- Leather repair question
- Speedo Problem
- Sounds system completely went out, head unit still works though
- where can i find a 5v source?
- jdm projectors ?any1 seen these
- ABS light goes on and off intermittently
- Heli Coil for Transmission pan bolts?
- 03 i35 steering wheel on 96 max
- After 3 Maximas, making the jump...
- Cleaning salt corrosion from sawblades
- HELP...Mushy clutch!!
- Pulley noise - harmonic dampener or other?
- RIMS for my Pearl White SE
- EU 2-step question...
- Front suspension member issue - Stripped bolt
- Newbie Question Reguarding Engine Oil???
- Weird Alarm Problem
- Sunroof won't slide back
- NEED ADVICE ON INSTALLING HIDS FOGS
- Anyone not like Tokico HPs?
- Door handle lining removal
- Engine bay makeover
- is there any way we can put THIS in our maxis?
- What to look for when purchasing a used 4th gen
- Clutch Advice
- Rear Caliper Question (sticking??)
- Shifter trim shape
- 5 spd tranny problem need help!!!!
- Urgent Problem
- Where to find the best deal on window motors.
- Code P0138
- High-flow cat or Test pipe? For better sound and perfromence
- Front Marker Lights???
- different intake?
- 97 5speed couldnt put car into any gear
- Resetting ECU.
- When you buy foglights for a GXE do you need to buy a stalk too?
- 2 problems: Doors lock when I slam LF door, leaking PS hoses
- Exhaust question
- HOW TO- 5.5 Gen Front Brakes on 4th Gen
- how to remove spoiler from trunk lid
- Finally I sold my I30.
- spent the last 4 hours trying to take off the KS *epic fail* any alternatives?
- Question about brake pads
- when the car is turned to "on" is the check engine light suposed to be on
- Where is the EGR valve?
- Stereo problems
- Has anyone gone to Autozone and bought a Duralast coil but instead got a Nissan coil?
- Installing LEDs
- Check engine light several codes
- What is this piece on the throttle body?
- help with greddy muffler sizes
- Is having extra HP in your car mess up the trans?
- do our factory anti-theft sound when lock/unlock?
- Dash, climate and radio lights turn off COMPLETELY when headlights are on
- Mulling Over Carbon Fiber But I Have No Experience With It...
- Significance of the C-clip on the drivers side axle
- how to improve D2 coilovers.
- Clutch problems
- rusted nut, strange question(s)
- XENON vs ,MTEC Halogens (4 kinds) vs. Sylvania Xtravisions
- help with codes
- 00vi(hood or no hood)
- Coolant Leak on 5th gen maxima (made it into engine)..
- 95-99 DiamondCut Euro Headlights OEM Replacement (Clear Corners? 95-96)
- didnt pass socal smog
- Thinking about getting a drop, and have no idea how to go about..
- Changed my KS. Got the CEL cleared the car feels no different...why
- Blower Resistor or Blower Switch?
- Is it save to drive on 2 strut screws ?
- Trying to rest my ECU and now SES light went back on... lol
- motor swaps
- Shaft: hub or splined end?
- How do i reset my ECU ( I HAVE Searched)
- P0400 EGR Problem
- spark plug gap? should i bother or no
- Congratulations to The Wizard! - The Wizard's Maxi. featured in Nissan Sport magazine
- womp, womp, womp?
- My hood wont stay up automatically
- no sound from stock bose system 95
- Ground plug help plz ...
- Bose HU shutting off randomly
- please help...car stalling out
- Going one up in tire size from stock?
- New Clutch/Flywheel
- For thouse who has trannys rebuilt/replaced what milage did u do it at? Auto only.
- att those who have headers on the there max
- changed my fuel filter and maaan was it dirty!
- Need some help, cracked oil pan
- Flash lights or beep on unlock?
- Better for HID's? - OEM Cefiros, aftermarket Cefiros, or R34-style?
- Imput Shaft Bearing or Throwout Bearing?
- new/solid motor mounts???
- Power Steering Fluid Leaking
- fuel filter the out side is down or up?
- Difference in A/C condensers?
- fuel filter placement question
- Clutch Problem?? HELP!!
- obx catback.... 97 maxima
- Are our AC systems designed not to activate if there is not a certain amount of.....
- Where is the ASCD control unit located?
- 10" sub in between rear 6.5
- Just a recomendation...
- Tranny makes sounds after rebuild.
- out with old, in with new
- I'm Desperate, what is wrong with my dam car?
- stillen or Magnaflow?
- Wierd A/C
- Spoiler Light - Model PUT-SB-001, 4 screws... approx 20"
- Maxima lowering question
- Where to buy ASCD clutch switch?
- 5 speed swap concerns.
- running amp wires... help
- Anyone know what this is?
- Spring Recommendations for Illuminas
- cars been pulling very crappy... Time for tuneup
- Flashing airbag light on 99
- Low gas indicator light
- Rear wing
- DE-K have different mounts/brackets?
- What oil filter do you use in your 4th gen Maxima?
- does 98 come prewired for powerseats??
- Couple wiring questions...
- Foglight problems
- just wondering how much would it cost to convert to stick.
- Pulling off viynl on rear window
- Ugh.. this is starting to get on my last nerve
- :))) HAS anyone thought about tan leather seats in black maxi
- Radar Hardwire *Pics*
- check engine light IACV related
- maxima twin turbo?
- Pondering battery relocation, Have questions.
- Am I missing something?
- need help, ball joint or control arm ???
- Bose Eats My CD's....
- Bee-r limiter installation
- Code p0420
- Need clutch / clutch pedal expert help ...
- Question about 97 maxima car audio system
- What would you do ??
- A/C smells bad, I tried Lysol, something's not right!
- Cleaning Maf video
- Ebay ignition coils
- Can't find the leak....
- Im back and im black :P
- spark plug stuck in the engine
- Help w/ P1605 OBD II Code
- alternator question
- Noobie Brake Noise Problem Question! Help
- QUICK: should my buddy buy this max?
- What is wrong with my car!!! trans issue? chime in maxima proz
- removing "maxima"
- Over the next few days ill be changing my transmission, questions and pics in here
- 1-10 how hard is it to change all oxygen sensors yourself.?
- where is the brake booster vacuum line located?
- Want to make clear lens stock fogs
- For Remote Start Install....
- Got an oxygen sensor code. Whitch sensor to change?
- A/C Compressor/ECU Ground Question
- New little experiment
- wiring question...audio related...
- Misfire Question, suggestions needed.....
- Brake master thoughts...
- Alternator keeps dying. 5 alternators in 9 months
- EGR ROFL
- pathfinder sc
- VERY firm rear springs?
- Anyone Know Koolseven?
- Maxima value??
- I want your opinion.
- 2008 NOPI Nationals Canceled
- SPEEDO HEAD
- $20 reward....replaced fuel injectors, now car wont start...
- Headlight leads
- Dropping the car with monroe struts
- Subwoofer mounting question
- Double-Din Stereo Question... JVC KWXG500
- HELP PDQ
- What is a "vacume leak" ?
- Question About coil packs
- dumb question
- Powder coated stock se 5spk wheels
- h3 luminics yellow
- DIY: Cheap Lip Kit?
- MY First Car
- how much cooling do the fans really provide?
- newb question - spark plugs
- car choking, after $500 nobody knows what it is
- What does "check grounds" mean?
- Strange sound
- Knock Sensor?
- CV Boot replacement
- brake problem
- car wont go into reverse
- weird hesitation
- Rear Window all the way down
- PW issues! no control/locks on D/S, P/S window stuck down!
- 96 I30 a/c compressor stopped???
- Hard start hot and cold, but runs awesome.
- Air Bag Light! make this a recall? Who wants in?!
- Red Clock?
- Trying to install warpspeed B-pipe, rusted nut?
- When to shift while driving?
- What else?
- Speedometer/Odometer issue - 1996 SE Max
- 2200 miles, over 30 hours of driving, 6 states, and 6 tanks of premium.
- Is there posiblle way to put steering cover on
- Simple exhaust question
- Horn stopped working. Help
- Misifring..?
- Fault codes!
- Tinted My Tails "PICS"
- what happend to the VQ power link?
- Intake Air Temperature Sensor
- leds in a 4th gen?
- 1997 SE - NO AC - Fricken hot!
- Somewhat of problem...
- Couple Hardwiring + EGR questions
- hood spacers?
- Who has had to replace their Drop Resistor?
- Front End Noise Mystery! HELP!!
- Need wiring diagram for Bose radio
- Read tire is wearing bad.
- TPS diagnosing
- Rear multi link beam
- coolant leaking b/c of new radiator cap???
- Help! Misfire or something else?
- things to do
- Maxima or no maxima?
- which oil and filter for my situation?
- Warpspeed Hanger....
- Fixing broken clock?
- trunk key hole question
- Issues-need advice!
- New to the forum...
- Fuel Filter Fuse
- yet another suspension question
- '96 Steering Loose Help!
- fuel disappearing, what can be the cause?
- P0153 sensor Location
- 4th Gen Suspension in a 2000?
- My car definately starts
- Squeaking/Clicking Noise
- griding noise in front of engine
- Sorry, but this is another "Starting Issue" thread
- clutch problems!!!
- Exhaust rattle vibrations...annoying and need help?
- Another problem...maybe
- car problems need help
- Rotors
