- i wanna vtec maxima!
- Well, tried out the VI to the track.....
- 2 General Mod Questions! HELP!
- Where to buy KYB/AGX cheap and B&G's?
- Got my new wheels and tires in the mail from wheel max
- Field SFC Installation Help Needed
- Konig Tantrums:: cheapest place?
- CV Joints
- 0701 - Multiple Cylinder Misfire
- info for those who need a new a/c compressor.... read on..
- lots of questions/problems PLEASE HELP!
- 99 Maxima factory car alarm
- Konig Tantrums or Enkei Rs6. How do i choose?
- shades of blue on 4th gen
- still have KS problem
- where do I order??
- Opinions needed!
- ACT clutch glazing?
- questions about my new engine??-
- what does VQ stand for anyways??
- Quick & cheap B pipe mod
- Maximum Tunings Body kit Updates???
- How much to lower if planning on getting body kit and...
- half on gen II attezas
- HELP HELP! 5 speed converters HELP HELP!!
- Where Do I Find These Parts??
- preventing rust on y pipe and cat back
- LSD vs. No LSD
- Improving Mpg
- The ongoing Maxspeed saga
- Another way to do VB mod?
- Almost died last night ABS lifesaver
- How do you program your keyless remote?
- What should I do with changing my knock sensor?
- cold air intake?
- Some one tried to steal my Max last night
- Question on foglight bulbs
- Alignment
- stock orange blinkers
- Guys with VIs: make sure and test your vacuum
- Different TB
- possible trans problem!! please help!!
- Test Pipe Installed
- Will 38 Offset On 5lug Rims Fit My 95 Max??
- Anyone got Konig Reign's on their car?
- UGHHH...LOST search results, have been searching for 1.5 hours...HELP!
- Faster?? 93-96 GS300 or 4th gen??
- Need opinion on 18X8 Voxx Scorze rims
- 60K service....Question
- Is this a sign of tranny going out?
- Want to get lowering springs, how do stock struts hold up?
- Weapon R Coil Over!
- Loose sun visors
- Are the Y-pipe power gains worth it with Stock Cat and Exhaust?
- What would happen if I don't change the EGR valve?
- do i need a new suspension?
- speak up, whats next on the mod list
- alignment???????
- Radio Mounting kit
- cheap people....I just dont get some of them
- blower motor
- intake causing big loss of power
- ? for those with manual controlled fans
- Subwoofers making my trunk sag!! What do i do??
- I have P0325 problem
- Need O2 senor!!!!!!!
- R.I.P 97blk GLE August16, 1996 - August 18,2002
- Question about programming a Maxima remote for an I30
- i want these wheels!!
- Problem...RPM too high
- whistling sound at low rpms
- possible painting...(ALL RED) Altezza
- What did Consumer Reports think of the Fourth Gen?
- Camshaft Position Sensor
- question for mechanics...knock sensor and starting problmes related?
- Cattman install help!
- Stillen Grille
- BAH! Want better tail light options!
- Strut bars
- stupid person asking question about location of s/c
- P0325 P0115 P0125 codes where do I start first
- what rims look good on max's
- governors on all 95s??
- New question re: Painting Altezzas and 95-96 V. 97-99 differences...Please Help!
- Front engine mount on GLE has a cable?
- Car handles so much better now
- budget f-pipe
- Maxima's and 20 inch rims?
- anyone running 18's or 19's on a non-lowered max?
- Searched for paint sellers, found ONLY paintscratch.com. Are there any others?
- Knock Sensor Prices????
- need recommendation...
- ECU Code Help!!!!!!
- illumina's are here...maybe
- Fuel Pressure @ 120 PSI !!!???
- Lowering max.......what shocks/springs?
- Flywheel or MEVI: which would you do?
- Broken factory fog light
- rear maxima emblem
- Air Con and rough idle.
- Tach, keyless entry, intake questions
- driver side window roll up too slow
- 98 power antenna install
- strut installation
- 300ZX Injectors
- how often do u guys change ur spark plugs
- this neads to be done
- new kit
- turbo vs. super
- vtec
- Konig Subzero rims - is this a good deal? I have two options here... need opinions.
- Custommaxima's kit work with my 97 auto?
- check engine troubles and questions
- painting CAI
- Nitrous Express
- Attn: those installed factory white gauges to replace old cluster
- Does anyone use Motul oil???
- How long before you have to clean filter for CAI
- My car Domain page finally started.
- Y pipe cost
- Acceleration data acquisition…
- 96 Maxima Vs. 94 Talon Tsi
- 7" mid spoiler??
- VI guys: Why are we using a vacuum tank?
- finally got check engine light but whats the PROBLEM?
- Timing chain noise : TSB?
- Why doesnt my power antenna work?
- look at this max on ebay
- Custom Shift knob from Mad Dahn installed
- I need to know the voltage for the bulbs behind the ACC
- Got my warpseed y-pipe installed this morning
- Well the VI definately works, took it to 6500rpm in 5th last night
- screwing in clear corners
- Would the interior 2000 NISSAN MAXIMA fit a 4gen
- anyone with brembro with oem pads
- MOMO ARROW Wheels
- where can i find anti seize grease?
- OEM Struts and Spindle
- How to disable the automatic door locking/unlocking?
- Need help with VI problems
- Tranny Fluid level checking mechanism on a manual tranny
- Dying Interior
- windshied wipper fluid tank broke.
- manual vs auto tranny oil change... any difference?
- franken intake
- A/C not that cold
- 99 Maxima ES... How much horsepower?
- Windshield Banner
- Inexpensive place fro KYB Dust Boots
- stillen front spoiler
- SHELL or MOBIL
- Scratches
- Alignment needed for H&Rs
- Camshafts Regrinds
- Underbody Light Install - questions for anyone who has done it
- What are signs of worn front struts???
- My Peal White hit 120k. More inside..
- rebuilding auto...
- Where to buy indaglo gauges for 96 GLE?
- parts
- which is a better buy??
- question to those w/ drop
- 98' 16' inch 5 spoke wheel needed
- Tranny is going, but mechanic couldn't make it slip
- Installing Fog Light Bulbs
- KYB AGX Adjusting
- NJ State Inspection
- Manual Tranny Leak
- Correct Tire pressure for 18x8 235/40 tires
- What RMP range is considered "low end?" How about "midrange?"
- Brake Pad
- Finally In - AGX and B&G
- Anyone w/pics of 5gen 17in SE wheels on 4th Gen?
- new battery
- Max is making a funny noise
- Our VQ Engines have "VTEC" ?
- Need buying advice
- My baby was stolen
- Will the 4th Gen Ever look old ??
- Stillen Body Kit on Stock SE Wheels
- Budget Y pipe question
- SC belt tightness?
- light bulb question
- My Score Board / How About Yours
- Are these head gasket symptoms ?
- People who know about Car CAre
- VQ sound vs. say...acura?
- New trunk Lid sitting slightly crooked, any ideas?
- Polarg Hyper White Bulbs
- for those who have diagnosed air bag light
- Touring tires
- apex ws exhaust
- Just Stillen Front Lip
- anyone know how to do this mod?
- Has anybody painted the cluster needle gauges?
- Annoying Rattle with Stilen Mid/B Pipe
- Clear LED Wing Light
- gas tank size
- Start problem
- Tranny reverse slippage
- Noise coming from my right front strut
- Sounds after Brake Pad Replacement
- which scews to use for stillen side skirts?
- wht kkind of exhausts.. u all tell me!!
- need help with Autometer fuel pressure and EGT gauge install
- Cheapest/Best place to order Greddy SP cat-back?
- BLACK EBOOT... Anyone have one lying around???
- a few newbish worries :)
- How do I take care of the idle speedcode 0205?
- Mod I don't see too often
- Best Brand of bulbs...
- Transmission Trouble?
- New I30t pics
- is there any diferrent on the MAF sensor between 95-2001
- ? to those with Permacool Sandwich adaptor
- anyone instaled an autometer electric oil pressure gauge
- H&R guys with 16s, can you measure your fender gap
- ECU Codes
- cleaning engine
- b pipe question
- an interesting thought (a "should read" for people with 5 speed conversions and......
- More VI track times, something's not right...
- replacing headlight bulbs...
- Am I the only G4 Max owner w/ 19's?
- do they exist?
- Remote Starter and Alarm
- New intake
- Weird acceleration.....
- Does the frankencar help alot?
- 0-60
- all supercharger guys-look at this hose
- Wierd starting problems after Dead Battery?
- is there any way to stop brake squeak on slotted/ drilled rotors????
- Stillen Front Lip - Avalon Racing?
- 99 Maxima SE options
- Metal On Metal Sound
- cutting the stock springs?
- Who Wants Stillen Body Kits??? 95-97..
- Check engine light stays on after resetting
- has anyone instaled an auto meter electric oil pressure gague
- Dead ECU?
- New Guy and I need some help.
- raced a grand am GT
- Car Is Surging!!???? Help!!!!
- Max is back - And I'm very happy with the paint match!
- Another believer in KNOCK SENSOR replacement.
- courtesy light wont turn on, bulb is fine .. ?
- approx. HP in this car...
- Anyone ever heard of Sprint shocks/struts?
- Installing WSP b now and have questions
