- The case of the disappearing coolant
- Leather seats repair in NYC?
- cloth to leather seat swap
- '99 Max antenna woes...how to replace?
- MAF Sensor
- HELP ME!
- Rear Main Seal Replacement
- windows, auto up and down
- Mysterious(?!) misfire problem (99 SE Auto Cali emissions)
- Alternator How TO
- Exhaust Leak.. How hard....?
- Ugh... Another knock Sensor gone
- WOW.....
- Aftermarket stereos??
- rough idle
- Could we add this question to the stickies please
- car won't start suddenly
- Corner LED Light
- Help with new starter grinding/getting stuck
- 0701 Mult. Cylinder Misfire
- Exhaust Question's / Suggestions
- 5spd swappers: quick parts question.
- Question for those of you who have done a starter rebuild
- I think Max is trying to tell me something important...
- No Spark in Cylinder 2 and 3!
- Changing gear shift light
- Intake hose???
- Bad battery or bad alternator?
- Water pump O-rings
- What's your opinion on these rims?
- Rear Passenger Caliper Needs to be Replaced
- 1995 Maxima: Alarm Goes Off When Starting Car
- Advice needed on replacing the car radio
- where to buy/part number trans seal
- bucking, stuttering, low idle etc
- need help on car
- this is pro in the wrong forum but here goes
- $200 Rebate on Pioneer Navigation [Holiday Rebate]
- Subframe / frame bushing replacement
- Need a site for all my maxima needs
- 0303 front O2 sensor cause car to run like its on 5 cylinders?
- Ignition coil difference?
- Car Having problems running in morning.
- car won't pass 3rd gear with headlights on? but shifts passed 3rd with it off...
- axle help
- Maxima is stalling on me, could o2 sensors be the cause?
- Can someone show me where is the maxima power everybody is singing about ?
- Problem with bolt on transmission pan
- tail lights question
- leather seat swap :D
- 96 maxima no start after storage...fine before storage
- RIP 97 Maxima
- Kyb gr2 and Progress Springs
- sweet craigslist find, somebody should buy this asap!!
- How to R&R your radiator
- anyone sill produce SFC or Fender braces????
- Ignition Interlock Device?
- maxima cutting off
- 4 gen maxima shell
- swap 96 maxima engine
- reliable HID kit?
- How can I check to see if a new tire is bad.....
- STARTER STUCK IN ENGINE......TRIED ALMOST EVERYTHING
- Amber interior LEDs
- NEED HELP changing p1400 cod EGR SOLENOID VLAVE
- Mechanic says Air Mass Meter. I need advice
- Thinking of buying a 4th generation Maxima!
- Weird Steering Problem
- Rubbing issue on the rear of my max
- best sites for maxima parts
- biggest sized rims for maxima??
- ATTN: Lowered Maximas
- Help with "Stuttering" Issues
- big fuse on the battery terminal ????????????
- Two Electrical Issues. Are they related?
- 97 maxima se
- 235/45/18 Problem?
- HELLPPP
- Loud Squeak - A/C?
- Air Conditioning Problem - How to Test if Clutch or Compressor is the problem?
- what is this part
- Front Left Heated O2 sensor
- a 4th generation Wagon? well a Cefiro...
- Should I trade my max in for a BMW??
- Pioneer releases FREE iPhone App [demo video]
- Wiring question
- Demodding the max.
- Brake problems, should be simple but I'm stumped
- ever since 9007 mod....
- dumb question i know....but...
- Driver's seat getting mushy
- Weird Noise maybe brakes
- Loose TC cover bolts?
- pics of cattman intakes
- A/T doesn't like 4th gear at low speed/RPM
- ABS Issues
- Weird clunking noise from front of car
- Vibration when stopped
- weird isssue can even title this right, help me please.
- Any pics of black shift boot vs. tan shift boot on tan interior?
- HIgh idle after TPS replaced
- Aftermarket Parts
- Dogdish
- AC Pulley Bearing Problem
- Tranny stuck in third after emergency stop
- put in too much transmission fluid, how bad?
- Lost accessory belt tensioner, accesory belt tensioner pulley
- Has anyone complete the 4th gen Big 3 upgrade?
- Power Steering
- another f**kin MAP/Baro Thread :mad:
- Which of these 2 RPM switches? (MEVI)
- brake dust
- amber fogs
- Cluster fuse blowing when in reverse
- Misfire when cold
- ebay maf's any good?
- POWER STEERING BELT SQUEAK!!
- 9007 conversion
- Steering rack boot
- help my tach is freakingout!!
- Help with MEVI Install PLEASE!
- Clunking, Clicking, Noises from a 5 Speed
- Changing out Power Steering Fluid??
- anyone change their 95-96 airbag and steering wheel to a 97-99?
- 6th gen brake upgrade for 4th gen??
- starting problem? (attached a video to explain)
- Supercharging Questions
- Testing A32 IACV, need member input (Preferably 99's)
- Installed ES busings and they make lots of noise..what to do?
- Custom Enterprise Springs on GR2's Feedback??
- link for changing 02 sensors?
- ah man, starting problems again?!?!
- Car Battery... Need to replace it asap!
- How do you know when the suspension is worn out?
- help with gas millage
- DE-K Swap help!!!! Im getting confused!
- LONG STORY but..i'm now the proud owner of...
- PO150/0303 O2 Sensor (s)
- vacuum solenoid switch for MEVI
- weird turning/brake fart noise
- Levoc Shifter Question
- Ebay One Piece Headlights, Which Bulbs Do I Need?
- SE or what ???
- oil in spark plug? anything to worry?
- headlight re-wire
- Wheels/rims that look good on a black max?
- CEL wont go off??
- How do u replace these
- What is the p/n for a ECU pin?
- Injector or Coil issue? Ways to test it?
- Battery Drain
- 97-99 f/r bumpers covers on a 95-96 ????
- Broken Headlight
- 5th gen vs . 4th Gen
- advice on inexpensive exhaust replacement
- Extended stud help
- Need administrator help
- Airbag Control Module Part Numbers (what years can be swapped)
- code 0407?
- Crap, hit a deer and airbags deployed need help with the repair
- ground wire points
- Gas in charcoal canister!!! HELP!!!
- i have rust problems
- high idle (over 2k) when cold then drops to normal when warm
- Oil Leak
- Has anyone installed a 10 inch cone filter?
- No Start, but runs...
- Learning with lights.Xenons.
- What to do with my a/c...
- 95-99 SE 16" Alloy Rims Question
- Reprogram ECU
- exhaust for sale
- Lowering your car?
- Another Strange Hard Starting Problem... Possibly ECU???
- 2k rpm problem !!!
- A couple of things regarding gauge cluster mods...
- What car alarm/Remote start ?
- where to buy knock sensor? cheap
- HO alternators. Anyone know where I can get one good price?
- I can't see!!
- clutch line confusion!
- Replaced 3 starters in 4 years—What gives?
- Any cheap possible way to mod our back seats to go down?
- Fuel problems slowly creeping
- DRL = Passenger side highbeam
- R34 fitment issue
- Bad idle, bad driving, and p0300 code
- selling cool stuff, turning in the max :( pics
- Spark Plugs
- Jumpy temperature gauge
- tire rating max speed
- 95-96 SMOKED tails
- dead battery or alternator?
- 5th gen clutch install
- Everyone should invest in this Scanner
- having a problem with my maxima (LONGG STORY)
- Can damper pulley squeal?
- Apexi afc version 1 or 2
- defroster fuse locaction?
- Y pipe installed, getting smoke from the pipes? Like evaporating...
- Additional information on replacing your transmission
- might have clutch problem
- Need help with rear brakes...complications.
- fx35 18's
- Spotted 4th gen!!!
- Strange headlight problem on 1995 Maxima no low beam on one side
- Need some assistance please
- 97-99 stillin lip kit for 1996 nissan maxima?
- Little honorage
- Quick and dirty power antenna mast replacement
- 0505 Code: No Failure Recorded/Detected
- key fob question
- Are these parts interchangeable from a 99 to a 95 & 97?
- 99 to 95 ECM swap a Success! +1 Later NATS :)
- Need help diagnosing a weird sound (RPM 1100 - 1300)
- Grill on 98...........
- Ionic Lip kit install??
- Please tell me this is my axle gone bad (Video)
- new motor mount thoughts?
- 95 gle 5spd swap. 2 faults so far, any comments will help
- Retrofit question
- Where to buy KYB Strut Bellows (Dust Boots)??
- Air bag light on, bose radio not working, possable water damage
- OBX Catback System
- Steering at highway speeds
- New fenders already painted?
- 0-60 times for our cars? Getting Lots of disrespect from ricers.
- Tein Coilover Q
- Do our remotes generate random codes?
- Hard starting question: Hold key for 15+ seconds before car starts.
- Alternator help!
- Ambient light in Maxima
- Resonator Removal
- Bose surround sound
- STERLING MIST was made '98-'99 right??
- Rack & Pinion leak
- cam sprocket spacers for vq35 swap?!
- Replacing alternator
- checking motor mounts?
- '97 cali spec
- 97 SE MT / 5 Speed to 6 Speed swap
- Knock Sensor Fail Inspection in NJ?
- 11 year old radiator: how long can it last?
- CAI vs Short Ram
- Engine Mounts Please help......95SE AUTO
- Battery questions
- Brake Booster Question
- 5th gen mirrors
- stillen lip?
- Moving from my trusted '95 GLE to a '97 I30
