- Engine coolant temp sensor...where?
- Spoiler is fading
- Two-tone maxes?....
- Best tire size for my rims/setup?
- Whats the next Mod I should Get ?
- Pipes A-Z???
- Whistling from H+R springs?
- i got my KYB AGX struts today!!
- Towing a trailer with a 97 Max
- waxing by hand or buffer
- engine flush
- Wheels Alignment on MAXIMA
- How do you clean the TB?
- Completely Confused
- McCulloch HID Problem today =(
- B+G Springs
- Test Pipe Installation
- Should I get b-pipe with or without resonator?
- Question (since search is down)
- messed up rear end
- Tokico Premium Performance Shocks
- PLEASE HELP Immolbeizer is FUBAR
- GRrrr $107 to fix OBX fitment issue!
- Trunk won't open with the release button
- Check Engine light is out
- lowerin my max
- Tire difference..
- Hanabi HID Problem
- Glad to be back in the Max
- why in gods name does the 4th gen look like a new impala
- Perfect Alignment with lowered car. Is it possible?
- Those Bastards Scratched My Rim@@
- Gas Light
- Lowering Car
- What next
- Engine dying when cold... what should idle be?
- Accessory belt
- Auto 96 GXE vs Auto 2K2 ?
- Waxing RIMS
- trunk questions..
- Upstream o2 Sensor
- Do I really need camber kits (sprints)
- 95-96 cheap front options?
- Opinions or pics of 97-99 Stillen front lip only please.
- best place to get new coil packs
- 02 sensor shot?
- KYB AGX Settings
- wich intake should i get
- Opinions on CF hood on Black max
- 9004 to 9007 thing I did
- Writeup on the 9004 & H3 7000K H.I.D. Lights from Custommaxima.com
- Best body KIT for OUR Maximas
- Booster Sensor by Hitatchi?!?!!
- Gen II Altezzas For 95 Se?
- Cornering Lights
- Need to vent!
- Trouble acceleration!
- budget y pipe
- squeeking noise.. struts?
- gas pump problem
- where can i find a strut assembly diagram?
- H&R/AGX suspension installed...making noises...help???
- Control for all maximas?
- Vb mod removal help need
- starter problem?
- Hardwired Radar Detector... Best Way To Wire For Turn Off And On?
- I found red tape for tail lights!
- Help - Removal of door trim
- suspension ?
- racing pipe
- Ignition Signal Circuit
- Knock Sensor info needed.
- MEVI or Nitrous?
- Carbon
- Anyone of pixs of original clear bumper lenses next to DC ...
- NE1 installed a 3.5VQ in a 4th Gen
- 18" Rims
- WTF Civic vs Max Kill? check this out
- resetting ECU in a 99 (screw is not flat-head)
- Used Car Maintenance
- Interior Bulb WriteUp for A 98 SE
- springs/struts and WHAT ELSE?
- Tinted/Smoked lights
- Side Skerts
- just installed frankencar mid-pipe/stillen cone
- Can I use Franken Car Mid Pipe with Stillen Intake ?
- ecu error code 0505
- from Sprints to H&R's , not impressed
- Just cleaned throttle body :)
- Help - I Can't find my coolant leak
- is there O2 sensor within b-pipe?
- RVM Lightened Crank Pulley (Same Diameter)
- Mesh filter removal?
- Electrical headache
- Custom Maxima 4th Gen Projector Update, about one more month (yea right).
- De-pinstriping was not a total success
- FAQ UPDATE: Vid of speed limiter in action
- Help Please...Aluminum Dash Kit Question
- Auto Trasmission........
- Question regarding ACT clutch kit?
- 96 ECU in 97 Maxima?
- 4th gen auto shifts by electronic signal, right?
- Overhaul 5sp tranny price?
- Suicide doors???
- Installed KYB Adjustables, Maxspeeds and Hella Supertones
- Need help with Driving light installation!
- My Windshield cracked.....
- new suspension
- Monza Exhaust
- which tires to buy for new wheels?
- top speed questions
- I need help with my Clutch squeeking, and lowering my car.
- HELP! Rear Brakes!
- SUNROOF repair ... ALL DONE!!
- where can i get gaskets for budget y pipe?
- HELP PULLED CODE 54 =Automatic Transmission Control Unit Signal to ECUwhat it means?
- Can I paint my stock grille silver?
- curious about something (95-96 owners)
- Budget Y pipe installed!! impressions
- Hazard Flasher Button Bulb
- Emergency Help Needed Clearing 97 Tails!!!!
- OK I know this is a juvenile question but...
- Changed Plugs Today, Car Runs Real Rough Please Help
- whistling when air conditioner is on
- Corner Light wont come on
- Door Solenoid busted
- Ignitions
- remote entry...acccessory or comes with the car ?
- Where are these headlights from?
- Does the 95 Max come with a full size spare?
- EGRC Solenoid valve or 1005 code help please
- Just a few questions
- Paint job...
- Knock sensor install tools needed
- If you don't like it... shove it up your muffler
- Is there any "Japan only" parts or the like for us?
- 300zx wheels
- PPSSSSSHHHHH When Shifting ??
- Cant get it to start. HElP ME.
- Putting on my Cattman Y-pipe help!
- Can anyone recommend a MAGNAFLOW muffler? or any.....
- Power Door Lock Problem
- Grills And Spills
- tranny cooler
- Miglia Emotions
- how much grease when fixing starter noise?
- Clutch or tranny dying??
- Help!! 95' Max stalls at randome!
- seat swap question
- Cat Converter bolts rusted badly...suggestions?
- lanyards...
- 99 SE won't go past 120
- Testing injectors?
- Bad night at the track
- upside down springs
- HELP -- 2 codes popping up from ECU*****
- Knock Sensor Rant...
- 4th gen FAQs problem!! rewired corner blubs v.s. fuse voltage!!!
- ACT clutch is the shlt! I just got on it.
- runnung rich
- Clutch Going.. or worse????
- sarona grill
- Installin the Clear bumper l;ights???
- Coilovers
- quick question: eBay bumper?
- Got ECU Code 04 13 From My 99 ECU, Help!
- 95 Cali vs. Fed ECU ?
- finding out what tint % i have
- Help!
- Got a question regarding braking...
- Remote Starter
- Question about ppl with underdrive pullies
- photoshop help pls?
- $100 to make my VI work
- What companies bore out throttle bodies?
- Motivational Rear Mount Question
- installing AE pedals...
- VIS body kit in stillen mag
- Mufflers
- Peps with stillen kit and sprints, how much clearance you have from ground to lip ...
- where to install alarm siren?
- 96 subaru SVX, vs 97 maxima
- tint advise
- Clutch Suggestions.......spring break ruined
- Installed a wind deflector
- VI stress
- BOSE Model Number
- Exhaust Heat
- Y-Pipe Flexible Coupling Wrapping to Quiet the Buzz & Hiss
- Do 5-Speed non LSD & 5-speed LSD share case???
- Pulsing brakes - Rotor opinions
- Budget B-pipe
- full exhaust cost, quality, performance?!?
- threadlock on EGT probe?
- front sway bar bushing?
- 2 Color Indiglow Gauges
- Trenz Aluminum Grille Insert
- Can I paint orange taillights clear?
- The true "dry" weight of the GXE, SE, and GLE
- FSTB Installed
- Where to get CV boot kit?
- 95-99 2 Color Gauges
- EVAP ecu codes
- Clutch noise
- Trying to find speed sensor
- OMG! me f***ing blew out 5 15A fuse + 6 20A fuse 2nite!!!
- OK so could someone recommend a tire or do a search for me?
- strange air leak type noise
- YES there is MAXIMA ES, I HAVE IT.
- No power until 3k
- Weird clank sound in the rear of I30
- Timing chain faliure.. post gone?
- splah guard suggestion???
- Brake dust shields inside wheels
- cold starting problem
- Remove Front Grill on a 1995 search plz....
- Putting in my xbox
- low pro tires longevity on 18''s
- I35 t 17'' rims
- Big Trouble Starting up Please Help !!!!!!!!!!
- Payoff on my MAX
- Anybody heard of these tires????
- Painting calipers and dash???
- Got a question.
- What magnaflow muffler do you have?
- OEM spec hot, medium, cold spark plugs
- Speed Limiter- still isnt making sense
- is there anyway to make my windows go down w/o holding the button?
- Do I need need new shocks and struts when lowering my car 2"
- '99 Maxima ES - fact or fiction??
- Crash the Max!!
- Anyone seen these?
- help with red/clear tails
- max pulley
- Fog Lights
- RT Cat
- resetting the ECU vs. Resetting the CEL
- Slotted/drilled Rotors for looks...
- Holy Rip off? Thoughts please :(
- 0505 No Failure Recorded/Detected
- Need help lowering my 95 Maxima
- Budget y installed wooo!
- Do Maxima rear brakes come with shims?
- Come and check out my cardomain page!!!!
- Engine Vibration
- Stock clutch rating?
- how to protect the paint from salt air
- 300 zx caliper question
- Search request please: "Test pipe"
- Can't remove door handle trims...help
