- How much for a good suspension setup??
- car burns oil any idea what it is?
- Post Pics of Door Pillar Removed
- ford winstar motors?
- burn smell, maybe clutch??
- 0902 & 0608 Ses Help
- newb question: stillen pop charger
- Just got an oil change and now it smells like burning
- Power steering
- Photoshoped Signatures-Comments please
- worth modding?
- Just got ES motor mounts installed on auto max without manual motor mount bracket
- What are codes 0312 and 0213??
- grinding/rumbling noise from rear of car
- Has anyone ever done the "Alarm Beep" mod??
- newb to site, but no newb inside...exhaust?
- y pipe
- where do u get the red tape for the tails???
- humiliating video
- O/D started blinking
- Replacing Exhaust, need some advice
- is she totaled?
- Pennies in the CD Player -- Don't have twins...
- Changed Front O2 Sensors -- Codes Returned??
- How to recondition the starter motor
- Intermittent 'cold' starting
- Knocking Noise
- steering wheel shake
- clutch noise with spec stage 2
- Code 0115 keeps popping up, 4.5 gen need help bigtime!
- are these coilovers anygood?
- F/S lug nuts and wheel locks
- swap to auto climate control mod....again
- Red/cleared my tailights, figured i'd stick some LED's in there
- Maxima Owners in Socal
- light weight battery?
- odd sound in engine bay
- what could go wrong
- where can i find the led clear third brake light ?
- pics please
- lets see some interior mod pics
- Rim Question
- anyone hear of akita wheels??
- Why am I seeing 4th gens with SE-R badging?
- Non official Y pipe poll (real quick)
- exhaust options
- How to tighten up steering?
- Quick Answer Needed (Timing Advance via Consult II)
- check out my minivan wheels. :)
- Bent my 19" Konig....any ideas
- replacing tps what position to screw it on at?
- Battery tie down and one more question..
- Updated Timing Chain Tensioner Question
- what spark plugs are you guys using?
- quick question
- Gold Rims
- Will 5th Gen Struts Fit a 4th Gen?
- engine fuse block prevents car from starting
- Lowered w/ rear sway bar?
- more questions about 9007 conv.
- Want a GD!!
- exhaust prices
- Nice rims, but?
- engine swap labor cost
- steel seal
- Good and inexpensive car cover
- tranny swap prices
- car won't start
- car inspection
- Gave my car lipo
- Touch Up Paint
- G35 muffler on a 4th Gen, yeah...
- strange noise
- Univ. O2 Sensor Wiring
- What cause alignment to get off?
- Which Wheels ?
- Are Ebay Hi-Flow Cats any good?
- 3.5
- tint
- ebachcoil install... need help
- CAI = MAP Sensor Code Trigger?
- 87 Octane = Check Engine Light?
- Lug nut stub stripped or something
- question?.. What does the white se...............
- greddy SP replacement
- Need help with speedometer?????????
- Which stereo fits?
- fise for side mirros
- Sticky stuff that on rear tail lights?
- Angel Eye Headlights
- Omg.. 98SE w/65K..... $6700
- Rear wheel drive 4th gen Maxima
- Manumatic??
- Center Console Bulbs
- Bad sound coming from left wheel
- Vq30det
- stero removal help
- Front Lower Subframe Bushings
- Fans busted!
- replacing stock y-pipe, plz help those nuts
- New Engine Or New Max
- Really Bad Starting Problem!
- Aftermarket Radiator Core Support
- Check out the LED TAILS
- Need Help! Eibach Coils & Ground Control Suspension Setup
- Guess what?
- 18"x8" Mille Miglia MM1 fitment? on gen 4
- Overheating Problem, NEED HELP!!!
- Diagnostic Test Ran. Showed 0413
- Guys with no power steering
- which octane of gas do i use?
- 00VI Write Up
- How much did you pay to paint Stillen kit?
- Good price for a 99 se....
- Boes Stereo
- gauge needles
- What do you think of these Mille Miglia rims on my car?
- Need some help on flowmaster choice
- Timing Chain replacement
- Yellow Oil
- tokico illumina kit help
- Reasons why not to go big (wheel)
- mevi
- I need some advice on what to do with my car
- Replacing Exhaust w/stock: What do the Clamps do?
- Best springs to get
- electrical problem
- Uneven wear from Raybestos QS
- can i install my CV axle myself?
- Started driving my 5spd swap, no speedo?
- Fixxed my car well sort of
- Bought a new intake what do u guys think of it?
- New Tailights and system
- Extended Rev limit ?
- The Better Shift Knob
- Udp Users Enter!!
- Tranny Flush?
- Symptoms of a bad TCM??
- Knock sensor replacment
- Headlight problems.. please try and help.
- Need help with auto trans.
- 95 Maxima GLE--Missing & Surging
- 98 white se 115k price??
- Anyone think i payed too much?
- Tire Question
- Quick tire question
- Air Bag Light!!!
- Tranny rebuilding kits?
- **HELP** Winding noise when i accelerate
- Parting out help
- 95 maxima with a 98 engine - vacume and sensor questions
- leaking antifreeze
- rear end squat question
- Bose stereo on 1997 I30t
- anyone have 5th. gen hid's in their maximas?
- Got in a wreck today (pic)
- low rpm's
- KONI Yellows
- Can Somone Run a Car-Fax ??
- Backfire in the intake?
- 95 engine - part out? Or sell as rebuildable block?
- Why me? .... (pics)
- Help with vacuum lines (and an introduction)
- Tokico Illuminas and Bumpstops
- FSTB inquiry
- Bypassing A/C Comressor
- Clutch master cyl?
- the crank up
- DynamaT
- Help I'm Desperate! Took It To Dealership At Last Resort But Even More Uncertainty!
- Extended rear shock mounts
- Fidanza flywheel?
- Car manuals on cd from ebay?
- Is napa gearlube recommanded for MT
- Dust Shield behind the rotor
- I'm not usually impressed with oil additives...but
- Home Link. Doesn't work.
- Strange noise
- power seat
- Interest for another set of exhausts to be made? Axle Back Exhaust is on with Pics.
- cefiro head light conversion
- Bad front end?
- Anyone with clutchnet 6 puck and red pp.
- Should I get a 4th Gen or 5th Gen? Biased opinions welcome
- A-pillar wind noise
- Wierd Oil Leak...**PICS Included**
- Tire Size
- rpm question
- Amber corners not matching bumper lights? - paint them! *PICS*
- Getting power to my new power seats
- 5th gen clutch, SS lines -- very satisfied
- !!Antifreeze LEAK!! HELP!
- Touch-up Paint?
- I think I fried my alternator...or is it the starter?
- shorter steering arms
- Horspower rating for 4th gen max?
- Need iPod help (posted in audio section but no one helped!!)
- Exhaust hanger/ mounting hardware
- Exhuast Question
- Just got into an accident
- Starting Issue....
- would this navigation work in a 4th gen
- idle problem, power loss issue, tps?
- Clearance blue or amber bulbs
- LED Interior Progress
- hit the gas, Than it starts
- 99 Cali-Emissions | Stalling/Bouncing Idle.
- P0135, again?
- Fuse Locations
- The best way to gun an auto is to...
- can 20" wheels fit on a 95-96 max?????
- lookin for brembo cross drilled ! J30 ! rotors
- Another Alternator Question ...Maybe
- Headers and drop questions
- wheel hopping? bouncing?
- Hood Pins installation?
- vin check please anyone?
- Lets see your interior pics!!! 56k no way
- weird sound when trying to start car
- two tone leather
- How bad is it(auto trans.)
- Lightweight Wheels = Good?
- Bose HU AUX Input help
- 5th Gen struts on 4th gen
- Silvbania Silverstars...Mod req'd??
- what happens when you go WOT?
- Replace weather stripping?
- megan racing catback?
- Tail light problem
- Should I get the strut mounting nuts from Nissan, or will Hardware store nuts
- Help on Installing HID
- Bose Tweeter Removal???
- Next Mod
- Car rolls when engine off and in gear.
- Maf, Immobilizer??? Wtf Is Going On With My Max?
- No rear Sway bar!!!
- Manual Steering Rack for the max?
- Wheel Bearings while doing LCAs?
- REPLACING - ANTENNA mast Help :)
- Just when I thought that nothing else could possibly go wrong...my ebay axle breaks
- Cattman RSB fits both 4th and 5th gens, right?
- Coolant leak, possible water pump?
- For those who are lowered - FSTB?
- 04-07 CrankShaft Position Sensor
- Lambo doors on a 96 max se
- RPMs Problem
- vb mod ?
- Video: Maxima vs Skyline, Mitsu 3000GT, Type R Integra & More
- whos max is this
- Alternator
