- Help Multiple Cylinder Misfire
- MEVI is on
- DIY Intake
- Garage Door Opener on Visor
- Power seat repair
- Auto Climate Control Conversion
- Doesn't want to start!
- carbon fiber hoods?
- Lug Nuts
- Weight Of Your Maxima?
- 3rd brake light
- 4th gen better then 5th
- 95-96 taillights: euros or red/clear???
- Acceleration
- I Got It, Got It Got It Got It !
- quick mevi question
- A list of my Max's mods and the need for your suggestions...
- TOKYO xtreme racer 01 has a maxima in it...
- Question about Red/White Taillights
- Side Marker Light Wiring Question?
- Indiglo Needles to go with Reverse Indiglo Gauges
- Greasy wheels
- HIDs keep burning my wire harnesses
- heads and tails (lights)
- MOMO F16 Shift knob PICS?
- Cosmetic questions...
- finally got pictures
- best spring / shock setup out there??!
- Please Help!!!!
- INJEN intake WHOA
- Wiring LED windshield washer nossles to blinkers
- 95 Maxima SE Concerns
- keyless entry just stopped working?
- Sunroof Install help
- help! brake pedal still soft after replacing rear pads
- NEED PICS of INTRAX springs on a 98 max with 18's
- nissan 6sp conversion
- WHO has or seen ANGEL FOGS on CUSTOMMAXIMA.COM?
- homelink visor
- Has anyone done an I-30 auto. shift lever mod on thier auto. Max's?
- K&N or JWT????
- auto climate control...
- 95 SE - worth buying?
- Airbag Woes (Long)
- RAIN SUCKS....crashed the Max.
- car accident = new parts
- JWT ECU in a 1998
- How to change PS Pump Belt?
- Diamond bumper lights
- Moonroof not closing
- 95 SE A/T - maintenance problems?
- Hood Shocks
- Max alternator recall!!!!
- Cold air intake
- New struts needed
- Is there a maximium length that a muffler can be?
- Hiss noise when key turned to on!!!!!
- OBX Cat Back...
- Trouble with ECU!!!
- ECU problem
- Need your help
- Knock Sensor!
- painting stock tails on a 96
- Gas mileage question 462mi on tankful
- car fax report
- research #2: need ur recommend settin on AGX paired with sprints!
- Wimpy Maxima horn
- How many different things can cause fluid to not come out of WW nozzle?
- 98 Max Vs. 02 Sentra SE-R?
- where to buy y pipe wrap?
- Upgrading injectors on MEVI'd motor
- Exhaust Suggestions
- Power Antenna Broke
- brake light on helo
- RSB and O2 question
- What kind of intake do you use?
- question about what to expect in a 1997 maxima with 120000
- Oem Foglights
- Ignition Switch problem??
- Eibach to Intrax
- Eibach vs everything else
- SO.........How does a Y-PIPE sound???? I'm afraid it's not for me!
- coil over question OBX VS. Ground Control
- Swapped my Front Blues for a set of Illuminas
- HIDS from Freddy? (97GLES)
- What causes an engine to lose power and how would you restore it?
- foglight problems
- ACT or Exedy. . and install Q's
- Stillen Body Kit..
- Max endures her second attack
- Waterpump - DIY?
- Pics of 4th Gen Black Interior with Carbon Fiber dash kit?
- pics of anyone with maxspeed springs
- Where can I get coil packs ????
- Checked coils, all checked out fine, did I do it correctly?
- Changing Knock Sensor
- FAN BLOWER not working
- Do engine mounts wear out?
- car dies in the morning
- Knock Sensor Installed finally!
- How dumb are Nissan engineers?
- Another Knock Sensoe Question
- rotors
- How much space should be between clutch pedal and floor?
- Another Interior lighting question :-)
- codes 0510 and 0707; help.
- Need help removing ignition coil electrical wire!!!!!
- IAT or manifold air temperature sensor?
- Clear Corner Light doesn't work - bulb is fine
- Gas mileage getting better and better... WHY??
- Knock Sensor reading
- Why y pipes?
- Max Alternators Cost How Much??????!!!!!!!!!!
- 95-96 always-on cruise- Is thare a how-to on this?
- final idiot question re: 95 SE
- high miles
- blower resisitor
- help my guages wont move
- looking for pics (couldn't search =T)
- Removing headlight......
- indiglo guages
- S5 Sport Chrome grill
- eibach and kyb gr2's
- Filter and adapter plate
- Where to buy a 2.5 inch cat. converter?
- Strut tower bolt broke
- Install coilovers
- VI back on Courtesy website
- cleaning the engine bay...
- Re-wiring Blinker and Corner
- HELP!!!!!! Mechanics sux
- Regarding rear defrost button and hazard button.
- Anyone hit 150?
- Before a moderator blocks this...OD question
- Cutting Eibachs....
- Strut Life
- Beige owners- Pin stripe or no pin stripe?
- Midas Brakes $500
- Correct type of lug nut?
- Sylvania "Cool Blues" suck!
- 95 Max, rattle in front suspension.
- Cant pass emisions. 110 octane work?
- my car doesnt want to start....
- KS RE-LOCATED! =D
- Wheels rubbing splashguard. CAI?
- Installing Fog Lights GLE
- reseting the ECU ??
- new clutch acting up??
- blinking O/D light?
- anyone have pics of a superblack w/ redlinemax eyelids??
- 95 and 00 cat. the same?
- Installing a new rear wheel hub bearing assembly - advice?
- question on correct rpms...
- How Many Miles is too many for Mods
- Should I spend $60 on the KYB bumpstops???
- quick / about trans? 96 & 99 non locking
- Help! Funny Sound From Engine!
- Nissan Parts?
- NOTE: Clear lights on ebay: 22$
- Maxima whoas
- Air bag help
- Y-pipe hissing - Suggestions?
- Saw a Max with R32 headlights this weekend
- Ride type?
- Car won't Start
- Car won't Start
- replaced timing chain before 65k???
- Auto not shifting properly after 3000 rpms
- failed inspection help!
- Pic of NATICK meet
- Broke my intake!?! (Weird post) Hurry Frankencar!
- First Car
- ~corner lamps~ feeling naked
- Y pipe/ test pipe installed now SES light??
- front rotors
- Will this muffler fit? Any opinions on magnaflows?
- Warspeed Y-pipe
- Cam gurus..I've got some questions.
- Electrical Problem With Tails!!
- Removing The Pop Out Tray
- H&R vs. Progress/B&G Springs
- any sound clips of a g-reddy cat-bak
- Need pic of budget Y-pipe!
- tail light
- you know those grilles that....
- hollowing noise from front?
- Saw – CAI
- does anyone have megan racing cat back
- Battery or starter problem?
- Pillar trim and sunvisors questions...
- max speed cutoff
- Power Window Switches Color Change?
- Car dies with air filter on....??
- How much is this maxima worth ?
- Rear brake replacement
- May have bad O2 sensor.....?????
- Newbie saying "hello" & has a question
- 97 Stillen FSTB fit on a 2000?
- Tachometer hookup?
- Spring Rates
- brighten my '97 clearence lights
- Performance fuel injectors
- Carbon Fibor Hood
- interior light button on my remote
- WHERES THE interior door light fuse?
- Do you get extra attention from cops bc you have an aftermarket muffler?
- Knock sensor bypass q
- CAI giving me problems
- NATICK, MA meet was great...
- Cruise Control Always On
- Midpipe
- will all engines fit a 5 speed?
- Extra Parts on Courtesy Nissan MEVI???
- $15 intake from Lowes
- Did i see a max in the new movie with Jackie Chan?
- Where is the Water pump on my 97?
- weapon R coilovers installed on 95 5 speed with 365K miles !!!-Pics
- for $5000...
- 95 maxima se specs
- exhaust
- 99 Max Short Shifter Install???
- Altezzas
- Variable-Intake Runner Length Manifold Kit (VQ30DE) - 1995 to 1999 Maxima
- Rotor questions/recommendation please
- what is module in trunk?
- 4th Gen with Racing Hart C5s?
- pics of 97 front bumper with 96 grille
- spring/tire selection
- Got 2nd at the import/sport compact drags.
- Cleaned the throttle body..now I have problems..please help!!
- I just found out my rear caliper have been DEAD for at least 3 months...
- Moaning
- WTB knock sensor
- rust spot under the hood
- '96 Maxima Timing Belt or Chain?
- Does anyone know the voltage of our guage bulbs??
- need help!
- Progress and KYB GR2
- '98 SE hand-down now w/ over 100K, what do I need @ this point? .. & then some
- ECU's
- lowering car want to know how hard it is to do myself
- 1997 Maxima SE, is it worth it?
- Truly a unique looking Max!
- Cylinder Head bolt removal...
- MEVI - not working :(
- Unusual Knock Sensor Question...
- Stalling, and Knock sensor ecu code
- motor update.
- Painting Stock GXE Hubcaps...help!
