- All 4th gens with 20's step in...plz!
- 5-speed hydraulic pump problems...
- voltage issues? alternator possibly??
- speedometer not kicking in.
- 0606 diagnostic code
- Bose speaker sizes?
- slipping clutch
- o2 sensor quick question on location
- Is this exhaust crap? suggestions???
- Putting Headlights back togethar
- OBX short throw
- so make that 2 breakdowns during maxus......
- lip kit for a max98
- 5th gen springs?
- Car won't idle
- starting issue
- Anyone ever removed the rear exterior door handle???
- driveaxle boot has hole
- Help tring to program key fob but can't get light to flash after inserting key
- I need help ASAP please!~!
- 5speed swap FINALLY done.. wheres the TCM?
- Issues with Bose - Repair or Replace?
- What can I do?
- Need some help with my car
- vafcii broken?
- Strut Mount question
- wheel spacers,negative effects?
- Chain rattling noise won't go away after water pump change?
- need help with my max...
- Starting Problems...Gah.
- OEM parts for a lot less
- Stalling Issue Fixed but another concern
- Steering Issue
- New aluminum radiator??
- problem after installing flywheel!
- stripped center bolt.....
- threw code 1008
- Safe to use Run-Brite?
- Exhaust gasket (questions and rant)
- Painting Blinker bulbs?
- Electronic ignition
- Need some quick clarrification on tranny lines
- 97 max a/c problem(relay)
- How much does it cost to dyno?
- Fuel line closest to fuel injectors..
- CV Joint Second Opinion
- stock bose amp locations
- Is there such a thing call AC Evaporator
- Changing Valve Cover Gaskets
- i dunno what to do
- Changing master/slave...words of wisdom??
- P0153 code - O2 sensor slow response (bank 2)
- Fair Price
- spotted a white maxima
- Brake Bleeding problems - pedal still spongy
- Different type of starting issue
- torque specs for oil pressure sender
- Car hesitates and vibrates at idle when AC is on.
- cigarette lighter problem
- what strut in front?
- Stalling problem fixed!
- Help
- Radiator problem?
- R34 headlights and HID's....
- 3rd Gear Crunch...
- I checked the stickies but no answer???
- big coolant leak
- Power seat height adjustment broken - stripped gear?
- Question
- how about these brakes?
- Question!!
- why do I have to press the gas to get my car started???
- Car "squeaking"
- KS needed
- Araffio?
- 00-01 engine swap question
- warpspeed y-pipe question
- feeler thread... (pics included..looong thread, sorry)
- Pathfinder throttle body
- Stalling Issue
- HELP with my evap
- completely noob wheel question
- Carbon Fiber Gas Cover
- Anybody have the CAD for PF TBs?
- A/C smells
- Oil Seal Cover Tool (Halfshaft Seal)
- Loss of Power and Hesitation :(
- problem with stereo
- ABS light on...
- SOS - Where is cylinder 4? ... cylinder 4 mis-fire (0605)
- Is it possible to make manual AC to powered AC module or climate control, w.e
- Flush and Fill Radiator Kit
- need help on spoiler repair...
- valve job..how do you know you need one?
- W00t! The Max is down for the count AGAIN!
- Hesitation
- Who lives in PA/OH/MI/NY?
- well, thought of another issue that arised
- 2 things, 1)need part #...and 2)autozone coils....
- Mods vs. Tuning
- Apex'i S-AFCII
- problem w/ brake light on
- Car wouldnt start in park but it would start in neutual?
- what do u like most about your 4th gen???
- pads that are quiet and dustfree
- Congrats to Kevlo911, the newest 4th Gen moderator...
- Surging/Misfire? At Idle
- Tokico illuminas or S-teins?
- Number of Oxygen Sensors for 1998
- Starter signal fuse popping!!!!!!!!!
- Foglights, Ebay, which to buy ?
- How to check production date
- Stuck actuator?
- Catalytic Converter Ground?
- A/C problem
- ECTS Location help!!
- Greddy Evo2 Catback
- Part out
- chrome 5th gen wheels ona 4th gen hmmmm?
- Name that part (with rusty pictures included!)
- Warpspeed org discount?
- Which belt to buy to delete AC?
- K&N drop-in air filter COMPLETELY voided my warranty!
- When taking auto tranny pan off
- Have to crank the car over multiple time before it will start.
- want my max to get up and goooooo questions??
- brakes advice
- Painting Chrome Grill
- Are my diff bearings gone?
- anyone made a rear anti-sway bar
- changing intake manifold gasket
- Debadging
- the weirdest thing happened...
- what are the benefits or porting and polishing......
- WTF is wrong with people!! Dont Appreciate doo!
- Exhaust Help!
- AC on/lights on= RPM goes down
- Auto Tranny with Turbo or Supercharger?
- What happened to the MaximaHandling Page
- Iacv
- What Tire Pressure?
- when changing head units..
- ECM Question
- Stock water temperature gauge
- Starting problems...
- Is my transmission messed up?
- what to do next
- Question about CPS sensors
- OEM wheel specs
- Help! Tie rod or just boot (pic)
- Replaced outer CV boot - issues now
- low hanging b-pipe, and oil on spark plugs. *PICS *
- Bad TPS?
- Intake removal proceedure??
- 97 Magnaflow cat work in a 96???
- passenger side cv axle installation help
- how do i find the Nissan part number for a CV shaft?
- EGR valve to cap or not to cap?
- Maxus SFC sale
- Anyone see that Vq30det Sawp??
- Injen Intake -- not so bad afterall
- Do I Need new grommets/brackets for my radiator?
- question about shaving emblems..
- Auto JWT Ecu in 5spd
- Starting problem.
- best matching headlight
- Need some SERIOUS help. Put on your techie hat and help a brother out!
- Have to sell the max
- gear noise
- Suspension squeaks
- anyone buy the front end set from ebay?
- Pics of Max with only front spoiler
- Tire pressure when hot: fronts vs. rears?
- Good store (where)
- Door Inserts
- Couple quick code Q's
- Installing power seats in a nonpower Maxima
- To those who retroed TSX projectors
- looking for underdrive pulleys...advice
- A nightmare in Hesperia CA
- Mega squirt?
- Pic Requst:DR Mod WOT switch
- My Es300 fog retro.. I need help
- Lights on Ebay
- yellow fogs; yellow tint film
- jacking up a car with strut bar/torque ?'s
- Sway bar sway to much!!(rant)
- New exhaust and air intake (HELP) suggestions please
- strut cushioner bearing.....
- Shaking Pedal And Car!!!! Help
- Bubbling noise from coolant overflow
- Changing Base Timing
- transmission
- Found where oil leak is coming from!!
- Got sound? - The process
- wiperss on 4th gens
- Motorized Trunk
- Tranny Problem Getting in To first gear
- A/c Compressor Clutch wiring
- diameter of power steering return hose
- Sloppy/Loose Steering...
- question concern rear wheel hub/ bearing
- Is This A Good Turbo Kit?
- Changing Belts Tips
- Changing Front pads and rotors.
- Noise (low pitch whine) near idle
- 5spd flashing O/D light?!! hmmm
- Help Me Decide! D2 VS Ksport Vs GC With Konis
- 4th gens on 18's without a kit
- Heated Leather seats conversion
- Hit and Run!!
- Wheezing noise on acceleration
- SunRoof deflector
- ECU gone for Broke, now what?
- High Idle now
- Tap size for O2 sensor?
- wiring o2 sensor help
- Whats the difference in these springs
- How to change brake shoes?
- Help CV BOOT broken still driveable?
- Keyless entry(the clicker)
- Heat risers for exhaust headers -- do they help?
- Cigarette lighter doesnt work?
- projector guys
- jealous civic driver
- Big Problem help!
- HID retrofit harness question
- seat motor wearing out
- odd cold start and oil level sensor problems
- Getting an Emissions Test Waiver
- wtf - ss clutch line - am i just new???
- Car is totalled..
- Stripped bolt
- fogs refused to open
- Oil consumption
- Could this be possible ??
- No more MAXUS for me!
- Super Glue Issue
- Boot!
- Rear Bumper
- Bi-xenon wiring ???
- Starting Problem Looooooong Starts
- Pre maxus subframe deal
- How many miles??
- Turbo or 3.5 swap?
- exhaust help
- Rear strut easy fix?
- muffler opinion off ebay
- Need Help With Exhaust Leak
- i dont know what happened but...
