- Broke my key
- Does CEL ever throw you a fake code?
- Bad starter? Video included.
- Finally solved my rear end squeak. 5 minute fix
- Alternator size difference
- Air shocks
- Autozone CV axle(halfshaft) experience
- Vac leak ...
- Anyone replace A/C Blend door motor
- Lower Tie Bar II install for automatic
- Transmisson question
- Cooling manifold tubes rotted away.
- timing chain loud at start up even after warmed up
- Fidanza Flywheel Probs (pics)
- d2 coilovers??
- Name this part!
- Aluminum kick plates and door inserts?
- How do I disconnect my radio
- Strange electrical problem with door lights...
- Anybody heard of "Spyder V6 Header Exhaust"?
- Look whats FedEx brought me today
- clutch slipping in warm weather
- Magnetic Transmission Drain Plug
- speaker problems
- pulling relay....
- Axles replaced - still clicking! UGH!
- I don't want to waste another TB gasket !
- FUEL SMELL AND SLIGHT SIGHT OF WHITE SMOKE ???
- Name That Y-Pipe! (pics)
- LSD and NON LSD
- How to paint these scraches ?
- Is my Tranny Slipping?
- Engine Stalls after cleaning EGRC
- '99 GLE blower motor doesn't work at any speed, wiring always hot?
- JUST PULLED CODES !!!!!!!!
- trying to clean egr valve tube!!
- Installing aftermarket cd player
- Two issues: idle rpm and idler pulley whine at idle
- 2010 4th Gen Calendar Information!
- mileage on stock motor? just curious
- rear caliper problem
- 150k mile maintenance
- OBD Diagnostic help
- Throttle body gasket leak ?
- MT Transmission Gears ?? 91 vs 96
- what's the difference ?
- 2010 4th Gen Calendar?
- 95 Maxima power steering pump
- Bolt on Performance?
- Quick question
- Best Place For Bosal Exhaust Parts
- Cancer removed, EVAP 0705 code fixed
- writeup on rear brake replacement with pics
- Just bought used lowering kit
- EVAP diagnostic
- 95 Maxima Question
- Boosted Maxima needs your help!!
- New Idea..
- Radiator cracked, replaced it with an aluminum radiator, now tranny slips.
- Cheapest Place to buy a....
- (RICER) what not to do to a maxima lol
- my new retro: how many lumens? OVER NINE THOUSAND!!!
- Looking for a car for my mom, saw this...
- HELP! HID bulbs blown???
- Warm A/C
- Arms joints and links
- switching to ES control arm bushings, any tips or tricks?
- MAF SENSOR COMING UP HELP!!!
- 99 SEL Won't Crank - Battery Fine
- NEED HELP, hard start, 1800rpm rev limit, car dies, DE-K
- WRECKED!
- Wheel bearing replaced now have wheel vibration
- Quick question about cross member.
- Can I replace my intake manifold with a 99 cali spec manifold.
- exhaust video thrush muffler
- Cannot Open the Hood
- Stupid oil changer
- Wheel bearing issue?
- Can I get a fuse map or diagram?
- what kind and where to buy new ball joints
- Need help- engine dying out
- V2 OBX headers.. Help needed!!
- Need help
- Rear brake problem (not a seized caliper)
- General Question About 4th gen Trans...
- need a tune-up guide???
- does anyone still drive a 4th gen
- -26 flashing on Auto Climate
- Keyless entry..
- Megan exhaust install problem
- Rubber isolators between the spring
- Front Conv 96 to 98.
- Bose Problems
- Keeping it running problem!!!
- armrests-did they very over the years?
- broke a rotor! Brembo too :(
- Stuck caliper pins
- i think i found the problem....
- tranny not shifting right
- Idle question
- Better benefits
- what color should a paint my car?
- Please help, cylinder #6 location?
- car doesn't start well? is it ignition...?
- Time required to come from cold to warm engine
- Need input.....noise on the left side of the engine
- Bots on fenders
- I love my car
- Codes P0518 and P0618
- car wont pass inspection
- Rear suspension issue...
- Honeycomb rims refinish
- Replacing fender after accident
- Will '01 Maxima Wheels Fit on My 1995 GLE?
- R34 headlight w/ Infinity G35 Projector MOD
- Power Windows Are Confused?
- Cleaned my TB ... Leak ?
- 96 gle auto car jerking problem!!
- Strange Problem...
- Water pump service.
- Lucas ? STP ? for cleaning ?
- Weird sound from my Max after car is turned off
- Power Steering Reservoir Hoses Leaking
- AC Bypass Belt with Motorstorm UDP
- Stiff steering
- Driver door not latching
- QX4 projector foglight retro fit
- Shocks
- OK, so... I've been slacking off under the hood.
- Are these things ok ?
- Bolt pattern fitment
- Easy Knock Sensor Installation! Picture Tutorial
- Maxi pulls to right
- Opinions needed - "repeaters" / side markers (PICS inside)
- Putting in new radiator, anything I should know, any precautions?
- A/C is broken so I bypassed it with a smaller belt, want to take out whole A/C now
- 4th Gen With Eyelids
- Interior Overhaul process thread(2.0) - Custom Black/tan interior, 350z seats, +more
- Best Big Brake Upgrade...
- HELP! MAF problems! I think?
- white smoke on start up
- Put in new alternator in my 98, now car has horribly loud squeeking.
- I ran through a big puddle now my lowbeams and fogs dont work
- A/C compressor bearing replacement?
- Opinions Needed for Springs... Thanks
- Alternator/Battery Drain: Unbelievable Solution
- Thin metalic a/c hose leaking!
- How many motor mounts on a 96 SE?
- rpm not working on vq30dek
- Oil Leak
- eBay OBD II to USB reader
- Need Adivce/Help/Suggestions on making my Rear LED plate lights bracket w/ PIC
- Help Car Dies or surge when braking
- 97-99 automatic tranny owners who have replaced y-pipe please help
- anyone got a write up on how to change control arms/balljoints?
- How much would you pay? '99 SE-L
- firestone $145 lifetime aligment good deal!
- what to spend 100 bucks on.
- wtf, i can't open my trunk
- EGR delete=P1105 (MAP sensor)??
- Is This Normal, or should it be cleaned out?
- 3.0l to 2.5l swap
- stuck caliper piston?....
- 95-98 ECU IN 99. Immobilizer Question
- Calipers
- How long does it take to bleed your clutch mater and slave
- Oxygen Sensor Replacement.. B2 S1
- Are my coil packs going out?
- How many O2 sensors are there on a 98 Maxima SE?
- Bye Maxima.org
- VSS Vehicle Speed Sensor Replacement.. How to??
- Valve Cover Gasket Replacement
- Stupid desicion ----> Much regret !!
- brake fluid problem plz help!!
- Possible transmission problem?
- Whos a harder 4th gen rida then me
- is this for real???
- big Question 4th gen max
- New A ddition
- Transmission slip just before downshift
- Which Brakes Pads??
- ABS check light-high pitched whirring from dash
- 270 mA current leak through alternator B terminal
- few questions in 1 thread. clock din, keyless fob etc
- KYB Dust boot really that bad?
- Advice on A/C....
- colt state park meet MAY 3
- Back windows dont work and central lock
- Brake Battery Light
- Reflector Housing Repair - Foil Tape
- hit the curb trying to avoid an accident, shop quoted me 2.5k?? wtf
- 98, replacing side mirrors.. what bolts?
- Anyone replace rear brake lines on 4th gen?
- 6thgen Wheels on A 4thgen
- intake hack
- Car leans out and almost dies at angle
- Has your car made this horrible sound?
- Break in - Window regulator question
- VQ30DE TO VQ30DE-K swap with no spark
- EGR delete?
- Ok, EGR fixed ! strange....
- My car dies while shifting gears, wont pass 3000 rpms
- Need help with some codes
- cheap maitenence
- urgent problem: running lights fuse?
- Using some 5th gen parts on the 4th gen
- Frozen calipers and bad rotors on rear. Please help.
- Advice on choosing oxygen sensors
- Badly leaking sensors.....
- "Factory Spec" for current draw (drain) -- Is there?
- What part is this?
- What would you do with $2000?
- Does anyone run these single-connector TPS'?
- Windshield Replacement... (Cracked last night)
- Will 97-99 Trunk lid fit my 96?
- Racing axles
- 02 Sim ~ Downstream
- ALT.S circuit prevents current draw test -- why?
- 98 Cali Spec -- worth converting anything?
- where to go next
- is this eBay exhaust, actually...decent?
- MAF Sensors gone out on my 95 max
- 0.15 mA current leak through alternator -- normal ?
- EVAP Codes
- Keeps blowing 02 fuses
- Rebuilt starter, good battery, still no start
- 1997 GLE. Bank 1 is where?
- Climate control fan dial not working...
- 00vi swap or buy MEVI
- Intake manifold leak?
- racing axles
- 97 Max overheating problem
- A/C Compressor Bearing Post Mortem
- Engine check light (funny story)
- Car broken into overnight :-(
- LOW IDLE WHEN STOPPING QUICKLY??
- advanced timing for the 4th gen?
- Relocating the trunck open button from driver's door???
- Fog Install Help
- A little help please.. Knock Sensor/O2/ + Codes
- Resonated Exhaust Tips?
- Higher water temperature after coolant change, normal?
- What will happen if I will not replace my O2 sensors ?
- Question about IATS and Smog check-CA
- Help me find my IAT Sensor location
- 5th gen intake over 4th gen intake
- Half-clutching all the time? ftmfl.
- odometer - roll forward
- Need Help car wont start!!
- Need Help Quick! - Quarter Window
