- wood or aluminum dash kit
- Power steering and Acc belts both shredding at the same time?
- Where to buy
- I need help removing Timing Chain cover
- Body Kit Instalation Help!
- can any one help trans
- (belts?) Not for whipping
- steering wheel shaking
- white smoke
- starter same as 2000 model?
- Codes 0903 and 0705 EVAP need help.
- Code 0215 EVAP Vent Control Valve Closed
- Exhaust Question
- skyline tailights
- Regarding speed limiters
- clicking in engine bay at first startup
- High Beam Light
- Weatherstripping
- Has Anyone Tried Swapping 98-99 Digital Cluster in 97?
- What bulb to use for map light?
- What guage wire to use for blinker rewire?
- Remote start on 5spd installed, but only works when clutch is down :( ideas?
- Rear sway bar thickness?
- Mevi
- Anyone have pics of the one-piece headlights???!!!
- directionals does not cancel
- Speedo light out!!!!
- Car is running so rich that it turns off!
- Car alarm on stock Keyless entry?
- Does anyone have LED turn signal lights or break lights on their maxima?
- CV Joint or just the boot?
- Finally road raced my car!
- AEM bypass valves
- Exedy Clutch
- Help on Cold Air Intake Installation 98 Maxima SE (where does this plug go?)
- Has anybody used Adhesion Promoter to paint their dash?
- automatic transmission computer location?
- please help
- Uneven Brake Pad Wear
- Stereo installation help!
- NO START (Yes I have searched!) HELP!
- Rosewood Maxima Pictures???
- lights gone out
- How to get rid of wheel hop?
- Finally got pics of my Car on here CHECK IT OUT
- Fuel Injectors
- EVAP canister purge volume control valve??
- Intake Air Temp Sensor
- need help to choose which shocks are the best to get for my max asap
- 0401 code
- Exhaust Installed Today......
- 97 lights on my 95?
- need help with two codes regarding EVAP
- Right headlight out yet HIGH beam works?
- Having a Hard time Starting (grinding noise)
- MY CAR SHOULD BE IN THE NEXT "GOT CHOCLATE MILK" COMMERCIAL! brake problems !
- web pics of underhood parts location?
- Drove max with ACT clutch, beautiful
- Does my Maxima have an OBD II?
- Breather Filter
- Apex World Sport Exhaust keeps rattling
- Will the 18" G35 rims fit my 96' Max
- leather interior?
- Transmission problem?
- Officially a member
- MEVI installation/ for those who have it
- Sway Bar
- Need a New Keyless Entry Remote...Will this work?
- Tried to install rims, Problems with back Rotars...
- Made a grill, and changed clock/climate contol color..*pics* some problems :(
- Port and Polish & Bore and ReSleeve
- EGR system question ? How much to replace ?
- My Ebay Body Kit
- removing pulley off the AC compressor....any difference?
- set off my alarm while diagnosing ECU!!!!
- Wheel lock removal without the key
- PCV valve location????????
- Need A Lot of help acc belt tensioner.
- ABS Sensor Q?
- pure sex *drools*
- Need Help W/ VIN Numbers!
- seat removal
- Cylinder 1 misfire - Electrical Short?
- Where is Camshaft Position Sensor (POS)
- HELP! Gas mileage sucks with auto tragic
- The best brake rotors
- arrrg! car won't start
- Don't Shoot!! Search down...
- Diagnostic matrix
- Thinking to sell Maxima, what do you think I should sell it for?
- Pic of hacked airbox?
- car got broken into....
- overfilling transmission
- 1 quick question about alternator squel.
- suspension problems I NEED HELP!!!!
- Pathfinder TB
- Shocks for a 96 GLE
- I hit a deer last night.
- Help intake manifold.
- GRRRRRRRRR!!!! Need new iginition coil A-G-A-I-N!
- Re: Suspension Question
- gearing difference between a 5 speed and 6 speed
- 97-99 JWT intake
- if you have pics.....
- Suggestions from the org!!!!!
- When rewiring the turn signals to stay on with the parking lights...
- Short Circuit?
- Will 99' floor mats fit a 97?
- lights
- What's this??? I dont know how to describe it...
- Intake
- Who does 5spd conversions?
- Red/Clear's for my 95 SE?
- Leather seats
- Any of you been pulled over for cornerlight mod?
- Nissan Maxima 1996, when lowering require camber?
- Engine rebuilding...
- Eww That Smell!!
- Brake shims
- these real red/clears tails?
- Both front o2 sensors the same part #?
- Just bought a second underdrive pulley
- Anyone has LED bulbs in their tails?
- Is the loose cat heat shield rattle intermittent or constant?
- Feeling the Road in my Gas Pedal ??
- What dust boots do I need...
- Wierd Humming...
- I'm back......
- Headlight Conversion. Taillight Conversion, & Max Speed Problem
- Car won't start...makes clicking sounds
- 96 Tachometer goes wild
- AC probs
- I hate the snow
- Not sure if it's a bad ECU or Knock Sensor
- Sqeaking Belt....Should I Replace It?
- OK, quickly...what setup would YOU go with?
- need help leaking power steering fluid
- Tech's PLEASE HELP!!!
- Unorthodox racing UD Pulley kit??
- Seatbelt Warranty????
- hard transmission shift 1 to 2nd 41k..under warranty?
- help! mileage meter stop working
- make one touch windows
- Gauge rings
- max speed prob.
- sprint springs
- Check out these clear tails on ebay.
- transmision problem
- Intake Performance Chip
- brake pads
- Fog light problem...probably a short
- Bulbs burning out with brighter clearance light mod?
- hawk brake pads? rotors?
- Help me, car won't start.
- Rear wheel hub cotter pin size
- Normal temperature range for engine coolant?
- Just took a trip to Advance Auto Parts...
- More specific clutch bleeding q's
- ECU not ready for inspection
- modified stock airbox ?
- y- pipe
- Got my wheel studs and lugs!
- My bad auto body experience
- recall alternator
- Does anyone have these gauges???
- I need Instructions on how to use hoseclamps to align an OBX-H
- What is the easiest way to remove a decal?
- Bad Axle
- Just had a crazy Idea!!
- Post pics of your center dash
- chain of reactions = very bad night
- just got knock sensor, not sure if it works
- Wheel Question....................
- sound after hard breaking.
- more pics of obx type h catback installed?
- Throttle positioner changes
- Hi Flow Cat- lots louder? Anyone got one?
- 95 GLE Makeover Project completed [photo details]
- Maxima Realiability
- Ebay intakes
- What does your title say for model? 95
- show pics of your front lights
- My baby is hurt!!
- Maxima Compilation
- Bought a new Z: goodbye to the org :(
- how hard is it to find 99 gxe reverse indiglo gauges
- Need help With a new project!!!
- Gas door hard to release
- my brakes get a little tight every once in a while has anyone had this problem?
- Heat With No Blower
- Lubing
- Is there a temperature/drop relationship?
- Help! Need Fidanza Flywheel FAST!
- O2 sensor how many??
- My last mod until Spring '04....**PICS**
- check engine light, ECM, low idle
- ecu= undefined???
- Do you think this will fit in a max?
- Aluminum dash kit for 95 maxima
- Paint my car...am i nuts..
- Engine dies under load
- ivelweyz sucks **** all day long
- Speed up
- I need to speed up
- What the F is in the A-pillar that rattles?
- Bad Tach and Spedometer??
- Where can I buy gauges that are in KM/H???
- Maxima.org 2004 Calendar...Would you like your car to be featured in the calendar??
- howcome 95's have this part on intake while others don't?!?...
- Daniel B. Martin
- Ghost Code?
- making leather seats
- Brake shim help
- most gains ?? weird when over bumps accelerating help plz! ( =
- hood strut
- steering wheel hub
- valve cover gaskets
- "No you didn't," Yes I did. Repost.
- ??Popping noise when coming to a stop, any ideas??
- foglight brackets
- Misfiring bad..Please help
- Recall #P81520 96' "Emissions System Componant Replacement"
- I want 13's N/A, help me decide...
- anyone have a pic with a maxima.org window banner?
- WTB: Passenger Side Fog LENS!
- anyone with audio link to "bees in a can sound" ???
- where can i buy a apexi ws catback?
- My New Custom Red/ Clear White Tails
- 1995 Maxima
- bose system
- revenge
- I've searched - Please Help!
- different weird noises from y pipe
- All knowledgeable people I need help with TCM code...
- Who sells the best carbon fiber hood for the money ?
- wiper transmission
- Torching off stock exhaust. What sz bolts to replace old ones?
- PPL WITH OBX TYPE-H exhaust READ THIS
- Oxygen sensor went bad.
- wheel nuts size
- Hi guys
- Will a 97 stock b-pipe fit a 96?
- Narva Gold H3 fog bulbs burned out after 6 hours... defect, or problem with my car?
- Hawk break pads
- Corner lights
- Don't laugh
- Help! Maybe alternator problem...
- Lowering with a kit
- Anyone with JET ECU?
