- G-Tech testers, do they work?
- 95 Red Clears!!!
- What Struts To Use For Every Day Driving?
- Sprint And Kyb Gr2's, Any Good??
- installing guages (not my strong point)
- Catback Exhaust
- Rotors
- how to modify from double din to single din radio?
- Insurance company problems
- installing clear tail lights
- Need some help with paint
- Cheapest site for struts?
- rotors
- Is it safe to depress the gas pedal during ecu code extraction?
- Ok, HID's will be illigal aug 15, What's my next option??
- maxima AIM buddy icons
- AH! Emissions testing
- Am i missing the ECU check screw!? NEED HELP ASAP!
- anybody got carfax?
- Why not use ACT?
- 04 13 Error code....Anyone know what it is?
- 1997 Maxima GXE, is it worth it?
- Gold emblem to Chrome.
- B&M shifter, install question, and shop question
- Racing Seat Install
- Cylinder 4 misfire...Help
- what kinda piaa bulbs do i need
- Installing Gauge rings
- AC recharging
- Anyone Remove the silencer???
- Oxygen Sensor
- 5spd Conversion Questions
- Can anyone recommend a FUEL FILTER?
- help with wheel bearings!!
- where can i get porterfield pads?
- How to clean my filter......HELP
- code 04 09?
- which y-pipe?
- Rubbing noise coming from rear brake?
- For those with a 97+ F/E Conversion...
- What's your MPG?
- leak on 5-speed trany
- Finally took pics of engine bay.. Nothin special..
- Knock sensor code, Now what? (No search)
- Mass Air Flow Sensor 01 02 Error
- Power window/motor question
- Jigly driver's window
- Sticky Passenger doors
- Losing fuel pressure when car sits?
- have to part with my maxima...for the time being
- Saturated clutch
- close call with accident -- may need some repairs
- 1995 Maxima GLE, is it worth it?
- Lights went out
- help!!!! Brake problem!!!!
- ACT disc?
- Midnight battle w/ rsx-s(modded)......
- Why Would My Check Engine Light Come On?
- O2 sensor replacement
- Taking front bumper off...
- rear view mirror install problems
- Slammed Into Curb what could of happened.
- Price options for selling car
- popping springs
- Check Engine Light Is On
- MEVI on courtesy nissan site
- Y pipe question
- wierd noise when i drive slow
- MAXIMA Emlblem
- Are 18" 30 offset 350z wheels out of the question for 4th gen?
- Are all thermostats the same???
- synthetics ATF
- mileage and starting
- What Is Wrong With My Car??!
- cleaned IVAC , alot smoother running.
- FINALLY got 99 SE Black Leather.... **PICS** ---->
- should I have to change my knock sensor at 59k?
- manumatic HELP, need 97 service manual
- CHEAP and EASY WAYS TO UPGRADE MY 1995 GXE
- Cruise Control Limiter
- Clutch Question
- When do I know when to change the O2 sensor?
- Exhaust Rattle [Y Pipe/Cat?]. Help Needed.
- frankencar intake question
- 96 ECU is one better than the other 10/95 or 11/95 ?
- Some pics...
- red/clear tails ?
- PIAA Windshield Wipers
- Attn Franken Car Intake owners! Need opinion before purchase!
- Where is the Vehicle Speed Wire going into the ECU?
- Transmission woes (again)...
- fixing sticking gauges...
- 5th gen springs
- 5 speed questions
- does anyon ehave instructions on installing this?
- clutch options
- brake light on in morning only
- Clutch question! Please help.
- Reverse Indigglo and Foglight problem?
- Need a clutch...help me decide!
- blue led in the interior of max
- Help with MAF !!
- PIAA Xtreme white headlight bulb?
- Is this Ugly or what????
- Cluster Guage....
- Service/Warning Light Apparently Disabled
- Me = Audio Noob Questions Inside
- 99 ACC in a 95?
- Spark Plug Wires?
- Disturbing the Peace
- Anyone know the speaker size for a 1995 GXE?
- 99 fstb
- Got my hands on some Llluminsa this Saturday
- No offense, but someone payed nearly $500 to get their 'SES' light off.
- How many of you have had strange noises with your Y-Pipe?
- Painting Altezza
- will auto tranny axle seals fit a 5speed?
- engine lights is on -help
- Headlight Housing Question
- Blinking O/D light on dash please help!
- Can I check to see if Airbags are intact?
- Strenght of pistons and rods
- HELP!.. wiring diagram (tcm connector f109 & f108)
- Reverse Indiglo Problems
- i have a big problem
- Headers
- pics of my new skyline front
- Glue
- 95/96 red clears group deal
- Radiator support question
- Side skirt options with stillen front lip.
- Warpspeed Y pipe
- retrofitting a steering wheel?
- anyone order intake from autoaccessory Store
- covers for tail lights
- suspension upgrade for towing
- buying a bomz intake
- is this a fair repair cost?
- okay, any advice for 5-spd swap newbie
- Adjusting E-brake
- MaximaQx
- Cefiro one-piece headlights...
- New Remote
- A4?
- i30 grill on 96 max
- burnt out bulb harness!!!
- bad experience with greddy???
- After some test i replaced my O2s
- ECU resetting not working.
- knock sensor questions
- manual trans. remote startup
- how the exhaust works? pipes?
- How to take off rub strips?...
- MAF problem please help
- Headlights and corners with black around the housing?
- Dosent this suck major A$$
- Can someone host my WSP Ypipe and Apexi Sound clips?
- QUICKLY! 95-96 or 97-99??
- LOW idle RPM in my 95 5-spd - Pls. Help
- Aftermarket Exhaust hanging too Low?
- would bad Differential bearings cause this?
- Anyone got this code before?
- Question for people that is dropped...
- Starter Replacement
- AGX and GR-2??
- Can a VB mod wear out?
- Lights
- Budget B-pipe resonator or no resonator?
- PIAA Xtreme white - fog H3 bulbs
- maxima tragedy
- 5sp conversion guys- axle question
- body colored b-pillar mod
- Just ordered a Y pipe!
- looking for strut install tips, advice, pitfalls to avoid
- Q About Black Box Under Battery Tray
- Bled cluth Cylinders, still no pressure. what now?
- thinking about taking the hamburger off the back...
- What springs should I get?
- taking out my head unit
- TPS specs and adjustment
- KYB AGX- Alignment question...
- Q About Painting Calipers & Rotors
- Harlan stopped working for 1 day period
- System, or KYBS and H&R's?
- i30 with a skyline kit
- inner fender?
- 95-96/99 catback exhaust
- Opinion on body work, and situation...
- Shift Knob Question
- MEVI from Courtesy Nissan
- Removing Seats
- Brake Noise and Vibration
- hesitation in acceleration
- who knows this info about oxygen sensor
- Check Engine Code
- 97 SE repairs
- Need License Plate Ideas!
- Front passenger door light not working
- Hid..
- Question about JWT ECU ?
- Please Help Metal on Metal sound in wheel well
- what does this code mean?
- sprint and dropzone springs user ATTENTION!
- Wire next to oxygen sensor on cat hanging
- Down Pipe hung real low
- Routine Maintnence
- oxygen sensor...where to buy it!!!
- Car Started rough, then a pop from intake..
- "in its class"
- Door Pillar Adhesive
- 5th Gen Muffler on 4th Gen Aesthetics ...
- front lip shipping cost
- Passenger side window switch
- How to - installing Stillen RSB
- looking into 5spd
- stillen rear exhaust
- Help!
- HELP!!! No pressure in clutch hydrolic system
- Anyone do the s2000 Start button mod?
- Indiglow Guage Help
- OBX Catback owners look inside
- Where is the PCV ?
- suspension or audio n y-pipe?
- Hard shifting tranny....
- new pics at my updated cardomain 7-31-03
- Budget Y-pipe
- Question for those familiar with OBDII
- Check out my photochop, tell me what you think
- Attn Injen Intake Owners!
- Annoying Squeek sound from Rear? Anyone?
- Check engine light acting up Help!!!
- stainless steel brakelines ... should I?
- Battery terminals and what guage wire are we running to them
- crashed my max
- Specific button that has to be pushed before car will start
- Aerospeed springs?
- crank position sensor code
- Verify if springs are indeed SE Springs?
- Front Converter Pipe
- Got a Boat... Now I Got CAR Questions!!! ???
- Stainless ypipe worth the extra $$ ??
- Timing Chain about to explode!!!
- OEM NGK platinum or regular NGK copper plugs
- worst gas mileage after fuel filter change?
- Rear Brake Squeal Driving Me Nuts.....
- who is blkmax98se on car domain?
- Removing engine...and...
- key value brakes?
- tranny cooler
- 98 towing capacity?
