- Just ran ECU daignosis????
- Anyone with EBC Greenstuff or Hawk Performance Brakes ?
- Service Engine Soon light on
- 10000k HID Kit
- walbro fuel pump - how much can it support?
- odd maxima
- Question about 5 speed conversion.
- Blue Interior Lights...
- help! bose cd player not working
- which Maxima???
- Intake filter question
- THE nicest 4th gen I've ever seen... 322 original miles
- Clattering Valves
- When getting KYB and Eibach, should I replace anything else?
- Injen and tocking sound
- Court Cases
- New starter
- What is the BEST intake
- Good place to buy Headlamps
- Fuel Performance
- average on highway(gas mileage)
- Springs
- Control Arm bushing?????
- Poor Fuel Economy
- Odometer Issues
- newb questrion
- Exhaust Systems
- GC coilover ?
- Best way to REPAINT Wiper Arms
- Iridium Spark Plugs
- peeps with yellow foglight bulbs!
- Which wires are used to power the windows switch leds?
- do i need new motor mounts if if i go HOMEMADE
- Whoa custommaxima finally came out with their FSTB for 95-99 maximas!
- How many MILES are you guys getting out of your KYB AGX's???
- rotating tires
- How much for diagnostic?
- PIAA Xtreme White Headlight Bulbs
- Adding interior lights...front footwells and c-pillar/rear door...
- engine oil type
- Any one wanna help me out on RPM switch for VI
- Slotted Rotor Q's
- Blow off valve
- Reprogramming Ecu & Keys
- MEVI RPM switch questions
- Took some pics
- What are these mod chips that say +20 HP?
- ACT Clutch.
- how do i remove door siding?
- when to replace oxygen sensors?
- Blown Engine/Engine Replacement
- Q's on 4th gen max
- Where in BC can I auto-->5spd?
- What would it cost to get a full paint job?
- any past 3rd gen owners?
- Kyb Agx Is Wack This Is Why!
- struts
- What is a 96 Maxima Body Kit that you recommend
- O2 Sensor
- Headers??
- How do you install INJEN intake
- New tranny still a probelm!!!
- downshifting
- 3m Hand glaze
- funny sound when cold starting
- rotating tires
- INstalling KYB AGX question?
- i need pics of a pebble beige w/ cf hood
- Just asking
- CEL on/off switch mod
- Which of these gauges will fit a 1996 I30?
- New Car for me!!
- Mobile 1 vs. Royal purple
- intake
- To all with UDP
- How much is too much for Eibach pro kit?
- Any write-ups avail?
- 18x7.5 45 offset fit on a max?
- Headlight and corners
- ANYBODY got an ECU for a '98?
- straigh pipe
- Question on bumper
- please help... Axis Sevens...
- 96 max bose dead??
- interior maintenance tips?
- PIAA Xtreme White Headlights...
- Engine Swap
- Degreasing the engine...quick question.
- Cali or fed spec?
- gas mileage with 225/50 and 215/55?
- exhaust setup
- Cheapest place to get Injen Intake
- Pedals for m/t
- Need Alignment soon, Please Help!
- Clutch pedal spring noise? Is that possible?
- Wheels Spin in Rain
- Cattman Gen 1 Coilovers
- ? on light(s)
- Suspension noises.. rubbing issue?
- Production date for a 97 Question
- Giovanna Genoa
- Technafit SS lines?
- To buy or not to buy??
- To STS or not
- Help me find an Enkei wheel...
- Iindiglo Gauges
- ¿DS oxygen sensor circuir slow response fault?
- help! does this fit?? 18"x9.0JJ +40. PCD is 114.3 5lugs
- Strange sound when starting
- Knock Sensor
- Mufflers
- 9004 and H3's for sale ...
- Is it me...
- synthetic oil
- my new sponser.....
- Injen CAI
- chrome wheels peeling
- 300zx calipers
- Anyone know where I can read up on Nitrous? I'm considering it, but I'm clueless
- H&R/Tokico/AGX/M.V. Mounts = WOW
- AE headlights..
- Need help on 5 speed conversion ( ecu compatability question)
- I'm Going for it ( 5 speed conversion) but have questions about ecu
- When I Cut my Wheel.....
- anyone have experience with grilletech inserts...
- Am I getting ripped off?
- Cleaning out EVAP system
- How Would I know if my car was???
- anyone with wheelskin????
- water temp ?
- my clutch went last night, where to buy act, and fidanza flywheel FAST
- Breaking makes my car's RPM drop to 0 and makes it shut down on me.
- Short stick shifter question
- Pointless maxima question
- painting stillen lip
- Quick Question : Fstb Pressure : In Or Out???
- ECU code not on VBXMax - Code pulled by mechanic
- MAF wire extension NEED HELP!!!
- My car is hurting (ECU 0608 and 0304)
- Tried to bleed clutch need help ASAP!
- 350Z Rims/ 04 Maxima- On 4th gen
- Maxima in the News!
- Since when did we have a no-name aftermarket ECU?
- Energy Susp. torque settings??
- kyb install
- Other undefined codes...
- The first HOT day here in Wayne, NJ.....
- Size of Gas Tank in Gallons
- Engine knock and rough idle
- reset ECU instructions
- very important need fast respond
- Turtle Wax - Jet Wax?
- INCREASED STABILITY BETWEEN 180-240 km/h : ESSENTIAL MODS??
- Need Help
- Longer Lasting Tire Shine
- red/clears
- issue with the internal fan?
- Procedure for flushing brake fluid
- Rims and Tire size
- Anyone has a picture of your MAx with 300z Caliper ?
- STILLEN lip insadent
- Rattling sound in 1st gear... tranny rebuild time?
- what brake pads?
- Question about the Front Sidemarker
- JIC coilovers (FLT-A2)... worth it?
- how too rebuild a rear caliper 98 max????
- rims
- Cai Increases Low End And Y-pipe Increases High Then Is This The Match I Want????
- 19s on stock suspension?
- Help with rims!
- how much are my outer stock tailights worth?
- Haveing problems with my tail lights
- CAI INSTALL gone bad please help
- NOT AGain :(
- Trip Meter / Odometer Problems
- intakes and the seasons
- Want pics of tan interior with chrome door handles
- B&M Shifter Question (Sorry No Search)
- HID Color Poll
- i'm confused
- Maxima Body Kit
- any1 know where i can find those 2 spindle lock nuts from rear strut assembly?
- radiator fan????
- 5th Gen rims fit on 4th Gen?
- rewired corner lights v.s. orange corner lights
- need help with calipers.. :(
- Rubbing problem
- Which exhaust should I get?
- Blown rear main seal
- How do I take my door panel off?
- best place to get vq30de motor???
- Prices of stuff
- cd changer...
- Ram air thing?
- Clutch question
- www.leatherseats.com
- Air Condition useage
- Fuel Additives?
- sequence when flushing brake system
- Diffence Between 99 and 99.5 Max?
- Rear rotor warp?
- Changing Clutch and Flywheel
- Where's the oil coming from?
- Inner CV joint removal
- Unever Brake Pad Wear
- 200,000 miles and counting....who's there with me???
- Advice on 99 Cal spec motor in 97
- Cali or Fed Spec Y Pipe?
- Replacing Vinyl Window Trim
- Idle RPM
- JRNissanParts offers discount shopping online
- 95-96 and 97-99 intake differences
- Reverse lights—on/off whenever I want
- Anybody w/the front bra...
- Changing tranny fluid to redline...???
- New Brake Kit..
- Free muffler for my car?
- Knock Sensor ISSUES (long explanation, sorry hehe)
- Throttle Cable
- How did you install your Stillen rear piece?
- 97 Alarm Question?
- slow response
- Door won't close
- Help winshield fluid spray
- Best Wheels ? Please Guide Me To The Thread *search Not Working
- How to clean monster flow filter ?
- help.. ecu code 0504
- does anyone have maxspeed springs
- just got my new 98 max need help
- a quick question on lowering
- question on h.i.d?
- should every auto have the vb mod??
- Shift knob question
- windshield wipers?
- Went to Stage II on my WSP SFCs
- shocks and struts help
- 04 Rims
- Headlight Houseing
- Sticky Accelerator Pedal
- ECU fault code: Undefined
- New Here!
- steering wobbles at about 70mph
- Pics of my New system
- Amber side marker and corner lights - pics inside
- Any pics of RedlineMax M-Bumper installed?
- Alignment, 4 wheel adjustable?
- Fog Lights for Skyline Body Kit has anyone tried to install a set????
- Starter Noise Fix
- Tanabe Exhaust??
- What does this Knock Sensor ??
