- New Project: Skyline tails or Clear Clear Clear tails
- ME VI for a SC car
- Don't want to deal with Autoloc? One-Touch Sunroof from I30?
- Question for people with Weopon R intake
- Help - Urgent - Ignition key won't turn
- Funny noise coming from intake
- Transmission service
- Whine noise from wheel...bearing gone?
- Whos car was this?
- Manual Trans. Startup In Summer. My Owners Manual Says What?
- what kind of bulbs?
- Unhappy Electrical...
- which springs would you recommend?
- 1996 Maxima Owner Manuel
- Factory exhaust - stainless or steel?
- I want to remove outside door trim, questions
- Finally Got My Tint !!
- Free stillen Y-pipe!!!
- 97-99 Bose different than 95-99? or Same POS?
- !7" 2001 Maxima Se Rims in my 1995 Max Question-
- maximum tuning kit on car pics
- my car club website
- Window Switch Choices.......?
- 2000 Maxima Symbols
- clear corners for i30
- tell me what u think
- vb mod
- To the peole who ever had the dons valve body mode
- Will they fit?
- My wifes Saturn broke down, I think its the shifter Help!
- Time For A Totally Different Look!!!
- Any one know muffler shop in Milwaukee to install Y pipe?
- trouble installing a spoiler. PLEASE HELP ME
- about to get my max
- Mandrel Budget Y-pipe- annoying noise fixed!
- i30 owners
- auto=5 speed
- rewire my blinkers?
- autometer gauge install
- Topped out my GXE today at 116 mph - one bad thing though
- Can I change my A/C on my dash?
- Maxima Altezza lights
- pulled over for loud music
- Wsp
- top speed
- bosh planitum spark plugs for max?
- pics of my 4th gen up on hills...
- Wtb: 99 Maxima Headlights On A 95 Maxima.....do They Fit?
- Wheel Balancing w/spacer
- New Budget Y pipe owners......Bees in the can?
- Need info on shocks/struts with Maxspeed springs
- Polished Aluminum Trunk Insert
- 15" vs. 16" wheel - ride difference?
- 95 sputtering
- in racing- how significant are more people in car
- CEL predicament
- Autos : does your OD light blink after you start your car?
- anyone with gen 2 altezzas yet?
- Altezza w/ LED --- New to Me (link only)
- company willing to make ANY products out of CF or fiberglass..
- Why do they sleep on Maximas?
- Vitek Clutch
- Clear Corners
- budget y pipe
- I need good junk yard parts
- Max's with 17" or higher rims
- Air Horns + Shock Sensor to Factory Alarm... Enough?
- Airbag light
- Body help
- Tints on Sterling mist
- Auto Transmission Shifting
- Finishing my ZEX install - 99 GXE
- Miasma:0 AC:1
- Lights pulsate, car shakes????????
- Tried to change transmission oil..but..affraid to break the bolt head..
- Front Alignment only OR All four??
- best application to lower my car?
- almost became a 5th genner
- buzzing sound when I turn on my ignition
- my window won't move
- New struts+springs - How long until I need an alignment?
- Haynes computer codes and engine managment systems manual
- Rubbing sound/sensation felt while coming to a stop
- Buying a 4th gen maxima
- If your Max is affected by the alternator recall, don't run the following...
- Headlights...
- Loud vs Quiet
- Notchy Tranny, Already using Redline MTL
- strange electric power problem
- Headlight out?
- Lowering w/ Stock Struts .. What's the Real Danger?
- Snapped Strut Tower Bolt
- $225 for a Y pipe including installation.....
- Popping noinse in turns after replacing manual tranny bearings
- Please help ppl with place racing intakes !!
- GP2000? Anyone heard of it?
- 97 - 98 Alternator Recall VIN # Info
- Question for those with Energy Suspension Control arm bushings
- Leaking Air Conditioner?
- What do cefiro headlights and grille cost?
- car drops in neutral
- Changed coolant, increased mpg??
- Rims/Wheels why stock?
- lights dimming more than usual??
- Performance Question
- Performance Chip?
- Have you all seen the new Type -S kit for the 4th gens.
- question for all the "juicy boosters"
- Question about Performance chip??
- Rear brake smoking
- Some Cefiro pics!
- Head light......
- 97 console on 95 max....fitment issues? kind of
- do I need an AC compressor?
- Some newbie questions (split from sticky)
- where to get valve covers?
- A/C cycles at 4th fan speed
- did a new sig pic...your opinions?
- carfax report
- No front license plate on my Max... no holes for it, either - is that standard/legal?
- UR pulley....does it help??
- Radio Shack Wire Stuff
- People with place racing cai need help
- Bose amp question...search was useless
- AC blower making noise - advice needed
- got some body work and oil ?'s
- Installing Side Marker or Side Blinker??
- Pics of Maxximum Tuning's Type-S Kit
- problems starting after engine swap
- Problem with starting the car
- What is this wire harness on the Manual Tranny?
- summit racing intake adapter......need help
- need help PLEASE
- anybody had SC belt alignment probs?
- alternator has just been replaced under recall
- final attempt at blue gauges
- clear rear lights?
- custommaxima turbo pics
- Installed new brake pads... now weird noise from FR wheel when turning...
- Alloy vs. Steelies - Weight Difference?
- maxima limited question...
- Even ticking sound from engine when "on"
- Appropriate voltage for Intake Air Temp. Sensor
- Rear Windows
- 1995 Maxima/Skyline R34 Custom Show Car for Sale or Trade
- My Maxima won't start!
- Will a Greddy for a 98 fit?
- Sidewall crack!
- AT w/2nd gear lag anyone?
- Water leak
- Thinking of some wheels... pics anyone?
- help with launches > > ACT clutch
- Shift Knob off a 2k
- Front Sway Bar Questions
- Push-open Ash Tray/Coin Holder...
- Question about cut wires under my dash...
- how loud does it get INSIDE the car after y-pipe installed...
- Do you use your adjustable RSB?
- Fogs dont turn on after replacing bulbs
- What cars have you raced and beat?
- ? about corner lights
- Installing Tokicos without a bench vise?
- Clear Bumper Lights
- need some links and PRICES??
- Thump Thump Thump while turning
- 98-99 Automatic Climate Control swap into a 96 with ACC
- Installing Air/Fuel Gauge..... few questions
- Maxima hits 60,000... questions!?
- can my max take them....
- help me pick a solution for my a/t problem
- HAHAHA, just thought of the funniest thing!!!
- rear windows all the way down?
- 120K service and mpg down why??
- What happened to the Suspension Thread??
- turbo question (oil return)
- Lookin for a good first mod
- Brake pad retailers?
- Car Alarm ?
- automatic tranns
- where to purchase intake adapter
- Where to find a Nissan Maxima Model Car?
- regular unleaded gas
- what size tires do i need for these rims???help!
- For those with 99 white max
- Rain sensor
- 225-50-16's and now my mileage is shot?
- Humming noise while driving?????
- How fast is the BMW 325i ? Because I had an interesting experience with one...
- OK...so, all my problems may boil down to one thing -- Torque Converter
- Did anyone get there high beam light after installing....
- Finally here are the pics of my new 99 Max SE 5 Speed
- Timing Chain
- I Need some Muffler Help
- few things in one thread
- ptatohed or anyone with SC
- i want brighter lights!
- how much does it cost to paint front lip?
- Error codes say TPS AND Knock senor...could one trip the other?
- Chrome to black door handle question
- cleaning haze on clock & plastic over instruments
- battery or alternator
- AHHHHH!! Chipped paint!
- Stock Wheels/Tires .. Reasonable Price To Ask?
- Hood Dings - Washing car?
- short throw shifter...
- Ebay question
- Help Please!
- my cone for my CAI fell off
- Please Save Me !!! !!! !!!
- Did something bad just happen to my car??? HELP!!!
- Made my own midpipe
- Question for those with Stillen: y-pipe, b-pipe, rear section and Random Tech cat.
- Need Help ASP please
- A/C compressor squeals on start up and for a few minutes afterwards.
- tire wear
- contacting budget about y pipe?
- Code 0605 cylinder4 misfiring?
- Antenna is stuck
- My temp guage is going thru the roof in this heat with A/C on. Whats the problem?
- Nos question
- Lowering Springs
- reattaching maxima lettering how difficult?
- Check out my new Sounddomain Site
- PIAA bulbs
- Wheels with lips
- Do you need HID?
- How to tell if vlsd or not
- Throttle cable tension?
- Best Material for clearing Tail Lights
- Confirmation on parts needed for a 5 spd trans leak
- Maxima exhaust question
- engine code 1106
- Wire Harnes Melted Again
- carfax request
- NUMBER RATHER THAN OPINION....Franckencar & Fast Lane Performance
- OMG please how to diagnostic my engine
- Idle Problem PLEASE HELP!!!! (Long)
- TORNADO thingy adds 20 hp for 70 bucks????
- Blown fuses
- Warpspeed Y Pipe or Budget Y Pipe?
- Bulbs...
- your opinions
- Dyno vs. 1/4Mi Database
- We want Pics of your suspensions....
- 300zx brakes
- Gas pedal too light
- Choosing between buying a 5spd or auto?
- 300zx Caliper and Rotor Size for Conversion?
- chiltons is no help(transmission code)
- Maxima gains for little $$$'s.
