- are the ebay intakes really worth it?
- Anyone know where I can find the indiglow gauges w/o the big blue thing in the middle
- Fixing transmission notchiness? Honda transmission?
- Nissan Maxima Jdm Black Bumper Lights???
- Will It Bolt On !
- How to change rear license plate bulb?
- price of converting 96 front to 97+??
- 95-99 fog lights mounting question
- Stillen Body Kit
- replacing 96 trunk W/97 for taillights?
- Which would you do first?
- Removing grill
- Just installed Techonosquare ECU for my MAX!!!
- Siren in passenger compartment
- 02 spec v with intake vs 98 maxima se auto stock
- Subframe connectors, who has them?
- exhaust
- car wash=frozen maxima
- Energy Suspensioni Lower Control Arm Bushings Replacement
- 96 or 97 Max se Adding performance
- Strip Question..
- whistling at high speeds
- Bodykit Question?
- Lowering the Max.. help
- Stealth Box from JLAUDIO for 98 maxima, your opinions
- Blinker Help
- cold idle circuit (plunger)
- Bumper Removal Process
- Will these fit
- Finally got my homepage up
- what the heck did my tranny do?!
- Map lights- what kind of bulb?
- 4x4 Skyline
- BACK to the .ORG
- 99 Maxima SE-L vs. 97 Grand Prix
- CEL codes please translate
- Shocks/Struts for Eibachs
- ignition coils
- cylinder head volume help
- Clutch Question
- How Do I Get Rid of My Suspension Noise?
- Terribly unexciting: Another Maxima with a full Stillen body kit w/tinted tails
- front strut bar installation on a 99
- grinding noise from rear brakes
- Need Advice w/ Error Codes on 99 SE
- Jet performance chip
- fed spec or cali? how to tell for y-pipe?
- leds in manual climate control
- can someone check out this vin# ?
- Stripped the bolts in the bottom of my auto trans.
- Smashed the max... Stillen Survives :)
- camber question
- Is it okay to take the screen off the MAF sensor???
- Will these fit 19X8.5 MILLE MIGLIA EVO5's??
- Acc. Belt replacement help
- How much did you spend on your suspension?
- Body Kit combos
- timing chain
- AutoQ's
- Is the HEAT SHIELD really Worth it????
- 96 maxima gle vs 2001 mustang v6
- i dont understand this....
- Porting ECU codes and car monitoring to a PC
- which shocks are better
- Some Kills for tonight
- Taking apart the tail light?
- Anyone tried the Wagner Truview Bulbs?
- Help me get rid of 4x4 look
- Help! ECU codes after GeForce ECU install
- What should I match with H&R springs?
- Installing rear spoiler
- Pulls to the right - Brake
- 2nd Battery in parallel with main batt?
- Alarm Beep relay ?
- Bixenon Headlights= Bad News
- where can i purchase 2 additional clamps for progress/addco rear sway bar?
- Starter problems ???
- click click click
- colored #74 bulbs on ebay for our 98-99 clusters...
- 1997 foglights needed!!!
- Thermostat Question ?? Cold Winter...
- Answers to super reposted questions! PLEASE READ
- Can someone run a VIN through CARFAX for me?
- Intrax Or Progress?
- indiglo for 1999 SE?
- Pacesetter STS vs B&M (or others)
- REprogramming your keyless entry?
- Installing leather door inserts.
- Underdrive Pulley
- H&Rs on 4th Gen w/ MANUAL Tranny- level, or high in the front?
- Best shocks for 95 SE? and where to get?
- Very Nice car computer mod. Not on a max but could be implemented on one.
- Turbo or Bullet Proof Tranny?
- Trenz Lower Valence Grille Question
- sell my 95 maxima for a 98 maxima 5 speed?
- 1995 BMW 325 for my Max? Ey?
- tranny rebuild and 2nd gen valve body
- Update about RedlineGoods.com leather boots
- Need advise - Vibration
- Wiring up an aftermarket spoiler brake light, got some questions.
- Car Just Got Broken Into!!!! Need Help!!!!!
- wheels hubs...
- transgo do it yourself valvebody mod
- which tranny cooler to buy
- Car slower with intake
- This is ridicolous!!!!
- how do i change the bulb in sidemarker?
- Who would win?????????
- What exactly is the VB Mod??
- Why aren't I getting emails from my posts?
- carbon fiber vs poly-urethane
- bad gas mileage
- Springs replacement
- After installing y-pipe + race pipe wierd CEL code..
- My brights work but my dims went out
- possible cv joint problem
- ACT clutch
- splash guard question....
- Remote Start
- Post Your Exhaust Setup
- Exhaust Installed (FINALLY)
- n/a mods
- Yes, another suspension question. Those who have owned both Eibach & progress??
- Torque Braking?
- Will aftermarket struts and shocks make that big of a difference?
- Side Mirror Replacement
- hard starting
- Found discounted strut/spring
- Progress/eibachs
- Lowered My 95-ride Is Crappy!!!!!
- Phillips blue vision/melted harnesses
- How do you make a mesh grill?
- though this was kinda funny...
- Tough Suspension choice!
- Whats your GAS Mileage?
- for $20, the muffler shop used a heatgun and fixed my low-hanging muffler...wtf??
- cheapest way to make exaust system easier to flow?
- Ebay Dash kits???
- **New** legally improved All-Reds on my 99...***PICS***
- Possible NEW Mod, for us who have did everything
- Back Seat Removal?
- Heated Mirrors question
- best N/A mods???
- Heated seat switch
- Stillen Body Kit
- More possible good news for those needing Technosquare ECUs for 98+...
- my run-in with the new turbo beetle =P
- Problem during Start, VIDEO INCLUDED
- Getting codes p1320 and 300???
- The new 'Zaust (pics)
- Intake question please HELP
- Intake q looking for an a
- Modding my car this coming month.
- Anyone with the altezza Skyline Mod
- clutch making squeaky noise help!
- dual exhaust...
- Cheapest place to find ngk platinums or coppers
- 95/96 owners who want red/clears should check this site.......
- 98 able to swap in 95/96 ECU?
- **Custom Bumper Work**Pics?
- Stillen Lip alone
- windshield wipers
- Just got 02+ HID, any installation advice?
- knock knock
- 95-96' Rear Clear Tail Lights.....
- How to Remove Rear Bumper Cover
- tail lamps
- Design Engineering Inc. Exhaust Wrap impression on Warpspeed y-pipe!(pix + video!!!!)
- faulty starter problem
- Need Input about which lowering springs to buy
- Article on UDP.
- I have a bleeding axel, please help.
- Headlight and Foglight Bulbs, Advice for an Overzealous Newbie
- K&N and the plight of MAF Sensors
- Windshield
- Post any and all Videos you have of 4th gens
- 95-96 Red/Clears=****ING INSANITY
- would this ECU swap work with no problems?
- Santa finally came to my house!!!
- outside air
- Collison Work Question
- Front Lip
- pr cai and apexi exhaust installed
- 1995 engine in 1997 car
- OEM muffler with aftermarket exhaust
- compression check?
- Anybody have pics of their car with eibach springs?
- Removing Clearance Lights....Help!
- WOW! Anyone bidding on these?
- Deal? [99 SE-L 5 Spd]
- ebay y pipes????????????
- white-face gauges for us GXE/GLE owners...
- Where can I get a 99 FED spec rear O2 sensor online??
- Corner light question...
- just changed my KS...thankyou to everyone for their help
- Help finding Vehicle Speed Sensor
- Headers
- Whatcha think about my new turn signals?
- lug nuts/tuner lug size
- How to clear the air bag light?
- K&N replacement filter for Injen Intake?
- cost to paint just lip?
- Where can I get a socket for turn Signal?
- I need pics of the bcm
- please help with power seat
- No More K&N for me
- P1220 what does this code mean?
- Any Pics of BLACK Aluminum Dash in Black Interior?
- Recent 4th Gen purchasers: Where did you get financing?
- Fuel Injectors????
- Knock Sensor Diagnosis?
- air bag repair
- MAF testing?
- The weather is cold and dry, but the car doesn't seem as happy
- spark plugs
- Thinkin about gettin HIDs
- Has anyone been successful in taking apart Altezzas? I tried last night...
- Car sitting in cold weather
- CAI improve gas mileage?
- Loud squeeling just after I start the car?
- Mass Air Flow Sensor Issue
- Antanna broke. . .questions
- stainless brake lines?? best place
- beige interior with black seats
- Runs Great, SUCKS gas...still
- abs light went on
- '97 Leather interior color-Official name of brown color?
- Performance Mod Estimates
- 96 SE Auto Transmission slipping
- finally made a web site
- Switch Panel (CF)
- Ypipe link??
- Air bag light
- OEM parts
- Auto to Manual Conversion Questions
- HIDs installed!!! woohooo
- Max needs a new corner lamp
- Switching Parts
- PICS of my Crashed Max
- My GReddy SP2 exhaust just came in!
- RE: Tint removal
- Where to buy a starter?
- Anyone here changed the color of there dashes, etc?
- Sensor screwed into airbox?
- Help! My gas mileage is teh lame!
- Ballast Mounting...
- Adjustable rears / non adj front struts
- Anyone know the part # for 98 SE 5-Speed ECU?
- Can all hid bulbs work with any kit with the same color temp rating???
