- ECU code 0702 on 99 Cali Spec: Bad 02 sensor?
- Window fell down
- repainting the maxima! want advice
- My Stall when i was driving
- few pics of egr tube removal
- Does anyone know where i can find these two parts?
- Rear Rotors And Brake Pads
- Power Steering Problem
- Help me Car starts and then dies I am stuck
- Replacing shocks & springs
- what brand of gas?
- Throttle body removal, how to stop coolant leak
- installed retro's.. using vampire clips to power HIDS??
- Whats better? A Supercharger, or a Turbo
- Looking 4 Inland Empire Mechanic to do tran swap
- Wow, LOTSA CEL codes...HELP!
- Did I install KYB AGX struts and shocks, or Pogo sticks?
- Shift Lock/Brake Light Problem
- Installing KS (New Jersey)
- headlight wiring?
- Car turns off while driving HELP!
- Hum/Vibration from rear of car.
- 99 maxima SE won't take gas
- Repair/install you're not proud of
- altinator went
- 97 vs 98 auto ecu
- Shimmy/ scraping when starting forward and reverse
- Exhaust install..
- Rough Idle-Almost Stall
- Dash lights/electrical problem
- Are there any good mechanics or maxima enthusiasts in NE Philly?
- New Clutch
- Marker lights Clear
- Altenators keep blowing!! Need help!!
- Looseness/noise in left front end
- body guys pls help!
- Whats the biggest differencs btw?
- trubble codes
- The boost is loose!!
- rear brakes
- Optima Red Top Battery.... are they different
- auto tranny failing? (w/ VB mob)
- Drop'd and Tint'd
- What to look for in a CF hood/trunk?
- keyless entry
- 4th gens in MN
- M3 mirror fitment question
- Opinion on Dash.. Paint or Not to Paint
- Full DEK swap or 00vi?
- Front end vibration during moderate braking?
- was i supposed to have these fuses?
- Bad headlight switch?
- Steering won't return to center after strut install.
- DIY site
- Painting my oem wheels??
- Best place to buy trim piece around shifter for a '99?
- Max gets face lift, new feet, new Lungs - and more...!!! WOOT! - (large pix)
- Does 5th gen muffler fit 4th?
- New Motor Mounts?
- Cutting out where fog lights would be?
- windshield wiper blades
- Injen Hai
- TB coolant and idling
- which of these rims will look good?
- Shuts off when at a light or idling....hmmm
- Best settings for AGX's and Progress???
- New Mod and airbag light still on!
- Help! How do I reposition the alternator?
- new guage overlays
- Base fuel pressure
- anyone wanna pm me their phone # to help with dek high idel
- Cam or Crankshaft problem
- Weekend Engine Cleaning
- main pin on torque member
- 95/96 fogs
- KS fault automaticlly retards even if its good
- Is the Dealers Engine Diagnostics Test Worth the Money
- 0604 code
- Ecu Code 201
- WTF? Why is VIP Maxima (Mike) banned?
- raed if you have a rsb, drop then took off your rsb
- Snapped the radiator dampener bolt...
- 5 speed convertion
- A few questions about heated seats install
- For those of you who bought a full Tokico Illumina kit...
- Loud scratching sound at startup/idle
- Aluminum vs. Stainless Steel
- Are muffler hangers on a 5th gen muffler the same as 4th gen?
- Grounding kit?
- Guyz i need ur help! my control arm bushings are gone
- Dash kit intrest
- Understanding an ECU code
- Corey at RedlineMax or Associates ??
- flashing airbag light
- Need help with parking lights
- BRAKE LIGHT stuck on!
- 02 sensors
- Can bushings affect steering shake/wobble???
- Motor Mount Bushing Replacement
- fuel filter help!!!
- so cal help with clutch job for $$
- Can this be caused by a bad knock sensor?
- suggestions for sways
- Bought A 99 SE
- Will this tire size fit?
- Headlight electric question
- Strange Sound from FD wheel.....
- Anyone heard of python fuel injectors?
- Brakes were quiet, replaced rotors, now squeaking..
- BF Goodrich Traction T/A H
- Those with custom catbacks...uninstall?
- Rust Issue need some advice on
- Back up light switch / reverse switch
- I want to install Bosch Compact 100 aftermarket fogs, I beg your help
- AC Problems
- HID Install Problems
- New TS ECU throwing all kinds of CEL codes! HELP!!!!! Please!
- Brake light is on
- tranny swap from 5sp to auto...anyone?
- Gauges problem
- ""Rusted Fuel filler""
- best place to buy, or good after market tie end rods
- Fog light installation
- maxima not starting
- How To: regrease Starter
- rear disc brake calipers
- Anyone have any experience with StoneRacing Y-Pipe/Headers?
- car totaled
- back firing noise from exhaust help?
- Anyones else have problems with the bolts on the Cat?
- Resistance on Crankshaft Position Sensor
- Non Obd-ii
- p1336 0905 - guess what!
- 0404 and 1308 ECU Codes
- bushings, help please asap
- Mass Air Flow Sensor
- got nismo exhaust hangers and got a rattle..
- 96 rear spoiler
- were to buy auto rx?
- Which threads strip first: Drain hole or drain bolt?
- check engine light!!!
- HELP!! Alignment problems
- STARTER guru's please help!
- How's e-bay control arms
- Lock problems...
- How to Change MTF
- carfax
- Muffler recommendations?
- alignment question?
- 97 Nissan Maxima SE vs. Porsche Cayenne Turbo Video
- gas smell (i cant search for some reason)
- new KS on ebay
- Something banging near the rear right wheel
- Reverse Lights
- Climate control?
- Lean Right Bank Code 115
- Any draw backs to running test pipe?
- Conceal the V1 concealed display
- Turn Signals Problem
- Car Cranks but wont fire
- Auto shift knob, Cut to perfection????
- Rear Brake Pads Slightly Touching
- HELP NEEDED NOW - Tie Rod End
- wow, I can't believe this...need help
- Parts needed to do the rear main seal
- Anybody dealt with Car Parts Wholesale?
- odometer swap
- Brake pads hanging up?
- Stock Intake Manifold Question & EGR
- clutch question. yes i searched first
- tranny swap
- intake manifolds
- Fixed my IDLE problem. Is this yours?
- Working on my car is becoming impossible.
- Friend's max got hit, airbags went off--totaled??
- Iacv question for the dek swap I got a idea?
- Clutch sinks to floor, doesnt come up!!
- SS break line banjo bolt broke WTF?
- Thoes who have seafoamed....
- JB Weld question. Will this work?
- Need more power!
- Light Bulbs
- couple questions about FSTB / RSB
- Got them codes codes codes
- Is this normal MPG?
- Cheap replacement exhaust cat-back
- replacing the dashboard
- Power Seat
- Is my clutch slipping or a bigger problem?
- Ben's rear suspension mounts
- Injector Mystery
- Spark Plug and idol . question
- today did KS and hood strut almost starter too
- Lookin for a full exhaust
- 00vi price vs 00 engine price
- RPM issue
- Looking for a good price on a B pipe
- 2000 5-spd tranny in my 95?
- Axle Problemssss???
- Need little help,,, electrical!!!
- Adjust IAC valve after Throttle bottle cleanup?
- Will a 98 Gauge Cluster work in my 95?
- Removing the Climate Control.
- after market muffer?
- Anybody who installed their own b-pipe or exhaust step in
- exhaust leak under front seats
- How to determine a bad ECU?
- carbon fiber front lip pics?
- intake manifold swap
- Cheapest suspension set-up thats better than stock
- 95/96 Taillights. Need your Opinion
- Winterizing car (heated dipstick)
- BMW M3 trunk lip spoiler for maxima
- diagnosing a technosquare or JWT ECU for a CEL
- Car sounds like a dump truck--Test Pipe??
- Starting problem FIXED!
- evap code - bogging and running rough
- Sway Bar Link Kit (97Max)
- Turn signal question
- a short vid of my car
- any idea what this connector is? (pics)
- Battery died now remote key wont work
- Heads Up Display - Has anyone ever tried their own?
- HELP asap!
- Axle boots torn, what to do?
- Stupid mistake a massive annoyance?
- how to remove center vent cover
- Where is NSS and the BCM
- Size of Hub nut
- coil packs
- Car will not start...on it's own
- How-To Q: Evaporation Pressure Sensor
- Body kit or Lip kit
- sell the max
- LED Interior Lights
- car wont start.. tried to get a jump, no use
- URGENT HELP NEEDED (Overheating) !
- 99 cali spec MAF help?
- Type of grease used to grease the starter
- Replacing BELTS any suggestions
- Free 1995 Maxima parts for a limited time!!!
- Final Suspension question
- ebay smoked tails FTMFW ?
- My Maxima got its Mojo back
- I think my struts are going
- Ipod placement
- TEIN Basic Coilovers Thread
- scan tool
- Radiator Coolling Fans - options/advice
