- HID parts? bulbs?
- removing and replacing gauge needles on 99
- hallowed stock ypipe
- New here need some help
- New Pics of my car
- Pics of my hurt but getting repair max.
- Crashed the max! :(
- Drivers Side Axle Removal (auto) HELP!
- What is your next Mod?
- got the obx type h cat back :pics:
- Which Down Pipe is Best for 4th Gen Maxima?
- Cleaning the Intake Manifold
- agx rears or gr-2s?
- how much would it cost me to repace the ignition coil?
- Clean IAC dosent do the trick...
- How many MPG should I be getting?
- new clutch! but hard to get into first...
- 0302 and 0304 codes on Maxima and light problems on Pathfinder
- Y-pipe installed
- simple question
- ReCall
- Pics of my AE pedals installed.
- EGR code 0302
- IAT Sensor Relocation
- gauging interest deal for tok blue front + gr-2 rears.
- Hallowed Stock Cat vs. High Flow Cat
- Will this setup Drone
- Tranny failure @ 31,000 miles?
- stillen y-pipe (fed or cali)?
- EBC or Akebono brake pads
- Harlan LED in Gauge Cluster
- How much for a new transmission?
- manual transmission wont go into reverse??
- Bolt size to unseize rotors from the hub?
- 02 Sensor ?
- Diff. GLE, SE, GXE
- How to change inner tie rod ?
- keep it or get stock muffler?
- Help :) Muffler size for the max. (inlet/outlet)....
- Check engine codes 0302, 1003
- Would Gen2 Altezza tail lights fit my 95?
- BMW 330ci vs '96 Max 5spd.
- Oxygen Sensor Color Codes for '99 Cali. Spec. Cars
- Would this help my A/F Ratio
- Installed hacked air box with midpipe and fixed IAT sensor = 13% better gas MPG?
- Quick ? about the PCV valve...
- VB mods what are they exactly? How do they work?
- need help with ghost CEL!
- The Quietest Catback
- 6th gen v6 accord coupe
- Cartoonized Picture of a Maxima?
- 100,000 miles this weekend
- Popping sound...
- How do I put the brake line clip back on the front strut?
- Pics of my Max on new website
- Clear headlights for 95 maxima
- 99 Issues
- Buzzing/Vibration like noise at 65+, ONLY in cold weather
- noises...noobie
- ANYONE tried the PHANTOM LSD?
- Has anybody tried the new Tein or Tokico springs?
- JWT chip??
- Ciggarette lighter... (((spelling)))
- Shift Knobs
- trunk opening...
- put a few pic on my cardomain page
- is there any way this can be done with foglights?
- backlight conversion?
- aftermarket radios
- Im stupid and need help!!!
- What's wrong?
- Technosquare ECU Opinions?
- CustomMaxima Headlamps?
- lost my key
- Red/Clears done by yourself?!!!!!!!!
- can someone explain me this...
- 5 spd owners- How many miles on your ORIGINAL clutch before replacing?
- can any one help me tranny oil leaking
- lowering springs
- panel filter installation
- whizzing noise when climate control is on
- Wierd?
- Front end noise problem 1995
- Apex or B&G???
- Help PLEASE the noise is really annoying
- Hard shifting at WOT and sounds once car is off
- Removal of rear hub dust caps
- redding out my tails on a 95 se...
- OBX vs Weapon R
- Some A** Hole decided to spray paint my car tonight!!! *PICS*
- USIM/JWT ECU vs MEVI/JWT ECU using Cartest
- problem with VB mod?
- Urgent - To those who bought KS of Ebay from Yoshi
- Replacing 95-96 grill with 97-99 Grill...need input
- Once they see your ride, you get revd.......
- Check Engine light wrong report?
- To Auto guys, how much wheel spin you get going WOT from a stop?
- 5.0 Got Me
- Rear Brakes
- car dies out after wot
- Question about gauges??
- Horsepower?????
- Indiglo Needles???
- Need help with LED KeyRing Mod
- Quick questions before I install my LEDs
- Taillight Idea...
- Where can you find REAL front clears?
- i am not sure if i even have a knock sensor :(
- Cefiro One Piece Headlights
- Tachometer
- Clearing Out Amber Rear Taillights 95-96
- Anyone interested in Apexi Power Intake Filter
- Exhaust and intake videos...
- map light question
- became one of the privileged finally! 95 red/clears!
- Back To The Basics-RED/CLEARS! Bike Mirrors and other updates..
- ecu codes
- Which combo of performance parts should I get?
- Replaced knock sensor, still throwing code
- insurance costs?
- where can I find diagrams of the main wiring harness?
- quick question
- since it's the weekend.......
- Should I get this intake?
- Airbag throwing 0201???
- Sorry im a newbie!! but...
- how many people can fit in a maxima
- pic of gasket
- New pics of my Maxima by the Water......
- New pics of my ride by the water.....
- WS Y-Pipe & PR CAI... Love it... Pics
- Ebay Bumper Lights
- Drove a V5 maxima for about 1/2 hr
- Drivers side rear door sensor problem?
- would you buy this maxima
- knock sensor
- argh i cant find bulbs to match my headlight ones
- About the accelerator and Cruise Control cables
- My maxima is dieseling..
- Fairly new to the .org,, Pics of my Max
- My max (pics inside)
- [help] My taillights are not working... please gimme a hand
- My shift knob and pedal setup PICS
- Dyno pre install Cattman Header & Catback insta
- seatbelt problems
- All Thieves Should Die!
- headlight is out on low beam but fine for high...
- HELP - Steering Knuckle Removal
- Struts for a 98 SE
- A few issues with new clutch
- Why is my 99 starting up so weird???
- Re:Banned from modding for life!
- brake pad replacement question
- Ignition Coil
- Intstalling Gle In Gxe
- I HATE autotragic lag
- Banned from modding 4 life!
- changed plugs...what's up with my old ones?
- Who'as brought here before
- Changing my CV boots, and looking for any tips...
- Thinking about selling the max
- ahhh.....need help fast
- infiniti
- Froze my balls off this morning because temp gauge never came up to temp....
- The Green Machine [Weekend Project Car/Daily Driver]
- 4th gen obx catback
- APEXi WS Cat Back Exhaust
- Will a 96 airbag work with 97-99 steering wheel?
- Transmission Problem
- Replace Brake Pads?
- Full headers?
- need assitance on window problem
- Pic of my girl
- Weird GRINDING sound???
- Need opinions on this lighting setup
- My new ride(edited)
- Cubic inches?
- Just ordered a MEVI
- EGR control solenoid valve
- air/fuel ratio controller and na maxima
- Racing Stripes
- What exhaust I have??? (pic inside)
- custom CRX
- need a little help on gauge lighting..
- Nissan doesnt Make a Oil Pan Gasket. whyz?
- Is 97 engine wiring harness different then 98?
- any pics of BLUE 4 gen with black cf hood
- ECU location???
- Airbags in the seats
- shifting gears on an automatic
- knock sensor bolt
- new guy with exhaust questions
- Poll How Modified Is Your Max?
- Higher octane: better mileage offser premium cost?
- need help with some electrical problems
- Pics New CustomMaxima.com CF Engine Cover
- everybody with 5sp diff. bearing problems
- Need Half-moon Pan seal advice
- Yet another emission question
- Anyone know what is a EGR wiring harness and where it is located?
- Tein Springs
- Bad Alternator....My letter to Nissan.
- Look what I found underneath my max.
- Intake Temp Sensor affects gas mileage?
- Maximum tuning or Mobiltek racing??
- Please Help!!!
- Pics of Greddy SP ??
- Hey my dad is leaving me a 96 maxima
- C/E light goes on and shuts off in a few days
- Cam chain jumped ? won't start
- optima: blue top or yellow?>\
- How Common? Engine Front Oil Leak?
- Hyperwhite H3 (55W/65W) bulbs keep burning out... what to do?
- Valves ticking sound
- ? about CAI's
- clock and overdrive question
- stillen front lip?
- How much will this help??
- Pistons,heads
- About to buy brake setup...Got a few questions
- Squeeking clutch pedal after long drive
- is bosch refill OK on stock arm?
- will a 24" wiper blade fit?
- exhuast throwing flames
- help....my airhorns quit
- Engine Coolant Temp. Sensor Question???
- Relocating Antenna
- Hard shift tranny.
- Spacers in the rear for a more muscular look?
- SE speed limiters
- Are any of you 4th gener with H.I.D.S afraid of getting them stolen...
- Suspension Question?
- will a injen cai fit in my max?
- performance coil packs?
- E-brake sticking at caliper
- I need some help installing altezza lights
- oxygen sensors
- front strut tower bar installaation prob
- Should I buy this max??
- Hacked Air Box (OSCAI) How-To & Results
- need some advice
- Quick CV/Axle Replace Question
- Stand Alone Fuel Management?
- Budget Buyer
- rear brakes ( finally) serviced .. my story
- Warped rotors!!!!
- 5th Gen Greddy EVO Catback installed on 99.5 Maxima??
- just bought 98 gle
- 4th gen smokers .. yes or no
- Potential auto transmission problem??
