- Maxspeed Springs
- All of the sudden soft/ loose clutch pedal!?
- Those with TEIN Basic Damper coilovers
- one spark plug reaked of gas wonder whats up
- where to mount radar detector?
- Need help ASAP WELDING WHOLES IN Y-PIPE
- gauge bulbs
- Whoa this sucked...(story)
- Pics
- Stock OEM radio/cd/tape player PN question
- Antifreeze bursting out of somewhere
- Unknown Coolant Leak
- struts?
- Chip Tuning
- Torque Converter Replacement
- lots of gas smelling exhaust
- 90k service
- Ocassional starting problem
- Shift_ stickers
- Symptoms of auto tranny failure???
- how do you take out fog lights
- Polished Al Head (pics)
- Can anyone explain the Stillen VQ pro?
- Newbie here
- P0300 code any ideas
- Gas Mileage
- Help! --> Clutch slip, how much time left till i need to replace?
- Auto climate control
- Super hard start and CEL
- Automagic in "Park" question...
- how hard is it to replace o2 sensors?
- new alternator, new electrical issue
- What shocks should I use for my '95SE
- Need help with 0201 code AGAIN!!!
- Two Mechanics Stumped:Starting Issues 97 Maxima
- so confused with o2 sensors.. damn you cali-spec!
- SE, limiter or not?
- Just bought a 97 5 speed, get it Friday but question...
- What are the syptoms of slave master malfuctioning???
- Question about engine/tranny
- 97-99 Street Scenes grill
- Is this a good price?
- Can anyone help with color match paint
- Good site for fiberglassing
- Why Cant I Use The Search Function!?!?
- NOS in a can?
- Fog Light Wiring
- anyone with ADR SZ1 wheels?
- My clutch lets out too high
- Aftermarket Clutch
- Water condensation in winter question
- Spoiler or no Spoiler.....
- 97-99 Ebay Red/Clears...
- people with the cm type 2 spoiler
- gauge bezels
- Rear Bumper Reinforement.
- troubleshooting
- 95 rear yellow blinker light
- What is cali spec
- engine jerks when stopping at the stop lights
- *NEW* y-pipe FOR SALE
- remove the ashtray
- projector bezel?????
- 98 gauge sawp!!! help needed
- pissed!!!
- Drone with Y-pipe?
- odometer
- how would this look.....
- Anyone had a timing chain tensioner/guide go bad on them?
- allignment after lowering??
- 95 electrical problem-HELP!!!
- Sensor question
- Need a quiter Muffler
- Vibration when engaging gear in 1st & Reverse
- Question about Coilpacks
- RPM Question
- 96 GXE and ABS
- Gauges
- rear suspension problem?
- No one appreciates my girl
- Ok...I'm just fed up now
- oBX CAT BACK
- Nismo parts for 4th gen. Maximas/I30's?
- My cruise control isn't working
- How do I know that my clutch is going?
- ERG Vavle/KS? Does this have an effect on the tranny?
- Help Error Codes!
- Pics of Pearl white w/ these altezza's please
- RPMs "jump" between 1st and 2nd gear, kind of weird...
- Need Boost parts
- New Headlights done (R32)
- Radiator support-Bolt in or Weld in?[Pic]
- climate control 96
- 3week vacation...and 2000 dollars later...
- Is my Tranny going out?
- code 1447
- Engine cut out on me this morning
- Hey ROSEWOODS!
- Do I need to panic?
- Exhaust for a 99
- Need your experts opinions
- Exhausts
- Under the hood air turbulence
- Message of thanks!!
- *A Time to Kill*
- head gasket problems, need advice
- knock sensor harness....what does it look like? HELP!
- does ur BOOST SENSOR attached to anything?
- how much to install shocks/springs?
- cattman headers...... where 2 get the gaskets???
- dealing with the rear end
- Weird noise from front wheel (long)
- Broken Key Ring on remote
- Steering wobble
- brake problems
- Check Out My Turbo Process !!
- Weight of stock 97 SE rims?
- What you think of VW Jetta antenna
- O/D OFF light blinks when starting up
- Greddy Muffler Possible?
- bose problem
- intakes
- Dome Light # in a 99
- where o buy a new light for my spoiler ?
- need help dropping!!
- Control arm Bushings
- How long does my clutch have?
- Wanted a picture of Optima battery and Stillen tie down
- should i sell it fix it...any advice
- LED ARE Not Bright Help!
- transmission swap?
- remote start doesnt crank long enough
- rattliing noise from engine when accelerate
- how much drop?
- fuel filter change and tb cleaning
- Gettin my max this weekend!
- pics of painted engine bays
- Protector in front of sunroof.
- HELP I bought a ALTIMA factory stereo for my MAX!
- car won't start
- clear corner ?
- clear corners
- Who Here has the DTM(Dallas Taillight Mod)???
- Post your mileage
- California Spec...Pros/Cons?
- Where is oxygen sensor bank 2 sensor 2?
- Axxis Ultimate brake pads review
- Vq30det Swap
- HELP With HID Install Please
- Where's a good place to find dust boots
- Question About Turnsignal Bulb
- Side Mirror Help
- Pacesetter Exhaust?
- Cold Air Intake?
- New Toys
- OBDII plug on the max
- Did I buy wrong year......?
- Sunroof stuck
- Low Fuel Light
- aftermarket interior
- Stick with the max? & suspension setups?
- e-brake adjustment ..
- H&R springs with stock shocks
- lights
- Stalling when tranny is cold?
- 0210 code
- Clutch/STS questions
- Rear End Sagging.... ?
- bottle of fuel injector cleaners work?
- just got my tank filled up....needle doesnt seem to move anymore?
- just got some Denso-iridium sparks installed but.....
- Need help installing the airbag...horn is sounding going off
- AC compressor question
- fog light question
- little advice needed for wheel
- Brake lights only sometimes working
- Ported/Polished Heads- Feedback?
- transmission bad shifts .. please help!
- Pedals
- Whistling noise from timing chain area
- engine turns over fine but it won't run
- Something wrong with gas gauge
- Loud Heater Blower Fan (At Times)
- EGRC Solenoid valve?? what is dat?
- Who's running on wide wheels and tires?
- cv joints replacement
- Stone racing y-pipe
- 2000+ Guages
- Should I be concerned with this stuff that was in my radiator? *pic*
- Crankshaft Position Sensor
- Passing cars down the family line
- catalytic converter failure???
- Cold Weather Package
- H&R sport springs insteadof my cheap coilovers
- Diag says two rear fuel injectors are bad. How to test for myself?
- Did tranny diagnostic "Throttle Sensor Circuit"?
- Bose speaker System HELP!!!
- Airbag/seatbealt light flashing in unison
- What does this Mean (pictures of spark PLugs)
- *sigh* Engine still "whistling" on idle with new idler pulley and Nissan belts...
- 95-99 Maxima (early years better)?
- Unorthodox Racing Uderdrive pulley install tips (PICS)
- 6500rpm-5th Gear(does this look normal PICS)
- stone racing headers
- Time for a Front end Conversion
- cv joint carrier bearing
- i cant believe owners manual doesnt mention bulb types !!
- FSTB Issue
- 12V fuse on with ign?
- Throwing the knock sensor code...
- level 10 torque converter
- X-Drill and Slotted Brake Rotors?
- frankencar intake
- Bose Sound System
- KS Ready to Come Out
- Swap Info
- sway bar rim job
- what r the symptoms of BAD COILPACKS?
- People with *WINDOW VENT VISORS* show pics
- Ripping out the Bose
- 95 maxima clutch
- Replace Engine or Fix oil leaks
- HELP 02 Sensors TRIPPPING!!
- Water pump ?'s and Repair prices
- Question about ignition, and key
- Shock sensor intall help on 1996
- Remote Starter 1997!!!
- Car vibrating during traffic stop
- help with tranny
- Raw Gas smell
- 95 Rear Deck Speakers
- Center Console Conversion(Question)
- Engine speed
- Any body from Chicago
- ride height ...Please HELP
- Limited Slip Differential
- Tokicos, help!
- ECU replacement.
- 00VI install pics
- serious electrical problems, long...plz help
- seafaom
- catalitic converter help
- Has anyone has a rattling, jingling type noise
- Need help with smog
- HELP! Installed CAI and car won't start
- Accleration goes down when on for a while
- lowest drop with Stillen kit?
- good clutch review
- gauge cluster wrong readings
