- Lawd if you listenin, HELP!
- A/C Problem. 95 w/ auto climate control
- rear license plate light bracket, screws rusted...now what?
- Couple Clutch Questions
- harmonic balancer
- Car wont start after sitting months
- Radio Fuse Blows When Braking..?
- AEM fuel/ignition controller
- Z32 rims, now with color!!!
- HID questions
- Put in new/used Transmission OR new car?
- Where to get parts?
- What do you love about your maxima?
- knocking over bumps.
- Lower my 4th gen on stock 16" SE wheels?
- Odd A/C problem
- I GOT MY CAR BACK!
- aftermarket sunroof
- Just got a 1997 Maxima, black SE
- Noob 96 transmission questions
- Its been fun.
- 96 maxima unsolved problem
- Happy...Front end completed!
- Fluctuating Idle. Possible IACV?
- 2 step launch control
- Local Car Meet showing Maxima Love
- Properly grounding alternator
- Oil Leaks - What else to replace w/ valve cover gaskets?
- Got pulled over and....
- 3.5 Swappers LOOK!!
- gass gauge randomly broke? wtf?
- P400 & 171 system too lean.. egr..
- ggenius has turned a over new leaf
- 31 mpg averge in my max
- VSS and Rev Sensor codes on TCU, Code 54 on ECU
- Autozone injector won't fit
- Trunk Lid Question 95-99
- interior question for the interior guru's
- Weird ANNOYING Awful noise
- Rpm raves up them drop back to normal
- big LOL. many europeans can't tell an a32 from a b14
- Looking for part, Serious help needed.
- '95-'96 CF trunks!!
- 95 maxima rough idle
- help identify where this vacuum hose should go
- EMISSION ISSUES
- Recalibrate Tachometer??
- Why you shouldn't use an aftermarket radiator support......
- Always Illuminated Manual Climate Control - Is it Possible and How?
- Temporary KS resistor mod?
- Want to drop a vehicle lower?
- Is it just me or...
- Projector retrofit
- Rear Suspension Issue-Exhaust Pipe Hitting Rear Suspension Beam
- mpg suffering... is it this??
- Max1008's Build thread
- Black 99 Se mANUAL not running.
- Control arm splitting
- Oil leak out of starter...
- Sparatic misfiring, runs but dies when driven, started after engine wash
- Any reason to go w/ clear used OEM headlights or new aftermarket?
- Limp Mode Woes
- car problems and confused
- Poll: Auto transmission clunky shifting
- hitting up junkyard this week anyone need anything?
- '96 GLE won't crank
- To sell or not to sell..
- Cant get rear caliper cylinder to push in.
- Blown Headgasket on a Maxima ?
- how to install the stillen clip?
- Evap canister charcoal leak
- New Maxima!
- P0446 Help needed...
- Starting problem = Stupid battery cable design
- Nasty old fuel filter!!
- How difficult is to to replace the A/C evaporator core?
- Retrofit question
- Curious: OBD Consult w/ TECU Software
- Stuck rotor/bolt size...
- Clutch pedal adjustment
- Front driver side stiff is hell and other side soft?
- Progress RSB
- Axle boot leaking grease
- exhaust
- Change springs alone or entire suspension?
- Trying To Locate a Photo.
- Parts to Order for Water Pump Replacement?>
- odometer motor repair within cluster ?
- Part name? Possible vacuum leak? Low Idle
- Thumping when *slightly* turning
- Finally got some sound clips of new exhaust
- Front And Rear Lighting Problem
- Bad day but all is well
- Poor idle after changing valve cover gaskets.
- 4 banger in a 4th gen?
- How do I cut off this pivot joint on wheel hub?
- Addco RSB Installation question - HALP!
- Tire and Rims Question
- REPLACE CROSSMEMBER BUSHINGS QUESTION
- Clutch Q
- Found crank pulley bolt loose, resetting timing necessary?
- Car Wreck and Airbags Deployed. Car will not Start
- Warning: When changing front suspension!
- Where Does this connect???
- Would a vacuum leak really drascally decrease MPG in our cars?
- Intake problems
- front sub frame
- still overheating
- Low voltage courtesy light
- Help: after cleaning EGR, car has rough idle and stalls
- anti-theft system/car won't start.
- New *****?
- bad thermostat?
- Control arm bolts
- failed e-test horribly(posted results)
- Rear valve cover breather filter
- P1497 code?
- Knock Sensors
- in need of a EVAP PURGE VALVE
- Front end questions
- Spark plug tube seal question
- Shift fork seal????
- secruity problem
- car won't start
- tein s tech
- Here is my paint job
- Bank 1 Sensor 2 - will this fit
- Just won't run right....and I'm stumped!
- Do you buy the front wheel bearing as a whole assembly? or by itself?
- Waterpump housing fix????
- AIR BAG REPLACEMENT
- Rusted bolts
- Dual alternators
- exhaust
- Ok, anyone else have this problem?
- Official 00VI thread
- Weird starting issues after swap
- Can bad crankshaft pulley cause belt squeal?
- hard starting only start when pumping the gas
- just wondering?
- Maxima- AIR RIDE - 1900, Opinions/thoughts
- air conditioner problem
- Power steering hose routing? Rubbing against A/C line
- Stripped Caliper Mounting Bracket Bolt
- Car wont start
- problem with power steering pump belt install
- engine swap - starting issues
- Part #? [EXHAUST PIC]
- Strut mounts broken twice in 3 months
- car wont turn on
- P300/P1400
- 02 Simulator
- willl not take more than one gallon of gas
- 1999 SE Cali Spec Exhaust help...
- opinions needed
- bendix brake pad experience?
- Bellows Boot and Fluid Leakage
- HAZARD/WARNING LIGHT SWITCH
- Something loose in my transmission
- post pictures of your 4th gen with NON-Nissan OEM wheels...
- 2002 I35 horns = 4thgen
- shocks and/or struts
- Clutch problems
- Blown VQ30DE!
- Need help! Transmission swap
- I have to know...
- 5th Gen A/C lines in a 4th Gen
- 02-03 iv swap
- 4th gen VQ35 swap
- building the best! lets do this!
- Air conditioning issue (from texas so it's hot here!)
- 4/99 Brakes different from the rest of 4th gens?
- 5-Speed 98 Maxima SE-L idling disaster!!
- Goodbye everyone :/
- Black Bumper light for a good 50 shipping and all
- GTR alike taillignt,, where to buy?
- Matic D for 97 Maxima tranny ?
- 4th gen electrical
- new rack and pinion is leaking out of high pressure line
- Crank But no Start
- NEED HELP WITH ES BUSHING DIMENSIONS
- Fresh Oil is black after just changing.
- typical leaking trunk
- 5th gen motor in a 4th gen?
- Need a new Cluster because I broke my speedo tryign to fix the odometer. lol
- Rack and pinion, new, used or remaufactred?
- high pitched whistle and engine hesitation
- Prestone phosphate free
- How can one dampen engine vibration in the cabin?
- Help with steering wheel!
- used maf?
- need advice on oem flex repair?
- E Brake not holding on passenger side
- any one running MB battles?
- A/C Alternator belt question
- EGRC Solenoid Apart
- Official Special Application Maxima Discussion Thread
- Kensei exhaust review (ebay exhaust)
- seized caliper ftmfl!!!!
- Two years on the .Org so far
- Engine swap - I30 with maxima california model
- Almost $1000 later, noise is still present.
- Hard start, not your typical maxima issues
- There's 2 4th gen SE's at the boneyard!
- crazy coolant leak (pics)
- ANYONE KNOW O-RING SIZE OF CAMSHAFT PS?
- #Random Are the 95,96's smaller? lol
- removing starter. 2 bolts off. still wont come off?
- Anyone else have a rough ride with tokico hp's?
- Getting my car str8 piped(no cat)
- Reintroduction. Same Me,New Car !
- timing ring bolt torque spec
- car stuck in park
- EGR Pipe Sensor
- Alternator Problem?
- immobilised or crank sensor
- Charging problem.
- help with issue of fluttering @ 2000rpm
- anyone have a ks wire diagram for cali motor?
- Oiled air filters and maf problems survey
- dealing with evap code please help
- Sensen from apx review
- ddm tuning hid kit install issues
- windshield washer pump... wtf?? ghetto DIY instructions???
- Stock Exhaust Question
- Anyone know diameter/size of power steering rubber hoses?
- 95 Max - P0701 & P0304, No power, rough idle
- I haz exhaust project :)
- 4th gen maxima.org maximas are on youtube #2
- Starter went out with a fzzzzz
- questions about solenoids & trans-go shift kit
- Cooling System problem
- vq35de intake mani swap to vq30de?
- Ghost Codes ?
- A witty title that explains everything.
- Exhaust took a dump..
- Help: Hesitation Issue
- Bitten by the mod bug.... any cures?
- help with knock sensor change on cali motor
- Knock-off/replica wheels
- Strange gas needle / gas tank symptoms.
- Headers for 3.5 swap in a 4th Gen...
- I need a Maxima guru!
- 95 Max - Soft jerking at idle
- Check you gas tank straps......
- Picked up a 5 spd 1995 Maxima SE
- A32 Tribute #2 is almost done. However....
- big bass, little maxima. hello everyone
- Hesitation/stall on 97 Maxima
- submodel?
