- Lookin To Sell My Stock Steelies A Few Questions
- EGRC Solenoid valve
- transmission fluid leak. NEED HELP
- to the people who work at a nissan dealership....
- Need pics of 4th gen with bra
- how to remove door handles???
- emergency, need help!
- where to find cheep ks? need help NOW!
- Just because our paint is 9 years old...
- Intake question...
- Stuff to check
- LED brake lights?
- 2005 G35x rims on a 4th gen
- Cat back advice!
- where my check engine light go?
- Car Antenna
- What spot do the axle jack stands go?
- EVAP control system/Flow??
- Home 2,000 Miles Later, and I have my New Max!! PICS
- UpdaTeD CaRDoMaIN SiTe (check it out)
- rough idle and diming lights???
- Black Interior
- picture posting
- Body Kit?
- Quick Question
- shocker info needed
- port and polish?
- is Tranny cooler supposed to feel "to hot to touch" at idle?
- dual exhaust
- Cylinder number locations
- 96 Bodykit
- Trouble code P1335 need help pronto
- Got Lucky
- need help installing PVC valve
- auto tranny question
- Best struts with Sprint springs?
- Best Gas Milage...recommendations?
- A/C specifications?
- Best Handling Wheels
- what kind of catalytic converter should i buy?
- maxima wide body
- What year bumpers will fit?
- any1 here put screws in their floor? how did it go?
- Tein H-Techs and KYB boots......
- 17x8 wheels too wide for max?
- ?Clutch Help!
- Led Brake Light Problem
- Budget SS pipe problems
- bulldog shock sensor
- how can i tell if i have an aftermarket y-pipe?
- Just found a disturbing picture
- Drive axle NEED Help
- Foglight Bracket?
- total bs?
- Back light bulb for defrost button?
- whats a good way to drop w/o messing up alignment
- new car and pix
- Wheel Studs
- Are the 1995-99 Maxima(s) faster than...
- throwout bearing prob?
- slipping tryanny?
- Co2 B1s1 Question
- chammy peeled cleaning my TB out
- Replacing the rear oil seal
- Need a y-pipe, need help please
- Bad sensor?
- P1130 Error Code
- Quick Question About Catback
- My car hates me
- How much would you pay for my car?
- HELP! steering problems...questions?
- 200k club
- Nissan Shift_ stickers?
- Car wont turn over
- Just installed KYB GR-2 shocks...
- in the process of researching camber,I thought maximas didnt have rear camber?..
- CHECK THIS OUT:A must have Nissan ecu tool
- Shifter question
- 1996 OEM Replace Rim Site (Sawblade)
- Hid Helppp!
- Installing Autometer gauges
- Just a quick question about the Greddy SP2
- Hard starts...
- adding atf fluid plz help quick
- Are Drop Zone Coilovers any good?
- Complete Crap? "Leather-like custom seat covers" $69
- z32 maf and j30 maf same thing?
- Need DESPERATE help!
- stripped bolt
- maxima stillen lip kit
- question, rsb with tein basics necessary?
- Tool Set for MAX
- help with tail lights and hazard light...im an idiot!
- My Max is offically dead
- AC Dying... What to do...
- jacking problem
- 2.5 inch or 3 inch exhaust system?
- Sunroof Help Please.
- coilpacks or MAF???
- Rotors and brake pads
- Correction Programming on AFC/AFCII
- Show Me Ur Tints!
- Foglights?
- Some exhaust advice needed
- Center Part Of Wheel
- What all should I replace when changing my clutch?
- pinstripe removal
- illumina settings?
- Need Seat belt help
- Big Problem
- AutoTrader joke
- need help in picking exterior color
- Another KS Question/Advice
- Removing Rusted Rear Manifold Studs (Y Pipe Install)
- The "How to troubleshoot EGR problems" link is not working in the "how to's" section
- flywheel
- washed and waxed my car 56K alert
- Throttle body cleaning...
- Gauges
- Mivec
- illuminas or Agx
- driver side door lock problem and then some.
- one-touch windows
- Tokico HP Struts
- Replaced the Knock Sensor tonight...
- GC coilovers
- need Help, just installed budget y pipe and UDP, car is sputtering
- grinding noise from rear driver's side wheel
- Where to get fender mounted marker lights
- Buying new Y-pipe... Wich one's best??
- Loud LOUD squeaking sound.
- Difference in 97'-99' Stillen Kit and 95'-96' Kit
- Max Off-Roading
- Tranny snorkel leaking fluid?
- LED ignition trim ring mod...
- Teins and AGX
- 95 ECU in 98 GLE?
- Broken Trunk Latch... will not close, tied down with bungey cord
- Just failed smog check
- Name that noise......
- Suspension question
- any one have vids of take off or drive by' in there max
- what do u guys think about this clutch
- Frustrated: Camshaft Pos Sensor
- 3.5 inside **56k killer**
- Failed Emissions (NOx) - best way to test EGR?
- what ATF do you guys use and what mileage?
- rough idling when in drive
- Custom Enterprise discount
- seats
- Question about axles
- update on my car
- Bose HU
- EGR Error-0302 Most frequent fix?
- stock head unit question...
- Changing the big belt...
- AC Compressor Electrical Overview
- Codes
- WTF?? RPM's jump up sometimes when warming up the car...
- Can anyone give me any useful info on upgraded trannys?
- Y-Pipe.....Check Eng. Light??
- Vavle cover bolt snapped HELP
- trany help
- Engine vin #?
- Write for absolute pressure sensor
- Starting trouble...
- Knocking sound == bad CV? How hard to replace?
- tune up
- Need Pics of 97-99 Grill on 95-96 Bumper
- drag racing Boo Boo story!!!!
- advice on buying 4th gen
- cv axle replacement - close but no cigar....help?
- Charging system problems
- yet another maxima with cefiros
- A helpful searching tip
- Engine Swaps
- getting to evap core. how do i remove the dash?
- 4th Gen is being retired.
- calipers
- Squashed Progress springs
- AC/Heater Issue Advice Needed
- Looking for pic of ecu pin lay out
- replacing shocks, do H&R springs need replacing too?
- Gauge Needle coloring
- Steering Wheel options ?
- Any pics of painted S5 or Trenz grill?
- opinions and exterior picture request
- taking apart corners
- Passenger Side Mirror
- I was put to shame...haha..
- need spoiler led replacement
- 300zx Brakes: How does it feel (compared to stock?)
- Suggestions before replacing struts.
- did i just trip a sensor or somthing?
- Just had Tokico Illumina Kit put in! (PICS)
- Puzzling ignition switch behavior
- installing RS type coilovers...got questions
- Updated Cardomain. Lots of new stuff.
- New exhaust system-- dynomat???
- Finally got a Page up!!
- Show me your air intake hacks!!
- Where to find Apexi cheap?
- AC charge guide
- alternator?
- Where to get a rear header gasket
- Still looking for the perfect exhaust set up.
- 13" COBRA BRAKES
- VLSD Tranny - Driver's axle leaking.
- considering engine swap soon, need suggestions!
- Stall Torque Converter
- Creaking center console components = chassis flex?
- Quick Question FOr Brakes
- JWT intake vids
- F'ed up tach
- Need New CV Boot..Replace Axle Too?
- My stupidity mixed with cheap pads...new rotors?
- Squeeky and Stinky A/C
- no transmission fluid!
- Bbk
- ECU code 0505
- break in period
- FSTB bolts, factory torque spec.?
- Timing adjustment???
- My new car
- Wheel choice poll. Thanks for your time.
- Tire ??
- Need Help fast !!!!!!
- Motor Mounts
- Clucth lost pressure???? why?
- Fit-altima Chrome Interior Handles?
- any max owners in richmond, va?
- jerkiness?
- stabilizer bar link pin?
- Enkei PK6s...
- removing transmision, problem, help.
- For Sale- 97 Maxima With Smoked Cefiro Headlights $3950
- Front Caliper Rebuild: How to?
- Clear Corner Install Question
- Anyone else have fitment problems w/ their ebay fstb?
- mild street Maxima Torque Converter
- Reverse/neutral switch replacement
- my comparison:OEM pads vs. axxis ultimate(junk)pads, OEM pads are the way to go..
- Thinking about Coilovers
- Chargin AC question
- microvision
- Tein basic question for those who have them installed...
- Manual transmission spewing oil through overflow !!! ???
- Anyone have this?
- 97 Max owner considering adding 02 pathfinder...
