- Blown electrical system?
- Where can I get a budget Y-pipe?
- Possible ECU for 99s?
- If I were to put a new steering wheel on, what would happen to cruise control?
- spark plug????
- Oil light keeps comming on?
- What to do next?
- Anyone seen this nissan commercial Its kinda old???
- Clutch!!!
- Check out my new hompage!!!
- Which B-Pipe?
- Drop resistor mod
- need feedback on agx's
- Isn't there black carpet,headliner for our car
- would getting my leather seats redone bring back that "new car smell"?
- Stuck torque member(brakes) slider
- stillen RSB link/write up
- tips on launching on slicks ?
- Euro Dezigns - 6000K Blue Bulb
- Battery relocations kits?
- BlehmCo Maxima Big Brake Kit
- How to soup up a max!!!
- where to get a light weight battery?
- To whoever has replaced there starter...
- Really Rough Idle
- Strut mount problem
- Is my 96 Maxima BOSE Stereo Dead?
- OBD2 tool for pc software
- Keyless entry
- clanking noise around 2500-3000 rpm
- Need Advice on Exhaust
- Are all USDM 4th gen intake manifolds the same?
- How Tinted Is Your Max?
- Front End Repairs, need Opinion ..Help
- Leaky tranny
- Where do I put Jackstands ???
- 0802 Wtf!
- parking brake
- I want to be a 4th Gen. Maxima owner againg.
- I need a mod under 100 dollars...can someone suggest something?
- running rough at idol
- --==Stats website==--
- Help! pics and sound, few questions... Long
- cai
- Shaved...
- creaking noise
- Ypipe is on.....WOW what a mod!! write up too
- Reprogram JWT ECU for MEVI
- Question about 0203
- need opinion on HIDz companies
- Does anyone have mesh in a stock 97-99 grille?
- Hood strut replacement.
- New HIDs... I can't find a place to buy
- Why Would you Get a bad Knock Sensor?
- Help with red clear tails for 97
- Headlight Harness Upgrade Install?
- Tell Me What The Hell The EGR Is!!
- Interior Swappers From Tan to Black
- how do i program a used remote (lock, unlock, trunk etc)
- How much HP
- car shakes when idling--any ideas why?
- Your Cat Converter Failed for a Reason
- i never knew 4th produces the color of "midnight blue"...until today.
- Are JWT cams ok for forced induction?
- besides MEVI- what performance mod is left to do???
- Auto Auction
- Code 0302 - EGR System Hi/Low Flow
- Jerky Throttle Response
- Rear Sway Bar Question.
- Anyone ever have this happen...
- Air Bag Light - tried reset - Trouble Codes?
- maxspeed springs weapon r coilovers...any opinions?
- Scraping off rear o2 sensor?
- Only on Full or less than 1/4 tank
- Bad coil affect MPG?
- advice on aftermarket speaker installation
- NGK type BKR5E-11 Copper Spark Plugs
- Lug nuts?
- Bought new (to me, but used) Maxima SE
- Coolant Temperature Sensor
- Spark Plug Question
- Abs
- Removing dealer decals
- My own "Project Maxima" starts tomorrow!
- What kind of Spark Plugs to buy?
- AC Valve?
- Help changing PCV Valve...
- SLIP Light won't turn off....
- Sunroof cover loose? need assistance
- Gas Light On....How many miles can I go?
- Stillen ram air
- Headlight cleaning
- Buzzing sound from winshield (I Think?)
- ECU code problems. Can you solve?
- new engine or salvage?
- Steering wheel hub kit
- knock sensor again...
- Need Engine Swap
- update on sick tranny.
- HELP!!: Injen CAI INSTALL
- Need some pics of H&R drop
- need help with this car.
- climate control question
- Which spoiler to get?
- California Spec Max MEVI install
- Expected Repair Cost? *Pic Inside*
- Why do people buy carbon fiber hoods?
- fog lights
- Stillen Front lip
- Who's "strapped" in the Max....
- Hey guys, need advice on this car
- where do i find the paint code?
- ATTN:groundcontrol/spring rate gurus
- Need tips on installing a new ECU
- what do u guys think.
- particular ? for those who have had Tok blues and Gr-2's
- Droppin' it...
- 99s come with factory tint?
- Need Oil Change ASAP!!! Contributing to Horrbile Gas Milage?
- Springs w/out Changing Stock Struts?
- spoiler light screw wont come off
- 20th anniversary headlight mod to 95-99??!!
- Mr. Clean...again
- do you need different harnesses for the taillights when converting to 97-99?
- Magna Flow...
- weird noise
- anyone have these headlights?
- I just ordered Dropzone Springs.
- {{{{{{{CAI Help!!!!!!}}}}}}}}}}
- how do i fix the lights behind the heater picture buttons (vents, feet, defrost, etc)
- antenna mast or complete with motor?
- Matt93SE's Groundwire kit installed(PICS inside):
- Interior swap.
- led size for window switch?
- **** knob problems...plz help
- Wierd Computer codes (Help)
- Help Me!! Quickly Asap
- Just picked up my new toys... *Pics*
- Replacement headlamp lense....
- Just got my type-x spoiler painted.. what's the best way to mount it?..
- what headlight bulb matches polarg hyper white bulbs best and has the best vision ?
- Please help me guys !!!!
- Weird. Car died during traffic
- Who has a Megan Racing Cat Back?
- rust under paint
- think i destroyed my transmission
- I'm a Believer
- How much would a B-pipe add with Y pipe??
- Please help! Can't remove steering wheel!
- Anyone ever seen this max??
- minor troubles with 96 maxima
- new small interior mod...
- rotors
- 97-99 Parts.
- Basketball hoop fell on my maxima
- Does anyone know what the PCV Valve for the enigne is?
- Thinking of taking the HID's out
- Wipers went dead
- Check Engine Code 1106, Someone please help!!
- O2 sensor problem.....need help ASAP
- How do you bleed the clutch fluid? Need help
- Opinions Needed
- Fuel Guage And 02 Sensor
- Pulled three codes and i need a little help
- wierd idle problem
- What UDP to get???
- How do I get to the starter? (4th gen max)
- changed KS, took 30 minutes
- Does this sound lowered??
- help with jerking
- 5th gen catback on 4th gen?
- do you put a bigger fuse for ..?
- installing indiglo gauges
- code 07 05 EECS
- Suspension Diagram for 4th Gen? Online?
- Running in Washington State
- Do Illuminas get rid of the bouncy ride?
- Rear Window Rubber Moulding
- Missing ECU screw
- 0215 Code: Evap Pressure Sensor, right?
- Air Bag Light and Sensor
- brembo sport slotted rotors vs. brembo core with slots added
- Swirl solenoids keep going bad after engine swap
- custom 95-96 tail lights
- Fuel Injector, can't find one anywhere!!!
- I need new front and rear bumpers (painted), how much will that cost?
- Deals on HID?
- Popcharger
- What does it mean when my clutch sticks?
- Anyone know where I can get some new pedals (for an automatic)
- Anyone have Ground Control instructions? (rear)
- fog light question with pics
- Just ordered some wheelskins...how hard is it to install?
- strut bearings and timing chain tensioner
- motor mounts and trans mount
- Fudgin Wheel Hop!! Mad!!
- Where to find a clear third brake light in the spoiler?
- airbag light keeps flashing?
- Replacing Driver's LH Mirror
- Need Write up on Front Sway Bar bushings
- Need write up on LED Tail Lights
- ball joints
- CV Knock
- How to install tail-lights...
- I finally pulled the codes from my ecu
- Question about Odometer, Airbag, CV Boot
- Greddy or Cattman
- y pipe installation
- Ouch.... why I hate SUV's
- Quick garbage bag question
- Anyone who has removed outside door trim...
- silverstar thread.. ..
- How Loud?
- Are Brake Lines Hard to Install ??
- directions for cutting the nubs on the corner light lightbulbs (next to headlights)
- 99 Max won't start - code 1402
- could this be the problem with my tokico blues - with pics
- how to beat a 2K/2K1!?!?!?!?!?!?!
- anyone ever had bad input shaft bearings?
- melted headlight harness.
- LED tail lights question
- parking lights
- Which Light Bulb?
- Maaco Paint Job: Beige-->Black: Unsatisfied- Need Help
- Reading ECM outputs and Lazy coil pack
- converting 99 cali to fed?
- Warpspeed Complete 2.5" Exhaust System
- got my cardomain site done!!!!!
- Tail Light idea
- real quick please
- Maxima with Reversin Problems...
- anyone here with tokico blues? blown tokico blues in rear?
- breakes
- Fast & Furious MAX car spec
- Where to buy a good quality breather filter ?
- Anybody replaced or had one replaced?
- Anti-Theft Question
- caliper
- KYB GR2's
- manual vs. auto (merged threads)
- muffler silencer
- Question about intake install
- Which color wires?
- 96 I30 tranny/ecu in 98
- brake pads
- Which emblem setup looks best? *PICS*
- trunk
- Parts arrived, and did Red/Clear mod! (Pics)
- Right Front Wheel turning in Neutral!
