- Sticky Problem
- Maxima problems
- Mystery coolant leak - WTF?
- Belt squeal for first couple minutes of driving?
- Ceasarschariot.com let me know what you think
- Blinking SES light and lots of codes ahhh!!
- witch o2 sensor is this
- wheel camber question
- what is wrong?
- changing heated seat lights
- 9004 HID's???
- weird a$$ idle stall
- 96 Maxima Tach Problem
- Does anyone do Blue LED Climate Console/bose radio/window switchs etc?
- cat back Q
- cold start schreeching
- Wtb Radio Bezel
- Rims in snow... on or off??
- Need help with Borla
- need 5spd tranny, quick question...
- Stocks question....
- Retrofited E55 Projectors into my Headlights
- water pump replacement
- New Design LED tails Done (pics)
- Anyone ever try to remove front sway bar end link?
- Forced to get PACESETTER CATBACK
- Possible Transmission Problem
- Motor mounts
- hi-flow cats
- How important is a hi-flow cat to the power gains of a y-pipe?
- Jic FLT-A2
- painting calipers????
- are cross-drilled/slotted rotors really worth it?
- Removing stripes from maxima...but how to remove the glue?
- Smoke in or out???
- Conclusive Answer Needed.
- 95 ecu in a 98 no cel
- '97 map light bulb change-out
- Smt6
- Skyline Installation
- Dynomat??
- maxmods website???
- Does 350Zbrak pads fit 4thgens?
- motivational rear strut mounts
- Tracking down short/bad ground
- UDP install: strap wrench?
- Mitsubishi Coil packs discontinued?
- Does Anyone Know How To Fix The Warning Chime Buzzer?????? Its Near The Fuses Inside
- how much is my max worth? 98 Max SE 5spd (many mods)
- '96 Steering Squeak
- Solenoid Valve assembly- A/T- 95 Max
- Time for a New Car - Trade or Keep the Max?
- overwatt bulbs
- Eibach Pro-Kit springs used for $145??
- 2k2 Maxima Rims Put On 98 Maxima "Pics Inside"
- Noise! Noise !
- Noise! Noise !
- Need Springs & Struts
- No Brake Lights....
- ECU help needed
- cattman header install?
- stall speed?
- 1995 maxima drivers side window
- radiator worth the trouble ?
- Broke my dam spoiler!!!
- How fast is too fast?
- Bose speaker cuts out even with rebuilt amplifier???
- Loss of Power
- Shock/Strut Advice?
- New Maxima Owner
- Performance parts and online stores
- Liquid Leather Repair
- Side Headlight Bulb
- Air Bag Light on....how to turn it off???
- Is Installation Of Y-pipe Hard, And Sound Any Good ?
- leather installation problem, Help!
- Feels like clutch chatter but its not???
- Mysterious Connector in Driver's Side Door
- I need an ignition switch.
- The Dreaded Code P1320...
- Left or right on a V-6 engine in a front wheel drive?
- My Max's New L0oK !
- Some questions from new owner
- on a black max what does everyone perfer
- Replacing rear brake pads and rotors
- All Nissan Nationals
- Turn Arrow Signal Bulb Size(inside) Is It A 194 Or What? Want To Replace With Leds
- '97 max sideview mirror
- Fuel line leaking?
- 5spd conversion for 99 Auto???
- Tranny spring just "fell" out....
- Spoiler Brake Light
- People with E55 Retrofit Step in
- Do those Z32/Cobra BBK hub-centric rings really work on the 4th gen?
- Cefiro H4 Lights Blow Less?
- Bra just for the hood
- aftermarket fogs in the fog light part of the bumper
- newbie question about strut bar...
- I need feedback on Energy Suspension bushings for front sway bar...
- aluminum dash kit
- where to get parts for 5spd conversion
- Battery Died, fixed it, and now tail lights wont work! WTF?
- Driving without the wheel well shield?
- car got hit
- Help me! Please!
- What other cars do you guys own/drive?
- 00vi
- Accelerator Pedal feels heavy to press at times
- SES Light on but no codes???????
- HLSD Does, In Fact, Rule!
- 4th gen/5th gen accelerator assembly interchangeable
- Ignition upgrade.
- So called "pop in a box" intake installed
- Camshaft Position Sensor
- 5 speed tranny on ebay
- 12V to the head lights?
- Coolant leaking from near oil pan
- Ground wire kit installation
- Touch up paint
- where to get OEM muffler?
- $600 to fix rear brakes (pads,rotors,and calipers)!!! DIY job???
- Tried Everything, but Stater is still stumping me
- wheelskins covers any good?
- 96 Auto Tranny Maxima Problems- HELP!Please!
- Wierd but i need some picture! Part 2 56k warning
- Please Helpp I Dunt Know What Happend Tryed To Find My Codessss
- What HID proyectors fit in headlights?
- Pics Of Ae Mod On Green Or Black Max!!
- Quick Question - Bank 2, Sensor 1 - o2 Sensor Circuit?
- The Crank sensors....
- Clutch question....
- lowersprings=Stock Struts
- manual climate control leds - mcd?
- 4th gen private party wit mods?
- Cattman exhaust
- Overheating with A/C :(
- cold weather+5spd=???
- DuuuDDE.............. never seen these headlights nor this bodykit on a maxima b4!!
- Where can I find a legit place racing intake!?
- Can I Make All Four Windows Roll by the remote?
- rear right wheel making NOISES* HELP! sounds like metal rubbin on metal!!!
- Remote Starter Question
- AE Headlight Mod
- Overheat and "Vent Control Valve"
- exhaust
- Teeth on ring gear missing, why?
- Alternator Dead
- Tein S-Tech+Tokico Illuminas or Tein Basic Damper (sleeve coilover)
- Are these legit?!
- stone racing ypipe
- Figured out some crap on my car.
- Alignment/Camber Correction question
- knock sensor sucks
- Post pics of tint on black
- need help quick!
- GReddy
- exhaust system
- Installing newer VQ w/some rust and have questions
- H&R 15mm Wheel Spacers Question
- CV Boot problems
- Ground Wire Help I Know It Was Asked Before But Help
- Looking 4 help buying fog lamps!!!!!!!!!!!!!
- any interest in CF mevi covers to match those CF engine covers...
- Need Pics from you 95-96 guys
- poly filled motor mounts review!!!
- Flowmaster Clip
- Rear axle seal leak question...how much $$?
- Need Help - Trouble Code 0401: Intake Air Temperature Sensor
- making stock gauges brighter?
- Accessing fuel injectors/fuel rails
- 95 V6 sputters & stalls, DRIVING ME INSANE!
- My 5 speed goes into gear hard
- leds in bose help
- 97-99 corner lenses fit on a 96
- EGR solenoid part number
- Led Bulbs Off Of Superbrightleds.com, Use Them For Gauges????
- Should I Get A Bomz Cold Air Intake For 97 Max Off Of Ebay?????? Worth It???
- Exhaust ?
- My 99 maxima failed NJ inspection&I got some Q's...
- Whats the widest size rim you can have without any rubbing inssues??
- 96 Maxima damaged suspension
- what is seafoam?
- Damaged suspension
- Wiring in a toggle switch to the Harlan RPM switch and MEVI
- 95-96 Full Coverage Insurance?
- Mystery ECU code + strange activity = Confusion
- Different methods of grounding, which is it?
- air intake questions for a 95
- Throttle body cleaning question
- What's your favorite mod?
- Rewire Bumper Lights
- Miles Per Gallon
- Friend looking to buy Maxima *Questions*
- need advice on maxima purchase, carfax
- front corner lights
- Which Spark Plugs?
- smog question
- ****ing kyb strut boots POS
- "Extra" Storage space...
- The heat/ac is affecting my lights/engine..why?
- Is the humidity maybe making my gears sticky?
- a few pics of my semi-completed interior -56k im using thumbnails so you should be ok
- 1999 Cefiro VQ20 brake question
- You know youre AWESOME when........
- ONE more ecu question
- hole for intake
- Updated website
- Bought Ce Race Pipe And Having Trouble, My Socket Broke!!!!!! Need Suggestions!!!!!!
- exhaust and headlights
- Best sounding exhaust ive heard
- is the extra $50 worth it 4 the CE y-pipe
- Mass Air Flow Meter Problem
- *****does Anyone Know How To Install Reverse Indigo Gauges 97-99?
- Alternator overload? Is this possible?
- Exhaust tone of Magnaflow
- how do i test my ABS?
- Ignition coils for 99 Maxima
- Vent control valve & EVAP leaks
- Urgent: Please help
- CrankShaft pulley question (with picture)
- clearing 98 max needle gauges. need help!
- Bee's Flying Noise Generated from My Max
- My Car Wont Stop Stalling!
- What kind of SPRINGS should I get?
- quick help.. taking off front rotors
- The Bast Short Shifter???
- 96 electrical problems......help!!!
- thread size
- a/c problems.... compressor maybe?
- anybody get these?
- Why wont this work for 95/96 Clears
- Overdrive?
- Front O2 sensor
- I Know This Was Asked But Please Help Ground Wire Kit
- i rebuilt chain system
- Airbag light
- Headlights??
- knock sensor???
- Found out whats wrong with my car
- Necessary for lowering
- Lookin for a lip
- WOOT! 99 digital gauges in a 96
- Hard starting when cold
- what headlights fit on a 95 max
- EGR write-up
- Which MAxima Car Manual does everyone have?
- wrong section for my ?, but i need help
- Lamborghini doors??
- What exactly are synchronizers?
