- I want to REALLY reset my ECU...
- This a good deal?
- Will a 5 x 4.5 (114.3), 18" x 7.5", offset +42 rim fit?
- Installed my leather interior! Pics!
- Check out this thread @ clubrsx.com
- People with the Type S rear bumper....
- how to fix loose shifting?
- Where do i get Filter cleaner ?
- Bad radio reception with aftermarket headunit?
- STARTER PROBLEMS!!! pleeez help!!!
- Budget Y-PIPE???????? VS. stillen/cattman???
- what should I do with the MAXIMA on the trunk...
- Why do people lie about their cars? Just venting!
- Need help with Passenger Side Driveaxle
- This is why I am glad I drive a 97
- where can i get a quality carbon fiber hood?
- Clutch (ACT) seems to be slipping with low mileage
- suspension question
- Spark Plugs
- Wheel alignment
- What lube are you guys using on your RSB?
- momentary loss of power......alternator?
- Funky idle
- Got a new scratch added to my collection
- Vibration when accellerating
- This clutch decent??
- new guy here...
- I just purchased a '97 Max!
- What should i Replaced when doing my differential bearing???syncro??
- grind noise going into 2nd gear when its cold?? trans work?
- where can I buy gunmetal gauge rings?
- Can foglights be installed on my car?
- Discovered something cool about our gauges....
- racing wheels
- anyone have pics of 3M CLEARGUARD installed on their car?
- i want to paint my spark plug cover
- Airbag question 95 Maxima
- My air bag light is blinking. How do I stop it.
- Jumping R.M.P. Needle
- Manual or Automatic
- Maxima 5 Speed Max Speed
- Canadian Newbie
- Need help choosing the car
- Speed Control
- Speed Control
- tick sound
- the max won't start!! HELP
- Anyone know exhaust shops to do mandrel bends?
- which rims ?
- Stiff Seat heater switch
- Part # guys.......help
- which fuse is it?
- Problem with rewiring corner lights..
- Car is vapor locking.....help???
- window tint
- Strange Idle
- drive belt problems
- Removing emblem
- Clutch squeaking. How to fix?
- Airbag clockspring
- Suspension Question
- Oil Viscoity Question
- tired of maxima
- Budget Y Pipe? Where is it?
- anyone have pics of gen 2 altezza lights
- my Corner Lights are very strange!!!
- undefine ecu code...
- "bees in a can" fix
- Need desperate help in getting max to start : alternator changed
- Removal of Side Guards on Doors
- guys what the he!! is this???
- 95+ to 97+ bumper swap question
- 4th generation frankencar intakes!!!
- I saw the custommaxima.com dual exhaust setup the other day
- '95 Falling Apart?
- Installing indiglo gauges--how hard?
- type 2 brake light
- Nissan Maxima Intake Sensor Mod
- problem with max
- 99se First and Hopefully last Problem.
- Clunking Noise When Turning
- is there any performance headers or cams for 5 speed trannys ?
- Which is better. a used tranny or a rebuilt new tranny ?
- installed mid pipe, still having problems with cold weather starts
- 5th generation rear strut bar will be perfectly fit on 4th generation ?
- HELP: Turn Signals Not Working!!
- oldest 4th gen
- Anyone Have Pictures of Drilled Rotors MOUNTED ON THE CAR???
- system moving ... please help
- replacing water pump and im stuck - please help
- auto tranny ?????
- Anyone with PR CAI in winter location please look
- finally some Pics of my Baby
- ES FSB bushing information...
- To buy or not to buy
- Gauges on TV Screen, Is it possible??!!??
- HKS or Stillen Muffler??
- gauges
- Strange sounds at high RPM
- Where can i get a...
- all sho no go: resonator question!
- Dressing up the Engine. Wire Loom?
- Cone Intake that Hisses!?
- Help Needed....
- 99 headlights on 95? any fitment problems found?
- I have a problem with my brakes! can you help me identify it?
- Exhuast
- simple question on maxspeed springs
- pocket tray
- Can't find fuse
- cefiro headlights and emblems?
- quick question about bulb # on License plate rear
- R34 headlights
- I found the perfect exhaust!
- i30 Owners....kinda long
- D.I.Y. Angel Eyes........
- 1995-1999 bumpers
- Service Engine Soon code 0214 problem solved.
- universal hose kit
- any i30's?
- Jackstands
- odd sound when put in reverse
- Good price for Maxima 96 Keyless entry fob
- Front Suspension Bolts
- gold
- engine "hiccups"
- Ontario Drive Clean emissions test problems?
- Is it possible to get BOTH a 7-1 AND a 6-4 code?
- Hood mod
- 5th Gen Gear Shift Fit 4th Gen?
- Gas Milage loss and Ignition coil problem
- 95-96 conversion 97-98
- OEM replica bumper
- Peep these rims.
- Need to borrow Type II wing, easy money!
- Front End Noise
- Resonator/B-pipe question
- Update: Suspension rattle....
- 95/96 Red/Clears ?
- VQ20de = VI ?
- throttle body, and MAF sensor
- My rear view mirror sucks!
- Size of nut on rear wheel hub
- automatic climate control problems
- Rear speaker - Worth the effort?
- vehicle speed sensor....
- I may need to reset ECU
- Boggs at around 83MPH
- KUDOS to Maxima.org - blower motor problem
- Quietiest Intake
- Where do I get Corner Marker Lights ??
- engine revs high suddenly
- What does Differential Bearing Noise sound like ??
- need some bulbs that are kinda yellowish
- Bumper Lights
- Possibly buying a 97 5spd maxima...need some help!
- to shave or not to shave
- MEVI install help.
- 4th Gen MAF Adapter
- Road noise
- Grill & Headlight Removal on my 97SE
- Timing Belt
- Max VS VW
- JeremiahMaximaSE's Dual Exhaust/Skyline kit courtesy..Custommaxima.com
- Some pics of my Max.
- Wow, MEVI is awesome for top speed!
- warpspeed substrate cat. really worth it?
- Anyone have this problem with Warpspeed's B PIPE?
- Ward's Engine Opinion
- exhaust opinions
- When I replace the faulty coil pack....
- Where can I get a blue PRCAI
- '96 15" wheel (rim) bolt and bore size needed.
- My factory alarm going off by itself
- power steering pump giving out?
- what happens when you hit the rev limiter?
- Get a 2nd resonator installed?
- Austin area MAX enthusiasts!!
- pics ofcarbon fiber door handles and pilars
- Limited
- Just got car back today....now more problems.....
- finaly pic of my baby MAXI
- Where can i find rims or hub caps?
- Fuel Pump Cut-off idea?
- My 99 max is sick. PLEASE HELP ME.
- Has anyone tried to put the beep on the alarm?
- Q about fuel light
- Where I can buy WILWOOD Brake kit for Maxima ?
- Problems getting in garage which stands below a down-hill level,what are my options?
- need help install VI pls help!!!!!
- 97 Tail light Mod
- Oil Temp Gauge
- Where to get hood locks?
- Different starting problem........
- piaa ion crystal fogs/headlights
- hard to shift...
- Advice needed.....>>>
- PIAA extreme white plus
- PIAA wiper blades?
- Bose Display and Clock fade in and out???
- Got knock sensor code...
- whats the nicest 194 bulb?
- maxspeed and h&r springs
- g35 wheel ??
- alarm beep mod question
- AC/Heat Blower - Not working in positions 1,2,3,4
- What is a better starter?!
- Gen II Altezzas--- What happens if an LED Burns out???
- 97 Pebble Beige Metallic Maxima w/Gen. 1 Black Chrome Altezzas
- Is there a way to test for heated mirrors?
- what do you guys think of this...?
- How bad is it to not have Dust Boots??
- What do you guys think about this Nissan logo?
- Engine coolant temp sensor...
- trans problem
- Tranny Question
- The knock sensor only has one wire?????
- 1996 Maxima dies after start up
- What Headlight Bulbs Do You Guys Use?
- Alternator recall on 97-98 maxima
- front bumper q&a
- Engine Vibration, need opinion
- cold weather screech during start
- I saw this pic on Custommaxima.com...
- 5sp Engine Mounts
- Questions about aluminum dash kits
- Killed my 95
- Installed B&G and Tokico today
- wheel hop with ACT
- my first autocross experience...
- 17" wheels vs factory "acceleration"
- Was about to order VI, now dyno proof shows no gains in 1/4, now what?
- Anybody have problems with lowering...I hear these noises
- Starter Question
- KYB Bumpstops
- Testing the coil packs
- Interior Blinker/Directional/Green Arrow things
- Top 6 Reasons I chose not to buy a `95 Maxima that I had hoped to buy today
- pics pics pics finally!
- Nice wheels on ebay..
- I've come to the conclusion that I'm one of the only ones that...
- A/C Compressor Troubleshooting help
- Transmission upgrades and 1/4mile times
- Where and what to buy to fix speedometer?
- Which fuse controls the antenna motor?
- 03-02 EGR system Hi/low flow what to do?
- Worth of Exhaust Systems
- Dyno on stock 4gen max??
- Brake pads
- New Full Exhaust
