- dumb question
- adjust instead of grinding?
- help removing dash on 98 SE
- 2 MEVI questions - wire size and torque spec for manifold
- New Things for the Max
- what is the BEST lookin tail light mod on a 96'?
- anybody else hate their stage 2 vb?
- Stumped? idle issues
- Where to buy H&R springs?
- special tool for axle seals??
- epoxy like smell.....
- Four Door Sports Car Stickers
- No luck finding parts for nosemask at dealership
- What Brake Combo ???
- 2k2 steering wheel and mirror controls
- Trouble Code
- i30 rear headrest. any have screens on them?
- What was your First Mod?
- How to Chnage spoiler light Bulbs
- Coolant Temp Sensor
- Bomz Cold Air Intake
- This will be my new exhaust set-up....
- Flywheel and power gains
- removal of stock intake
- Putting a new engine in the 4th gen.. What else can I replace?
- Hesitaiton during cruising
- 97-99 grille on 95-96 bumper
- Hardwiring Aftermarket Fog Lights
- CEL at start up?
- Car Color
- Reseting the IDLE SPEED
- What corner bulbs give off white light, yet don't tint the corner light blue?
- broken cruise control button...help
- Removing Back seat
- Cross-Member Bar
- how do i post pics?
- need help...
- 95-99 Or 99-01
- Tranny Troubles please read
- Just got my maxima :-)
- Speed limiter
- How Does This Nissan Recall Work?
- Odd sqeaking noise from 97 Max after gear shifting.
- corner comparison
- only driver power window and lock working
- engine mount
- Check Engine Light not working
- ? about Intake Air Temp. Sensor
- Eibach Springs Question
- Tinted Window Advice
- Can anyone recognize these springs (pic inside).
- M.a.p Sensor Price!
- how long for your stillen kits to come???
- anybody ever had to get their locks changed?
- Flashing Airbag Light
- Clutch pedal dropped
- how to check 5-spd gear/tranny oil?
- 4th Black Gen Spot ( Sunrise,FL Japaneese Inn)
- I hate big wing/spoilers
- how low is ur car?
- Rack and Pinion
- Ecu
- Gen. 4 Recall Info
- Clear Bumper Lights install help
- Sprinkler Sound
- Knock sensor testing HELP
- vq30de
- Shocks struts question.
- Popping while turning - only when it is cold though
- Clear Corners
- Chocolate Milk In Engine
- Cefiro Headlight difficulty??
- Dash Trim Removal
- Procedure for Testing Evap Vent valve..?
- Bose to not bose, possible?
- Emissions Fail NOx
- Stone Racing Users Step Inside
- brake problem
- Skyline Taillights...
- Crazy Erratic Speedometer
- Tanny help
- Silly 02 sensor question
- To fog log, or to not fog light, that is the question.
- humming sound from wheels... bearings?!
- newb troubles
- Custom Turbo Project. Intrested Step in.....
- Sensor on Cat?
- Light Bulbs ???
- ABS Light and Dimming Dash lights Question
- istallation of stock 4ht gen spoiler
- Help: knock sensor
- Where to wrap the exhaust wrap- for sound reduction
- bogging problems?
- CRACKED Engine Block?
- Lowered Pics....Tryin this again
- Amber Turns
- Bose head Unit?
- ECU reseting
- 02 sensor
- y pipe and headers for 95 max?
- 1996 Maxima Trans Problems
- Fuses HELP!
- Belt NOISE!
- My new exhaust setup w/ problems
- replaced cv boot/axle, now abs light?
- Whoa, STALLING!!
- Possible Tranny leak/ Redline MT-90 Fluid
- Antenna - Goes down, but not up.
- Anyone paint their rotors?
- egr valve 0302
- jujeracing.com shift boots?
- Before/After pics of lowering job---56k KILLER
- Black Rims?
- Brake calipers interchangeable?
- LEDs too bright? Variable brightness exists...
- Difference in NGK plugs installation???
- Help w/ Throttle Position Sensor
- obsessed?
- Anyone done this?
- is this suppose to happen
- How much to install springs and struts?
- Alarm Beep
- wierd ..shut off! how?
- 1996 Max OBD ll location?
- Help with my idler pulley
- Polyurethene Gasket for Strut Housings
- Autoo tranny problem
- ecu upgrade question for 97 maximas
- Need help w/ part #
- alternator amps? stock vs. H.O. (for Cold Weather Package)
- Taillights Led's??
- Wheel Moves from side to side
- Engine Internals
- Help, need the Maxima Bible site addy
- Maxspeed springs....any failures for anyone?
- Seats in 95-99 maximas
- check engine light problem
- How do you resolve understeer?
- Is it the Springs or Struts...
- Back 2 Stock muffler??
- Purchasing a Maxima via public auction...
- transmission is died
- interested in TRADE .. 99i30cluster... for 95-97 cluster..
- Shocks/Struts Question
- Painted pinstripes + Easy Off = Too good to be true?
- Led Research, Mods, Questions, And Hookups. Step In
- Charging problem, Car loses electrical power intermittantly (long)
- High idle (~1700 rpm) after engine warmup on 95 SE
- What motor?
- Help?
- I Need To Know Fast!
- Antenna relocation
- 6th gen mufler on 4gen?
- Sup all - question about sunroof.
- illumina/ S-tech question
- car jerks while driving + loss of power
- striped ball joint stud
- Everyone that is lowered Please read
- Red line
- 150,000 check up?
- P1446 Code
- Squeeking!!GRRR
- benz style remote control
- Did all 99 SE Limited Max's come with leather
- Excel h-50 rims?
- :hyper: Ordered my....
- Heeeere's yur sign? LOL
- Remote Program HELP PLEAZE!!!!!!!!!!
- Strut boot
- Strut Dust Boots
- just redid climate control leds
- stalling
- P1105 @p0325
- muffler WAY too loud, any suggestions?
- Used motors sources..
- 1999 Maxima lights
- Tokico Warranty?
- Trunk lock not working..
- torque converter
- MEVI vs VI
- 96/97 Headlight hybrid
- Maxima motor
- Exhaust help
- Must one absolutely get an alignment done after dropping?
- TS ECU with 7000rpm limit should be here tomorrow
- running speaker wire
- where do i find red vinyl for tails? plz help
- I'm trying to put an i30 auto-dimming mirrow in my max -- HELP!!!
- My OBD II is not working
- Diff. Whinning
- pedal vibrations...help
- New *Pics* Stillen lip / HiD's
- O2 hell
- Just had all of my motor mounts replaced....
- New suspension, same problem
- How to replace engine seals
- How much trouble is it to fix. Help Plz!!!!
- Help Please!!!!!!
- ignition/ lock problems
- O2 Sensor Fuse???
- Help with EGR
- good parts site.ca
- dashboard removal question
- Cruise Control Problem HELP
- 98 Max Conversion 2001
- in-cabin filter
- Need Help with Auto Shifter lockout.
- Double UDP question
- A picture from this weekend**
- Replacing the clock = Ripoff!
- Adjusting Cefiros
- So that was what that noise was from...
- PICS OF 97-99 non-OEM FOGS..?
- Nissan Alternator Recall Reimbursment (HELP!)
- Need Help finding Upper/Front Strut bearings
- minor accident, expensive repair!
- Throttle body cleaning
- Exhaust has Exhausted me......
- Sunroof wind deflector-advise wanted
- Basic Tune Up Questions
- broken and stuck antena
- Missing oil??
- why doesnt my radar fit in the cigarette lighter?
- Does anyone have; fidanza w/ spec stage II?
- Valve Job
- How much did you all pay for your stillen kits???
- 60K service on my 99.......what really needs done?
- I think my diff. bearings are shot..few questions
- 5spd grinding.....?
- Changing bumper lights to parking lights and corner light to turn signal? Help.
- Franken car Intake
- PLZ help ...need help ASAP
- The New Guy
- very strange window switch problem, need help!
- Pic's of 4th Gen w/ 17" G35 Sedan Wheels
- *%&#^ passenger side axle piece a #(*&)@
- Cheap Muffler on Ebay
- help!!! Brake light + Battery light on!!!
- Pulled new codes today
- max quest HELP PLEAZ
- Will These Fit my 97 Gxe?
- '95 Maxima Audio Problem
- CV Axle
- exhaust sound clips
- Car Got Keyed!!!!!!
- lcd+ps2 installation
- My car remote started itself twice this evening!!!
- Anyone know if the 240SX FSTB fits the A32 Maxima ?
- why you shouldn't let charcoal95gxe get drunk
