning with a new question about MT
- Quick question about heater hose
- 1999 to 1995 ecu swap questions
- Car turns off
- Locations Of Essential Grounds?
- Best Alternative for FIPG
- still have a p0300 code! help save my max
- new to maxima
- Rear Wheel Sound w/ Video
- Rim question!
- small hoses
- Odd Tire wear on all 1" all outside edges?
- Shock/Strut Suggestions?
- Wheel Noise Found Cause But how to fix?
- rough idle, white smoke, smells strongly of gas??? Need help!
- got my car back
- 96 AT Questions
- Advice For Over-tight and Rounded/Stripped Ball Joint Nut?
- Camber adjustment question
- Changed the radiator at 177,###
- P0500 from speedometer. How to solve it?
- help with the relay rad fan 1
- Mass Air Flow Sensor on a 1997 Maxima.
- Don't buy aftermarket alternators
- Car does not move when its put in gear help please!
- Part suppliers?
- question about sound in front of car
- Maxima j32 compatibile with i30
- Planning a road trip, would it go that far?
- 97 Maxima 5 Speed Crankshaft Position Sensors
- 1999 maxima won't go into drive or reverse
- Whining sound in park or drive
- Million Dollar Question, Weight and Hp effects 0-60 times correct?
- Front left splash guard fell off
- fun with pollen....
- Are these new?
- Starting issues???
- Axle Seal Leak
- '99 Maxima getting 11 mpg - no CEL
- Dog Track/Yaw Issue
- Overdrive button
- My first Maxima
- Anyone used Koni STR.T struts?
- Need help with UIM cooling lines
- Help
- Common oil leaks on the front of the engine?
- help guys
- Reusing suspension parts, yay or nay?
- My second attempt at body work
- what is this where the egr should be
- Hard Starting issue with other factors, need help with diagnosis
- Grinding
- Need a second opinion for suspension problem
- 99 GLE intermittent no crank
- 5th Gen Sway Bar on 4th Gen?
- 95 maxima stalling
- Maxima A/C compressor cycle.
- Bought new rear hubs - noob questions
- Mystery fluid leak
- I need someone who really know a 95 maxima good! Help
- 5 speed trans timing
- Replace vehicle speed sensor and knock sensor
- cooling fan question?
- 97 Maxima, nothing when I turn the key
- A/C Trouble Time
- Alternator Failure Qs ...
- Has anyone had to align the driver's door?
- EGR delete - solenoid questions
- 95 maxima programmer?
- 97 se automatic prob shifting after bell housing cleaned, multiple CEL codes
- Where to buy Rear Sway Bar
- pic of maxima
- Pipe under throttle body without a hose
- Has anyone used a Walker Quiet Flow 3 muffler?
- Grease for Rebuilding Rear Calipers
- I Found A Broken Ground Strap ...
- Wont start.
- How do i find out if my car is cali spec or not?
- car will not start
- small power steering leak
- Lowering the car
- This Is loose but don't know what it is?
- What engine harnesses are compatible with a 96'?
- Just Flushed Transmission
- Does anyone sell ANY aftermarket headlights anymore?!
- Another Satisfied H&R KYB driver!
- What happened???
- P0755 shift solenoid valve b
- TC-W3 Additive, Clean TB/MAF/EGR/IACV Before or After
- U shaped hose on the upper intake
- Buy or pass, Oil leak timing belt cover
- Stall and rough idle while stopped, & other problems
- Best wheels for a 4th gen
- Best maxima manual ever
- extra hose sticking out by MAF driving me insane help
- 97 Maxima Battery & Brake Lights ON. Bad Battery Terminals?
- Anyone know how the wiring works with Power Seats?
- Smog Inspection Success
- Car wont start after intake manifold, rear valve cover job
- bose stock stereo clicks on and off at random
- 98 I30 manual F50V oil change. HELP
- Radio shuts off when car starts - question
- HELP! 98 Maxima Auto Transmission Swap Hard Starting.
- Rust on 99 Maxima
- 95 Maxima Anti theft system
- Where to buy AC clutches?
- Headlight Restoration and Sidelight+Taillight Ambers Question
- Hesitating to accelerate
- Speedometer needle problems
- o2 sensors/gas mileage
- Weird tail light issue.. 98 maxima
- Just finished up water pump tips and a question on oil
- RH CV Axle for 1998 SE 5-spd LSD
- P0902-P0903 Clutch Actuator Circuit Low/high, explanation?
- Timing chain
- Valve cover gone wrong
- 98 Auto - positive cable connector
- Please help identify this leak.
- My wife borrowed the car for work...
- 97 Maxima Reverse lights switch
- Non-contact front license plate?
- 99 sel idle/warm start ups
- Clear lens cornering lights, are they still being sold anywhere?
- Best O2 sensor?
- High RPM at idle/run
- Code 0420, but I dont have pre-cats..
- MAF sensor??
- What is this? In A 1995 Nissan Maxima
- Stripped rear bushing clamp bolt
- 3in exhaust question
- LCA bolt pics please
- How Many Knock Sensors are in a 95 Nissan Maxima?
- Help!!!!
- 1998 Maxima AUTO Transmission Issue SOS!!!
- i have a dilemma.....
- Retrofitted G37 sedan projectors + Custom DRL
- What's the 0-60 in your stock automatic 4th gen
- Spongy brakes
- Door Removal Electrical
- Driver Door Lock/Power Window Failure
- Front Bumper OEM?
- Anyone lowered their 4th gen with lowering springs?
- Went to the track
- Riddle me this riddle me that, why won't Max attempt 2 start w/ a slightly low bat?
- What Idle shoukd be on drive for a 98 maxima 4th gen?
- car wont start after winter storage
- replacement harmonic balancer
- Screwdriver self-diagnosis not giving codes
- P0500 Speed Sensor code with very little symptoms
- Manual Tranny Fill Plug Part number?
- OBX Underdrive Crank Pulley - Help
- Are 4th and 5th gen ATs interchangeable?
- Power Windows / Locks ONLY work for 24-48 hours after resetting battery
- Need help deciding what order to mod!
- Suspension woes. Advice please.
- Adding Digital temp gauge
- Replacing control arm
- 1999 Nissan Maxima- No crank, start, and fuel pump not turning
- Replaced rack and pinion
- 4th gen passenger side drive axles
- Bad coil
- Any other transmissions fit the VQ30?
- bar under my engine is cracked
- how much to replace motor
- a32 inline 6
- anybody know what this hose is
- short thread
- stumped. stalls. Doesent stall. idk
- window issue
- help please, Maxima won't always start
- HELP! 99 Maxima SE Limited bad idle & extreme loss of power
- replacing knock sensor, dealer says, "waste of time"
- How to adjust idle with a broken tach.
- Noise/burning oil diagnosis (Valve adj? Timing chain?)
- Fog light options
- Another O2 Sensor thread: P0141 - Rear HO2S Sensor
- vq30 rebuild?
- my some advice/opinions on potential engine swap
- Tachometer inconsistant reading
- awd 4th
- 1997 Part out or Scrap?
- Best way to remove crank pulley
- Brake Fluid Change Question
- Oil Catch and the Intake Port
- Power Steering Belt Adjustment- What's Missing?
- is wheel hop suspension or something else??
- i need custom installation seats
- I have a egr EGR ??
- 3 spoke steering wheel swap with working cruise and air bag
- fuel pump
- Help me decide! and do smart choices!
- 96 maxima 98 i30 swap questions
- 95 maxima shifting problem
- Replacing Rear Torsion Beam
- Maf question
- 1995 m/t ecu/ecm (srt) system readiness/ emissions ready
- Odd O2 sensors
- 97 maxima want stay started
- Need some input on crank seal oil leak
- Pointers on removing the intake plenum
- 'Spose I'll Need To Recalibrate My TPS?
- Clock Spring
- Need help with tire sizes
- 99 Max GLE Revival - What Else? What Next? Life Expectancy?
- My eBay Y pipe thread
- misfiring
- What plugs in here?
- cat back ??
- 00vi swap
- Axle question
- 5spd MT Passenger side Axle seal help needed asap plz!!
- code P0154 and P0304
- Got me new clear taillights, one small crack
- 1995 maxima won't start when hot
- does dip stick level influence oil leaks
- Question about changing rear brake pads...
- my motor is filling up with gas
- HO Alternator
- blue thread locker on inner tie rod - to use or not to use?
- Car Stuck In 5th Gear And Won't Move Now But Speedometer Shows Speed Increasing
- Advice on 97 with oil leak
- 18 inch PSi question
- Cylinder 5 misfire?
- 2015 4th gen Picture Thread
- Trunk mat recomendations?
- 98 maxima cylinder numbers?
- What are some good cheap performance upgrades I can do to a 4th gen?
- Help please! 95 maxima->doesn't want to rev, stalls, loss of power
- Won't Start After Jump
- Fixing up a '95 Maxima GXE
- Which front caliper slide pin?
- ECU turn-screw loose, broken or no?
- 96 maxima needs help massive rear oil leak
- Hard start on 99 max
