- help.. what is this sound?
- Rear Dust Boots For Shocks
- Brake Pads
- What is so special about this strut bar?
- Warpspeed frame rails
- is 87 octane ok?
- Can an aftermarket key fog work with stock alarm??
- Rear Alignment
- Ignition Switch Controlled Circuit
- how much does an auto to 5 speed conversion cost?
- what do you guys think about ground controls?
- what kind of bodykit do you guys think i should get????
- is there an altima.org?????
- How much difference does price matter on suspension?
- Shift & E-Brake Boot Install
- engine problem, HELP!
- rotors
- questions about knock sensors
- Please Help !!!!! How do I take out ecu
- PLEASE! Where is the front right o2 sensor?
- Bose Problems....
- Please HELP PLEASE HELP!!!!
- stearing wheel shakes above 75mph
- maxspeed springs or progress from maxima.org?
- O/D light blinking on startup???
- Best Carbon Fiber hood?
- Temp Needle bobs alot under heavy acceleration
- Unusual Clutch Slippage Problem
- still cant install my y-pipe
- 100 octane too much?
- face lift
- Rotten Egg smell
- Lower Ball Joint Replacement..How??
- KYB Boots and Tokico Illuminas
- Buzzing/Rattling Noise from shifter area after y-pipe install
- Grounding Wires
- Cattman headers are in!. WOW!!!!
- QUestion about receiving technosquare ECU...
- Need Pics... Sprint drop, Stock exterior and stock SE wheels.
- It wont stay on help!!!
- 6-speed in the 4th Gen??
- Tranny problems almost over: Axle seal problem!!!
- Who's S/C is this?
- Changing transmission oil - a tip for removing old oil
- Weird steering problem.
- Motivational Strut Mounts
- sprint springs suck a**
- Titanium Edition?
- FREE CARFAX!!! ENDS in 3 hours?
- VQ35with 6speed
- Lowering Springs on OEM New maxima struts
- Best Gauge Cluster Bulbs
- need help with removing starter
- Good Price..
- Can't fill tank
- Performance with CAI/Y-pipe/Exhaust?
- Possible Greddy SP2 G/D
- Will these rims fit?
- Blue LED Interior **PICS**
- 96 Ford Probe GT 24V DOHC
- White smoke, I think?
- Bad ECU (I think)
- removing grille
- Installation Help
- Mufflers
- estimated LOST HP
- Help me decide......
- Good private shop in ATL, GA area Max Specialist
- noise after FSTB install
- How much would it cost to get a new rear bumper painted?
- CEL light anyone have this before
- Wiper washer doesn't work
- Want to polish some engine parts
- Please help me with Hard-wiring a radar detector!
- drop resistor mod
- My New Max!
- How Do I Replace The Climate Control Bulbs ???????????
- I must be getting old - I took off my spoiler today.
- Worst Maxima Video EVER... Caution: Viewer discretion advised.
- What is a knock sensor?
- Need a few quick questions answered
- Are o2 sensors interchangable??
- Is lowering my ride really worth it?
- fog light
- Painting the car
- what color is my car????????
- *PETITION* Sign it for a 4th Gen Maxima Model Car
- Just ordered the MEVI!!!
- bad idle and lag
- one touch power window up mod...help finalizing
- BodyKit???
- EVERYONE WITH A Y-PIPE: What sound does yours make?
- Maxima Model car?
- something hanging from my car
- headlight wire harness upgrade install
- ASAP went to auto zone got a code p1400
- when you put in the new knock sensor
- Clutch/transmission woes
- how did you fix Evap Control Volume???????
- Bose Stereo
- Code 0308 - What does Closed loop control mean?
- tranny
- Now what the h*ll is thiss???
- auto to manual conv.
- Reason for our droning exhausts
- Starts only when I jump selenoid,?
- hp at the crank or whp
- removing gauge needles
- Should I clean the O2 sensors???
- cefrio headlight pics please
- Carfax....gratis
- Radio Cassette player lcd backlight out
- s/s brake lines
- braking problem
- Who has the link for the auto vs the stick
- Springs, struts, and overall suspension (mine is shot)
- SVT contour vs ME vs SVT focus
- question about niteshades tint spray....
- A Budget Y pipe...
- belts
- changing 95 cupholders to 97-99
- Lowering W/out Changing Stock Struts/Shocks?????
- cattman headers install in progress. part-1
- Can strut bearings cause spring wear?
- LIMAXIMAS.COM meet today 2/28 see pics
- What Do you think about this?
- 95-96 grill
- timing chain
- E-brake not functioning right
- Need an advice about steering rack pinion
- How much for stock spoiler?
- Debadged my Tail *PICS*
- Rear cat O2 sensor
- question
- 98 Maxima v.s Spec V
- Ebay drilled/slotted rotors any good?
- Lowering
- Axle question
- cat goin bad?
- pager alarm system question.
- M Bumper pictures?
- how to tell if coil is going bad?
- Clutch master cylinder?
- need new paint job, need ADVICE
- anyone with a chiltons
- 97-99 conversion am i leaving anything out???????
- Black/Yellow Interior?
- Is super black supposed to have metal flakes?
- can i swap my 95-96 trunk for a 97-99 trunk?
- Dimensions of a 1996 Maxima trunk
- AE headlights - can't get assembly out!
- replacing hood struts
- Need help! Gone through 2 y-pipes in 8 months
- Y-pipe stone shield help asap
- hard starting, possible fuel starvation?
- Magnaflow soundclips anyone?
- RAM-AIR that works!!!!!
- Airbag light on PLEASE HELP
- Airbag light on
- Who Here Has Nissan Maxima Aluminum Door Sills On ....
- Need Exhaust Cam For 95 Max Se
- Spark plug gap for NGK Platnums
- pls help with my IAC valve
- y-pipe/cat bolts
- lighting issues
- installed RSB- Q
- How can I make my car sound better
- Help, exhaust noise.
- Injen question
- SC on ebay?
- Changed the 02 sensor but still need help
- Cylinder 4 misfire and ignition signal circuit
- Why do CA and the rest of US have different Specs?
- Intake setups - I'm torn!
- family car match up
- Q: after installing knock sensor
- personal lamp
- finally! new knock sensor w/ nismo14 relocation!
- what do you use to cut the light cover for red/clear mod?
- Suspension Sticky??
- Started problem, not really the starter
- More Aggresive Stance: Sprints?
- Trying to find rear clear/read tails
- where can i get a new keyless entry system?
- intermitant stalls/hard to start
- whats a good cat converter to get
- intercooler w/o SC?
- who has over 120000 miles on their auto max
- Resetting ECU
- What affects MPG
- ---Are there BIRDS in my engine???---Sound Clip Included
- Clunking sound from the rear suspension
- Buying a '99 Tomorrow...
- highest mileage on original water pump
- Exhaust Wrap
- plug for fith cylinder??
- stereo problem again
- eBay Intakes
- cheap oxygen sensor
- OBX Fuel Pressure Regulator
- lowering
- 98 maxima, code 0604 help
- engine light
- adjusting the ebrake...
- Rear Sway Bar is on, very pleased
- Spring Suggestions
- Noob with question about clear corners
- break lights stay on
- Confirming (hopefully) the right Spark Plugs
- Denso & NGK
- Has anyone gotten a 10/03 cel after a 5 speed conversion?
- Would a straight pipe kill my o2 sensor?
- i need to find a airbag/steering wheel microfeche
- Suspension Advice
- Same kit as custommaxima.com???
- Using a 95-98 ECU in a 99
- lowering spring thread
- 300zx brake upgrade?
- Which Shocks and Struts to buy?
- quick oem wheel question.
- How many Qts of Oil?
- What's the best spring/shock combo for a budget?
- brembo cross/drilled rotors both front and rear! (review + pix later...)
- 1998 max se rattle/clanging sound
- windows roll up too slow
- opinions on coilovers
- VQ35DE in 4th gen?
- Those interested in a rear brake kit...
- Need some info on what i need to do to car it has 109000 miles on it..
- How to take off trunk lid snaps off??!!
- Problem with Warp. Y pipe?
- Brake shims needed?
- Hello .. Newbie here
- Altima Forum
- are any of those mufflers off ebay good?
- What plug is this??.. Maybe used for factory spoiler?
- creak/rattle from front of car
- starting issues
- Rusted and broken bolts
- Budget or Cattman Y-PIPE. $200 each
- i really need help with rear brakes on my 95
- Cleaning IACV?
- brake question
- Has anyone replaced their own rear O2 sensor?
- Anyone know Nissan's part no. for copper plugs?
- Lowered the Maxima Finally!!**Pics**Before/After**
- throttle body what is this part on it
- Need write up for Auto --> Manual Swap
- Is my clutch slipping?
- Main seal
