- breaks squeek first couple minutes, then are fine...anyone know why??
- finally got my y pipe in
- CEL issues - aftermarket exhaust - need assistance
- Fuel Filler Door Latch
- Replacing valve cover bolts
- Paint SE rims, or buy new rims?
- Anyone know how to check if the spark plug coil is bad??
- Adding shock sensor to factory alarm
- FSTB Worth it?
- WHat size and weight is an Unorthodox Racing UDP?
- 1995 maxima intake,PLEASE READ
- reverse indiglo for 99-01
- Another VI insstall is complete
- hi pips i'm hew
- Frankencar installed, AC issues
- budget pricing??
- max tunning kit
- 19" rims with 2" drop = problems?
- best b-pipe?
- FrankenCar Intake, Resetting the ECU?
- grille
- engine start button , which wire!?
- shaved door moldings?
- Winter Time
- Dropping the Max
- Best Place to buy Maxima parts>
- chrome around the windows
- 4th gen Reliability
- 35mm offset with 18X8's rim
- can I order budget y online?
- wheelhop..please help!
- Variable Intak
- The Maxima's reliability...
- Just installed my OEM white gauges... questions about lighting (pics posted inside)
- Just got the Frankencar Intake, but...
- more problems with my reverse indiglos....
- just me, or did resetting ecu give me more power??
- factory fog lamps poll
- joining the Navy in january and parking my max..preventive maintenance?
- Stock Fog Lamps
- need some clutch advice
- 98 Mustang GT vs. Maxima
- Weird Sound
- 235/45/17 Tires???????
- Ok thats it I'm getting ****ed.
- Integra vs. Maxima
- hey guys, i jus made my homepage..PICS
- Weird Carfax report?
- Stereo Question
- Ah! Max wont start. Need help ASAP!!!
- Just installed Frakencar, comments -
- ***96 to a 97-99 SE steering wheel is COMPLETE***
- RT Cat/Apexi WS installed.
- red "NISSAN" in front burger
- Engine Rebuilding
- Levoc Automatic Shift Knob
- Could anybody run this VIN for me??
- Problem starting after engine is hot
- Just got springs...Question
- Was anyone in boston yesterday?
- understeer? oversteer?
- Bodykits
- check out my max
- Intelli glow needles work with reverse indiglo gauges?
- Will Rockford Fosgate FRC3206 fit??
- Placeracing CAI or Injen?
- flip top trunk
- VI going in tomorrow(Sunday) any suggestions
- spoiler
- intake
- Anyone have a pic with Intrax springs installed?
- First time, cleaned my under the hood /w Simple green
- stillen race pipe
- what's a good magazine???
- Trunk does not open with key - any help?
- rewire for altezzas... how do I fix?
- can a do it your selfer replace a knock senser
- AGX in winter?
- q45
- Local Strut Installer?
- Longevity of aftermarket lift supports
- Help I Need Some Opinions?
- Dynoed two VIs today (plus other cars)
- shift knob and E-Bake combo
- Idea about collector for force inducted cars.
- Need help with installing indiglo gauges.
- Axle seal part Number??? trans oil?? =(
- starter wire question! where is ground wire?
- what do i need to install a cd player (and radio Help)
- 60 k Maintenance Notes & Tips
- Is there a How2 for the Tranny Fluid Flush and Coolant Flush anywhere?
- Help - Frankencar install, can't get MAF off resonator
- Whats up w/cardomain?
- Heh
- Just put on my frankencar...couple questions...
- 97 SE Foglights Stopped Working??
- 9004 PIAA, Silverstar, CoolBlue, XtraVision?
- 95 SE: ? on boots, rotors, and struts.
- Best Looking Soft Bra?
- Interesting Tire Wear Pattern....
- Idle problem
- About time Nissan gets Back to racing
- Q on springs
- so i FINALLY install my frankencar midpipe...
- Question on H&R spring install
- what are stock auto maxima times?
- Car shakes when letting off gas
- 95 maxima se gas problems .....
- Gauges ?
- best tailight for max
- best spoilers for my max
- read if you have rims
- Compression Test Results (2 very High) , and Oil on plug/coil
- indiglo's sticking....how can i fix this?
- What is the point...
- Need some help with Polargs...
- What are my options...
- my HIDs are acting funny...did they blow?
- installing mid pipe question
- race straight pipe question<-------$99 add 11hp
- Pics of these gauges, tell me your opinion on them!!
- Opinion on Bumper Lenses for White Max
- Question about swapping GXE gauges with OEM white gauges (odometer issues)
- Got my Maxspeed's and KYB GR-2's installed today! Pics inside!
- wanna photoshop some rims
- y pipe gasket and o-ring part #'s?
- grills
- Extreme Weather Nitrous users
- Anyone know the flow rate of the OEM fuel pump?
- max goin into surgery... need some feedback pls!
- really sucky day at the 1/8 mile
- Fog light cut out?
- Check this ECU from Japan
- Oil Pressure Question
- Meet?
- does anyone tried or have a racing pipe on theyre car?
- Cattman y-pipe: new or old?
- Help! Spark plug boot stuck!
- ***IMPORTANT: Everyone with Installed MEVI's***
- skyline ground effects
- changing belts?
- changing that ATF
- Hanabi 8000k question for current users
- Lexus Yellow Fog question. Anyone has lexus IS300 to answer my question?
- Automotive Repair Manual for 4th Gen
- Free Car Clinic: Clutch hard 2 depress. Way more tension than used 2 b. brakes squeak
- Cattman y-pipe price?
- Matching the bulbs!! 95 Maxima SE
- What do you guys think about this mod?
- Need help about these ebay gauges!!
- My 2500 mile road trip is complete, Thanks JDawgX
- Idiot Question
- Intakes
- light question
- tried these rims?
- AMSOIL transmission fluid in 99
- Dents - plunger, dent wizard
- 97 SE 90,500 miles for 10,000...hmmm
- Unknown Problems
- The Experiment: MEVI activation via a toggle switch
- Brembo rotors?? got a question about them. HELP!
- Question on KYB -- AGX vs. GR2
- Max with 350z rays?
- Test Drove Benz CLK 320 vs. Maxima Comparison
- Found a 97 GXE 5 speed
- Which bulbs match best with the Polarg corner lights?
- Need help about installing air filter
- i need to know this real quick (oil)
- wining noise and burning smell
- 5th gen centre console on a 4th gen.
- Throttle Body Question?
- What should I expect to pay to get my body kit painted?
- Cruise Contorl Problems
- KYB AGX / Maxspeed setup
- Humming Noise / Grinding
- Cruise Control Doesn't Engage.
- Clutch is making noise.. help...
- In need of alternator, is this ideal time to change pulley as well
- Abs
- Got the Black on Black 98 GLE!
- IDIOTS or LIARS ~~ you decide....
- Cooling Fans
- Anti-theft/Security System/Door locks outta control
- almost done with leather install *pics*
- Well What Does Everyone Think About Intake Sensor Mod?
- Custom Exhaust / Custom Muffler
- more horesepower!
- best plugs for nitrous?
- Dupli Color Wheels
- Tinted MAXima
- Anyone with JoshuaTree Italian Burlwood in a Tan Max
- 2.87" SC Pulley Cookbook
- What is the most restrictive part of the STOCK intake assembly?
- Quick 95/96 Red/Clear question
- No ABS on a 99 SE Limited??
- Big Update On My Totaled Maxima
- What symptoms would a bad coil have?
- new stock clutch + 50shot
- How to properly tighten belt on my 97.
- ValveBody Recal - DIY?
- Valve/cam specs
- Installing new pads and x-drilled rotors at the same time..
- CAI Whistle at 1700RPMs ??
- Average Mileage for 97 SE???
- How long will stock struts hold with Maxspeeds on.
- Just installed 225/50-16 Yokohama AVS ES100's
- Max (stock engine) Maxima Power?
- Help w/ Mod selection
- WTF is wrong with my HYBRID? Hoses "blow off" every time I drive!!!
- Damn Tire!!!!
- irotors cross drilled/slotted rotors
- 300ZX conversion.........WORTH IT OR NO ?
- Best Drag Racing Tire on a 15" Steel Rim ??
- front seat problems
- which $100.00 mod
- dont know what to name this
- An exhaust question
- Horsepower Calculator for you guys
- Question for mechanicaly inclined
- OK i have a question
- Anyone have Enkei RF1's? Pics?
- I GOT KEY"D!!!!! (long-ish)
- Front Brake Problem???? Help Needed
- Is it safe to clean the headlights?
- I have this annoying squeaking sound
- how hard to paint altezza's(skyline tails) for sagemist green?
- Random thought on gutting cat.....
- anyone have this kit combo?
- Noise from Front after rotate/balance
- is the culprit thy knock sensor?
- KYB AGX Compatibility w/Eibach Pro-Kit
- No surprise ... most dependable
- My 97 SE is missing!!! HELP!!!!
- OLD 4th gen nissan commerical.. the pigeons chasing the maxima
- Wife called, she got in accident
- Finally after months of waiting its is time!
- How to make 95 corners brighter?
- Hmmm, burning plastic smell can't be good :(
- how often do you change your plugs
- will some1 plz photoshop something for me
- Clutch change pricing
- ECU removal
- Engine tap noise
- Fuse Question HELP!! pleeasee
- what would you do next?
- Difference between V1 and V2 SC?
- Am I the only idiot with wheel bearing problem???
- might buy a 95 SE, tell me if its worth it....
- My Airbag suspension should be here today or tomorrow
