- help i need tires .
- Gen 2 Altezzas
- specs on the car
- Head light bulbs...
- 225/50 16 or 225/55 16 tires on 99SE
- Throttle Body
- Fast And Furiuos Hood !!!!????
- Got a 97 SE 5spd =)
- how is the ride in a manual?
- have anyone seen this cold air intake?
- rear sway or front strut??
- I shaved for the first time....lol....
- Where to mount the air temp sensor????
- Intake Temp Sensor mod, no not E-Bay
- PCV - wrong one for my 99 SE !!
- cornor lights
- Lighting Question
- Maximas Have Crappy Clutches?
- Maxima widebody kit
- Cheap Body parts? fenders-hoods etc..??
- Aerogear makes a carbon fiber hood for 4th gen
- No more engine codes!
- Fog lights dont work
- In that 95 turbo max complilation video...
- Hid's For The Maxima?
- Color Leds and Rewired Fog Lights????
- Advice on Underbody Neon Kits
- Brake Caliper Piston
- Is it Possible to Repair a Tach? How does the Tach work?
- Tune up????
- Summer Tires or All Season ???
- Silverstars
- Does jet work?
- fog lights
- Stillen Intake Q's
- Weight of beam axle?
- Pretty Interesting Stuff about the LSD Manual Tranny's !!!
- Gas smell when i turn on heater. HELP
- polarG hyper red 1157
- Knock Sensor
- Spark Plugs
- Vertical Door Mod
- Anybody have the Skyline kit for thier max?!
- Haynes manual electrical help..
- Air Ride Suspension
- power steering problem????
- Dim Headlights
- question on slave cylinder and hydraulic hose
- Anyone have a '96 stock muffler?
- GC Coilovers Installation: Is there a write-up available??
- 95 Maxima GV immobiliser problems
- What is a good price for stock y-pipe, cat and b-pipe on a 4th Gen?
- Just got back from the Nissan dealership...stay out post whores
- Compression and Leak Down Test
- Best gap for NGK Coppers
- Tranny swap do it yourself or pay some bastid!
- cheap way to get a cold air intake
- Which break pads to get for my Maxima?
- Got 03 02 code: help!!
- Stock shock with either maxspeed or h&r springs?
- Is it harmfull to keep using my OD button?
- LSD Manual Transmissions Part Numbers
- Sam feels like venting
- where can I find a shift kit for the 4th gen?
- New to the .org
- Maxima GV will not start, immobiliser problem
- putting a vq30 or vq35 in another car?
- Really BAD Wheel Hop !!!
- WTF? ECU Different? Help!
- 99 Ecu
- supercharget advice on auto
- Intake Suggestions, whos the best for the money
- Silver 4th gen?
- mini Nissan emblam for 95/96 steering wheel...?
- 95-96 Maxima Red/Clear Taillights
- What color should i get?
- NEW PICS OF Pearl96max's MAXIMA (warning dial up'ers)
- Finding the pcv valve
- 96 Grill?
- New to Maximas--Trim Line Question???
- cel After Battery Died
- Twin Turbo For 4th Generation Maximas!!!!
- Driver's Side Door Broken Window
- Cattman RSB fittment issues
- best exhast set-up out their (Quiet)
- Front Timing Cover O-Ring
- Does anyone else's 5 spd lurch in 2nd gear?
- Aftermarket H3s crack fog light lens?
- question about the roof wing
- Code 0505 (No Failure Recorded/Detected)
- Tell me your opinions on the UR UDP
- Code 0707
- E-brake light
- Wheel Hub: Anyone know what it will cost?
- Sunroof sticking...
- What do yall think about these rims?????
- gold package
- blown oxygen fuse--Why?
- Side markers
- Exhaust Installation $$$
- I just bought a 4th Gen 5 speed!.....hooray for me!
- 98 Max SE- 91K miles, Automatic
- brake bleeder screw size?
- Big difference
- ebay updates: new reverse gauges 95-97
- removing pin stripe
- E-Bay O2 sensor chips worth buying???
- 4th Gen Maxima model car ( sort of)
- n00b question: y-pipe v.s. header
- ECU question
- Best aftermarket bumper for an otherwise stock MAX?
- light bulb question
- I Can't Find Auto Insurance!
- Mini nitrous
- Oil Presure GAUGE
- High Wattage Bulb WITH harness
- acceleration is slowly getting better
- PCV valve hose question
- No more "umph" from my max
- buying 99 se
- 0304 & 0215- anything special about this combo
- Who's got a MSD 8950 rpm switch installed
- Just a thought...
- has anyone gone from aftermarket y-pipe to stock y?
- Brake Problem - Sometimes severe Grinding or churning
- Recall question
- Better Rear View Mirror
- Have Any of you Replaced your Bucket Seats? Questions
- piston and ring size??????
- Advantages of a CAI
- How many 5-speeds vs. automatics?
- For those who removed their cat shield for STS clearance
- O/D light blinks....
- Which setup kit for Walbro 255lph fuel pump?
- Car Care Question
- Reverse Indiglows Help!! Got jerked by eBay!!
- Wheel opinion..
- Denso Plugs for VQ30DE. IK20 or IK16? or Should I go NGK?
- Concerned with sound of starting car
- Airbag Suspension Vs. Spring / Strut Suspension
- 96 maxima
- Bucking Max
- What is the formula for a NA 13 sec ?
- y pipe smog
- How do you take out your headlight?
- gettin water in ur cai
- warpspeed y pipe question
- light shaking in idle
- Starter Motor Fun!
- does any1 have lowering springs with stock..
- what do you think of the randoms hi flow
- Short Shifter....Is it worth it?
- all those with automagic's
- Differential Bearings on I30 LSD and Canadian Maxima LSD
- anyone want a photoshop challenge?
- HID's
- anyone put decals on their max
- Factory Flywheel??? Part #s?? HELP ME OUT!!
- Place Racing CIA
- Emissions w/ aftermarket Y-Pipe
- Review: headlight lens restoration kit
- NEW pics of the MAX
- Where can i find the cheapest y-pipe?
- new polargs
- My car belt is squeeking, the black belt
- Brother trashed the max, he can have it back
- I only had my new max a week before i did this to it...
- dust covers or center caps for my 16s??
- OEM Spring replacement needed. Thanks for any info..
- Caliper sticking do I need to replace the rotor as well?
- prob with JIM Wolf air intake/ambient temp snsr?
- intercooler piping
- What size exhaust do you run??
- I need to know the 99 SE/ GLE difference!
- Best low end torque mod
- Some good 300ZX caliper info.....
- TPS sensor
- scratched paint
- nissan really moves with recall
- start up problem PLEASE HELP
- error codes and hard starts
- Starting it up
- My auto made me so proud yesterday
- Cam Position Sensor?
- K&N Cone Intake leads to MAS failure?
- UGH - Sprint Spring/Suspension Help
- Rear tail light? for people with 95/96
- WHat's MEVI?
- Automatic Turbo coming in Jan
- HELP...My car just shut off while driving......
- Got a nasty Scratch and need to get some Nissan Paint
- how many 4th gen 5spds?
- Offset for Katana C5s
- Will Straight Pipe Damage O2 Sensor?
- royal purple
- My Maxima Took A Big Hit, Today. I'm Sad.
- where can I get dc corner lights?
- Synthetic MT Fluid causing leaks?
- New lowering springs with stock shocks
- Question...
- headlight bulb problems...
- omg.. im getting terrible gas mileage..
- My vin says GLE but...
- Shift light install help!
- Custom Maxima's projector headlight housing?
- spray paint the spoiler?
- IS this a good deal? please help
- Hit and run
- how much is your car insurance?
- Red Translucent Vinyl tape?????
- No power to cigarette lighter
- Had a go with a Corrado G60....
- Storing car for winter
- cheapest price for knock sensor
- Good deal on this Maxima??
- Brake job / upgrade help
- questions on auto zone parts
- getting y and b installed today
- topping off fuel tank ?
- Rwd?
- Spark plugs
- why two grounding points on same bracket?
- some of you lighting guys may like this..
- my car is sitting for 3 weeks
- Dash Kit
- Need For Speed
- CM discount code?
- Car wouldn't start...
- Catback
- Error Code 0102 (Mass Air Flow Sensor) *Help*
- Photoshop Help
- 1999 SE with Stock Chrome SE 5 spoke wheels
- Battery or alt. problem?
- strange noise....
- cold starting trble
- what to get: UDP or Exhaust??
- Heated leather seat question
- Check out my updated webpage...
- Car keeps cutting off and slips in reverse any ideas?
- Want Good Sound
- Apexi WS muffler to 2k1 muffler...any loss in power?
- Rattle drivng me crazy
- Place Racing vs. WarpSpeed CAI
- Which is the better 1999 5sd, se ltd or gxe
- Visors
- red/clear taillights
- 5spd conversion
- Thanks Maxima.org - 60k tune up
