- loose/noisy strut
- Will I fail emissions if....
- Dyno close to Albany, NY?
- Y-pipe install, help!!
- Looking for a Left Front Knuckle
- Thinking about buying a '99 Max
- Black 95 Part Out
- Just installed my triple gauge pod
- Control arm question
- Just a Rant on "what to do first"
- Dash Board Light Bulb Type?
- Drive Axle Brand Preference??
- Retro-Fit Projectors...E-46
- Where to buy Gauges?
- Rear Brake Assistance
- 97-99 Red/Clears on Ebay
- Manual shifter trim piece is hard to find!!
- MEVI Parts
- anyone swap out there radiator fan assembly?
- Will this mess up my new wheels?
- Introducing myself
- What do you think ABOUT this exhaust?
- Best Place for buying Redline MT-90 or Amsoil MTG?
- New Grinding Noise- What to look for?
- Newbie With Brakes
- Engine idle speed
- Help Unusual Car not starting
- Any tutorials for clutch cylinder R&R?
- Factory bose stereo static?
- idle pulley nut
- Clutch has no resistance!
- Carfax Anyone
- Bad starter causing faux-CPS code?
- Auto Climate Control Lighting Issue
- If not faulty ECU...what could it be?
- Cleaned TB, but now have Service engine soon
- How do you know you should change your spark plugs?
- Improving manual shifter feel
- New hood struts
- Updated Ignotion Coil Identification Question
- Radiator hose fell off -- how messed up is my Max?
- HOw to remove the front bumper in maxima 1997
- vq35de 4th gen 0-100 accel clip
- Does any 1 have a performance chip in their max
- Cant replace antennae
- Best way to get rid of teh CEL for o2 sensors
- what does the EVAP Canister Purge Volume Control do?
- A/C Problems Still !!
- If you replaced the auto tranny, what was the reason?
- will full-size spare fit in donut compartment?
- For driving in rain, is running with more air or less air in tires a benefit?
- suggestions about low hanging b-pipe
- 2" drop, now problems
- OK i made a boo boo 9660rpms recorded
- backed into car > back lights no longer work unless pressing the brake..
- Front End Makeover - Failure (Pics)
- Car won't start??
- Can someone with a 5spd do a quick experiment for me?
- oil filter question
- my spoiler broke off today...
- Starter Question - Photos Inside!
- just got a 96 GLE in excellent condition..got some questions
- Which headers are these?
- Mevi's Rod contact points
- Need suggestions for reducing body lean on turns
- seat
- Steering stabilizers
- Mevi with Stock ECU
- exhaust break-in?
- guages shroud rattle
- Exhaust Help?
- rear camber adjustment
- Headlight missaligned...How to fix?
- Cano someone identify this connector for me?
- New Magnaflow exhaust way too quiet?
- Will a 3rd gen altternator fit my 4th?
- MEVI Gasket
- 99 Max Gone :(
- Weird Starter problem
- Crazy alternator problems
- Water Pump labor and cost whoas...
- '95 Maxima cranks but doesn't start
- Exhaust crossmember, do I need it?
- Whine under the hood..another one?
- Help, Windows won't roll up or down, Sunroof out
- Dash lights go out when lites turned on ?
- Should I do it?
- Does anyone know which one will work in my car
- I need the PN for Crankshaft Position Sensor
- Replaced the clutch, now the max doesn't move at all.
- UDP Subs Dead Alternator?? HELP
- thinkin about changing my Setup
- Planning on doing a small tune-up to improve mileage.
- 0908 Ects, Now 0302 Egr.
- Could premature wheel bearing failure caused by cheap axles?
- Question about knocksensor and small evap leak
- Axle Seal Part numbers?
- Front Bumper Removal
- Summit Switch
- A/C Fully recharged but not cold enough
- Kinda annoying
- Need Carfax Report!!
- TechnoSquare ECU
- cv shaft needs replacing (aka help for the mechanically inept)
- manual transmission fluid question help!
- How much have you invested?
- Gauge making sound?
- whine from hood area (haha)
- Driver front grinding/rubbing after Ksport install
- rear seats
- Need help on rear end sagging!
- Help me decipher this error code.
- The y-pipe is nice... but my resinator had a big hole on top... so loud
- vq35 swap done
- I need a dent remover tool
- Lower Control Arm
- Ksport install with pics. Possible writeup.
- Trying to replace my control arm bushings...help
- Just put motor and tranny back in and the car will not pull!!WTF
- Launch Control?
- Anyone running lowering springs on stock struts
- EVAP canister valve
- hti a skunk....
- Friend Crashed Maxima, seeking advice!
- Ignition problem
- A couple of questions I'm hoping you guys can help me out on a few things.
- Looking for ideas - Removing ABS Sensor from Knuckle
- WTB: JWT ECU with ext rev limit
- Quick Question - Limited Slip Differential
- Quick question tranny oil capcity
- Wtb: Stock Bose For 96 Max
- ECU replacement or reprogrammed
- Lets see your gauges
- Parking Brake Mechanism siezed - any ideas ?
- Good for my 4th gen or not
- Had some extra time.
- Stillen Lip After A Crazy Night
- Please help with knock sensor
- need some quick electrical help...front speaker wire
- Showing off my custom boots...*pics inside*
- Does any 1 have a Monza, Cat-Back exhaust system from summit
- A/C Problems
- poor gas mileage?
- 5spd Peddal set - aftermarket
- Brake troubles!!!
- Torque Wrench question....
- Easy brake pad questions
- goodbye my baby
- Crank but doesn't start, part 2
- illumina strut and spring kit? How are they
- removed that fading vinil off the pillars!!!
- leaking axle seal
- Dupli-Color Vinyl and Fabric really works!!! *pics inside*
- Metal grinding near pulley area
- Does adding a y-pipe decrease mpg?
- Is my starter the problem? (video inside)
- a/r gauge vs in cabin fuel psi gauge
- Passenger side CV axle
- Wiring a kill switch
- expensive maximas
- Maxima sputters
- O/D light not working
- cant remember about springs...
- Raked Stance or Just Hug the ground?
- What can cause this?!?!
- So i got a 0702 code driving today!!
- To Hell with Chrome!!! Now what??
- Weak trunk springs
- Replaced your radiator/heater hoses?
- Code 0407 - CEL Flashes intermittently
- awww jeez another HID retro!
- auto tranny hard shifter problem
- Same problem with my car....
- Where to get OEM parts
- Crank but no start
- $595 a reasonable price for a custom exhaust??
- legitimate question
- Beep Horn with keyless entry?
- Told that my engine is going to fall out?
- Odd running problem.
- Highway Vibrations
- Carbon Creations CF Hood + Aerocatch Hood Latches
- Engine mount
- Gas gauge doesn't read full
- popping noise when pumping brakes???
- Q about manual tranny...
- Inaccurate gas gauge...
- Front Shocks leaning
- Huh? Fuel Pressure Gauge maxing out?
- Suggestions or ideas????
- E Brake light???
- Megan Racing Catback Questions
- Adjust trunk???
- TS ECU (stock rev limit) vs. MEVI
- Header Removal - EGR Valve Large Nut
- Trouble
- I installed a CAI today and I have a feeling the filter is going to fall out
- Noise is really annoying the **** out of me....
- oil pressure light help
- This will fit right?
- Hood Risers
- A second look at the 4th gen brochure (98)
- Trying to spread the word
- Adding air to tires on a full tank?
- O2 sensors
- Help drivers side light doesnt work
- BlueBatMobile 97-99 Yellow Fogs
- Broken Window (Falls Down...)
- water under carpet
- Will this fit a 1997 maxima gxe?
- who can do a carfax !?
- transmission signal to ecu code????
- body molding fix
- has anyone ever experienced exhaust leak with this setup?...
- starting problems
- Got out of the hospital today ... Maxima gone
- A/C Issue
- Looking to buy new 4th gen
- heated mirrors?? Please help
- Noise when not accelerating or braking?
- Switched to 93 tonight...
- How much do you think my car is worth?
- High Milage?
- PO133 oxygen sensor
- LED mirror shells....
- header install write-up
- I love my Maxima.
- A question for the 5-speed rebuilders
- shaved body moldings
- Can't find the CAI 3" hole template
- front end thumping????
- suspension ?
- Leather Steering Wheel Repair
- optima red top
- knock sensor code, HELP!!!!!!!!!!
- Y-pipe, Knock Sensor and other stuff...good weekend.
- auto headlights
- acceleration problem
- help=wheel spacers
- 00vi gives P1130...
- A problem on the road
- Very uncomfortable ride....your opinion
- Has anyone even bought one of these chassis kits?
- help hurry cant read codes
- anyone have the cattman headers/y-pipe combo for a 4th gen?
- steering wheel removal
- chip
- Lower temp on auto Climate?!?
- no injector pulse and no codes
- Y Pipe ?
