- Need some suspension advice
- Cai Location
- Meccanoble is BACK!!! Thanks to TILLEY *LONG*
- can't decide what to do with front lights rewire...any suggestions?
- Rear deffroster does not work.
- which flywheel is better: Unordthodox or fidanza
- need advice on hi-cat
- Where can I find the "MAXIMA" letters?
- Jacking positions on 95/96?
- CF or alum. dash kit
- Throttle boddy cleaning question
- Rattling & Vibration in the stick
- any suggestions on a clutch?
- Just an opinion/what to do next thread...(PICS)
- ECU Check up!
- Please help me, problem with the pickup/shifting
- The New And Improved Poor man's search
- Cutting Shift Lever
- JDM Black Chrome Diamond Cut Bumper Lights
- Stick is shaking on 4th gear!
- HIDs
- Those of you who have groundcontrol coilovers and installed them
- New Member :)
- Which Max?
- Rattle and Dash Removal
- Real Quick: Just need a how to.. change the rear brake pads
- Speedometer Change
- Hood Damage
- Solenoid Pack A/T
- Power flushing the transmission?
- need pics
- My Maxima forgot how to start
- Turn Signal Problem...
- Will removing speed sensor let fluid out the trans?
- Complete Tune Up
- Finally !!! I have a CarDomain Site...
- Time to play... Name that noise!
- Car Computer
- Car Vibrating alot on Highway
- tranmission service question
- High Output Alternator
- Projectors Vs. 9004 Housings
- How reliable is the 4th gen?
- Can you clean coil packs?
- im startin to hate my max!
- burning smell from clutch!
- Fuse box diagram for my Max!
- Where can i get a replacement HID ballast?
- Shift Knot for Automatic
- Clutch dead...I think, plus bonus (5spd tran ques.)
- Drivers side suspension/front end noises
- Does anyone have a Grille Tech grill?
- High Amp alternators available for a 98 SE?
- 6MT with VQ30?
- Help with ABS
- need help from suspension gurus installed progress/kybgr2 combo and drop is uneven
- HELP!! Buying a 98 SE...
- Header & Y-Pipe Options
- Weird noise coming from front wheel area....
- Dash kit for manuals?
- Updated Cardomain...tell me what you think
- New Maxima Owner - Quick Question
- Led Mirror Covers
- i don't know how to bleed the brakes on my car
- circuit sensor code issue help~
- Stainless steel clutch lines?
- Anyone with LEDs in heat vents?
- recall
- Whining noise in engine, help please!
- 99s with Cattman Headers
- Cattman headers/ypipe combo
- speed sensitive power steering Factory screw up?
- Hard Starting Help!!!!!!1
- fitting on top of tranny
- What do you think of my Maxima
- my new project
- CustomMaxima STS or B&M STS?
- Bad Gas Mileage
- 99 se limited?
- Walker / Universal Oxygen sensors
- cefiro fitment THAT bad?
- suggestions on rear shocks
- www.oxygensensors.com???
- high flow racing pipe on ebay?
- Check Engine Light
- Those That Tested Their Own Ignition Coils
- daymn it i screwed up! tried to re-tint my tail but...!)(@*# any suggestion?
- KS question
- Where can i get a cheap test pipe?
- Anyone have a pic of these TYC lights on their car
- simple question for those with y pipes
- Exhausts for 95-96 and 97 on......Whats the difference?
- What's wrong with this max???
- What Color Should My Max Be?
- single in dual out exhaust? or no?
- please help with my p.o.s. b4 i junk her!!!!
- looking for a blank nissan key
- clear tails
- Guys w/ 2k or 2k1 Trans HELP!
- HELP! Code 0312 - EVAP Problems
- oem dash kit
- Which is better at noise suppression: N1-type w/silencer or stock muffler?
- 200 miles to the tank?! (city)
- Good Question For Ya...
- Where can I get a valet key made?
- can I use 2001 5spd axles in my 1995 5spd?
- Excess Oil
- would cattman mottor mounts for a 5th gen fit a 4th gen mottor
- Please help to identify open ended rubber hose near MAF.
- Strut Mounting Parts?
- shifter knob?
- Which O2 sensor
- Should I get NEX Coilovers for $400 installed?
- cattman vs. budget y-pipe
- Addco RSB adjustment ?
- Car is being retarded and not starting! Help
- Taillight question
- Just got Budget Y & STS...
- eBay universal seats
- with $1,000 what mods would you do?
- New 97-99 Maxima Black/Clear JDM Headlights & Corners
- Exhaust system stretching
- 4th Gen on Wanda Does It (Comedy Central)
- Recalls, will nissan still honor it?
- Where is ECU in the 99 maxima?
- 4th gen engine
- ECU fault code 0214 and 0215 Undefined
- map/borrow code Question
- CAI with K&N
- 2nd at high rpm's
- what coil packs/ignition coils to replace with....??
- Need help on strut/spring install
- Need Grille Opinion
- Broken axle in tranny...
- Where to buy Ignition Switch
- Anyone cut a coil off of their stock SE springs?
- rear windows are off track
- 97 SE Master Cylinder Replacement
- P1605 Code, Need help!!
- Red/Clear Side Reflector Problems?
- Blacked out Headlights
- Help w/ CEL Evap Control System/ABS
- Remote Starter install!!
- hood support struts - advice on cheapest source?
- stock struts with lowering springs?
- Megan Racing catback...good/bad?
- Transmission Control Module Problems
- Fuel O-Ring Question...
- mevi woes...
- Headlight Question
- How to insatll remote car starter
- Quick ? on Corner Lights
- Uneven tire wear.
- Ever had this happen
- I need a plastic mirror cover asap
- Gearshift knob - poll, opinions, etc.
- HELP!!! CEL on, No codes firing
- Y pipe
- Picked up ECU Codes 0705 and 0903
- engine swap?
- Will I get flak from cops with smoked tails?
- ATTN: Anyone with Xenon Lights
- Considering this short shifter...
- bumper lites
- looking for the guy who polish's upper intakes
- Parts to swap from '01 to '96 engine?
- RPM meter won't go beyond 25000?
- Swapped Engine!
- What are the most common parts that break?
- not warming up
- Ebay CF hood any good?
- HID in cefiro? beam pattern?
- My intake's maf adaptor is cracked...
- Need some advice
- Sensors ???????
- using a 2001 20th anniv tranny VLSD...
- Axle questions:
- Dynomax vs Magnaflow
- hard engine start and change of engine control model (ECM)
- What size are the guage cluster lights? for 97 auto
- Re: Curious on a mid-pipe
- Headers
- So my $40 e-bay intake came in today...
- 97 Auto gear ratios?
- how do blown motor mounts effect the car?
- whos maxima is this?
- what the hell wrong with A/C
- Front/Rear seat removal + heater install
- Got my Stillen Sides on My 96 Max and New Pics of My Bros 98 Maxima Enjoy
- clear corner help
- Problem with Engine Cooling
- Tar on tires, help please!
- Tach Stopped Workin ??
- Squeeky Muffler!!
- where can i get a box to ship y pipe?
- Mass Air Flow ?????????
- wierd wobble at high speeds.
- Bad strut mounts casuing bad alignment?
- clock
- Broken wire. Where is coming from?
- Throwing 02 01 code
- anyone have the DIY guide for rear brakes? the links in the sticky are dead.
- Got Code 01 04, Vehicle Speed Sensor
- what would cause a not smooth drive at low speeds / wobbling almost feeling?
- Need help quick! Starter is out?
- good headlights to custom fit
- Timing belt or chain??? 4th gen max
- Exhaust question
- Finally decided on exhaust dilemma... CUTOUTS!
- High FLow Catalytic Converters in good ole CA!
- ECU Codes 706,806
- Dent in Carbonfiber Hood
- 2000-01 Tranny in 1996?
- misfire in cylinder #1
- Need Help, Weird noise coming from Rear Brake
- Who Had Motor Mounts Replaced???
- want to paint grill. GLE grill just annoys me.
- flywheel install help
- Maxima Short Shifter cross-applications...
- Short Ram Rattles...
- Who has this nissan key?
- Need a grill. Who can help me out?
- Maximachad is back!
- Strobes?
- 5-SPD: Noise When De-Clutching in 1st (yes, i read the FAQ's)
- Photshop GAUGES GAUGE Templates
- Hookup points for engine hoist
- Bose Radio Dead but fuse OK, what do I check next?
- Remove Rear brake light?
- which AFTERMARKET AIR PANEL FILTERS are available ??
- Mobiletek VB Mod
- Can we get a sticky for the UDP please?
- Trans probs, hesitating and slipping when acc.
- 4th gen MPG
- a few pics
- Rear Strut Tower Bars
- Led Fun Time!
- 97-99 headlights on a 96
- interior noise
- 4th Gen representing at Nopi
- Can someone photoshop rims on a max
- Misc Pics of current state.......56K......
- horsepower bang for buck?
- Cost of Tranny Rebuild
- headers
- GLE VLSD 5Spd Swap Q's.
- PPl w/ 17's and drop please post pic
- tie rod loose?
- heater mirror instal
- Tein H-tech springs
