- Header wrap, how to install
- Trouble programming my remote transmitter for 96
- Daniel Martin: Car Ramp Question
- does repainting lower the value?
- sc question
- worth it?
- Just got rear-ended ::sniff:: ::sniff::
- Good price
- Fuel filter and manual trans fluid changing help needed.
- Which brands of headlights are good?
- Cheap torque wrench!!!
- Brake pad question
- air purifier
- Brake fluid bleeding idea... will this work?
- max vs. civic
- sway bar
- 4th Gen 97 - 99 Maxima ES??????
- squeeking clutch
- Need Help Fast__ Code 0903----->>????
- Prices for Intrax Springs
- 65w/45w vs. 65w/55w
- Front to rear brake bias question
- Brakes!!!!!
- How would a .........sound ?
- 97' GXE 57k miles NEW tranny, 12 grand.. whadduya think?
- NOS kit on Jc whitney site.. how much hp?
- need help
- Redline MT-90
- How do you rate your Max ??
- Damn it, my H3 fog light bulbs keep blowing
- intake
- ML Light ON codes 0303 and 0304...Daniel B?
- homemade intake?
- Fancy dash lights, gauges
- San Diego Anyone?
- wassup with making a grill from metal mesh from home depot?
- Stainless Steel Brake Lines install how-to
- Springs and Shocks
- I don't live in CA but my car has CA spec emissions??
- Rust prevention on matal parts in the engine
- Disappearing coolant mystery !?
- Mod dilema >>
- Couple of sightings Saturday Night in ATL
- D. Martin HELP! Flywheel probs.
- Ground control coil overs / Koni set up
- New Brakes
- boiling power steering fluid
- Dual Exhaust
- No Dash Lights
- Y-Pipe Questions
- I Had A Moment With My Maxima Tonight
- GReddy exhaust--------->
- group buy for generation two reverse indiglo gauges for 98-99 maximas
- Aftermarket ignition boxes
- Need help with the FSTB
- Really High RPMs on Startup..
- Dead OD Button on Shifter...
- Night of racing with the Maxima boys
- Night of racing with the Max boys
- Speaker Ohms
- pipe tips
- Another max victory ....
- Air Cleaner Mod
- Brake Squeal
- which is better
- POLL: MAXIMA with tint or no tint??
- xexon bulbs?
- trans cooler lines
- Urethane motor mounts? Who has a set?
- any one got a pic of a painted dash ? i haite the brown
- how much performance does the alluminum flywheel offer??
- Yet another balancing question
- Bose CD Player Problem
- Stock Fog Light Switch Work WIth Aftermarket Fog Lights?
- exhaust question
- Lower Prices for getting work done on Maximas. Atlanta,GA
- lowered 4th gens with stillen aero kit....
- FTSB - does it make a diff in ordinary driving ?
- Who has installed a "Window Module" for their alarms?
- Best 2"+ drop?
- what's the proper way to break in new x-drilled rotors and pads?
- NE1 have a modify Torque Converter?? If so->
- Pothole Victim, Should I fix it?
- Will a 1997 non-Bose radio fit a 95 GXE(cd/tape combo)
- Air filter options?
- Installing Clear Corners
- b-pipe question....
- Howling sound from brand new tires.....
- People who have upgraded your brakes.....
- Wheel Balancing: Why can't these guys get it right?
- POPcharger roars....
- weapon r coil over
- Engine Stalling for no apparent reason??? Please help! LONG
- Problem With My Tail Lights...
- Need more help, Busted engine mount bolt
- "GrillCraft" grills for 4th gens available?
- Anyone try TurtleWax Color Cure?
- Why does my car Hate low Rpm's ??
- Where do I buy an Apexi WS
- Dan Maxima...Another relay questioin
- Bug deflector
- need opinion and pics
- need HELP on intake on eBay
- Stillen Maxima Day Product Pricing . . .
- which 4th gens have limiters?...
- Rear Bose Speaker assistance requested
- rim weight
- Need help! My car is still stalling>>
- If you have 18' rims on your max, please post.
- Clogged sunroof drain
- New front bumber design!!!
- Anyone in SoCal has a JL Stealthbox?
- 2K I30T rims fit 98 MAX?
- SSR Wheels
- CD player skips - anyone else have this problem? (x-post)
- not passing inspection test?
- sprint spring and shock??
- MAX vs. GSX
- any one else see this on ebay???
- Race story
- WIll the Trenz Grille Fit on 95/96
- Stock Air Filter
- Door Panel Removal
- How come there's no Max coupe?
- SP5000 impressions 235/45/17
- Clear Corners at Courtesy Nissan - Diamond cut ?
- how does the CAI sound?
- How much power can I get, and what mods look best?
- What are my times?
- Y pipe and CAT question
- WTF! Take it easy on Hamilton, guys . . .
- Need Shocks Recommendations
- Finally, check out a pic of my cah
- driver side door panel lights
- Missing CAI template - baggs533, anyone?
- Tires & Speedo error?
- changeing air filter
- A few pics of my car
- neon lighting
- SE vs. GXE
- gauge cluster and clips...
- Optima Battery
- Panel Filter for 95-96 vs 97-98
- indiglo gauges
- how to install indiglo gauges?
- please post pics of costum hoods..
- 65w/45w
- Maxima.org Table on Stillen Maxima Day . . .
- Coil Overs
- Tranny Swap
- K&N Air Filter
- K&N Air Filter
- Pictures of my Ghetto Cruiser
- Fast and Furious Max
- Clutch opinion? Mine feels like its going. What can be done?
- Clear Corner Fix!!!
- engine, rim and gauges question
- I finally got my long awaited Max the only problem is--->>
- Jerking.......
- How do you race and how do you burn out in an auto???
- Spoiler
- SC and TURBO
- Custom Max
- Crashed Car Web Site?
- EyeLids Need em
- question about shortshifter install
- Best Catback Performance Least sound
- Has this ever happend to you???
- Sound coming from suspension?
- Checking ECU codes
- Help!!! Error Code 07 04
- Looking for a hood....cheap
- Sound system
- 10% Discount on Stillen Products . . .
- Maxima sighting in Suwanee
- NGK cold plugs vs. NGK stock plugs
- I'm too lazy to search and need the scoop on your thoughts of Kumho 712 tires
- Who has ES bushings for more than 20k miles...
- Speedo problemo
- Diamond CUt CORnERS???
- kuhmo ecsta 712 tire owners
- whistleing noises when accellerating
- 99 se 5sp vs. 95 ford taurs sho auto
- Side Markers on a 4th Gen ?
- Wtf! My damn harness connectors keep burning!?!?
- Dismantling Dash
- Does DTC Motorsport have a website
- leather car on a 98 se
- Cold engine makes 'chug chug' sound
- Got My Cai Today
- clutch Whine??? - aftermarket available.
- Question about MIL code.
- what's just right?
- Is this possible...
- Who wants David L's Red/Clear tails ?? 160$$
- What are the chances of this engine swap?
- How many people know about this site???
- Get a 2002 Max now, or wait for a 240 HP Altima (in 2003)
- Paint Recommendations
- A question for Don...
- SE question
- Manual Transmission Switch Replacement...
- Need torque specs for suspension bolts, whoever answers is my hero.
- Group Deal ECU
- Need Ideas !!
- Attn: Emax.......................
- Skyline Maxima
- i am gonna punch out my cat tomorrow.
- stock to stock V6 camaro vs. V6 maxima.
- could these be acting poorly and me not even know it?
- ok what should i do tomorrow?
- 14.74 @93mph w/ypipe & intake only
- how much does it cost to have 4 tires mounted & balanced?
- 25000 mile motor oil
- Courtesy Nissan FSTB Question
- Bummed Out Over 95 5-speed
- Need a "hood bra" or sports bra any suggestions where to get one cheap?
- What bulbs do i get ??
- engine code questions (0705, 0903, 0304)
- Automatic Max Mods
- Fogs Half Out
- Water thermostat temperature rating
- y-pipe rattle coming from under the shifter..
- Compression test results
- just installed sprints by myself
- Tennessee Maxima Owners
- my keyless is broken somehow. Daniel Martin?
- HIGHEST output (wattage) BULBS
- 1997 factory alarm reset switch
- clear corner replacement bulbs do not flash help
- thnx...
- Got New Rims / New Color / Much Better
- G-Force ecu upgrade! Like Woh...
- Scratches
- Southern Ontario Maxima Meet!!!!
- y-pipe without catback exhuast good or bad
- Wierd Squeal Noise....
- !!!wat cars can the 4th gen max beat?!?!?!?
- Transmission Flush
- tru or false?
- Cattman y-pipe
- Manual transmission bearing wear and whining noise!?!?!
- Intelliglo Needles
- Daniel B. Martin..Please help us....
- Speed!!
- Anyone had good luck using Chem-tool in the fuel system?
- Is it necessary to reset ECU after installing highflow intake
- Pics Of My New Rims
- Rewire foglights
- I need some help with technical issues...ecu 0304...and others
