- found solution to rough idle/misfiring above 3k
- My 97 wont start, what should I look for?
- Loud, Mean sounding intake?
- y-pipe is ruining my exhaust note
- I want your input. What should I do; fix my 95 max or buy a new 4th Gen?
- cv boot replacement question
- HELP! Highbeam indicator always on, and one headlamp doesnt work...
- Locking Nuts w/ Racing Hart C5s??
- do i need alginment after putting on rims?
- Checking Redlinemax and saw gen 3 Altezzas??
- NGK Iridium Spark Plug Question
- Replacing windsheid in NJ
- Voltage Stabilizer Question
- Stabilizes Floor Bar question...
- Just installed my turn signal mirrors
- where can i buy a carbon fiber trunk lid?
- Ebay-where?
- need new calipers!!!
- got the new custom maxima corner lights in today PICS!
- A bunch of updated pics!! check it out
- Which is positive?
- O2 sensors and Cali Spec
- BOSE nonfunctional
- New Tranny Advice
- Manumatic Acting Up
- Rear suspension problem
- Bad Tie Rods?????????
- 1st and 2nd Gear VERY NOTCHY !
- Does an ATF filler bolt exist?
- Stock intake box
- Team Voodoo Shift Knobs
- BOSE I30 Question
- AC actin up!!
- One day Left on Stillen maxima on ebay
- Window Tint Removal
- Can't believe that happened...
- tail light idea
- H&R vs Maxspeed
- 5spd shift points for everyday driving
- Side Markers that do what they are supposed to
- 5th gen tranny in 4th gen
- Rpm Gauge Flutters!
- how to change swaybar bushings
- Fluttering noise while accelerating....
- E.A. engine dress up kit
- Matt Blehm lower tie bar
- Help! Car keeps dying on start up
- Any1 Got Pics Of Ae Headlights?????
- Driver side axle...
- Maybe Upcomming GD on Split Fires Direct Ignition
- Tires For 4th Gen
- Verify part numbers
- Headlight brightness not the same
- Comment about 5th gen tranny swap
- photoshopped grill
- Problem, anyone else have the same?
- Why does my new Y-pipe sound like a 1980s compact car with a hole in it's muffler??
- belts size for no ac
- Setting the clutch to softer /99
- RPM fluctuation
- HID's
- who has RE-WIRED the car due to SERIOUS ELECTRICAL PROBLEM
- Apexi WS2 exhaust in **(pics)***, now i gotta install it, need advice
- spark plug gap
- 1 random pic of my/dads max
- 5th gen muffler on a 4th gen?
- Procarparts black/clear corner question..
- She's being prude and wont open up! need help
- JIC Suspension
- Any Danger of explosion with the 0801 VCVBV code??
- writeup for cutting down the stock Shifter....
- indigloe gauges
- Great News!!!
- radiator
- need advice on a clunk noise.....
- budget exhaust
- Computer in his car??!!
- Lost a Lug Nut B/C garage stripped threads!!
- Steering wheel still vibrates!?!?!?!
- help with curb rash(pics inside)
- Energy Suspension bushings
- Inside photo of 95/96 stock tails - post here
- Put stock airfilter back on and don't pass Smog? Any Ideas?
- my tach is going crazy
- Intake Tract Questions
- Need pics of 4th gens with a dual tip exhaust
- Glow Gauges Or Leds
- shaking problems / stalling sometimes
- Replaced starter 2 months ago, car acting up...
- Help out a newb, the Max stalls
- A/C Experts - Evaporator Question
- Socket to remove Spark plugs
- Who has ever received a CEL from installing an aftermarket intake and/or y-pipe?
- Intakes...
- All east coasters?
- 300zx tt brake caliper ?s
- Strut or strut/wheel bearing or CV joint?
- cleaning/replacing PCV, EGR, IACV Valves
- Headlight question?
- Why does my Maxima smell like shicrap?
- Ambient Lighting
- Tokiko Blues w/ low springs (2") ?
- Did I mention I love my Max....
- code P0133 => 0409...wat is it??
- Trunk Dimensions
- What is the purpose of the boost sensor?
- control arm and inner tie rod install
- Linkage Arm on Wipers
- Been on vacation for 3 weeks and now car wont start?
- Need Part Numbers
- Couple of camera phone pics: a lil update
- Off rail injector cleaning
- Anti-seize in lug nuts?
- code 0336? crankshaft position
- anyone have pics of a realy low max
- Replaced Thermostat, STILL reads above H after a few blocks...
- Driver Side CV Boot and Axle
- what do you think of these rims?
- Seriously considering racing
- PCV and EGR valves
- Polishing Question
- Warpspeed Performance - alive?
- What happened 2 the CF ionic kit?
- 120K Mile Service
- Poll: Y-pipe Owners with & without BITC
- Overfilled ATF and broke drain pan bolt.
- People with headers please come in!
- Lower ball joint replaceable?
- cant find coolant leak
- is a high flow cat worth the money ....
- Cleaning INSIDE the headlight housing
- 1st road trip on MAX
- HELP NOW!! how do i tighten the crankshaft pulley/underdrive pulley to 140lbs?
- Fixing a speedometer and odometer that work sporadically
- wrong tire size?
- Replaceing the left front shock mount
- Rear brake squeaking..yes just one! :(
- Y-Pipes been a bad boy!!
- Passenger Air Bag Cover, can it be changed out by itself?
- Need help diagnosing...misfire at idle...not sure it is coilpacks...help!
- 2 Different types of Illuminas for 99's?
- Welcome back from the army present for my cousin...
- Money well spent = feels new again!
- Alternator ?
- Funny shaking under the car .... :squint:
- resseting computer
- Help me with my car antenna!!!
- Nasty smell from AC -- I've read stickies
- aftermarket sidemarker turn signal pictures?
- exhaust question
- Clutch feel different day-to-day - smooth and quit vs. rough and squeaky
- PLZ LOOK: proof on passing emissions with a aftermarket y-pipe
- Liscence plate light
- Short Ram Intake
- Help w/2 issues! Catalytic converter and control arms...
- can some1 please make me a sig pic
- blue led 194 gauges
- Just Installed my VAFC in the Dash (pics)
- No more 4 x 4... finally...
- Ball joints etc...
- bought 89 octane
- AHHH Dead bird in my engine
- Disabling Power Steering??
- Aluminum trunk floor mat
- Wheels Torque Values?
- Got code 0702?
- I did the bright clearance mod. So far so good, but.
- Can breaks squeel when worn out?
- Still Reading Ks Code!!!!!
- Stripped axle nut
- suggestion on rims
- Best Springs/Shocks Combo?
- ECU differences b/w CA and Fed spec
- pics of euro clear headlights
- Reverse lights keep going out
- Replacing the Idler Pulley
- CV joints
- Connecting subs to BOSE system.
- twin turbo VQ30DE
- Painting calipers, where to put jack stands
- Any Wrapped Maximas?
- who makes good hyper whites or blue's?
- Bose Headunit fades in and out
- Brake issue---
- changing colors on my maxima.
- Spark Plugs
- how to tell if running rich or lean ?
- HID Projector retrofit - DONE - PICS - NO 56k
- Might Buy a 4th Gen, Need Advice
- Stock alarm
- need your help!! need everyones help!! i tink i blew my tranny again! help plz every1
- 95-99 Nissan Maxima Twin/Dual Air Intake Filter 96 97
- Shifter bushing review.... and RANT...
- A/T Fuse ---> Chk Engine Light
- Strange whining noise from motor...
- How to read Service engine soon code?
- Neuspeed lowering springs?
- Help with stereo
- Reoccurring ECU Codes
- Rain Woes
- left wheel making a noise.
- Burn rubber smell.
- Why does my rear driver-side caliper keep seizing
- bad day for my maxima( evergreen bad luck.
- 0504 = Automatic Transmission Control Unit Signal to ECU???
- Goodbye Doo Doo Brown, Hello Sexy Black
- Help, car wont start again!! (kinda long)
- 350Z / G35 Exhaust on 4th Generation Max
- Replaced Timing Chain Tensioner and STILL have a rattle!
- CE foglights?
- 96 Steering wheel to 97 steering wheel.... EXPERIENCED? Please step inside!
- The Green Fuild
- wheel spacers or no?
- Compression
- Worklog: Bi-Xenon Headlights Retrofit
- Why might there be oil on my sparkplug??
- Couple Noob Mod Questions
- So depressed... Got bad news from my mechanic, what do you guys thing?
- parcel shelf brake light removal
- rough idle when warm engine
- quick question y-pipe
- Hard Start
- Just got my suspension mod/tune-up bill...
- [B]Car sounds like a deisel engine upon idle[/B]
- Cracking/clicking when starting to move from full stop
- Help, passenger side driveaxle keeps failing
- cheapest Knock sensor
- fog lights
- Headlight Removal?
- JWT ECU for 97-99 Maximas
- TB question need some org members help...
- Final Drive Ratio of 4th Gens?
- Rear Beam
- any 4th gens have trunk open dash light indicator?
- Air Intake question
- pics of 4th gen on 6th gen 18's?
- Wiring to Cig Lighter Adapter
- Thinking about get Hawk pads and powerslot rotors...
- Do-It-Yourself Maxima Wiki (encyclopedia for how-to information on repair/tuning)
- Missed Maxeen's 200k Anniversary
- back up light problem
- Identifying ecu's
- Exhaust Experts
- Mass. inspection Visual Y pipe Check?
- Brakes very sensitive
- budget y-pipe, am i missing something?
- door wont lock
- What is this part called?
- OEM Parts needed for suspension swap
